View Full Version : Audi allroad
- 2001 Allroad transmission issue!
- Inner Tie Rod - grease?
- Shifter loose
- Vibration at idle
- 2013 allroad steering issues
- Highest Mileage allroads
- expensive to repair scratches and gouges in bumper?
- Xmas sales on Becker Mexico 7948..Apple iphone 5 32gb on sale for Xmas
- 01 Allroad air suspension N111
- New Audi Owner
- Cam Seals and Emission Fail
- '03 Heat problem
- Lowest Mileage Allroads?
- 2013 allroad vs 2013 Q5 vs 2014 Q5 vs 2014 Q3...?
- Very sad with the newest G2 front bags. I got two consecutive defect for 2 weeks.
- White Smoke - No Turbo Whine - No Apparent Loss of Power - Need help Diagnosing
- Buying a 2002 Allroad...What to look for?
- ADD Satellite Radio to 03' with RNS-E
- Winter to-do list suggestions?
- cel help
- Fan Control Module Smoked!!
- Black Friday 2012 Special is here!
- Is my 6 speed Allroad really unreplaceable?
- :: ECS Tuning :: The 8th Annual Customer Appreciation Holiday Sale!!!
- Sloppy Shifting
- Drive train and suspension overhaul
- You know what's wrong with getting a new audi...
- What more could possibly go wrong??
- F/S 2001 Audi Allroad 2.7 T - Manual - 101K Miles - $8,999
- Allroad Manual Transmission? Is it possible?
- USB power panel project
- audi allroad antenna
- Turning off all of the beeps!
- Two cars - both now 'brake pad wear' warning
- Swapping radio
- Aftermarket head lights
- Parts Here- Advice needed - Arnott Coil Spring Conversion Kit
- 2013 allroad: First Big Road Trip
- Lower control arms...how do you...Part 2!
- Full steel allroad specific engine and transmission skid plates. Anyone interested?
- 2003 2.7T Tiptronic whiny noise when ABS kicks in
- Bag out. 1st time. Woo!
- Photo of the wheels and tires I have for sale
- allroad '02 HP-2 front calipers
- FS: Rear Airbags
- Help with coolant??? leak
- advice
- $695 for 4 Michelin Pilot Alpin PA3 225/55R/17 winter tires on set of 4 OEM 5 spoke
- Replacing lower control arms -how do you.....
- Tires mildly cupped, getting noisy. Suspension components seem OK.
- 3.0L TDI 2001 allroad
- What are the prefered aftermarket Nav's, Bluetooths, and Seat Heaters
- has anyone done this to fix the below threshold cat codes?
- Wheels arrived yesterday; now all I need is the car...
- did some maintenance recently - headlight moisture, drain plug
- Replacing suspension mounts/bushing
- Bring your C5 to a halt with StopTech Brakes, from AWE Tuning.
- Have you ever been stranded somewhere in an allroad?
- stock roof colour?
- new driver front level sensor Q's
- CV boots or more?
- Suspension vibration ?
- need advice: low milage 04, or higher milage 05?
- Finally!
- Arnott Bilstein - revalving
- Auto 1st gear shift delay on incline right turn
- Raising your Allroad...
- Anyone have the Mileage Plus ext warranty from western-general or now protective
- Turbo Leaking Oil ?
- Missing engine, replaced coils & plugs, but still the problem.
- Should I buy 2013 Allroad?
- Dead dash - Here are the VAG Codes - ideas?
- Are Bosch & Valeo Alternators Interchangeable?
- Instruments (not LCD) failure?
- extended warranty question again-on my first audi(05 allroad 2.7t)
- Where's the J403 relay in a 2004 Allroad?
- Back of Drivers Seat not heating...
- Just posted 4 allroad 5 spoke wheels and 4 Michelin PA3 winter tires in classifieds
- RNS-E for sale in CT
- Heated MFSW Conversion?
- Deal Breaker....?
- Level Warning mystery
- Audi D2 S8 Rear BBK
- tire wear
- Air Bag Replacement, Bilstein or Not?
- Blauparts Suspension Conversion Install
- window regulator attach point
- Suspension pump valve block issue**
- Arnott Suspension Parts
- RNSe 2011/2012 DVD
- two fog spots at the bottom of windshield
- 02 allroad 2 piece rims......please help
- oil temp
- 2013 allroad upgrades
- How do I remove trim to get to the brake light switch??
- Would love to find the previous owner of my allroad came from alaska
- Ride height fuse panel
- Save 10% on Arnott Air Suspension Products
- whats up new guy here
- Driving in Tiptronic mode
- Changing transmission oil
- Some allroad parts for sale
- need a good indy around Boulder, CO
- Some hope for a 3.0 engine on the AR
- GOOD RIDDANCE AUDI!
- Raced a new allroad with my old allroad last nite
- The old P0431 Code - DIY fix? - Help Please
- Does 18 inch wheel makes a difference?
- Found a 02 Allroad 167k
- Suspension Warning Lights Again
- Audi vs Audi crime
- 2002 Allroad Engine Over Heating Issue
- Air Suspension Hi-Jinks
- Ball bearing turbo conversion for '01 2.7T
- Just Got Some Codes In My Audi A6 2002 For Secondery Air Pump
- The Air Suspension...again...please help
- RS6 Grill? Does it fit?
- How to remove the front grille
- Would this code explain the car not moving in DRIVE?
- Is the rubber Y boot on the intake a vacuum source?
- Transmission reverse issue. Indy doesn't bother looking for root of problem.
- Molded trunk mat for 2013
- Replace whole shaft for torn boot?
- Indash dvd/nav
- Anybody tried to lower the AR by removing subframe spacers?
- Spider hose replacement
- allroad tire
- Is there anyone with unlimited carfax
- 2005 allroad idiot Suspension light on
- Programing New Key with VagCom, Help!
- 2002 Audi Allroad for Sale - Seattle
- Yellow Fog lights
- Duke; 2005 4.2 allroad showing his age
- My 2013 allroad (A4) gas mileage
- 03 ar air filter
- Cleaning up door blades
- I want to put RS6 rims on my 2002??
- Rear diff mount bolts missing / snapped off
- My 2013 allroad - New Pictures
- Bled the brakes with VAG-COM, now ABS light on
- 2002 Allroad For Sale
- Phone Feature Question
- New on Audiworld from France
- Tallest OD tires for snow?
- Windshield base tray adhesive question...
- 03 Allroad Vibration at 60+ MPH
- Replacement Shock Absorbers
- Leaky cam plug
- Check Engine Light
- Need your opinions on using Bilstein shocks with Arnott Gen1's or Gen2's on Allroad
- The "Yet another suspension issue" thread
- P1432 Sec.Air Inj.Valve Open - Help Please
- 2004 AR front end dropping in position 1 only
- C5 Allroad air suspension wiring diagram
- Allroad stage I, II, and III
- 01 Allroad suspension issues, please help!
- 2001 AllRoad EP35 Flasher Location
- AR shaking like crazy
- Electric fan issues ?
- What shocks w\ Arnott G2?
- Need 1 OEM allroad wheel
- C5 allroad meets B8 allroad
- Labor Day Special at Detailer's Domain
- Jack stand points on allroad?
- 2004 Audi allroad quattro 4.2
- Front Differential Leak
- My 2013 allroad Has Arrived
- Get your Allroad ship for free. Courtesy of AWE Tuning.
- Price info on 2013 allroad? (Keeping my 2003.
- Audi Allroad used Air suspension module available 300$.
- Any special considerations when purchasing a high mileage allroad?
- If anyone is looking to buy an 034 x34 intake or heatshield only, PM me.....
- FS- 2003 allroad 2.7T, Tip, 80K
- Spark plugs
- New ride
- Trailer hitch for 2013 Allroad
- How to lower even more than 402?
- R6 style headlight in eBay
- I know it is lame to do this but....
- Looking for a MT all road
- Springs wont air up
- Audi Mechanic Career
- Arnott's airbag Gen I or OEM airbags ??
- FS: 2001 6MT Blk/Blk in NY
- When to say When
- Inflator?
- Passenger door light flicker
- 2005 Allroad - Needs Transmission - Fix or ?
- Recently picked up a 2001 allroad
- Allroad Trailer hitch - connection, communication
- Exhaust Woes
- Cargo Area Liner
- Hood Strut?
- Auto dimming side mirrors?
- Anybody use EMPI Axles have shake/wobble issues?
- Need pair of front axles from manual trans allroad.
- Got a shake I can't get rid of..
- Interested in buying... but how is reliability / costs?
- Interior lights, windows and sunroof all not working
- Suspension Level Control Calibration error
- badge content, German edition
- (FOR SALE IN SACRAMENTO,CA) 2002 AR 2.7AUTO 113Kmi priced FAR BELOW$ kbb value today
- Passenger Side Mirror Dipping Down On Reverse
- New Allroad owner here
- Air Spring compressor PISTON RING KIT FOR SALE
- New front suspension, no leaks but compressor runs
- Rear hatch door not locking
- Allroad Light Bar / Brush Guard
- Trade-in value for 2004 Allroad
- NE1 have a front bumper chrome trim piece that goes under driver headlight?
- Air Suspension on Bump stops
- Allroad Air Suspension Repair Issue
- Front Air Suspension Repair Problem
- Exhaust Leak in my 2004 allroad
- allroad sport logo caliper decals and shirts.....
- How to disable fogs when headlights on?
- Conti DWS anyone?
- Air Suspension Lowers Immediately???
- front suspension leaking air need help
- Need Key Cutting near Boston, Help!
- New Q5 owner looking for good mechanic in Columbus, OH area..
- SALVAGE title question...
- Looking at purchasing an allroad...how fast should the suspension raise/lower?
- Compressor kit, piston ring on sale ebay ONLY 2 LEFT!!
- allroad REVO Stage 1
- Left Bumper Trim Question?
- Suggestions please - Should the new allroad have its own forum, or...
- Have you driven and Audi TT?
- Help w/ Piggie Pipes
- Just finished a Valve Cover Gasket replace and then this....
- 2 new front Arnotts and compressor continuously runs HELP
- C5 Facebook Group
- New style allroad sport badge
- 2013 3.0tdi V6 Bi-Turbo
- Suspension Level Mod?
- RNSE Disclaimer
- Waterfest 18 Special Starts Now - Get your detailing gear before the big day!
- suspension does not automatically adjust
- The Truth About Cars reviews the new Audi Allroad
- Rear window switches not working
- AC Blowing weak
- 17" OE rim paint code
- shop blew my front suspension
- Hesitation at idle
- My 2001 Allroad coolant leak-HELP ME!
- S4 - allroad MAF
- 2013 Allroad towing
- new bags and shocks or coilovers
- Sage Advice Desperately Needed
