View Full Version : Audi allroad
- Rebuilt Tranny - TC codes start...and the story begins
- Potential AR buyer questions...
- LLTek LED DRL Headlights-Installed! Pics...
- Will manual S4 downpipes fit on manual AR?
- Hitch wiring madness
- Coolant leak
- Gas fumes
- front suspension sag
- Trying to find a replacement for my '98 Volvo V70R
- odd behavior at WOT
- FL speaker intermittent
- Did read FAQ Need clarity on Euro-Hitches
- Paging allroadrunnervscyote please read...
- Both banks too lean, possible air leak?
- General Grabber UHP tires 225-55-17
- 4.2 rear brakes
- EGT Sensor-2 drivers or passenger side?
- anyone have any thule/yakima silver roof rack bars they are willing to get rid of?
- Hsports for $345 + shipping
- 2.7t rear brake upgrade...
- Factory car-top cargo box -- how does it attach?
- any reputable body shop in NYC area?
- Who has been spared Tiptronic Woes ?
- Looking to add another Audi to the family.. Allroad.. Need advice
- what is this warning indicator?
- Headlight cover hazing
- PES Supercharger Free Install
- '01 bumper vs other model years
- need passenger side mirror ( glass only)
- TIMING BELT REPLACEMENT???
- Locations ?
- Getting some new shoes
- Torque Converter / New Tranny
- Broken MAF plug
- Best Timing Belt Kit ?
- Calipers on '04 AllRoad 2.7
- Detailer's Domain Labor Day Special
- Arnott GENII springs & bilstein shocks arrived
- Transmission Control Module
- Possible Answer to Brake-Throttle Lag BTL... read on you Tipsters...
- Problems with a lot of idicators, help please
- Collapsed Driver Side Front Suspension - Please help!
- separate Arnott airbag from bilstein shock sleeve
- 2010 Audi Allroad - European Commercial
- AR suspension.
- Front wheel sinks down all the way within 30 minutes
- Would you tow this boat with your ar?
- Gotchas? - Wheel Bearing Housing (Spindle/Steering Knuckle) replacement
- help needed about a vehicle
- Towing/ Hitch Questions...
- So... My turn for new suspension
- Couple ?'s on a 2004 4.2 transmission and alignment
- Navigation plus ipod integration trouble
- HELP - Looking for an XM Satellite Tuner for 04 allroad
- latest Audi Navigation Plus
- Tire Pressure Monitor Option
- one week with Arnott coil spring kit
- Will be pulling engine out, any AR specific write up out there?
- NEWS from Arnott!!! Front Generation-II Air Springs
- ECU replacement
- Proper Introduction
- What's up with the "chastity-belt" case around my ECU?
- while doing timing belt...
- screaming condenser fan
- Just got 02 allroad back from Indy - Now car leaks oil
- Jammed rear passenger window -- manual override?
- Whining sound heard from tranny when cold
- Chrome/Stealth Bulbs
- ECS Tuning Cargo Rack on sale - anybody has opinion on this?
- Any thought on what to look for on a 2004?
- Keyless Remote After Car Battery Replacement
- Warranty providers
- Mechanic Recommendation Northern NJ
- air spring futility ...need help... kinda long.. kinda funny
- 00776 - Level Control Sensor error
- Whats the most unusual thing you have carried in/on your ar?
- Is the timing belt supposed to be loose? And other questions.
- Burning smell and a little smoke - details in side.
- Dice iphone - ipod adapter on amazon for $115
- acceleration hesitation
- shocks, oe only?
- Three very nice Allroads up for auction tomorrow (see inside)
- oem airbag and level sensors
- Air Suspension Problems
- LED clock issue and ODB engine check lights ON
- Allroad is not a company car
- boost gauge
- 6 speed vibration through shifter
- Black Book Value
- The adventures of 2 allroads
- when warm, system goes haywire
- AC not cooling/Econo button?
- Colorado allroad 4x4 Run on Saturday(tomorrow)
- Internal LED illumination upgrade.
- turn signal fuse
- Gas tank replaced on wife's '02 43K mi allroad
- a/c getting warmer at idle
- Anybody else's car missing trim strip along top edge of windshield after new glass?
- Anyone have a hatch they want to sell me?
- Any body running 390 mod?
- Lockout code
- Kumho Ecsta ASX $700 installed at local shop
- 2005 AR Luggage Compartment Cover
- Where is the Allroad Suspension Compressor Motor Relay?
- Air suspension help
- Fog light mod
- 0-60 time
- Subframe bolt locations
- Another "how much is my car worth" post
- pacifica, ca
- Rear suspension
- What kind of ODB scanner?
- How do I know which cylinder is No 6?
- HP-2 Upgrade worth it?
- So long... Had to take advantage of C.A.R.S.
- Navteq
- Air suspension goes up and down each time I stop
- Help. Driver's side leak at turbo (?) ...
- Reset Service Interval?
- Need new tie rod ends
- Self Leveling/ ESP/ABS lights on at once??
- Anyone keeping a full-sized spare in the car instead of the donut?
- All Wheel Drive Club (could the ar make it round a basic course?)
- coolant reservoir replacement
- Good Allroad suspension repair shop in/near NYC needed.
- oil pressure switch/sensor
- Check Engine light
- banned
- Former A8 owner Considering an 05 AR
- can i run 245/55/17 on the rear standard 17" 5 Spoke 17x7.5?
- Mechanic Drivetrain Inspection Results - feedback appreciated
- VAG com purchase
- Looking for a luggage blind cargo cover or parts ?
- New front axles fixed shake
- New AR owner w/ a Exhaust Rattle question
- Power steering whistling sound- is this normal?
- air suspension being replaced this month
- Help replacing headlight bulbs (Xenons)...
- new 2001 allroad owner
- what tyre size do you think this is? ar concept.
- F/S : Nokia N97,Apple Iphone 3G s 32GB,Htc HERO for just $200USD
- '04 4.2 AR oil change re: '01 2.7t?
- Ignition coil
- tranny question:
- To oil the compresor's intake or not to.. Interesting answer from Adam Arnott
- Questions before buying an AR 2.7t
- will be Audinized tomorrow...maintenance questions
- Need new car battery - what brand?
- APB ECU coding
- Air Suspension Compressor
- Anybody with Westfalia hitch wiring on a 2001
- Another Air Suspension Question
- Air Suspension Diagnosis Help
- Is there an easy way to replace the seal between the rear diff and the axle?
- new 2001 Allroad owner
- All Wheel Driver competitors
- Double checking on high beam & fog bulb types and brands before purchase.
- Heat Coming Into Passenger Cabin
- Extra pair of fog light
- aux cooling fan,, Help!!!!!!!!!
- Air Spring Question
- Locking ride height
- rubbing noise front drivers side worse when cornering
- Wanted 2001-2002 Audi Allroad!!!
- The race for 200,000 is on!
- My allroad will turn 180,000 this afternoon.
- Torque converter and other such excitment
- Aux. Fan issue...Help!!!!
- 02' "Olympic Edition" Allroad For Sale
- longest wearing tires / best value for stock 18 rims?
- things that can tear / damage cv boots ?
- Largest wheel/tire on allroad
- Display out
- Rear Brake Rotors
- water/leather seats
- Oil Temperature Sensor failure
- Oil Pan gasket
- suspension dilema and question..
- iphone speed trap apps, just getting into this
- getting an iphone to work with a navplus grom audio adapter
- Allroad questions...?
- had major engine work done at 38k, no need to replace ATF fluid at 78k?
- aul reserve warranty (exlusionary) denying cv boot claim..
- TRANSMISSION PROBLEM $4500?
- square and round brake sensors??
- Torque Converter question??
- Allroad Regular Service Times/Maintainence
- oscillation / rubbing noise starts at about 30mph, loudest @40
- a8 navigation to allroad? would this work?
- Air Ride system dead! Left side slammed. Help.
- Cam Lock Bar - Philly Area
- Price check please - repair estimate
- Scary Rattleing
- wagons: a4/a6/allroad/passat
- Suspension leak at Level 1
- EGT sensors and misfires
- RMcQ
- Brake Pads....
- JUST FIX MY AIR SUSPENSION LEAK For 12$
- fastroad
- So you set your suspension to auto height adjust, or do it manually?
- allroad tires
- allroad suspension work in Los Angeles area
- 2.7t motor running rough under certain circumstances - thoughts?
- 4.2 / Cayenne Brakes ?
- Is a 90" Thule cargo box too long for the AR?
- 4 month old Arnott airbag suffers explosive decompression
- One a lemon always a Lemon?
- A4 AllRoad UK
- 2001 allroad for sale, kansas.
- Clutch Switch
- 120amp alt fit on allroad?
- $20 Cupra-Style Front Lip
- AC cooling issues when stopped/'02 AR
- Uughh....
- A possible hitch solution?
- A8 Fat 5's in case you guys were wondering...
- Considering new car for the wife
- Coolant leak help - maybe aux. pump?
- Flashing ESP light
- Allroad questions.....
- Todays Drive
- Need some help deciding
- Front passenger side drops down
- Contemplating buying 05 allroad
- Who's going to the Audi Expo this weekend in WA?
- in the summertime
- Error Code 1857?
- Allroad '05 pads/rotors question
- Audi Sirius Instal help...xpost
- Bilsteins = mint!
- Front end noise.
- Thinking of trading the allroad
- why no 3.0 vs. 2.7T in AR?
- which aftermarket head unit will drive ar speakers and oem sub?
- 2003 with 52k mls, 2.7TT manual 12K
- system bank 1 & 2 too rich
- Self Leveling / ESP / ABS lights on at once ?????
- Level Control Pressue Sensor - G291..where to purchase and how much?
- AR goes psshhhhh when you shut it off
- Aftermarket Headunits
- cv boots totally ripped and spraying grease
- APR Commemorative Sale - June 22 – July 31
- summer tyre advice
- Leaky bags
- DTC - 01780 ??
- canadian daytime running lights
- New Center Driveshaft Bearing For Sale
- allroad turbos
