View Full Version : Q5/SQ5 MKII Discussion
- MMI Bug
- Knock Sensor 1 Location
- Any mechanics here that can offer guidance on how to replace climate controls?
- 2018 Coolant - G12Evo or G13
- 2021 Q5 Tail lights
- Touch-up silver paint: "Foil Silver"?
- Spotify and Text
- Another Oil Leak - Cracked Oil Filter Housing?
- Traffic Light Indicator Next to Outside Temp on Dash
- Ticking/clicking noise in time with RPM
- 2018 Audi Q5
- Q5 Calipers on a Q3
- 2018 Q5 Surging/Bucking
- Thermostat issue ??
- Traffic and Assist
- ABT HAS problems
- Keys?
- Mysterious Overheating SQ5
- Q5/SQ5 Aluminum window trim
- Peripheral Camera Failure
- SQ5 Advice
- 2018 Audi Q5 2.8l VR6 Swap
- 2019 Audi B9 SQ5 Build
- 2024 SQ5 Plastic Tabs Under Car?
- Replacing Water Pump on 3.0 SQ5
- Weird noise on SQ5 at 60ish MPH
- Map updates - the real easy way
- Traffic Jam Assist Not Available
- PHEV Charge Cable Recall: Parts Now Available
- Leaf stuck in door frame 2018 Q5
- 2018 SQ5 Rear lower taillight
- Activate VZE traffic sign recognition
- Q5 dipstick?
- FM radio song and artist info not displaying
- q5 80a 03.ABS\BRAKE akcess code \ code for authorized access
- Audi Q5 80a 2019 parking brake after engaging P
- Sunroof - how can I tighten seal between panels?
- 2025 Q5 PHEV ordering info
- Drive Select behavior
- Remove & Repair Rear Cupholder
- SQ5 Thigh Extender Lifting From Seat
- UA: How to turn off USA tail side marks?
- Cabin filter 2020 Q5 ?
- Sirius XM 360L
- JB4 or TDI Tuning for Piggyback?
- Keep or sell? 21 Q5e
- De Auto LeD
- Exhaust Valve on 2020 SQ5 - Unplug with Car OFF!?
- e85 in 20’ SQ5? Non-flex fuel rated?
- Bulb Size?
- New Owner: 2021 Audi Q5 55 eTSFI - wood trim replacement?
- HELP My distorted B&W audio system...2020 Q5 prem+
- Setting charge level
- Best price on new 2024 Q5
- Apr stage 3 turbo?
- Weird whine/chirp after installing IE Intake
- Specific Q5 Build - Adding in Wheels and Black Optics
- 2024 SQ5 cornering lights?
- Turn on ACC using obd11 2021 q5
- Mild Hybrid???
- Hybrid Mode Question;Battery usage
- Weird MMI play
- PHEV coolant temperature low and fluctuates - Broken thermostat?
- Replace Front Brake Pads 22' SQ5
- Damaged oil pressure switch wire
- Q5e Level 1 charge time faster than expected?
- HU: Clutch slippage (?) from 2nd to 3rd after Revo Stage 1 tune on B9 SQ5
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- Unfortunatley need to install a front plate
- SQ5 rust near rear spring suspension
- Higher Left Side of AUDI Q5 FY 2017 AIR SUSPENSION
- Temperature Display Adjustment?
- 2020 q5...was there an S Line version?
- Best way to replace rear coil springs
- Q5 PHEV Jerking shifting low gears
- Can’t set rear temperature.
- Exhaust Valves - A Definitive Conclusion
- 2021 SQ5 Extended Warranty Q
- Bad alternator belt tensioner
- SQ5 Rear Cargo Mat
- Brake job and spark plugs, what nobody tells you
- Q5 PHEV Battery issues (2021)
- Q5 SE PHEV issues (2021)
- CCS to J1772 connection?
- lost Q5 key
- MIB2 USA --> EU
- Valve Cleaning at 69k
- Lost AirTag: Is there a way to get into the body cavity under the driver seat?
- Replacing front center cubby light?
- SQ5 Premium+ vs Prestige headlights/taillights
- Newbie - door auto lock
- what are my options?
- Downloadable PDF Owners Manuals
- Parts Catalog?
- Engine Mounts and More
- Need length of airbox fasteners
- lane guidance in q5e
- When To Replace Fuel Injector Q5
- can I get oil changed at Canadian Audi dealer while on vacation over there?
- Have you ever had to insert your key into the cup holder?
- Wireless CarPlay not working at all - Help
- Strange MP3 Playback Problem
- Thermostat Housing Unit
- Unlocking using key fob button triggers car alarm
- Learning about the Q5/SQ5
- PCV Woes!
- 2018 SQ5 3.0 TFSI 02 Sensor Location (B1L1)
- 2018 Q5 motor
- Car jerks in park and at idle
- B9 Q5 Black Trim Question
- Q5 2021 PHEV Tow Hitch Help
- Would You? - Buy Q5 w/Tardy 1st Oil Change
- UK: Looking for a new set of front and rear 2023 Audi SQ5 Black Rubber floor mats?
- Help needed
- NA ACC control stalk
- Audi 2024 PHEV Immediate charging mode
- Loud Whirring from Rear Passenger Side - 20 Q5 P+
- Cyclic hum from driver side front
- Adaptive suspension?
- Nav 1320 to 1316 for Updates Assistance
- Red warning alert
- Way to leave engine running if I park and exit to get a coffee?
- Loading personal settings. Please wait...
- Q5 Sportback grill - Dealer drilled holes for plate - is this the whole grill?
- Q5 Driver Seat Mind of its own
- SOS Malfunction limited B18BD11
- Some issues with 2024 Q5
- Q5 Poor Heat
- Odd Message on my Screen
- 2019 SQ5 coolant temp sensor location
- Q5 Tail Light Faulty (But it's not)
- OEM battery lasts very long so how to tell if it's weak?
- Under Dash Sound Generator
- Tire Pressure for 21” wheels on 2018 Q5?
- Finicky EV Mode Button
- Keep adding coolant but the dealer can't find leak
- Heartbeat Soundbite on Exit
- 2024 SQ5 No Longer Available with Tow Package?
- Screwed up rear brake change
- 2018 Q5 Progressiv (Canada) - Back Up Light Error Message - Which Bulb Is This?
- C10AC07 Steering- Mechanical malfunction, but drives fine?
- gas vs electric
- Replacement battery for 2019 Q5
- Q5, SQ5 B9.5 Matrix LED Headlight Activation Information...
- Steering assist / steering rack failure SQ5
- Coolant smell in cabin.
- Auto headline feature
- Can 2023 SQ5 hug seatbelt when the engine starts?
- Anyone running Revo software on their B9?
- Service at dealership or not?
- Weather Radar on the MMI
- 21 SQ5 20” Tires-Opinion so Far
- 2020 Q5 TFSIe P030300 Cylinder 3 Misfire
- 20' SQ5 Left Taillamp Faulty
- Q5e JB4
- 2021 Audi Q5 Front Grill to S Line Honeycomb grille
- 2018 Audi Q5 Prestige
- 11089 - Engine Coolant Temperature Sensor 3
- Q5e super cold temperatures
- CV Joint failure
- 2016 Q5 does not start!
- SQ5 condensate drain location
- Porsche Macan EV
- CPO Vehicle Protection Package (Powertrain, Gold, Platinum)?
- Q5 scan tool (shade tree mechanic)
- Tailgate closing automatically
- 2023 Q5e PHEV transmission malfunction
- 2022 Q5 PHEV Battery (12v) Bad?
- From my 18 SQ5 w/JB4 to a 2020 SQ5 IE Stage 1
- Help diagnosing a pressure sensor issue
- New (to us) 2021 SQ5
- Level 2 charger for 2021 Q5 e
- Anyone ever try the 034 Motorsports Drivetrain Mods?
- 2020 Q5 Outer Bumper Grille - Mount Panel Clips?
- Transmission Lag/Clunk When Accelerating?
- 2021 SQ5 PP Sport - help OEM trailer hitch wiring work around
- Q5 Import to Switzerland from US - required changes?
- VC Phone Signal Strength Does Not Match MMI
- Mileage difference between dash and MMI
- Side-mounted Cargo Nets in Q5 PHEV
- Intermittent Malfunctions on 2021 Q5e
- Battery replacement causes car alarm
- Help trying to diagnose a pre sense communication error.
- Need help with wiring. Where does this go? 2017 q5
- 2023 SQ5 Remote Start Option?
- Should this be covered under warranty?
- Can I get a Q5 P+ Or Prestige without a sunroof?
- What is the little dot on the drivers seat heater button?
- 2021 Q5e rear fuse box: Am I too blind to find it?
- 2022 Q5 Towing limit
- Fastest Level 1 Charger for Q5 PHEV
- 2021 Q5 PHEV charging with 120
- Emissions codes - P245000 and P240700
- Lower left tail light replacement
- What's the deal with rear pads pre and post 2020 ??
- Average Cost of Charging My 2022 Q5e?
- Lost SiriusXM 360L
- Minor rear end = total loss. Mind blown
- SQ5 brake issue
- S-line grill
- Side assist retrofit mirror housing
- How to tell if 2023 Q5 has 40 or 45 TFSI Engine?
- Minimum oil level marker appears every few miles.
- Best OBD scanner
- 2023 Q5e PHEV
- New Battery in 2019 Q5 - Now Showing Errors!
- New recall for 2021 Q5 e
- Rough ride suddenly on 2023 Q5 with 10k miles
- OBDeleven battery adaptation variables
- Curious about random noises, clicking and whoosing, when opening doors
- Steering Wheel Heater malfunction...
- Audi Q5 Brake Parts
- Odd error and air bag light is on
- Door speakers out and rattle or buzzing
- q5 not allowing me to skip songs on wheel while in carplay
- Audi oil?
- recommendations on repair shop
- Q5 Start/Stop, Cruise Control, Limp Mode Fault
- 2020 SQ5 Tuning Question
- Hotspot and SIM card slot
- “No data connection available”
- RO: 2020 Q5 TFSIe Low battery coolant level?
- Phone Mount?
- torque specs?
- 2018 Q5 Battery replacement
- Help with parking controle module location
- 2016 Q5 3.0 TDI Leak in driver’s rear panel. If not sunroof, what else could it be??
- 2018 Q5 Screw in rear tire
- 2024 Q5 vibration and wind noise
- Nav Sat Image
- Indie shops in South L.A.?
- Not able to login MMI as key user
- Dipstick Needed
- 2016 Audi Q5 2.0t 66k miles hesitation rough idle start
- Heater temperature when engine is cold (2.0T)
- Roof Rack Tie Down
- Retractable cargo cover part number
- 2023 Q5 45 2.0T Technik comes with matrix headlight
- Wait Until 2025 Model Is Available?
- Lumbar support control specifics
- Need help identifying this coolant hose
- Tires for 2019 Q5 (not run flat)
- WORST CUSTOMER SERVICE EVER!!! BK-Motorsport, Inc. for SQ5 Rear Bumper Kit
- 2017 sq5 winter rims work on a 2024
- 18 SQ5 - Radio on, no volume
- P00B700 code
- Audi Connect Canadian Spec car in United States?
- Retractable Cargo Cover
- Update for pre sense & ACC ? or tips and tricks
