PDA
View Full Version : A4 (B8 Platform) Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. APR Ultralink: At Home Flash Tuning is Now Here! (2.0T EA888 Gen 2 Longitudinal)
  2. Unknown Error!
  3. 2008 CAGA 2.0 TDI very hard brake pedal
  4. IDE00556 outside temperatur sensor location?
  5. Stage 2 Tune
  6. First car option, is this a good deal?, and what mods could I have done to it?
  7. Completely clogged cat, do I straight pipe?
  8. Boot opens but doesn't close!
  9. AC unit screen replacement
  10. IE: Gray smoke when engine breaking
  11. Replaced Transmission
  12. Battery change and now won’t turn over
  13. Rattle at Specific RPM Under Rear Passenger Side Floor
  14. Brake lights always on -- ECU thinks brakes are activated
  15. Audi A4 B8 Driveselect.
  16. Climate Control not working
  17. 2014 A4 Quattro power steering inop.
  18. 2009 Audi A4 2.0T exhaust?
  19. Front control arm bushings.
  20. B8.5 Grille Replacement/Repair?
  21. Idling Temperature
  22. Bang & Olufsen MMI 2G Stuck on Pause/Mute
  23. TROUBLE WITH AC
  24. Manual sunroof sunshade apparently out of track on one side
  25. Reasonable (over scrap) valuation?
  26. Motor Blower Issue
  27. 2013 audi a4 quattro p2293
  28. Sprayed engine bay with water...got alternator not charging message...
  29. Audi engine won't shut off
  30. Should I get spark plug replaced in 5th year?
  31. Steering column issue
  32. UK: Hello Can someone please help?
  33. 2.0T vs 1.8T exhaust diameter
  34. Crank no start condition post-rebuild
  35. Engine codes?
  36. LED headlight conversion
  37. 2010 A4Q - aftermarket radio: BU camera blinks
  38. PCV Gen4 full retrofit with Venturi
  39. Audi a4 b8 2.0tdi no ignition after accident
  40. Fuel problems
  41. CV axle replacement B8.5 A4 2016
  42. Battery replacement for 2012 A4?
  43. For Audi A4 S4 RS4 2008-2018
  44. #4 cylinder misfire
  45. Enginge Rebuild with Low Oil Pressure/Crankshaft won't turn freely
  46. Headlight and Range Control issues
  47. UK: Audi A4 B8 2011
  48. Severe Metal Chunks in oil (Turbo?)
  49. Bending Wastegate Arm? Does it work?
  50. Door locking problem
  51. Trunk won’t open makes a weird noise have to manually open it
  52. 2.0T Oil Smoking
  53. B8.5 DRL not working
  54. Noise at specific rpms 1,400 - 1,600 only. Sounds similar to an exhaust or heat shiel
  55. Blue Smoke
  56. OK: Should I take the plunge.2013 a4 avant diesel?
  57. Strange rattle noise coming from engine
  58. 2.0 balance shaft intermediate gear
  59. 2011 b8 a4 balance shafts
  60. Wheel spacer recommendations
  61. mmi not turning back on!
  62. Oil Level Low
  63. Aftermarket Head-Unit Wiring (Need Help)
  64. MY: Engine temperature?
  65. 6.5” OEM display to 7” OEM display.
  66. 2014 A4 Quattro clunk when shifting from 1-2 or 3-2
  67. 2014 A4 Quattro - Rear Passenger Window Problems
  68. Interior LED issue
  69. I need help, my 2011 A4 wont stop misfiring
  70. 2010 Audi Concert - CarPlay and B/U Camera options?
  71. 2012 Engine Overheating and showing low oil pressure
  72. Where does this connector go? URGENT (Pictures and log)
  73. 2009 A4 Rear View Mirror
  74. Headlight problems..
  75. No dash, no ignition. Only passenger side door locks work
  76. J519 burned and replaced
  77. New Battery, Bad BMS Code, cleared codes, low battery charge
  78. Most reliable A4 platform B7, B8, B9
  79. Doest increasing rpm do damage to s tronic?
  80. Subwoofee
  81. Monochrome dis to Color dis cluster Audi A4 B8
  82. Friction spots in steering feel
  83. 2.0 tdi s tronic quatro vibration at idle
  84. Opinion on lemforder engine mounts?
  85. Successful solve for high oil consumption - 2009 Avant
  86. FI: Audi A4 2.0t fsi 2014 no engine power and code p0068
  87. 2.0 TDI 190 hp s tronic quatro vibration at idle only felt on the seats.
  88. Esp and TPMS light and adaptive cruise control not available
  89. 2012 A4 Avant intermittent stall on start.
  90. Can u turn off drls when dipped lights are on
  91. Acceleration Delay & Jerking on Inclines – 2011 Audi A4 B8 Avant TDI (280,000 km)
  92. Where does this hose go?
  93. Battery change
  94. AU: Right dipped headlight Alert
  95. Low oil level light - Oil sensor also replaced
  96. Audi A4 B8 MMI problems!
  97. Help me connect to my car threw teamviewer
  98. Audi a4 b8 2009 right inner tail light not working
  99. A4 B8 Crank, no start. Kinda
  100. Which parkinng sensor is the correct one
  101. 2013 A4 giving P2279
  102. which Power Steering Fluid for top off??
  103. HU: A4 B8.5 2.0TDI CVT manual conversion?
  104. Component protection eeprom swap
  105. Prefered Oil you use (502.00 spec) ?
  106. Saudis in Audis
  107. Canbus logs for bench project
  108. Been sitting for 5+ years, working on un-seizing engine and this happened?
  109. 2010 A4 downpipe + tune
  110. Navigation
  111. 275/30R19 on rear?
  112. date of manufacturing - cant find
  113. Audi a4 2.0tdi 2014 fuel problem
  114. small leak timing cover - fix?
  115. Control arms - is moog good enough or should i get lemforder?
  116. Headlight assembly replacement w upgrade
  117. Suspension upgrade recomendations
  118. Parking brake malfunction
  119. New Air filter makes car shake
  120. Engine Won’t Turn Over
  121. MK: A4 b8 2.0 tdi 8g - WORKING CONSTANTLY ON 1400 RPM
  122. Recommended Transmission Fluid ?
  123. help me! Do i have to recalibrate Grams Performance DBW Throttle Body
  124. SK: Audi A4 B8.5 Avant 2015 Quattro, heating the left rear wheel
  125. Audi A4 B8 to RS4 bumper
  126. Installing the module and parking sensors Audi A4B8 2010
  127. A4 Avant, rear suspension spring is broken, ...number?
  128. Idle up and down
  129. Uk tuners
  130. How to know the chassis code of my A4L
  131. ES: Advice on High Mileage Audi A4 3.0 TDI 180 kW / 245 PS
  132. UK: B8 or B9 ?
  133. need a fuel pump - good brands ??
  134. High Pressure Fuel Sensor ?
  135. 2010 Audi A4 Quattro crank no start
  136. Fuel Supply Hose 8T0201215Q
  137. Bad oxygen sensor?
  138. Lost Pep... CEL off but P11AA, 2984, and 2788 Codes
  139. Rediness lauly
  140. low voltage DTC's
  141. 2013 reverse light wiring
  142. Fog Light Bulbs - bright enough?
  143. P2187 Light after CTS Turbo Intake
  144. Missfiring on idle when engine warms up 2009 2.0TFSI
  145. SK: Steering and clutch heavy a4 b8 3,0 tdi
  146. 2016 A4 Premium Plus burning oil
  147. Key switch Defective (Please contact dealer)
  148. 2011 A4 Cat on a 2013 A4?
  149. best oil for hot summer Audi A4 ?
  150. Cam position sensor code, but sensor ok
  151. UK: What is this beeping noise?
  152. P01309 & C10AE13
  153. Audi a4 b8
  154. Underbody shields
  155. A4 B8.5 rear door handle loose? *video*
  156. Audi A4 clutch lagging and steering is noticeably harder past 3 o’clock
  157. Are performance 034 motorsport control arms worth it over Malay?
  158. Clutch/Flywheel - scammed?
  159. RS: Audi a4 b8 2.0T 2011.
  160. Starting problems
  161. 2013 Aud A4 B8 Backup sensor module
  162. Change or Flush Transmission
  163. Opinion on RaceChip GTS With App Control from ECS tuning
  164. Cylinder 3 misfire
  165. Where to get a DRL led replacement for audi a4 b8
  166. Right side headlight and fog light off!
  167. Where can I find a cat delete kit?
  168. Oxygen sensor/lambda fault. P0030/HELP PLEASE
  169. 12.3inch Touch Screen For A4 B8 2008-2016 | Apple Carplay & Android Auto
  170. whats the consensus on changing fuel filters
  171. Audi a4b8 - 2.0 tfsi 2010 Quattro
  172. Very strange noise
  173. Codes for headlight range after replacing headlight and mmi screen and lights dead.
  174. AUDI CODES PLEASE HELP
  175. No bluetooth, aux, ami, usb, ipod a4 2008
  176. replace spark plugs: how long should it take ?
  177. Help Please need Hood and front bumper
  178. Air leak on this part and how to fix it
  179. 2010 Audi A4 MMI Tuner Fried
  180. Bad fuel economy B8.5 Audi A4 Quattro
  181. Oil temperature to oil pressure ratio?
  182. SD Card Unreadable
  183. need Oxygen Sensor - help!
  184. Low/fluctuating engine temperature 2.0 TDI
  185. Fuel pressure issue
  186. CAGA 2.0TDI fuel consumption
  187. Electric handbrake whistling when parking
  188. Any idea what the issue can be?
  189. Random part or piece of car part found under car?
  190. The car suddenly stopped (fuel, immobilizer ...etc)
  191. What is this bracket I didn't put back in after a rebuild?
  192. ME: Which audio system is in my car?
  193. ME: Bad engine coolant temperature sensor?
  194. Bumper damage
  195. Wheel alignment. No guessing pls
  196. How to update 2014 Audi mimi? I am Korean.
  197. 2012 A4 headlight bulbs - need upgrade
  198. checking Oil - dip stick?
  199. Light bar behind honeycomb front grill, any ideas?
  200. Are the front doors on the A4 the same as the ones on the A6?
  201. 2015 Audi A4 gas pump keeps shutting off when refueling
  202. Variable Valve Timing vvt solenoid
  203. For Audi A4 A5 2009-2012 Linux Car Radio Multimedia Touch Screen
  204. V6 3.0tdi tuning
  205. Five engine error codes at the same time
  206. Clutch and dmf problems
  207. coolent hose from Overflow - need part info
  208. Add 1 Quart of Engine Oil
  209. coolant leak
  210. Oil Indicator Low after oil change?
  211. Brembo Calipers
  212. Water pump leak
  213. Oil leak below alternator Audi A4 B8.5
  214. A4 Audi 2.0T won’t start
  215. Mirror indicators always turned on Audi A4 B8.5
  216. Small problems with instrument cluster/door opening.
  217. Valve Body Question.
  218. Xenon headlights dissappointing
  219. IE: Audi A4 tfsi 2L auto TRANSMISSION MALFUNCTION
  220. Side assist question
  221. 2012 A4 Brake upgrades parts help needed
  222. NZ: Audi a4 2015 b8.5 8k5 2.0tfsi quattro temp gauge issue
  223. 2012 A4 Brakes Calipers?
  224. 2011 A4 Engine to a 2012 Car
  225. B8.5 possible ECM failure? Please Help
  226. LoJack/GPS tracker
  227. CAEB to CPMB Engine Swap Issue
  228. Clutch pedal clicking when released slowly
  229. Correct manufacturer date?
  230. UK: Purchasing a A4 Avant 3.0 TDI
  231. Steering rack problem
  232. Best spark plugs for stock car?
  233. How to open a partially opened hood?
  234. Audi A4 B8 heated seats bcm
  235. Weird sound from car
  236. Balance shaft oil strainers?
  237. IN: Oil pressure too low and glowplug lights
  238. Audi A4 2.0 TDI 2014 | Stalls after 5 seconds
  239. KOLBENSCHMIDT camshaft from chain!!
  240. 2011 Audi A4 Quattro 2.0T w/ ZF-8HP
  241. Glovebox bolt
  242. What to expect on a high mileage ‘09 A4 2.0T?
  243. 2012 Audi A4 2.0t Quattro Does Anyone Know What This Leak Is
  244. 2011 front end
  245. 2009 2.0T auto quattro - valve body part number
  246. 2013 A4 B8.5 TDI - DMF going bad?
  247. Germanautoparts.com real or fake?
  248. MMI still not working after replacing radio unit
  249. Backup Camera not working
  250. helllo from So Cal
