- Audi A4 Cabriolet s line engine misfires
- ignition lock defective
- Audi b8.5 s line bumper on non s line
- Q3 heater fan
- 08 A4 BoVee Adapter Installation
- Power Steering Issue?
- Puzzled by 2 MPG drop after wheel tire change...
- Key Sticking
- Audi A4 TDI consumption.
- Recall: ENGINE AND COOLING SYSTEM 19M1
- Considering buying 7 year old B8 with only 20k Miles
- Bluetooth Doesn't Reconnect Properly
- Running E85 on tune
- interior lights not turning on when I turn off the car
- On/Off Start Button
- 245/40/18 XL ?
- 09 A4 2.0 2-1 downshift issue
- 2009 audi A4 Quattro suspension question
- 2014 B8 Alignment Question
- 2009 a4 B8 remote key not working
- Lowering Springs
- Help: Dealership Claimed NO Oil Loss for Recall, Now Car is Past Millage
- oil consumption
- Transmission Mount, bracket, cap???
- Certified presented
- Exccessive burning of oil and misfiring
- Android Auto Options?
- 2014 A4 aftermarket rearview camera (maybe NAV)
- Home link and leather
- HVAC issues!
- 2008 2.0 Turbo Relacement
- Needs advice on MODS!
- A bad thermostat?
- i can't find the thread that i created
- Mpg?
- Newbie in NEED of your advice!
- Bluetooth
- 2012 A4 Premium+ Quattro - Stereo question
- Heated Miror
- Hard time finding my problem.
- Run in period
- How to enable VIM in 2010 Audi A4?
- AWE Touring Exhaust
- 2009 Audi A4 bent valves
- Motor -Year question for a biuld
- Round Center Cap fits on 5-arm Cap Wheel?
- Tire advice
- 2012 Audi A4 Avant Upgrades?
- Looking at purchasing an A4
- :: ECS Tuning :: Integrated Engineering FDS Intercooler | Audi B8 A4
- Audi Symphony questions
- Headlamp Housing Swap: Help? Regular DRL to LED DRL version
- :: ECS Tuning :: NEW!! ECS Metal Intake Manifold Catch Can | B8 A4 2.0T
- New member - question for a leak of the power break line near the engine-please help
- Timing belt
- NEW D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs | Interior LEDs!
- New Audi Owner -in need of help
- Audi A5 B8 8F7 2.0 TFSI QUATTRO
- A4 2009 loss of power(bref hickup) at 3000 rpm
- Advice please. Buying an A4 2.0 TFSI
- Replacing Coolant with Ethylene Glycol?
- Stevvo
- Spark plug replacement 2011 S4
- A4 B8 Trunk opening without battery
- Squeaking Brake sound and 4 years warranty
- 2011 Audi A4 Quattro
- Mileage has dropped like a rock!
- Too Late for Oil Consumption Test to be Done?
- 3.2 engine (CALA?) swap into 2009 B8 Avant
- Security access key for gruppe 56 - RADIO
- was the A4, Avant, or All Road offered with DSG/Paddle Shifters
- A4 B8 battery discharge HELP PLEASE
- How to turn in instrument illumination
- My Six month old 2016 Audi bursts into flames
- Bluetooth nothing???
- Help: Water leaking from sunroof + amp fried
- Audi A4 avant Vs A3
- Buying 2011 premium plus w/o seeing it
- Climate Control and 1 Other Thing
- Replacement speakers for A 2009 A4
- Can I switch to another type of CVT oil?
- Carista app as EPB release tool
- Electrical connection
- about remove/cover the bad smell asphalt insulation under the back seat
- Flashing Engine Light and EPC Light
- Strange vibration/ judder.
- Multiple errors need help
- PO299 Error Code
- Aftermarket drop in speakers?
- Request: VCDS help for B8.5 optical graphic overlay
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - January 1st - 7th, 2017***
- B8 vs B9 Suspension
- PCV part number question
- 2010 A4 pressure sensor question
- Help! sunroof issue with A4
- Blow Off Help Please!
- A4 not starting
- What screw hardware is used for the belly pan?
- Headlight Conversion Problem DT Moto LED
- Newcomer questions
- Digital speedometer
- AWE Tuning Holiday Special Pricing Event in Full Effect
- first (basic) upgrades to do??
- Dealer criteria for oil consumption stage 2?
- Nav. system update.
- 2014 a4 premium
- How to remove boot trim? Number Plate Screws Corroded
- WEAK BATTERY Warning
- Auto switch to reverse camera
- Just wanted to say hello!
- Oil Level Senor HELP!
- 2013 A4 Premium Plus won't play MP3s from SD card ???
- Buying high mileage 2012 A4
- 2013 Audi A4 B8.5 1.8T after run noise
- 2011 A4 rear inside lights stay on?
- !AUDI ONLINE PARTS WINTER RAFFLE!
- Oil Level Sensor ?
- :: ECS Tuning :: NEW!! Adjustable Headlight Leveling Sensor Bracket Kit
- Brake and Gas Pedal-too close together?
- New Audi a4 Avant 2010 Premium
- A4 to S4 Appearance Mods
- Oil Pressure too low Audi A4
- Another Oil Consumption Question
- Auto Level Headlights Problem
- 2014 A4 aftermarket upgrade from HID to Xenon lights
- My 1st Audi - Ditching the sound system
- WHAT DO YOU WANT TO SEE FROM A PARTS DEALER?
- Performance Problem
- Turbo muffler delete
- A4 B8 Power loss
- Difference between these two? MMI 2013 A4
- No more Audi Care
- HELP! Need New Engine
- Having headlight issues
- RPM jump when engaging first gear and then clutch
- A4 Race Chip Installed
- RS4 Grille Groupbuy
- B8 lease ending
- 2011 A4 B8 | Jerk on deceleration
- 5 Best Cheap Performance Mods for an Audi A4 B8
- Auto Door Lock Issues
- RACE CHIP
- 2013 Audi A4 - Fault code - 4695, 4698, 4699, 4708, 464384
- 2013 A4 Creaking Noise
- 2009 A4 3.2 Quattro Oil leak
- New to Audi - Some advice?
- is it safe to do Oil change at 30k km Audi A4 B8 -2008
- ECU Upgrade
- Bad vibrations
- When to change timing chain tensioner
- My2014 A4 Brakes
- A4 (B8) Turn Signal Malfunction
- 2014 A4 w/ Premium Plus & Sport Package vs 2017 A4
- Anyone familiar with B8 CVT issues?
- winter is coming in Canada
- Android integration on 2014 A4
- Continental Airbag Control Module Recall - NHTSA# 16V376 / Audi Action Code 6901
- On Line parts orders - Amazon
- Help With Check Engine Codes
- Upgrade MMI to Carplay
- New Owner of 2012 A4 80K miles. Any tips or things to look for!?
- MMI hidden green menu + rear sensors graphic display
- Climate control change
- 2011 Quattro Tiptronic - 8 Speed
- PCV Valve
- power loss exiting corners
- A4 new owner
- Strange noise at @ 1.9K RPM
- hill hold assist on by default?
- Another Tiptronic question, don't laugh please.
- Drive Select Suspension
- Dealer Install?
- multitronic "juddering"/"lagging"
- Automatic transmission fluid change?
- Two major issues with a potential a4 I'm trying to buy today
- Smoking from under the hood
- radiator fan replacement
- Clutch failed in 2 years - what? wear-and-tear?
- 2010 Audi A4 quattro brake rotors and pads
- A4 Shifting
- 2017 A4 - Playing Audiobooks for WIFE
- :: ECS Tuning :: Get Them Before They're Gone! | 68% Off Genuine Audi Base Bars!!
- Trip Computer stalks retrofit
- Fuel pump help!
- MY15 A4 B8 S line Sports Plus Auto Quattro problems
- My aluminum trim for your walnut. Anyone want to swap?
- :: ECS Tuning :: No More Inconvenience!
- 2010 A4 Quattro- New Audi owner
- Opinions on fitting AutoDAB in Glovebox or centre console...options
- Audi a4 b8 1.8tsfi rough idle
- 2010 A4 2.0T - What are the best upgrades?
- 2015 A4 B8 Left High/Low Headlight
- 2010 Audi a4 2.0t don't start
- Using VCDS Control Module to enable 12V, Cigarette lighter
- :: ECS Tuning :: Precise. Effortless. Shifts.
- 2012 A4 8-spd transmission fill plug
- Opinions on First Audi?
- Bluetooth pairing failing
- Generic OBD II Scannners
- HELP PLEASE mass flow sensor B8
- !NEW AUDIWORLD EXCLUSIVE PROMO!
- 7speed s-tronic problem!!!
- :: ECS Tuning :: Upgrade with Genuine Carbon Fiber from ECS!
- Has anybody replaced 2012 A4 Avant tail light bulbs with LEDs?
- Cost of service for 75K on my '12 A4 S-Line
- Po171 mass flow sensor
- 2012 A4 Avant won't start intermittently in warmer weather
- door trunk release how to disable
- Has anyone done a Trip Computer (new stalk) retrofit?
- MMI 3G High - No warning / No speed limit
- Bluetooth issues
- UK: Audi a4 b8.5 diesel w/low oil pressure
- 2013 Audi A4 - Long Crank when hot
- MMI and Aux jack.
- 1 fill up--and 1 Qt. of OIL
- Want to join the Audi family
- Engine Oil Consumption /Piston heads replaced
- Memory Seats on Premium a4 2013 2.0T
- Engine Fan Always Runs While Car On
- Audi A4 3.2 Quattro 2009 - a good buy?
- 09-11 2.0t or 3.0?
- Replace spark plugs every 40K?
- 2009 A4 (B8) Engine Growl/Rattle
- Is this a dumb purchase decision?
- Injector failed at 120K miles, in need of a DIY / video to follow
- :: ECS Tuning :: Suspension Techniques Promo | $50 ECS Gift Card + FREE Shipping!
- Leaking power steering pressure line
- Express roll down windows with remote before entering the car
- 2010 A4, 110K miles. What should I be worried about?
- Need help!
- no windowshield water coming out
- 2013 a4 2.0 0-60
- :: ECS Tuning :: Protect Your Pan! | ECS Stree Sheilds - $40 Off!
- How bad does this look?
- 2010 - 2014 xenon conversion
- Looking to Return to Audi
- Rear Inside Brake Pads Worn
- water deflector strip replacement
- Windshield Wiper Issue
- :: ECS Tuning :: The One-Two Punch! ECS GEOMET® Rotors & Exact-Fit SS Brake Lines
- :: ECS Tuning :: Now Available! | HRE Wheel Collection
- Turbo rebuild
- Grille panel removal
- Hot NEW Item! - front turns / reverse LEDs - error free & bright!
- BIRTHDAY SALE!
- Turn off MMI screen
- Evaporator (A/C) drain location 2011 A4 B8
- 2012 A4 Variant?
- Replacing standard headlights for xenons w/ LEDs?
- rain/light sensor problem
