PDA
View Full Version : A4 (B8 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. Replaced ignition switch and battery now nothing works
  2. 2011 A4 Parked and now dosen't crank.
  3. A4 2010 - Gear problems
  4. Question relating to the MMI software/tel button/bluetooth
  5. 3.0 TDI feels sluggish after remap?
  6. New Audi Owner
  7. Help with A4 B8 electric seat wiring
  8. Trailer Hitch wiring? Help a girl out!! :)
  9. RO: Audi A4 B8 diesel DPF frequent regens and problems
  10. Is my car possessed?
  11. Issues with starting my car on a cold start
  12. That "Rislone" thread...
  13. Avant PR Option Code Sticker Location
  14. Purchasing a 2013 A4 2.0, thoughts?
  15. 2009 A4 emergency brake issue please help!!!!!!
  16. Belt tensioner shifted 90 degrees
  17. Reverse camera fitment B8 2008
  18. Is this the idler pulley
  19. Idler pulley - help
  20. Brakes rubbing but only when hot
  21. Audi A4 2.0tdi CR heavy misfire/judder
  22. Audi A4 B8 ( 2010 ) 2.0 TFSI Radio error code - HELP
  23. Rack and pinion lines?
  24. Fitting RS4 (B7) wheels onto an Audi A4 (B8)
  25. UK: A4 b8 avant tailgate?
  26. Carplay Modification
  27. Rear brake piston popped out
  28. ESC Fault / TPMS / Check Engine light after installing interlock
  29. 2011 A4 EPS light
  30. A4 Rear Springs
  31. Jerky Car after ZF 8 ATF is changed
  32. AX: 2010 all road 2.0 tfsi s tronic oil change
  33. Revs drop when change from P to D
  34. UK: Audi vehicle data sticker
  35. Hard to shift when hot
  36. PSA: Check Those Manual Door Locks
  37. No heat
  38. 2011 Audi A4 quattro misfiring
  39. LV: 2.0 tdi warming up
  40. Light bulb
  41. Unusual noise from the roof and pillars
  42. Water Pump Extended Warranty
  43. audi a4 2012
  44. I have a transmission service question!!
  45. Brake caliper bracket bolt part numbers
  46. Bad mpg and slow acceleration? Please help!!!
  47. Fuel pressures, read with software?
  48. UK:A4 2.0 TFSI Poor MPG and Throttle Response
  49. DTE system to DIS system
  50. Silly, but fun
  51. 2009 A4 B8 Quattro P2293/P12A4
  52. A4 B8 TFSI won't crank
  53. UK: A4 B8 2.0 TDI cold start problem.
  54. Hill Descent Control on Audi A4?
  55. getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
  56. CTS Turbo Intercooler ADS Cooler
  57. What gearbox do I have? What do I need for an oil change?
  58. Speedometer cycle
  59. Black Friday / Cyber Monday SALE ON NOW – Best prices of the year!
  60. Reprogramming old key
  61. Delay in reverse
  62. Replacing rear caliper - how to swap ebrake motors over?
  63. Audi A4 B8 Clutch master cylinder needs replacement?
  64. Inflation Relief - Black Friday thru the end of November Sale...
  65. Substituting OEM wheel models?
  66. Oil pressure light car won’t start help
  67. Sensor on Manual Gearbox/Transmission
  68. A4 2.0TDI B8 Lower wishbone nut
  69. Car wont start after ontake manifold off
  70. IE: 2008 1.8tfsi p0300 code, Engine Jerking, Missfire
  71. Completely dead A4
  72. Fuel pump
  73. Picture of stuck injector after intake manifold removal
  74. New here
  75. Talk to me about the tire pressure monitoring
  76. UK: 3.0L Diesel a bad choice?
  77. Turn signal and high beam stock not working
  78. UK: Cruise control retrofit
  79. Gas smell when intake manifold off.
  80. SE: Turn up wastegate?
  81. Intake manifold - last question
  82. 2013 A4 Cold Air Intake
  83. Big orange clip under intake manifold by oil filter housing
  84. A4 b8 intake manifold removal
  85. Intake manifold removal
  86. Does this coolant hose look swollen?
  87. EPC light and power cuts at 2700rpm ? Urgent
  88. Stereo upgrade question
  89. UK: Audi A4 Automatic Estate. 2009 lights on front Passenger not working.
  90. A4 going into Limp Mode
  91. New battery, no screen/trunk
  92. Oil dipstick
  93. A4 2010 vibration
  94. Random Misfire - Pulling my hair out
  95. Just how sideways can this go? School a newbie
  96. Rear bearing change, FWD
  97. Misfire on one cylinder: New Injectors, New plugs, New Coil, swapped coils
  98. Please help define this sound!!
  99. About a couple of fuel related codes
  100. Audi A4 coolant leak
  101. UK: Brake holding/dragging. HELP!
  102. Rear brakes on the A4 B8 - Vag Com a necessity? Quick questions
  103. Violent shaking at idle, whining at low speed, stalling at warm start
  104. 2013 audi a4 misfire question
  105. Audi A4 Halogen yellow to white?
  106. Headlight leveling issue! 01537!
  107. UK: B8 A4 Xenon Dipped Headlight/Main Beam Fault
  108. Need help!! Please describe this part
  109. Any good axle back exhausts for 2015 Audi A4 s-line?
  110. Original screen replacement
  111. Is there AntiTheft system?
  112. No AMI port to enable Audio by bluetooth AUDI A4 S-line 2014
  113. What would cause hydraulic lifters to fly apart and damage camshaft?
  114. Help audi trouble codes
  115. UK: Oil gauge says no oil but just had full service
  116. Problem with seat swapping
  117. 2014 Check Engine Light Mystery
  118. Rough idle
  119. UK: Concert stereo and SD card problem
  120. Exhaust manifold installation tips?
  121. Exhaust manifold question
  122. 2013 audi a4 connector
  123. 8 speed transmission fluid and filter change?
  124. 2009 A4 Avant- Transmission clunk
  125. IE: 2008 1.8 TFSI Rough Idle, Missfire on Low Revs.
  126. EPC flashing
  127. 2013 audi a4 eats a spark plug electrode
  128. Need help with 2016 A4 quattro 2.0T
  129. 2011 A4 coolant leak
  130. Rear door won't open from outside
  131. Air Intake hose and MAF sensor measurements?
  132. 2015 A4 nightmare
  133. 2013 A4 2.0T
  134. 2010 A4 Question
  135. Water pump + auxiliary pump?
  136. Audi 2011 A4 Quattro - Coolant Leak
  137. 2011 2.0T Power Steering Noise
  138. Front tweeter speakers only working
  139. Need Help Finding This Part Name/Number
  140. A4 cannot decode VIN
  141. 2016 Audi A4 S-Line - Knocking noise from pedals/footwell
  142. 2012 Audi A4 S-line No sound. Please help
  143. Audi A4 B8 (2009) MMI PROBLEM ( Radio freeze/Buttons turn off/Navi restarts/freeze)
  144. Audi Radio Update Questions
  145. The Dreaded P0300/P0301 Code.
  146. Odd oil notification
  147. Intake manifold valve?
  148. 2016 Allroad needs new engine
  149. Check engine light after changing tires on 2014 A4 Quattro
  150. Consuming nearly half a quart of oil a day?
  151. Daily clutch use, and upgrades
  152. UK: Cold start issues, petrol
  153. Engine blow by?
  154. Reverse Light Wiring
  155. IE: No heat on driver's side?
  156. Acceleration hesitation when warm
  157. Timing Chain | Stretched or not?
  158. Air coming out from Spare tire
  159. NO: Throttle body issues
  160. Stumble/misfire issues
  161. Is one the oil pressure switch and the other an oil pressure sensor?
  162. MMI Update
  163. Difficult to accelerate?
  164. Newbie Audi Lover with contact issues
  165. Replaced radio?
  166. Top pf seat release lever Cabrio
  167. Passanger side doors won't Lock!
  168. How to remove rear upper control arm
  169. Fuel lines on intake manifold
  170. Discharged battery Audi A4 b*
  171. '14 Audi A4 2.0T Premium , worth it?
  172. Puddle Lights and Red Lights not Working After LED Install
  173. Coolant Leak Thermostat or Waterpump or all ?
  174. Sell '16 A4 w/75k or keep? Worried w/ repairs. Audi Care Worth it?
  175. 2009 A4 Sat for a year+
  176. Dipped headlight
  177. Dead animal smell 2015 A4 Allroad
  178. UK: DRL not working (2014 Audi A4 3.0L Quattro)
  179. 2011 A4 Avant - Rear Wiper Won't Turn Off
  180. 2013 A4 2.0 Quattro. Won't start.
  181. MMI help/Suggestions?
  182. Sunshade question
  183. Oil Pressure Warning - False
  184. V-6 GasMileage?
  185. Codes and AC
  186. 2013 A4 Quattro Engine Block Coolant Drain Plug?
  187. Please help?
  188. Can someone tell me what this is?
  189. Does coolant circulates through the reservoir?
  190. A good cheap oil pump?
  191. ZA: Battery Life?
  192. ZA: A4 Cambelt Failure
  193. Rear Anti-Roll Sway Bar Bushing
  194. Misfire on 1 and 4
  195. Updating transmission firmware
  196. P0345 camshaft position sensor (G163) malfunction
  197. Parking brake issue? Code 00473?
  198. How do I fix code 03020?
  199. How do I fix 02558?
  200. NZ: First Audi?
  201. UK: Where can I find genuine replacement parts?
  202. BW: MMI Issues
  203. Bang&Olufsen Amplifier Replacement
  204. Shocks and Springs question
  205. Bearing noise
  206. App-based bluetooth or cellular unlock on an A4 without AudiConnect?
  207. A4 B8 Rattle cold start, about 10-20 seconds
  208. UK: a4 avant towing electrics?
  209. Starter not engaging
  210. 2009 A4 quattro 6cyl 3.0L T Diesel Buying Advice
  211. 2012 A4 B8.5 S-Tronic issues
  212. Interior lights etc
  213. Gearbox warning + key stuck (P189000, U010E00, 03951, 01334 + more)
  214. Car won`t start, display all black
  215. Battery
  216. How to update TCM software
  217. AU: Misfiring after draining excess oil from A4 b8
  218. tire size on 19s?
  219. Timing cover update?
  220. Looking for a BEM code
  221. Caliper Covers
  222. Bluetooth module location
  223. Audi A3 8P Headlamp with DRL
  224. MMI 3g high retrofit no sound
  225. Green Menu activaror MMI 3G Basic
  226. Radiator Fans Running High All The Time !
  227. LOST KEYS
  228. SI: Audi A4 2.0 TFSI - OIL CONSUMPTION FIX!
  229. DK: Help me please, strange noises
  230. Hard to find vacuum leak
  231. CA: Y ep list keeps going on and off car rus fine only rough a little a cold start
  232. Sunshade & Cover
  233. Flush wheel fitment
  234. Optical visual sensor (MMI) B8.5 A4
  235. Help!!! Smoke from under catalytic converter area, not sure what the issue is.
  236. Came outside to B pillar cover smashed, where to buy replacement?
  237. Trunk adjust
  238. Price quote AC issues
  239. can you raise the front of the drive seat?
  240. Pulled out concert stereo unit to replace hooefully blown fuse
  241. How to make your AC cold again
  242. Engine block plate damaged?
  243. Audi a4 b8 2008 steering controls malfunction
  244. Drivers door malfunction after unplugging wires
  245. Audi A4 B8 screen fault
  246. 2013 A4 A/C problem
  247. SE: Cleaning DPF -14 Audi Avant?
  248. 2012 Audi a4 need new turbo
  249. Help identifying A4 2010 engine part
  250. AC Suddenly stopped working - quick question
