PDA
View Full Version : A4 (B8 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. how much boost for 1.8????
  2. NEED HELP!!!!!!!
  3. Recommendation on control arms and the alignment needed
  4. UK: Burnouts in FWD diesel without handbrake?
  5. 2011 2.0 engine replacement compatibility?
  6. end links and sway bar
  7. 30 mpg average
  8. remote start install issue..(help me)
  9. UK: no reverse light so no MOT! HELP PLEASE
  10. Rattle / clunk while turning and breaking..
  11. Rich Condition
  12. Need advice on A4 2014 Prestige oil consumption issues
  13. NEED HELP!!!
  14. Fuel filter replacement audi a4 2.0 tdi 143hp
  15. 1.8tfsi stronic
  16. Please help, fastener came off on vehicle and I don't know if it's safe to drive
  17. SOUNDAKTOR RETROFIT
  18. Car bucking and stalling with P0341 code
  19. Manually open rear door - no handles working (A4/B8)
  20. UK: diesel Running cold, bad thermostat?
  21. 2014 A4 MMI System Replacement?
  22. UK: A4 Avant Quattro 3.2FSI - New fuel pump to cure petrol smell from engine bay?
  23. A4 B8 2009 ABS Wiring problem
  24. How to identify MMI 2G or 3G or 3G+?
  25. 2013 Audi A4 Quattro Modifications?
  26. NEED A COMPLETE CYLINDER HEAD CAEB 2.0 TFSI
  27. UK: CVT Bucking and jerking when pulling away from stationery
  28. Troubleshooting Weird humming/vibrating noise
  29. AR: External P13W Activation in Halogen Headlights
  30. 2010 A4 Audi Concert sd card restarts song...
  31. Midpipe
  32. 2009 Audi A4 B8 2.0T balance shaft oil screen?
  33. IL: One Mirror doesn't automatically tilt down on engine start
  34. replacement Headlights not working
  35. Funny odor and hesitation on hard acceleration
  36. Last Manual Trans in the Avant.
  37. getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
  38. UK: Replacing DRL
  39. Advise on led and anywhere I can buy a honeycomb grill
  40. Front Suspension Noise
  41. 2013 A4 with catastrophic engine failure - What to do?
  42. Audi a4 2009 wont start - Bad alternator
  43. How to Tune-up your Audi A4/s4 b8/b8.5
  44. 3GP MMI Upgrade for my 2011 Avant
  45. 2013 a4 b8.5 intake manifold 06H133201AR removal
  46. 2009 a4 3.0tdi gearbox question
  47. Audi A4 B8.5
  48. Whining noise from fuel rail location ?
  49. about to do my vacuum pump
  50. Retrofit valet switch help
  51. Audi B8 A4 2009 ignition control module
  52. Crazy rear tire wear. Scallop type wear.
  53. bumper/headlight fitment
  54. Installing a resistor on a side mirror turn signal socket
  55. Audi A4 Avant 2013
  56. OBDEleven Dongle Failed after 2 years
  57. 2009 Audi BCM pinout
  58. 2015 a4 b8.5 electrical issues
  59. 2013 A4 - Which key fob to buy?
  60. What is causing this noise during acceleration?
  61. VCDS code-7859, Intake Manifold Flap Position Sensor P2015
  62. Wiring diagram
  63. Audi A4 Fault Codes help
  64. Audi A4 B8 Manual
  65. Low beam does NOT come on despite replacing headlight bulb
  66. Audi A4 avant 2010 Rear boot lid interior panel removal
  67. deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
  68. B8 allroad misfire- no codes showing
  69. AWE Black Friday 2020
  70. 2011 Audi A4 Quattro 2.0t: Catalytic Converter
  71. Weird door sensor issue
  72. B8.5 Noise under the car + noise from door.
  73. 2012 A4 How can I use my Android phone to play music
  74. 2011 Audi A4 heated seat not working
  75. 2012 A4 Quattro misfire cylinder 4. Have replaced a ton.. need help
  76. Black Friday Deals Are Already Here and More to Come...
  77. Crankshaft pulley seal leak
  78. audi a4 2013 does not start
  79. SE: S-tronic diesel stalling?
  80. Replacement Jack Needed
  81. 2012 Audi a4 2.0 engine noise.
  82. Battery draining overnight and dashlights staying on without key in ignition
  83. Battery draining overnight and flashlights staying on without key in ignition
  84. Audi A4 Quattro possessed
  85. CarPlay joyeauto installation
  86. Intermittent ECM codes P3043 and P0299
  87. 2014 CVT Transmission Fluid Change
  88. Fitting an allroad or 3.0 tailpipe on basic avant?
  89. Avant 2011 Speaker wire location/colors
  90. Turbo options?
  91. Wheel fitment for A4 b8.5 1.8 tfsi cvt 120HP
  92. Wheel fitment for A4 b8.5 1.8 tfsi cvt 120HP
  93. AU: Oil consumption
  94. Have I completely screwed up?
  95. Front Suspension Specs
  96. Quietest Performance Exhaust?
  97. AU: Maybe a blown head gasket ??? 2010 audi a4 1.8 tfsi 140,000km
  98. Audi a4 b8 dashboard flickering
  99. Audi A4 B8 Led Door Sills
  100. GE: high fuel consumption
  101. AC Fan not blowing -08 B8
  102. Used 2009 Audi A4 Quattro help
  103. Audi Sport Wheel Logo
  104. 2013 S4 Tach Light Out
  105. Passenger-side headlight, turn signal not working
  106. Heated leather seats install (HELP NEEDED)
  107. 2009 Audi A4 Multiple Misfires
  108. 2011 Engine Rebuild - seeking advice
  109. Steering wheel replacement w/ 3 spoke.. same airbag?
  110. K04 compete set vs CTS “Big Boss 600” complete set
  111. Strange underboost, rough power, goes away totally when CEL goes away
  112. NJ: 2015 A4 Engine Failure repair?
  113. Intermittent starting problem and 00955 code
  114. Brake job gone wrong: EPB
  115. Waterpump, DSG and lots of things failing - Please help!
  116. Weird lock problem - Avant tailgate
  117. A4 B8 - PCV/Vacuum issues
  118. Help with some OBD2 Codes!
  119. Audi a4 b8 repairing foggy/hazy headlights
  120. DE: Audi A4 AC blows only when recirculation is on
  121. Buying 2010 A4 quattro advice?
  122. ZA: login?
  123. AZ: A4 B8.5 - Vibration when stopped?
  124. DNA Motoring
  125. MMI 3G ISSUE - A4 B8 2010
  126. 2014 Audi A4
  127. Rear shock bolt seized
  128. Steering Wheel/Column
  129. Any Workaround? Door Lock Actuator + Chinese Part = no chirp!
  130. 2009 Audi A4 noise when reversing
  131. 2010 audi a4 2.0t premium Quattro questions
  132. Program new 3rd advanced key
  133. Aux port in 2014 A4?
  134. Fuel pump leaking!!
  135. A4 B8 1.8tfsi trans output speed sensor
  136. Audi A4 2009 2.0T // Test Pipe and its affect on stock software.
  137. 09 Audi A4 2.0T Misfire problems
  138. Timing belt?
  139. 2009 Audi A4 2.0t misfires rough exhaust and weird air escaping sounds
  140. Paint code Help
  141. Audi oil leak rear top of motor
  142. 2014 a4 turn signal light working but blinking faster then usual dash light comes ion
  143. 2014 A4 Premium Plus- belt or chain?
  144. Mmi screen very dark
  145. Brakes won't release - Squealing when moving forwards but not backwards
  146. Avant won't start, acts like it doesn't recognize key fob
  147. Engine cuts off at stoplight
  148. B8.5 2.0 JB4 Released!
  149. P2015 OBD II code for 09
  150. KR: A4 avant and sedan's tail lights is same?
  151. IE: Which diesel engine is the most reliable?
  152. UK: Audi A4 2L tdi B8
  153. 2012 A4 Sedan Door Replacement (DS)
  154. A4 Quattro Manual purchase advice - 2015 - 18K list price
  155. Mmi help please
  156. A4 2012 Trailer Wiring Question.......lots of fun.
  157. 2010 A4 premium plus rear main seal leak.
  158. BE: Navivox has no power, can't install nor switch it on
  159. test
  160. Navivox has no power, can't install nor switch it on
  161. Audi B8 P0300, P0303, P0304 Invisible Problem
  162. Battery drain, help needed -- positive cable corrosion?
  163. 2011 Audi A4 Quattro 2.0 Low Oil Pressure
  164. Help! Auxiliary Diesel water heater DIY
  165. 2011 Audi B8 2.0T Intermittent Starting Problem
  166. Help I need an adult! Oil filter housing question
  167. 2015 A4 rear backrest removal
  168. SE: Connect fuel line for aux diesel water heater?
  169. 2014 A4 S Line horn issue
  170. Mmi 3g basic problem
  171. Audi a4 b8 2.0tdi not starting
  172. Introducing OEM Folding Mirror Packages...
  173. Creaking/Knocking Sound
  174. Replacing the Thermostat? - B8 A4
  175. Front Parking Sensor Buzzer Help
  176. GR: O2 SENCOR LAMDA
  177. Rear lights error both left and right
  178. AU: A4 S-Line B8 front lighting issues
  179. Test drove a 2013 A4
  180. emissions control warning light when I drive
  181. How to set TDC on 2.0TFSI?
  182. Jukebox
  183. Jukebox
  184. Audi A4 CCWA reliability
  185. BE: Battery code
  186. Supercharger 2.0????
  187. AU: Audi Engine Rebuild required?
  188. Cant find colour code
  189. Front Wheel Bearing Replacement
  190. 2010 A4 Won't Start
  191. MMI Shuting down with engine start?
  192. How to undo this clip/bracket on trunk amp? (Speaker issues)
  193. P000A
  194. Any Info will help
  195. Questions About My Audi A4
  196. SE: Questions About My Audi A4
  197. Low beam actives automatically with High beam
  198. key fob
  199. Wheels
  200. Airbag light and Parking brake malfunction
  201. How do you de activate the immobiliser
  202. Chorus to other
  203. 2009 Audi A4 EPC light
  204. Audi A4 (B8) 2009 3.0 TDI white / grey smoke
  205. 2014 A4 -where is the Rear parking aid buzzer location and how do i get access?
  206. Tuning 2016 a4 cvt?
  207. Audi gray interior colour steering wheel upgrade
  208. AMI location
  209. NO: Don't find my amplifier?
  210. Tow hook for license plate?
  211. 2008 Audi A4 B8 8 speed multitronic
  212. Parkers and fog lights?
  213. 20" Q5/SQ5 wheels onto an A4 B8?
  214. 2009 Audi A4 Engine
  215. Ac stopped working and steering heavy belts seem fine
  216. Google Maps
  217. Google Maps
  218. Flutter noise Front end
  219. Coolant leak
  220. Intake Manifold Won't Come Off
  221. AU: Audi A4 B8 Allroad diesel - EGR fault codes
  222. Need your expert advise! Big decision!
  223. Increasing oil consumption, what's the end result without new rings?
  224. Passenger window not working
  225. New headlights B8
  226. Weird Honking Noise Under WOT
  227. Not starting
  228. Strut tower cover - necessary?
  229. Audi B8 A4 code P0234
  230. Right side windows not working
  231. AC stops when car stops (engine still on), back on when driving
  232. Random trim issue
  233. Sunroof rattle
  234. unknown ecu fault code meaning??
  235. Low speed Wobble/Vibration
  236. Vagcom query
  237. Which Injectors for 2.0L?
  238. 2009 A4 Oil Leak?
  239. AUDI MMI firmware update ver. K09426 for 3GP/3G Plus/HN+ (A4/A5/Q5/Q7)
  240. Audi a4 b8 rear suspension tracking - seized arm
  241. NO: Oil consumption Audi A4 2013 2.0T
  242. Air Filters?
  243. Audi A4 (B8) - Ignition lock defective - yellow light
  244. Opinion on filter
  245. Black Optic with Black rings??
  246. NO: Strange oil level readings MMI - Audi A4 2013 2.0T
  247. 2016 Audi A4 - Major Problems?
  248. No Aux - How can I add one?
  249. Bluetooth?
  250. Engine startup problem
