- Intermediate Steering Shaft
- ABS/ESP/TPMS/Brake lights flashing, no error codes
- Audi A4 B8 extra speaker connectivity problem
- 2010 TFSI no boost, wont start, only one crank
- A4 B8 Sevice manual?
- Fault Code 01496
- NEW! Rear Lower Control Arm Brace from ECS | Free Shipping
- It's finally here! The Pre-Facelift Non S-Line ECS Carbon Diffuser | Free Shipping
- A4 TFSI 2009 - Misfiring, oil leak
- Fuse
- How to connect extra speaker if there is no Amp in my car
- Exhaust systems
- RS honeycomb grille for a 2014 Audi A4
- Paddle Shifters retrofit
- Back in Stock!! The ECS Ultimate Adjustable Short Shifter! | Free Shipping
- Audio + Bluetooth
- oil extraction
- Changing a Wheel Bearing? Am I getting ripped off?
- Audi b8 2009 PTT speaker button stop working
- APR Performance Software Sale!!! 10% off and FREE SHIPPING!
- Audi A4 2011 Jerks & accelaration issues
- What is this cable for ??
- Research for replacement 2.0 engine
- Fog lamps S line???????
- Audi A4 2.0TDI Shakes while riding, rought ride, electrical problem.
- Which MMI version?
- I lost two bolt.
- Is it worth it.... New Parts vs. New Engine
- Rear view mirror socket help
- NEW!! B8 (pre-facelift) ECS Carbon Fiber Front Lip!
- Engine Studder at take off... OBDII Code P052A00
- 11 Audi a4 bonnet sensor
- 2015 A4 Quattro Brake Rotors
- NEW! ECS Intake Air Scoop for the B8 A4 | FREE SHIPPING
- APR Stage 2 Requirements
- New Schwaben Fender Roller! *$59.95* with Free Shipping!
- Key fob
- Oncoming Cars Flashing You?
- Fast fuel consumption?
- oil pressure?
- Does your car stink? Time for a new cabin filter from MANN
- A4 B8.5 Front Grille Strip Replacement
- Xenon Lamp go out in 70 seconds
- Rough Idle, Engine Shakes, EPC Light, Check Engine Light
- A4 (B8) Front Rotor Size Issue
- Last Day to SAVE up to 50% on your favorite brands!
- HEATER RECALL---CAMPAIGN 80C5-23
- MFSW cable pins (need help connecting)
- Slipping clutch
- Flash SALE up to 15% off ECS Carbon Intakes
- A4 Avant rear washer fluid?
- Flash sale! 15% off ECS Performance Baffled Oil Catch Can
- bluetooth or aux in audi a4
- Oil viscosity in B8 A4 2012
- Approach Lighting Not Working Now!
- Misfires, rough idle, lots of errors
- I want to upgrade to Dynavin N6
- Breaks Squeak
- GOLD!!!!!!! Limited Edition Forge Diverter Valves | In Stock | Free Shipping
- Audi A4 2.0 TDI Starting Problems
- Last day to save on over 25 of your favorite brands up to 30% off
- New car, check engine light
- Side assist not working
- New Guy Intro!
- Help a newbie
- B7 S4 wagon hidden hitch
- Engine Misfires every few hundred miles
- AC Not Working - Help!
- Audi A4 B8 Avant
- timing chain job , please help
- Epc problem
- Adding backup camera for B8.5 *with* MMI
- A4 Low MPG after emissions fix
- Transmission Oil
- up to $50 off ECS Street Shield Skid Plates!
- $50 ECS Gift Card + Free Shipping on select South Bend Clutch Kits | Best Deal!!!!!!!
- Valve cover gasket replacement
- Can anybody help me with this VCDS scan
- Scanner VAGCOM
- Engine Vibration - Please help!
- engine coolant type?
- HRE, Neuspeed, Radi8, Alzor Wheels up to 25% off!
- Throttle Valve faults
- How to find if service changed oil in automatic transmission?
- New to Forum - looking for Diagrams
- Snow Tires and Rims
- Seat Wobble
- 2013 Audi A4 2.0L Unusally High fuel consumption
- Transmission and Rear Differential
- Any problems with an A4 w/1.8TFSI, 2011?
- Mystery melody out of A4 dashboard
- Bad experience with Racechip ( customer service)
- On SALE HPA Motorsports | Sale ENDS 1/3/2018
- Free Shipping and up to 15% off P3 Gauges!!!!
- Have any of you tried the Racechip xlr for better throttle response?
- draining battery
- Can anybody tell me what part this is??
- Potential A4 Buyer - Advice?
- Drivers seat won't move Forward/Back
- 25% Off DINANTRONICS Sport Performance Tuner 2.0T
- A4 2005 1.8T Running Poorly
- Navigation Update 2011
- Heating problems
- Audi A5 clunk when braking
- 2010 A4 Heat/AC fan just stopped working
- my 2012 Audi A4
- Reinvent Your Floor Mats
- Audi TTS 2017 steering wheel discussion
- A4 B8 Slight misfire at high revs
- 2016 A4 MMI
- A4 B8 Avant Xenon Range Traffic Switchover Active Fault - help needed
- engine restorer and lubrican
- Xenon Running light replacement?
- Low oil pressure warning at idle and park ad misfire
- Need URGENT help on my 2010 Audi A4 please!
- HID Headlights Low after Brake Job
- Finally! ECS B8 A4 S-Line Pre-Facelift Rear Diffuser! It's HERE!
- Audi A4 2.0 TDi Mods
- 2011 A4 Rear Brake Light Len Replacement
- Idle RPMs? 1000?
- Buying 2009 Audi A4 Common/Known Issues
- High mileage 2013 A4
- 2009 a4 right dipped headlight.
- 2009 audi a4 engine shaking/w engine light on!
- Audi A4 Car system settings
- AC not heating nor cooling
- Need URGENT help on my used 2010 Audi A4 please!
- tubrocharger broost sensor valve
- P2779 Air Intake System Leak error. Help!
- Engine replacement
- up to 50% off over 60 of your favorite brands | ECS BLACK FRIDAY
- keyless entry inermittent , won't lock and beep
- One Day Sale! $50 off your B8 A4 ECS Street Shield!
- Jet engine in my car?
- Anything I'm missing on this used 2014 A4?
- - Europrice.us | Black Friday | Big Discounts | New Product Lines | Holiday Sales -
- 2013 A4 B8.5 Tune? (APR vs. Unitronic vs. GIAC)
- Save on Ziza! up to Half OFF!
- New owner of 2010 a4: strange transmission problem and oil leak
- reset bluetooth pin
- Need Blind Spot Mirrors
- Getting locked out
- Need headlight info
- Advice for a new purchase
- driver and passanger door don't lock
- audi a4 2.0t 2010
- audi a4 2.0t 2010
- AM/Fm Radio Not working
- Transfering CPO warranty
- RS Style Front Grills
- Just bought these..?
- 2018 Map Update
- NEW! A4 Facelift ECS Carbon Fiber Diffuser!
- Audi B8 Remote Central Locking No Longer Works - Help Please
- Backup sensors not working
- Rattle at front passanger side, near door panel
- Overboost?
- DLC
- Low oil pressure & P164B ECM light over 3700rpm
- AUDI A4 OEM Integrated Backup Camera System
- Can I mount lower front bumper from pre-facelift to facelift model ?
- MMI Anger & Despair HELP
- MMI Confussion/Anger & Despair
- 2013 A4 Avant accelerating noise when changing gears.
- Genuine Audi parts ON SALE | Two Days Only!!!
- 2011 Audi A4 Quattro w 127,000 miles needs new engine.
- 2013 A4 2.0T oil change. Confused.
- B8 To buy or not to buy
- 2010 A4 2.0T cam position sensor codes, could it be a bad timing belt tensioner??
- NEW!!! B8 A4 Transmission Street Shield Skid Plate
- Whining noise?
- Audi A4 B8.5 Front Grille Part Number
- Sliding over from the A6/C5 Discussion -- and backup sensor issue
- ami to mmi?
- 2010 a4 avant 2.0 tdi
- Up to 15% off Assembled By ECS Kits! | Ends November 12th, 2017
- A/C advice
- 3rd brake light on a4 b8 avant
- Error codes p2293 and p0304
- Advice on 2010 Avante purchase, ~$13k w/ 81k mi
- Customized Audi B8 compilation video! Great cars!
- Possible to Replace ECU/ECM
- Carista and the 2009 B8 A4
- 2010 Avante A4 B8 Alarm not working
- B8 Turbo replace ...
- 2011 A4 Quattro purchase advice
- Wanted 19 S4 Peelers
- Dorman | innovated part solutions | for your B8
- Rebate! Volant Performance Intakes | $50 back!
- Wont Start
- 2013 Audi A4 - A/C Blower gone crazy
- Winter Tire Repair Debacle
- Change of MMI Screen
- No A/C Fault In J519 Module
- Instrument cluster/gas guage backlight
- Deval Carbon Fiber Upgrades for your Audi!
- No Signal/Communication with ECM - Intermittent
- Head light change
- Noisy Sunroof---Solutions?
- 2010 B8 A4 Avant to RS4 Avant Conversion
- PCV FOR AN AUDI A4 2008
- NEW! OBDeleven PRO Scan Tool | FREE Shipping | Coding | Diagnostics
- Exhaust
- Question About PCV Valve/Oil Separator Versions -AH vs -AK
- Wheel suspension font axle left broken
- Vibration going down hill with cruise control engaged
- SACHS Performance now available!
- Shaking at all speeds
- Will 245/35/R20 tires fit?
- Radio interference
- Save 11% HPA Motorsports + Free Shipping
- check engine light after replacing timing chain
- a4 b8 oil level sensor slow
- 2014 A4Q Surging Idle and Codes P0507 P2187 P2279
- OEM amplifier issue
- 30% OFF B8 A4 2.0T Upgraded Diverter Valves
- New B8 driver looking for advice
- Rear armrest cup holders removal
- Kufatec Sound Booster Pro?
- Are my headlights too bright or what?
- Start-Up/Ignition Issues
- Surging on Highway
- Rear Differential Leak after Long Trips
- Am I getting scammed bc I'm female???
- which oil
- Replacing 2011 A4 Speaker w/ "Open Circuit"
- 2011 A4: oil pressure light on and coolant gauge keeps rising
- Bluetooth not working
- Audi Mirror Switch
- P2008 CEL Solenoid Valve
- 2013 CV boots -- 3rd failure in 15,000 miles...
- i need help identifying this part
- Need LED lighting info
- CPO terms
- "Advance Key Defective. Use Ignition Lock." What is going on?
- B8 A4 Dinan Performance Products!
- 10% off FrankenTurbo B8 A4 2.0T turbo upgrades! Ends 10/31/2017
- Dealer Offering CPO without inspecting
- Sale! B8 A4 ECS Baffled Oil Catch Can Systems|15% Off + Free Shipping|Ends 10/15/17
- B-Forged Performance Wheels - Collection and Gallery
- AC doing Clicking Noises When On + Car is reversing in Drive
- Audi A4 AMI USB Support
- Audi A4 B8 (2010) Avant Wagon Suspension info please
- ZF8 External Cooler
- Things to look for when purchasing a 2009 A4
- Upgrading MMI in 2007 Audi A8 to support Apple ios 11
- Looking for the oil pressure guru.
