PDA
View Full Version : A4 (B8 Platform) Discussion
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. 2012 Audi A4 Headlamp 8K0-941-029-BE and 8K0-941-029-BF
  2. new front axles cost?
  3. P0016 code with -25 degree phase position
  4. hard steering
  5. 2009 A4 B8 No ACC power, windows or start.
  6. Help with intake camshaft
  7. Audi Navigation Not showing directions
  8. component protection
  9. Wireless CarPlay Android Auto For Audi A4 2008-2018, With AirPlay Mirror Link
  10. Front bumper and left fender replacement instructions
  11. UK: Meyle parts distributor?
  12. Cleaning the head lamp
  13. Navigation update via SD card for Audi A4 from 2014.
  14. Audi A4 electronic suspension
  15. Coolant temperature sensor
  16. 1.8t cylinder 3 misfire, need advice!
  17. 00979 - Lamp for Low Beam; Right (M31) 012 - Electrical Fault in Circuit
  18. 8.8inch 12.3inch Carplay screen for Audi A4
  19. Question on Rear Wheel Bearing Replacement
  20. Steering wheel upgrade
  21. At what point is the IE intake manifold worth it and removing 5th injector?
  22. Any one know what goes in the whole on cylinder head?
  23. Service Interval Display Reset?
  24. 2015 A4 Transmission cooler bolt to filter
  25. Steering column assembly replacement
  26. 2015 Audi CVT line o-rings
  27. Audi A4 2010 fule range issue
  28. Help with audio problems!!
  29. 2009 a4 quattro 3.2l need help!!!!
  30. Brake pads or boiling fluid?
  31. UK: Clutch & Flywheel Replacement Cost - A4 Avant 2014
  32. MY: Audi a4 B8.5 ECT SENSOR?
  33. Audi A4 B8 panoramic roof sunblind
  34. TROUBLE with timing chain job! Please
  35. Low boost, but no boost leak?
  36. Oil consumption since replacing PCV
  37. 2012 A4 Quattro Blinking CEL, Rough Idle, Shuddering
  38. Hard Starting After Tune Up - VCDS Scan in Post
  39. Need help with amplifier replacement
  40. Speedometer clocks
  41. Old Timer needs help with fuel pressure P codes
  42. CJCA 2.0 tdi, excessive crankshaft pressure - dying
  43. P0016
  44. ESP, TPMS and Active Steering lamps on
  45. Fuse blows instantly
  46. Audi A4 1.8 Tfsi 2008 Mechatronic Automatic Gearbox
  47. Audi A4 1.8 Tfsi 2008 Mechatronic Automatic Gearbox
  48. Help With Odd Smell When A/C is Turned On
  49. Audi A4 Transmission fluid change CVT
  50. Help needed to locate the sound source
  51. Wo lassen Sie Ihre Autos reparieren?
  52. Fitting b9 parts on gen 3 b8.5
  53. Pass side axle reinstall - done it with suspension intact?
  54. 2013 Audi a4 Caeb ea888
  55. Outer CV joint - verify clip is engaged
  56. 2015 Audi A4 B8 2.0 163bhp TDI Ultra CNHC Flashing glow plug and limp mode
  57. LV: B8 airbag fault
  58. 2014 Audi A4 Quattro Dlex Fuel 2.0 Fuel filter
  59. AMI port audi a4 b8 concert
  60. Anyone replaced stock diverter valve?
  61. Front PDCs acting up
  62. Which Transmission Do I have?
  63. Problem with Driver Information Display
  64. 0aw transmission problem
  65. Dead battery problem
  66. UK: What cause this noise?
  67. Whining Noise Coming From Wheels 2015 Audi a4 Bb.5 CAED 6M
  68. UK: 2014 B8.5 CVT - whining noise on revs
  69. Test pipe cel
  70. Airbag clock spring replacement
  71. LT: Emission stickerv for CPMB
  72. Can water ruin my rearview mirror?
  73. AC pressure sensor?
  74. Well, emissions time again fellas...
  75. Audi fuel issues
  76. DTC Help + amp issues
  77. small crank no start Audi A4 2015 2.0t 6speed manual
  78. Flex fuel to non flex fuel
  79. Snapdragon665 Chip Android 13 8.8inch IPS Touch Screen with wireless Carplay Android
  80. UK: Audi A4 Engine - Whirring Sound
  81. Driver and Passenger Doors speakers and tweeters not getting any power
  82. Noise when Accelerating
  83. Transmission fluid and gear oil replacement on a 2011 A4 2.0
  84. 2009 Audi A4 Front door speakers not working
  85. Rattling noise from the dual mass flywheel. Gearbox issues?
  86. Fuel problems?
  87. MMI 3G OEM Spalsh screens
  88. Timing Chain Noise, I Think Not, but What?
  89. 2009 a4 2.0t oil level sensor reloacement?
  90. Normal wear on front brake Discs?
  91. Bad Sound out of Audi A4 B8.5
  92. DIY Custom Headlights / Taillights
  93. UK: Where can i get a working dipstick?
  94. P2015 & P0201 P0203 P0204 due to Injector Harness?
  95. Woke up to Warnings.
  96. 10 plate A4 not running up to temp
  97. 2016 A4 Quattro : Stabilisation control (ESC) fault! See owner's manual
  98. My timing chain broke on my 2011 A4
  99. Question on touch up paint
  100. 2009 A4 3.2 Quattro potential issues
  101. Intermittent ABS/ESP fault.
  102. Help - Intermittent Lean Bank 1
  103. Driveshaft Causing Vibration while accelerating?
  104. How to wire front camera to aftermarket head unit
  105. Which cable is the woofer cable
  106. Lost drive going up ramp
  107. Chirping/whistling alarm coming from 2011 A4
  108. Should I keep or trade my 2016 A4 at 90k miles?
  109. 2011 A4 Sedan Red on Black 90k Miles, not running: Buy?
  110. Carplay Interface and Android Screen for Audi A4 B8
  111. 2014 Audi A4 engine?
  112. Rotary scraping noise from N/S whilst accelerating
  113. RO: A4 B8 2008 (02261 - Data Medium Defective)
  114. Significant error codes causing LARGE issues
  115. Eng shuts down intermittently
  116. UK: P256300 code on AUDI A4 B8 Engine CAGA
  117. Audi A4 B8.5 (8K9) Service Light Message appears constantly after reset
  118. Transmission Issues on 2014 Audi A4
  119. A4 B8 allroad wagon premium plus MMI update
  120. Upgrades and Mod questions
  121. Recommended backup cams for 2009 A4 2.0T?
  122. Automatic headlights DIY
  123. Random dying on cold start
  124. 2013 Audi A4 Quattro Premium
  125. Audi A4 B8 Avant 2014
  126. Bluetooth and radio failure fix
  127. 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
  128. Audi A4 B8 Audi Chorus upgrade
  129. AMI port not working
  130. 2014 Audi A4 oil brand
  131. BR: A4. 2.0 TFSI - 2011 - Falhando somente com o ar condicionado ligado
  132. 2015 Audi A4 2.0l tdi ultra
  133. rear right window swtich can't roll up the window
  134. Front Strut Mount A4 B8 ECD vs Non-ECD difference
  135. New Forgedlite TF Series 1pc Forged Monoblock - Custom Made for your Audi
  136. I’m looking to purchase
  137. Audi a4 Sline Avant Oil Consumption
  138. Help/Advice for my 2013 Audi A4
  139. MMX Wheels 1P 2P 3P & 4P Forged Aluminum Wheels Master Distributor Wheel Designers
  140. Brake Calipers
  141. A4 tdi no start after changing fuel regulator switch
  142. Audi A4 B8, no codes, crank but won't start
  143. Advice needed for upgrading car's audio system
  144. YE: Audi 2011 A4 2.0T white smoke from exhaust pipe
  145. service manual
  146. A4 B8 Engine Rebuild Cylinder Bore question
  147. ccm handbrake module fuse issue confused
  148. B8 Audi a4 headlights flickering
  149. Here’s a dealer maintenance Quote
  150. Any idea how much the repair could cost?
  151. Oil Level
  152. Failed engine replaced - what other things may go wrong?
  153. 2014 A4 transmission question.
  154. Rebuilding engine - what else is worth replacing this deep?
  155. Idle surge HELP
  156. AU: Suggestions for Cold Air Intake?
  157. Is this tire okay after puling out small nail
  158. 2014 A4 Quattro 2.0L needs new motor. Fun Options?
  159. UK: Bonnet not showing when open on Dash (low oil add 1L)
  160. 2011 A4 B8 - Need timing chains and have questions
  161. Powered Mirror Wiring - Mirror Tap Radar Detector Install
  162. Vibration
  163. Audi a4 b8 fuel rail/system pressure
  164. A4 B8.5 Intermittent starting Issues
  165. B8.5 Has 4 Fuel Related Error Codes
  166. '08 Audi A4 slams into 1st and reverse when stationary, stalls when stopping
  167. Rear left door sometimes not opening from outside
  168. Engine won't even turn by hand
  169. Issues with 2 dealers inspecting same car
  170. Audi A4 door lock issues
  171. 2011 A 4 Malfunction Indicator Lamp
  172. Audi AUX problem
  173. Audi AUX problem
  174. A4 B8 clutch reset
  175. MMi Sh!t the bed
  176. Re: 2012 A4 B8- Camshaft sensor connector wire colors
  177. Source for new AGM H8 battery?
  178. Multiple Misfires - help!
  179. VCDS Log
  180. What is the function of the Engine Crankcase Breather Hose?
  181. B8 facelift CNHA 2.0 140kw heating
  182. MMI 3G High HNAV K0133-3 usa software
  183. Audi A4 B8 AV audio set-top box HS-1100KR1V2
  184. Stiff gearbox
  185. ABS-TPMS Malfunction-Limp Mode-No Speedometer-EPC
  186. Radio and Display Screen not working!
  187. Proposed Class Action suit
  188. Rear Door Locks - both now not opening from outside
  189. Persisting Rough Idle and Vibrations After Engine Mount Replacement with Lemforder
  190. UK: MMI buttons, cd and steering wheel buttons not illuminating
  191. UK: A4 B8 MMI Screen Vertical Lines Even After Replacement
  192. Exhaust Sound and underboosting.
  193. Can Anyone Help?!?
  194. 2011 B8 Avant Cranks but will not start (sometimes) runs fine other times - Fuel ??
  195. B8.5 steering fault?
  196. 2011 Audi A4 quattro rear door lock
  197. 2011 A4 digital speedometer
  198. Ambient lighting install - door control modules 12v pinout A4 B8(B8.5)
  199. 2016 A4 Front End Replacement with 2012 S4 Parts
  200. 2016 Audi A4 S-Line engine swap
  201. Same noise after wheel bearing replacement
  202. Engine swap
  203. Engine replacement recommendations
  204. Top end power loss, o2, muffler delete? 5th gear for 130mph
  205. iD Forged 17"- 20" Japanese Inspired 1pc Forged Wheels
  206. UK: Flat Battery, shut bonnet
  207. HW on display question.
  208. Engine coding issues
  209. Intermittent Wiper Issue
  210. EPC MIL codes A4 B8
  211. start up rough
  212. Misfire Issues
  213. Ami/ headunit upgrades
  214. Help! Clicking from front wheel, when up on axle stands sound from middle
  215. 2013 A4 B8 no power issue
  216. EPC light with mystery problem.
  217. Misfire mystery.
  218. P0011, P0327, P0341 - 11 A4….related?
  219. Shaking and misfiring on first ignition
  220. P200200 bank 1 dpf below threshold
  221. LV: question
  222. 2010 A4 Owners Manuals - Free to a good home
  223. P246F Audi A4 B8 2.0 2012 TDI EGT SENSOR BANK 1 SENSOR 4 URGENT HELP
  224. Allroad Engine Failure at 65k miles
  225. 2012 Audi A4 Avant timing chain question, 79,500 miles
  226. Water system A4 B8
  227. Front and rear door speaker replacement along with back sub
  228. Stiff brake pedal
  229. Electrical Problem
  230. 2010 Audi A4 B8 - Steering Kunckle Taper Bushing
  231. Pads and rotor replacement - right parts & questions
  232. Transmission replacement?
  233. Audi B8 Grab Handle springs
  234. Audi A4 P0016 Code after Intsalling new chain and doing head
  235. Coming home without light sensor
  236. p0341, p2279, multiple engine misfire codes, low oil pressure warning and car cuts of
  237. A4 B8 steering rack replacement
  238. Indications of a recent Transmission Fluid Change?
  239. 2015 allroad started using oil at 76K miles
  240. Vibration when Cruise Control brakes downhill.
  241. Audi a4 weird noise
  242. Missfire under load cylinder 2
  243. Audi A4 8K0 awd or no?
  244. Bent AC line
  245. Green Screen menu, aftermarket navi
  246. No heat + exhaust gasses in coolant
  247. Broken power folding mirror motor?
  248. BCM issues?
  249. Oil Pressure sensor install?
  250. Suspension fault
