- Looking For Mechanic Richmond Va
- Avant (facelift) and Saloon (facelift) rear valance/diffuser fit
- American message board members.....
- What is this!
- no sound from my speakers
- Intermittent spongy brakes
- Electric trunk
- mmi 3g screen power cable
- Recode Climate unit
- Auid A4 B8 2.0TFSI intake manifold failure P2015
- Wheel Speed Sensor question about Clip
- Gauge Cluster Replacement
- Error 01330 - Central Control Module (J393)
- Inner tail light plastic came off. What now?
- Brake upgrade A4 B8 quatro 2.0T
- LV: A4 help?
- Cruise control has gone very weird
- Best A 4
- Air Con not working
- Vacuum leaks
- B8.5 A4 2.0 CVT to manual transmisison - what all fits?
- No spark
- burning/leaking oil?
- 2011 a4 Avant wagon 3 lights on&now in limp mode
- Question about programming a spare key
- adaptive headlights only going "up" when turning right + airbag question
- CH: Help: vibration issues
- Help: vibration issues
- Audi Multitronic 0AW
- 2009 Audi A4 B8 2.0T Quattro
- Help - resetting / rebooting MMI - Audi 2011 A4 Avant Quattro 2.0L
- RO: Audi A4 B8 Weird symptoms
- KR: Specification inquiry
- MMI-Media Player Position 1 location
- Issues detected at 95k
- Audi A4 side mirror plastic
- Right head light not working.
- Audi a4 Catalytic Converter Troubles
- Greetings from SuperSprint Italy
- Green screen defaults
- Smash and grab?
- Transmission fault!?
- Need Assistance with Rough Idle Issue in Audi A4 B8 (2010)
- 2009 B8 - no heated seats - retrofit
- UK: Could someone tell what this is? Trim fixing from Audi A4 b8
- 2009 Avant Quattro 2.0T auto - trailer hitch
- 3.0 TDI coolant temperature issue (CCWA)
- 2011 Audi a4 b8 is misfiring in cylinders 3 and 4 when accelerating
- UK: Audi A4 2014 - Reset MMI to factory?
- IE: 2012 audi a4 1.8 tfsi epc light?
- FR: Gearbox/clutch
- Audi A4 B8 Brake caliper rebuild/restore
- AU: Audi A4 B8 Panoramic Sunroof issues
- Replacement engine issue please help
- Audi MMI problem please help
- Audi A4 2014 Quattro EVAP check engine light
- FI: Aircondition ventilation
- 2013 A4 Transmission?
- Grinding Noise Coming from transmission area.
- Looking to soften the ride on our 2015 A4 S-Line
- CZ: Audi A4 2008 Sunshade issue
- A4 Quattro 2017 - multiple problems - Professional assistance is required
- Help with hub assembly/wheel bearing part #? 2012 A4 Quattro
- Face lift LED tail lights for 2010 Avant
- QA: Cyl. Miss fire please any help?
- UA: Hood audi a4
- Transmission error code P178F00
- 2013 a4 2.0tdi 177hp wrong fuel consumption
- 2014 A4 Premium No Crank No Start
- Audi A4/S4 2015 Engine Start/Stop Failure
- Steering wheels and airbags
- Really bad gas mileage city A4 2014 TFSI Quattro
- Audi Connect
- UA: hood audi a4?
- Audi A4 B8.5 Making humming and creaking noise
- Headlights
- Adding Apple CarPlay to 2016
- Steering rack replacement
- Push the key once does not start th
- Reverse Parking sensor always beeps in reverse
- Problem with power steering (sound up)
- Dashboard Display stopped working
- Intake Manifold Error Codes
- UK: 2009 B8 A4 2.0tfsi - Timing chain/pump replacement
- Need new wing mirror
- Steering wheel controls not working
- Radiator Line/Hose Won’t Connect
- AE: Audi A4 2015 Damaged Pipe Identification
- 2009 B8 catalytic converter
- audi a4 b8 P0016 code after new timing chain install
- Low Coolant Indicator, even after new reservoir installed?
- Snapping sound from behind steering wheel
- AC Help
- Stage 1 Tune
- dead battery and screwed lock cylinder
- A4 2009 parking buzzer front side location plz
- clicking noise from rear driver wheel when jacking up
- Best Stage 1 Tune?
- Audi A4 Radio replacement
- Interior trim cracking
- B8 A4 Sound System Upgrade
- 2010 A4 starter
- MMI 2G High Stuck in Boot Loader,
- DIY tool for upper control arm
- High resistance on rear center seat belt
- Ignition could clip wired backward, car won’t start.
- Converting B8.5 4 spoke steering wheel to 3 spoke flat bottom
- High resistance on center seat belt...
- Half my speakers not working
- MMI not loading
- Interesting Issue with Doors
- 2014 Audi A4 interior trim help
- A4 Avant B8 Parking Sensor Front Buzzer Location.
- 09 A4 P2279 (Air Intake System Leak), P2188 System too rich at idle speed (Bank 4)
- B8 no dash and key stuck.
- Audi A4 B8 start button issues.
- Halogen to Xenon headlight conversion
- When i changed my left side front speaker, the right side speaker stoped working
- leather seach cracked
- 2013 allroad and coolant flush mixed answers
- IE: 2009 A4 B8 Engine failure
- Battery Advice
- SEEKING ADVICE: Should I Buy this 2011 Audi A4 2.0T Premium quattro?
- Door not always opening, able to replicate, looking for cause.
- Possible to change default drive select?
- B8 A4 piston ring replacement cost?
- Aircon not as cold
- steering column noise
- 2011 Audi A4 2.0 Tapping Sound
- Difference between CAGA and CAGC engines.
- NO: Audi a4 b8 2.0 diesel - flashing glow light and check engine light
- Parking Sensors installation Concert3
- AU: Tool to remove door panel from my Audi A4 2011?
- A4 b8 code help
- Repainting rear bumper
- Audi A4 B8 steering wheel noise
- 2013 - Alternator noise
- 2012 A4 in Limp Mode..... please help
- '10 A4 Avant doesn't like to use its locks
- B8 A4 towing (USA) *PSA*
- UK: 2011 Audi A4 B4 Avant 2.7
- Audi A4 2013 MMI turns off immediately after turning on
- 2011 Audi A4 2.0 radio no sound media player sound
- What causes the electric power steering to whine on lock?
- MMI fried from jumpstart?
- LT: What is that ball?
- MMI Update Fail Help ASA0
- LT: 2010 B8 Can someone explain EU suspension types? 1BA, 1Be..?
- High Oil consumption B8.5
- I measured 0-100km/h of my car (B8.5 2.0 TDI Quattro 177hp)
- What would I need to make 450WHP
- Can I Upgrade my wiper control???
- Esp ABS Parking brake fault with intermittent lack of engine power
- Correct Eibach/Bilstein pro kit
- Load grinding noise and crazy smell!
- High pressure pump question.
- A4 B8 2.0 TDI (NOISE WHEN ACCELARATING)
- Could N428 valve cause low idle oil pressure?
- eBay oil pump?
- Power wire for ecu board sparked off car frame now won’t start
- Want openpilot on your B8? Looking for testers!
- My 2012 Audi A4 Broke Down: Should I Spend Thousands on Repairs?
- Front Grill logo
- LT: Leak in the boot
- Can't access green menu
- A4 B8 Avant/Allroad - What’s in the trunk passengers side compartment?
- How can I wire amp with ien radio unit.
- Looking at an Audi A4 Avant Wagon
- Rough acceleration
- SK: Headlight with AFS
- UK: Phone connection
- CAHA swap
- DIS (colour LCD instrument display) connector pinout
- Is this sound normal?
- Driver Information Display
- IE: 2015 audi a4 engine noises and shaking when turning off?
- AW: Coolant Leak
- Engine rebuild
- VCDS ECU login code
- Key fob unlock driver door only?
- A4 B8 LED strip disassemble
- 2.0t b8?
- Passenger Mirror Heating Dead
- AMI USB adapter with Android
- Audi A4 b8 green menu System tone?
- Cannot see AMI as a media option
- Battery tests good, but no start
- 2011 Audi A4 B8 info LCD blank
- Looking for a CAEB Block and Misc
- 2014 A4 S Line rear shocks
- LV: EPB?
- UK: Audi A4 headlights?
- 2014 Audi A4 - very upset & need guidance, oil consumption
- UK: Auto wont select a gear, did after AA 'calibrated' but told thousands to fix.
- B8 Rear camber adjustment?
- SI: 245/45/R18 tires too big?
- Audi a4 b8.5 p0299 turbo extended warranty
- 2012 A4 Seat Adjust
- P045500 EVAP Emission Contr.Sys
- Engine swap
- RO: Retrofitted CAN with MOST on a car without MOST?
- UK: Tailgate Motors - Open Circuit
- KN: Transmission issues
- Considering 2016 A4 2.0T quattro premium plus as my next car
- Might buy an a4
- Engine swap
- MMI Screen Compatibility
- Fuel temperature sensor fix
- Torsen Differential, How it works? no worm gear!, helical gear is right!
- Steering Rack
- IE: Very loud SNAPPING noise from the engine area A4 2.0 TFSI
- Low Voltage Issue
- Troy’s 2010 A4 Avant
- Coolant issues
- Audi A4B8 Electrical Fault
- Infomation display stopped working
- Where to get a oil filter housing replacement part
- Amp Wiring Issue
- Door panel rattle after installing subwoofer
- Scratched my car in parking garage
- Clicking noise when i hit brake pedal
- Uneven Power Steering and Temp problems
- SI: What can i expect from Audi A4 diesel with 304,000 kms?
- Retrofitting Electric Tailgate - B8 A4 S4 RS4 DIY Guide
- I have a code for p0716 on my 2011 audi a4
- Quality performance, aftermarket, suspension parts
- Timing Chain service?
- 2014 A4 Car Running, Key Fob Outside, Doors Locked - Locked Out
- UK: Audi A4 B8 Alternator fault sometimes
- 2009 Audi A4 cabriolet headliner question
- 2013 Audi A4 Unknown Sound
- KR: Practicing drifting on snow with my B8.5 A4 2.0 TDI
- Rough idle no CEL
- RO: Audi A4 2010-2011 that I buy in the future or later?
- Bass in front doors problem
- What cars do these Autostop brakes fit?
- 2010 A4 wagon - failed turbo and can't pass Illinois emissions test
- MMI3G+ myAudi Import Contacts/Destinations with 3G Data ?
- Belt tensioner
- 2012 A4
- Seafoam?
- IE: Second key starts car but doesn't lock or unlock
- Parking sensors not working, parking aid greyed out
- VCDS diagnostic results
- Alternator problem
- Phase position bank 1
- K04 search?
- What could this problem be?
- UK: Lucas heavy duty stabiliser?
- Brake issue!!
