- 2015 BMW 328 switch to A4 B8?
- Replaced Dynamic Steering rack with Non Dynamic
- CEL light not coming on but ODB reads an error
- Which 19" OEM wheels fits the B8 comfortably?
- Just a really quick piston/con rod question
- New Member - Premium Plus worth $1000?
- Help with Engine Code P11A100..
- 2013 A4 (b8.5) oil consumption...
- UK: Poor fuel economy - B8.5 TDIe 2.0
- Need help with error code P0420
- A4 Quattro Avant control arms need replacing/bushings!!
- We Build Faster. Shorter lead times on AWE Exhausts.
- Retrofit system with Apple Carplay/Android Auto
- 1000 dollar performance
- Noisy fuel pump
- UK: Noise (whine/whorl) front left - Audi A4 B8 2.0tdi technik
- Does anyone have the same bad behaviour with his car ?
- New ECS Audi B8/B8.5 A4 2.0T Exhaust System Upgrades!
- Audi A4 B8 battery & air-con question
- UK: Help! Help!
- A4 Avant wheel tire question
- Electric issue, low temperature
- A4 b8 *dumbo* side mirrors to b8.5 retrofit possible ?
- Mmi/ami location
- 2011 A4 quattro won’t crank, won’t start, everything else works normally
- Looking for repair shop or dealer in Austin
- Repair job, Does this make sense?
- Rear parking sensors
- APR b8 a4 tuned fuel injectors
- Car stopped, works now but is it safe to drive?
- Intake manifold
- aem,injen,k&n or else??
- It won't start
- Rear Sunshade issue
- Weird noise (link to audio attached)
- Need help Audi A4 2013 trunk closed shut
- radio dead replaced it with 2013 audi a4 radio
- 2011 Audi 3.0 v6. HELP
- Audi A4 2010 serpentine belt diagram
- Clutch Save Cylinder Piston Extends Out Even When Clutch pedal is not pressed
- All lights within tailgate are not working - ‘08 B8 S Line
- 2015 audi a4 quattro 2.0T air intake
- Drastically Reduced MPG | 09 A4 3.2L
- Audi a4 avant b8 2009 few little problems
- 2015 A4 tow hook cover keeps popping out
- Sale TIME! Performance upgrades up to 15% off!
- A4 b8 no start just clicking from key reader.. please help
- I’m having issues after a transmission flush
- 2009 A4: Program TPMS?
- Need help AGAIN with sunroof
- CVT transmission Issues
- Changing climate control on remote starter
- A4 B8 to S4 B8.5 rear bumper conversion
- Moderate Exhaust.
- 2014 A4 rear seat removal
- 2.0t oil consumption issue
- A4 2009 3.2 trouble codes?
- Just got a 15 B8.5 Quattro s-line
- Music thru Bluetooth
- Oil smell
- water pump problems
- 09 A4 Quattro wagon 2.0t - rear plate screws? New owner 😅
- Part leftover. Where does this part go?
- Replace Dinner Door Seal on 2012 A4
- Looking for 2012 a4 b8 mods. Any suggestions?
- I pushed this in, maybe I could grab it with tongs or just order a new one?
- Looking for advise to prevent rust from spreading
- Valve Cover Gasket Question
- Looking into buying a 2016 Audi A4 need advice
- B8 A4 Avant Rear Bumper - Missing Piece
- Audi A4 B8.5 Interior Lights
- Xenon light issue
- Car died in highway, starter can barely turn the engine?
- B8.5 2016 A4 rear fog bulb replacement
- Need to know what hose/part name this is!
- 3.2L: Looking for new throttle body!
- Central Locking Issue
- 2013 b8.5 non B&O amplifier pinout
- Blinking CEL/Shaking/Now cranks but doesn't start
- 2013 Audi A4 Loose steering
- Audi Electrical Issues
- Rotational clicking noise F/L wheel
- Retrofitting Alpine X702D-A4
- Dealer experience CVT Fluid change
- Light Malfunction
- EURO taillamps coding
- Carbon Fiber Grille Accents!
- Voice Recognition - French to English
- SET Button Functionality
- Expensive A/C Leak, looking for options
- Fuel pressure test location
- AWE's Annual Holiday Special Pricing Event Starts Now.
- B8/B8.5 A4 ECS Carbon Fiber Rear Window Spoiler
- Coil Springs
- Seat Adjustment is not working
- 3.2 running rough?
- A4 S Line Suspension build code
- A4 B8 Won't start: "Ignition contact on" code
- Is it possible to turn off DRL with vcds when night?
- Key Fob Not Working
- A4 B8 clutch issue
- Epc problem?
- Backup camera not working. Pic
- SALE ALERT|Genuine Volkswagen Audi and European Parts are ON SALE
- Cylinder head removal - with turbo attached or not?
- Question about Chip Tunning
- Help with sunroof leak
- Left reverse light bulb went out
- Please help me take out this spark plug!!!!
- HPFP hard line won’t seal? Help
- UK: RH Drive, leak in passenger footwell.
- Decreased radio/media volume
- How to install sub and amp on non B&O system??
- Looking for turbo upgrade, 2010 A4 S Line
- A4 stalls/loses power in snow
- quattro A4 loses power & stalls in snow
- Main water pump failure 2.0L 2012-2014 class action settlement, extended warranty
- Need Help: Looking for bumper and grill (seperate or together)
- 2008 audi a4 estate
- 2012 Audi A4 Q S Line
- Cyber Monday SALES EXTENDED!!!!!
- 2009 Audi A4 2.0T B8 - Breather Hose for Oil Consumption Stage 1 Fix
- NO: How do I turn off ESP?
- 2012 A4: I NEED HELP WITH BLUETOOTH
- Totally Lost
- Type of transmission on a 2013 A4 B8
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- Over 90 Brand up to 50% off| ECS BLACK FRIDAY
- Audi A4 1.8TFSI 160hk MLT
- Intermittent wipers not working
- MMI 3G
- Audi A4 b8 won’t start
- New Audi A4 2012 Owner!
- ISO 2015 S-Line mudflaps/wheel well extension
- Is this Engine oil or some other leakage?
- New member
- 2011 A4 - Ran Through Carwash now no fan in cabin
- Parts Recommendations
- 2011 A4 Reliability
- Seat buckle malfunction.. Food stuck?
- Air sound when accelerate
- B8 A small shaking on reverse.
- No bass and midrange sound!
- Injector upgrade preferences? brand/flow
- GB: Audi A4 2010 diesel - Possible head gasket issue?
- MMI
- NEW ECS Adjustable B8 A4 Chassis Performance Coilovers
- AWE BLACK FRIDAY 2019 STARTS NOW.
- Switched outlets
- Heated mirrors not working?
- Oil Pressure Low - Turn Off Engine Now
- High Flow Catted 3.0" Downpipe! | Free Shipping
- Head gasket and valve replacement - help
- 2015 A4 S-Line Paint Protection-What part of body needs it?
- Can't ger my a4 b8 2010 display fuel consumption
- 2015 A4 - sudden oil consumption issues
- A4/B8 fuel and doorlock questions
- 2009 Audi A4 quattro 2.0t need repair manual for torque measurements
- ordering and programming a new key
- '11 A4 Quattro (B8) Parking Brake won't deactivate
- parking brake
- 2015 A4 2.0T Premium
- Bluetooth mic stuck on mute
- windshield washer not working
- 2012 A4 Quattro Premium Reliability
- B8.5 B9 same front lip fitment?
- Why the low armrest
- Life out of warranty. What is it like?
- Apple Carplay
- For an Audi A4 Avant 2009: I can't get my telephone to work anymore.
- Tips/ideas for selling 2011 A4
- UK: Audi A4 B8 Avant diesel 2009 Error code P0090 HELP.
- Common "Cranks but wont start" problem
- 2009 A4 Timing Belt replacement - how much work is necessary?
- Heater Core Failure?
- 2010 Audi A4 (B8) - Fuel tank pump leaking
- Update MMI
- 2013 Audi A4 filled oil too much
- P0303 and P0299 Code
- steering wheel without controls
- Part number for a b8 2015 europe spec
- B8 a4 manual top speed
- Wipers Defective Warning, Serviced Wrong, Noob Mistake
- 2011 A4 oil consumption issue
- my A4 bucking
- Used airbag controller
- Auto Leveling Issues
- 2013 A4 Cam Cover Oil leak
- 2013 or 2014 A4 Quattro, MT?
- ZA: Knocking sound from the engine, what could the problem. It sounds klap, klap,kl
- A4 2015 B8 Low Engine Oil Warining
- Engine Clicking noise for the first 30seconds
- Oil filter with swapable filter cartridge
- Reliability for a 2015 A4 any common issues or things to look out for
- Voice control not working
- P0016 Code After Timing Job
- b8.5 alarm horn active.... help me pls!!!!!
- Do I own a POS or a diamond?
- Trunk opens too powerfully - bad spring or strut?
- U111300
- New to the Forum...
- Amplifier issue
- Audi A4 Service maintenance?
- 2010 Audi A4 Quattro 2.0t: Engine Codes, P0300 etc.
- Lumbar support problem after seat swap
- Audi a4/s4 headlight issue
- Manual A4 Clutch and Drivetrain Capabilities
- i need a help. my a4 j393 and h12 diagram
- h12 alarm hion install
- New Owner 2009 A4
- b8.5 ccm error...
- how active alarm horn???
- 2009 Audi A4 Pre-purchase Checklist
- A4 2010 2.0t oil consumption
- B8.5 2.0 QUATTRO weird braking issue
- Anyone know what this part is?
- ‘10 A4 2.0T Avant ?
- Converting from halogen to hid xenon headlights
- 2.0 tfsi quattro Rough on idle and on revs.
- Rumbling sound
- Audi a4 B8: Rearview mirror with highbeam assist, compass and self dimming
- WTBForge Motorsport 2.0TFSI BOV
- Need help with CEL
- AUDI A4 QUATTRO 2.0 2009 LOW OIL LEVEL
- a4 b8.5 vcds ( remote control with "terminal 15 on" inactive
- 2008 board computer information
- 2011 Audi A4 Turning on Process.
- SZ: 2009 B8 engine light
- Serious Coolant Leak - Under inlet manifold
- ECS Atmospheric Diverter Valve Spacers!
- HELP: A4 B8 Symphony Head Unit Replacement
- Audi A4 b8.5 (2013) excessive oil consumption
- Rain/Light sensor retrofit \w Auto Headlights
- CAEB engine swap to 2012 and up
- 2014 A4 (B8) Quattro: HPFP?
- 2015 A4 B8.5 Backup Camera
- Transmission Conversion
- Strange Diagnosis by the Mechanic
- B8 a4 cvt trans (front wheel) p178f00 fix?
- New BFI B8 Engine and Drivetrain Mounts!! | ECS Exclusive
- 2011 A4 Won't Start for Hours After Turning Off
- Wheels & offsets
- Build code sticker location?
- O2 Sensor Heater Circuit Bank 1 Sensor 1 Location
- 2015 2.0 TFSI (155kw) engine huge fuel consumption after engine swap
- DPF pressure sensor replacement.
- MMI display vs. GPS navigation system
