PDA
View Full Version : A4 (B8 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. Window tint LTV?
  2. Will a 265/35 R19 fit a 19x10 +30 mm wheel on a 2013 Audi A4 Quattro?
  3. Turbo coolant return line replacement
  4. AL: A4 B8 2.0 tdi P0087
  5. P2681 Error code on Audi A4
  6. Very high pitch whine
  7. What part is this?
  8. Audi A4 2012 1.8t tfsi oil consumption
  9. New to B8in
  10. UK: Using a wing (fender) from a4 b8 estate (wagon) on a saloon (sedan)?
  11. Vcds and parking brake
  12. Low Turbo Boost Pressure check engine light after trip to the shop... story inside
  13. 2014-2016 Audi Avant
  14. Alternator Fault - Battery not being charged.
  15. No seat control module in my A4? donor seat has one
  16. Paint code
  17. Air Conditioner Fan Not Working, but a/c button something starts
  18. EGR oil leak
  19. EGR oil leak
  20. CEL, EPC (yellow), Rough Idle, White Smoke, Gas Smell
  21. Alternator Fault Battery Not Charging Woes
  22. Turbo exhaust nuts
  23. P0016 Related to Engine Mount Replacement?
  24. Wheel bearing bolts coming loose
  25. A4 Honeycomb grill - anyone with experience?
  26. Magnetic Clutch Relay position
  27. Will this spoiler fit my 2012 A4?
  28. Audi readiness drive cycle?
  29. MMi upgrade
  30. Best spoiler/grill option for for White 2012 2.0t A4 quattro b8?
  31. SPOILER and DIFFUSER
  32. DRL Set Up in VCDS
  33. Are these the correct spark plugs for my car?
  34. A4 B8.5 2.0L TDI - Engine Judder
  35. Surging under Full acceleration in boost
  36. Oil Consumption & Timing chain issue - what to do next?
  37. Installing grab handles?
  38. Constant misfire in cylinder 3
  39. Running on a flat tyre
  40. Odd vibration when coming to a stop or when shifting out of gear
  41. Potentially buying a 2012 A4 Quattro - what to look for? Engine seems a bit loud?
  42. Headliner fell down?
  43. IE Stage 1 Tune
  44. 2009 A4 Front Flex Pipe
  45. Serious head scratcher - 2011 Audi A4
  46. Audi A4 b8 8k 2008 1.8 l tfsi
  47. Sirius linking
  48. Lots of engine codes, blown fuse?
  49. 2.0tfsi quattro less than 400km per full tank of gasoline
  50. Any Dragy Times For Any B8.5’s With 2.0’s
  51. Manifold and Turbo Options
  52. B8.5 stops
  53. AMI to Bluetooth adapter stopped working
  54. a4 project
  55. Audi A4 B8 8k diffuser upgrade
  56. A4 (B8) Auxiliary Water Pump Wiring
  57. Purchased 2013 A4 w/70K Miles Warranty Question
  58. A?C not blowing cold
  59. Wrecked car ecu and motor swap into donor body???
  60. Heating problems
  61. Installation of MMI 3G Plus Navi Set Main Unit
  62. Balance shaft bearings?
  63. MMI won’t turn on - Audi 2010 A4 Premium plus NAV
  64. throttle body or manifoild???
  65. Lots and lots of white smoke!
  66. Audi A4 (B8) 2014 EPC Light and P0300 / P0506 Error Codes
  67. Timing Chain & Brake Pads and Rotors
  68. Alternator voltage
  69. Light Grinding/Rattling Noise Under RPM Decel
  70. tried to install Homelink, now have problems, please help
  71. EG: Black smoke coming out from the exhaust audi a4
  72. Aftermarket front coil spring too big
  73. 2015 B8.5 A4 Sound Gone Need Help
  74. Class Action Lawsuit For 2.0T from 2010 to 2017.
  75. 2014 A4 75k maintenance cost estimate
  76. p201500 im confused
  77. B8 2.0T Catch Can setup
  78. Audi A4 B8 Symphony Radio Grren Screen
  79. Charisma switch module
  80. EG: Rear Lid control module
  81. A4: Yes, I'm stupid
  82. EG: Head light rang control defective fault
  83. CZ: A4 B8 brake problem
  84. 2014 Audi A4 with engine issues
  85. EG: Audi a4 b8 2012 automatic transmission oil
  86. Turn Signal Error
  87. A4 B8 2008 Engine Swap EA888 gen 1 to Gen 3
  88. Help, car shuts off while coming to a stop
  89. A4 sunroof part 32
  90. Alientech KESS
  91. Audi avant S line 2009 rear bumper swap
  92. Top Tether
  93. Camshaft adjuster magnet screws stripped.
  94. HR: Please help me choose tires for my B8
  95. Audi A4 B8 Coding
  96. Upper Timing Chain cover bolts
  97. Audi A4 Avant B8 2.0 TDI VCDS Fault help
  98. SK: A4 2.0TDI 130kw vs A4 1.8TFSI
  99. A4 B8 2.0TFSI swap with S4 B8 3.0 TFSI !
  100. HR: Audi A4 B8 diesel Fuel Economy?
  101. UK: Audi A4 B8 2008
  102. Blow-off Valve 2.0 TFSI
  103. A4 B8 Dash Speaker Upgrade
  104. Upper Timing Chain cover
  105. How Much Will it Cost to Fix These Scratches?
  106. Is this oil pressure good?
  107. P2015 code still showing after replacing intake manifold a4 b8 2.0 tfsi
  108. Egr fault?
  109. 2015 Audi A4 Premium Plus
  110. Audi B8 2.0T Stock PCV or PCV Delete for Oil Catch Can?
  111. UK: Coolant keeps getting low 2010 A4 1.8T CVT
  112. Your tips on EGR Removal - Cant reach bolt - P0403
  113. Time to retire the 2010 A4?
  114. Su
  115. Cleaning the inside of the headlight lens
  116. A4 b8.5 xvt Vibration when letting of gas pedal
  117. UK: Audi A4 oil and fuel?
  118. Misfire on idle
  119. Front headlight LED array yellowish
  120. 2.0Tfsi CAEB Multiple weird misfires
  121. 2011 Audi A4 B8 2.0T AWD - check engine light
  122. Sudden loss of power steering few weeks after brake repair
  123. Let's have fun with mods for a newbie (crosspost from az)
  124. Hello please help me!!!restore the factory green menu?
  125. Simple engine swap
  126. Subwoofer/amplifier install
  127. UK: Good air intake for audi b8. 5 2.0L diesel a4?
  128. 2009 Audi A4 TSFI Cooling Fan problem
  129. 2013 A4 noise at 2-3k RPM passenger side
  130. 2010 Audi A4 2.0L (TFSI) CAEB - Oil Pump question
  131. Should I use Loctite for brake caliper bolts?
  132. DAB Radio Stopped working
  133. 2009 a4 fwd. No communication with ecu,obd,dash clusters or modules
  134. Change battery location (not battery replacement) - 2014 A4 B8.5 Allroad 2.0 TFSI 225
  135. 2010 avant a4 injectors keep blowing after 50 miles
  136. Radio Concern
  137. Turbo upgrade
  138. Want it to sound better, and best remap place to go?
  139. Electrical Demons
  140. 2009 vs 2012
  141. Aftermarket android screen problems Audi A4 2010
  142. NO: Audi A4 2010
  143. 2010 audi a4 timing chain
  144. A4 interior
  145. UK: A4 Coolant leak
  146. 2011 Audi A4 B8 2.0l AWD - P0506
  147. 2011 Audi A4 2.0t question
  148. 19" wheels with 245/40 tires work?
  149. What seals and gaskets do I need for timing chain job???
  150. 2012 A4 B8.5 Squeeking sound only when accelerating
  151. RS Style Honeycomb Grille
  152. “Lubeck” timing chain kit
  153. ES: Changing headlight bulbs to Led?
  154. A4 - Replaced Electronic Steering rack - How to clear fault VCDS?
  155. excessive oil consumption, timing chain, loud engine noises with acceleration
  156. Loud droning niose airplane engine type front passanger side?
  157. Android 10,25 Audi A4 b8 facelift 2014 mmi3
  158. Audi A4 b8 (facelift model 2014) mmi3
  159. 2010 Audi A4 quattro Wheel Questions from Newbie
  160. A4 2011: Hole in my oil pan? Or what part is it
  161. to fit or not to fit Rear Shocks
  162. CEL flashing, P0303 and a P2293 combo, oh boy!
  163. excessive oil consumption, timing chain, loud engine noises with acceleration
  164. a4 b8 sunroof prrrroblems
  165. Audi A4 B8.5 (2013) Oil Leak from Passenger Side Front Rear Control Arm?
  166. Oil pressure low when car warmed up
  167. NO RCA Detection
  168. Loud turbo whistle also breaks up
  169. I’ve been having oil pressure problems...
  170. 2010 Audi A4 Car Will Not Start
  171. Weird Electrical Problems Coming Out One after One
  172. American Audi A4 Premium 2015 Tail Light Conversion to UK Specifications newbie
  173. 0AW CVT Issues (P1743) ((My first Audi))
  174. 2009 A4 Quattro 2.0 violent idle
  175. Long crank to start + multiple error codes
  176. new Intake Manifold Adjuster VDO problem
  177. GROUP BUY | Schwaben Professional Scan Tool 25% to 40% off | Closes April 1st, 2021
  178. No Start, No Communition, No Crank, No dash
  179. Connecting rod plastic gauge clearances
  180. Leak Down Test - Question
  181. replace locking switch audi A4 2014
  182. 2013 A4 Avant B8 front brakes issue
  183. Telephone 77 adapting Optical Performance not working
  184. Security key to get into basic settings
  185. Low Oil Level Warning Light
  186. Is my turbo bad?
  187. 2008 V 2009 B8
  188. Disconnecting Battery
  189. A4 2011 sensor problem
  190. Audi A4 1.8TFSI light problem
  191. 2012 2.0TFSI, Oil consumption and oil cap vacuum.
  192. LV: B8 Suspension fault?
  193. Good quality reverse camera?
  194. double blowout tire size question
  195. Difficult to start when warm!
  196. Misfiring after changing coils and plugs
  197. Help Identifying a Cap Under Rear Seat - Fuel Leak Under Rear Seats (2009 B8 A4)
  198. Water pump failure-extended warranty help
  199. Coolant leak from rear of water pump
  200. Audi A4 B8: Transmission Jerk
  201. Microphone issue
  202. Steering rack 2013 Audi A4 b/8
  203. 14 A4 airbag module coding
  204. Undiagnosable rattle on a 2009 A4 B8
  205. A4 B8 can you open door manually from actuator?
  206. Airbag Control Module.. No signal..HELP!
  207. Unusually bad urban MPG compared to extra-urban
  208. Please check the pics and let me know.
  209. A4 Tailgate Button Failure
  210. 2010 Audi A4 Avant, 93k, yay or nay?
  211. A4 2010 a4b8 ecu replacement
  212. 2009 A4 Avant (wagon) - Left Reverse light - 01518 Reverse light malfunction.
  213. 25% off your Favorite brands during PERFORMANCE WEEK!
  214. A4b8 no start P0122 P0222 P2122 P2127
  215. Can somebody please tell me what these are?
  216. Time to move up
  217. GPS antenna shark fin removal
  218. MMI display issue
  219. Aux/Bluetooth
  220. 2013 B8.5 Asking for 1 quart just 270 miles after oil change
  221. No thread left on the screwhole near headlight (Front bumper replacement)
  222. B8 A4 TFT display went blank
  223. Motor Oil
  224. Awful Sound from Stock Radio
  225. A4 B8 Problem with air conditioning MMI 3G+ Please help
  226. MK: Audi a4 b8 2.0 diesel limp mode
  227. New purchase with a couple of noises
  228. 2102 Audi A4 Quattro Help with Error codes P2279 P 2180
  229. Can 17" 2017 wheels fit 2014 Audi A4 S Line?
  230. Parking sensors fail
  231. Rocker Guards
  232. Dealer break job recommendation
  233. B8 1.8 TFSI 2012 - Do not exceed 4000rpm warning
  234. 2012 A4 2.0T B8
  235. Engine mounts for Manual car
  236. Auto Start Stop malfunction Help
  237. mirror folds out over 90 degreees
  238. Dps software
  239. Audi A4 B8 2008 HeadLights problem
  240. A4 B8.5 Engine won’t Rev above 2500 rpm when stationary
  241. Oil light coming on and a P164D00 code
  242. How do I test my oil pressure?
  243. MMI 2g High Apple Carplay install
  244. Jumped Timing - 2010 Audi A4 2.0T (TFSI) - Quattro
  245. Disabling Voice Command
  246. p0304 1.8t cylinder misfire
  247. exterior lighting problem
  248. A4 avant 2.0 d B8 2015 timing belt tools
  249. Audi A4 B8 hard starting
  250. tuning my b8
