PDA
View Full Version : A4 (B8 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. 2010 A4 2.0T Quattro Multiple error codes, not starting
  2. What part is this?
  3. Corroded Exhaust...
  4. Starting with dash cam and GPS plugged in
  5. 10.25” android screen
  6. B8.5 3 Zone HVAC VCDS Label File Anyone?
  7. Vehicle light malfunction indicator came on
  8. Audi MMI issue
  9. 2014 A4 Avant S-Line Shut Down
  10. Newbie quest: what is the ami cable that would work on a a4 2009
  11. Coolant pump, longer cranking, start stop fault
  12. cylinder 2 misfire
  13. DRL full brightness on low beam
  14. Newbie Question: A4 B8 engine shakes/stutters
  15. Car paint mistake
  16. Rumbling sound
  17. subframe realignment
  18. Help needed with BCM electrical controller on 2010 A4 B8
  19. Drivers door stays locked when unlocking with infrared key
  20. IE: Radio Volume A4?
  21. Electromagnetic parking brake malfunction
  22. Is my Piston is Bad or Repair and re use?
  23. Rough Idle !!!
  24. Rear Seatbelts - cannot use
  25. Front passenger side brake sticking
  26. Weird sound on start up mostly on cold start
  27. Apple carplay retrofit
  28. 2015 avant Fuse location
  29. Audi A4 B8 Wheels Upgrade. Install 12mm+15mm Wheel Spacers
  30. Urgent help. Can't start the engine with mechanical key, alarm goes off all the time?
  31. Eliminate bulb warning error on rear
  32. intermittent air conditioner
  33. New to Audi Fam and Boards
  34. 2013 A4 oil
  35. Looking at APR tunes
  36. Audi side assist not working
  37. Power outlets not working?
  38. Best coilover?
  39. Rear view mirror not dimming
  40. Trunk width
  41. Crankshaft position sensor warning
  42. 2012 B8 A4 Exhaust suggestions?
  43. Consistent clunk and beep when car is off
  44. Rain sensor problem
  45. Audi A4 B8 Headunit Upgrade
  46. Wheel spacers installation steps
  47. Retrofit clarification
  48. 2013 Audi a4 not starting after sitting
  49. Help Rough idle
  50. UK: Calliper paint?
  51. Evaporative emissions system leak detection pump (Open/Circuit)
  52. Loud, almost fan like noise coming from the passenger side
  53. 20x9 et35 with 255 265 or 275?
  54. Passenger side front suspension dropped
  55. Start?
  56. whine/howl/whirring -- changing out rear differential
  57. MODS
  58. Is the wheel spacer really safe?
  59. Roof rack base bars and kayak mount
  60. What colour code is this
  61. Rsnav
  62. Best option for music
  63. At 130k miles, in for service. What other services should I have done?
  64. Is it dangerous to add a wheel spacer to Audi A4?
  65. Wheel math help...
  66. 2014 A4 SE - Help, advice needed on roof repair.
  67. FI: Amp location?
  68. Help! Stuck cv joint!
  69. NO: Audi A4 diesel engine issues, pls help!!
  70. Driver Window Switch Issue
  71. Introducing Billet Aluminum Front Strut Tower/Chassis Brace
  72. MMI/Radio repair and replacement advice
  73. help with race chip install
  74. Doesn't look like new tires, right?
  75. Mysterious cyl 3 misfire
  76. Mysterious cyl 3 misfire
  77. 2013 A4 left turn single
  78. What is this and how to remove it????
  79. which package should I go for - for 65k
  80. Can't get rid of Oil Level warning and EPC/4k RPM limit!!
  81. 2011 A4, blown engine, fix and keep or sell as is?
  82. RU: TPMS and Hill Hold?
  83. IE: From Chorus radio to Concert radio?
  84. Roof Antenna is broken
  85. BG: A4 B8 P0727 multitronic code?
  86. Camshaft adaptation value and timing chain stretching
  87. MMI / AMI firmware / map updates
  88. A4 Electric parking brake calibration. Leyland
  89. Aluminum Mirror caps
  90. 2010 Audi A4 blue smokr
  91. 2012 Audi A4 Cooling Fans Issue/CEL Light On
  92. A4 (B8)Stuck in limp mode
  93. Excessive engine oil consumption on 2011 A4
  94. A4 B8 2010 1.8 bcm1
  95. This helped my A4 b8.5 run better
  96. Pdc parking module sensors
  97. New 2 The Audi World!
  98. RS: A4 B8 turns off on uphill
  99. Specs?
  100. UK: 2010 2.0 tfsi clutch recommendation?
  101. Steering wheel?
  102. MMI System Glitch - Audio Cutting and morning AM/FM
  103. FEATURES NOT WORKING AFTER DISCONNECTING BATTERY?
  104. Bent gearbox cover plate 2.0tfsi
  105. PCV valve
  106. Oil consumption - reason to avoid?
  107. B8 8 speed auto trans: torque limit?
  108. Soooooo this happened today🤦🏿‍♂️
  109. Both back rear windowses do not go all way down
  110. Head Lights/Dash lights
  111. Another how much thread
  112. 2011 Audi B8 Valve Cover install issues
  113. Ami cable
  114. Battery Issue?
  115. Silicone intake tract set yay or nay?
  116. Finally bluetooth music
  117. Will B9 seats fit B8?
  118. UK: 2013 A4 Avant diesel Fuel Filter Change?
  119. Transmission Oil Change?
  120. Audi A4 b8 mmi 3G rescan Dab radio ?
  121. Battery issue
  122. P0299 Code Again...
  123. Picture of Updated Piston Rings
  124. Battery/ECU issues?
  125. Driver mirror issue
  126. UK: New poster with price quote?
  127. MMI GPS problem
  128. Replace radiator fans
  129. Rear Bumper Cover part numbers?
  130. 2012 A4 2.0tdi Aux Belt Chatter
  131. Audi b8 which tune should I go with?
  132. Audi a4 tdi 120bhp remapped
  133. A4 b8 thermostat housing??
  134. Famous P0016 issue
  135. Audi A4 sensor
  136. Really desperate HELP!!!! A4 B8 won’t crank !
  137. NO: Oil level gone down / Audi A4 B8.5 (2013)
  138. Clunk when hitting gas/brakes
  139. GE: How can I recognize 6 spd DSG gearbox vs 8 speed automatic gearbox?
  140. Who’s selling a 2010 Audi A4 2.0T AWD engine?
  141. 2010 a4 2.0T engine rattle
  142. *sigh* Oil level sensor problem Audi A4 B8 2.0t
  143. oil consumption issue
  144. Auto-level headlight pointing up after downwards sweep on ignition, no error code.
  145. A4 B8 2.0L TFSI Quattro Dynamik RHD High flow downpipe or testpipe.
  146. Need help with vehicle headlight leveling issue please! 01537
  147. part number for this?
  148. Tranny pan bolt torque?
  149. S5/S4 seats
  150. Emergency key problems.
  151. Anyone with 8.5 et28 wheels?
  152. B9 2019 a4 seats to fit into a b8 2016 a4. Help !
  153. 3.0 tdi engine number location ?
  154. Need help. Just got CEL , TPMS MALFUNCTION, PARKING BRAKE MALFUNCTION Code P0070
  155. Is my car a B8?
  156. ABS/ESP fault + parking break malfunction + headlight range control defective
  157. 2.0 TFSI Oil pan drain thread
  158. Pinch bolt and wish bone control arms help!
  159. Steering wheel retro fit
  160. PO299 Turbo Underboost Code / RaceChip.. Coincidence?
  161. Part# needed for canister purge valve N80
  162. A/c magnetic clutch problem
  163. 2013 a4 tdi 2.0l oil pressure switch location help please
  164. IN: N205 valve
  165. p0016?
  166. Donate to Discount so you can Quarantine in Your Garage...
  167. Sound problems
  168. ECP Light but no check engine
  169. HELP NEEDED - Sunroof Electronic Problem - 2015 A4
  170. Grille Accents Carbon Fiber and Gloss Black!
  171. UK: TP recordings
  172. 2015 A4 2.0 TDI - STEERING PROBLEM
  173. AU: Washer Fluid
  174. Check engine late came on again (turbo?)
  175. Need help with a P2293 code
  176. Recent ticking under load
  177. 2015 A4 2.0 TDI - STEERING PROBLEM
  178. 2015 A4 2.0 TDI - STEERING PROBLEM
  179. 2010 Audi b8 halogen to xenon
  180. 2015 A4 B8.5 Amplifier replaced twice.. help...
  181. Where to get tuned Western Massachusetts
  182. emissions control warning light
  183. Rear subwoofer ?
  184. MMI update
  185. Need opinions on A4 oil burning issue and how to go about it with my warranty
  186. Rear mirror compass not working
  187. P0327 Knock sensor
  188. MMI firmware and map version 2019
  189. AU: A4 Engine Sign on and Engine Shaking
  190. nightmare panoramic
  191. Problem installing Turbo hose
  192. Oil Pressure (Error: P164B00) Audi a4B8 3.0TDI
  193. SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
  194. Audi a4 2009 crank but no start
  195. Exhaust mods
  196. NEED HELP SHIFT LOCK OVERRIDE
  197. Flash SALE Maxton Design Exterior upgrades
  198. Audi A4 2.0T Code P0300, P0301, P0302, P0303, P0304 Miss fire HELP
  199. Can I disable Key Fob opening of the Boot/Trunk?
  200. 2015 A4 power steering failure help
  201. Smoke from exhaust when I get on throttle.
  202. New battery after 6 years
  203. trans fill
  204. Stock exhaust piping size?
  205. B8 a4 misfire
  206. HELP TICKING
  207. Clarifications needed--tranny fluid change?
  208. A4 advant sat nav issue
  209. High pitch noise
  210. Vibration help
  211. Did I eff up my car?
  212. General aftermarket selections?
  213. Hood Latch cable broken
  214. 2014 A4 with 102,000 Miles. What should I be worried about?
  215. 2014 A4 - Oil consumption
  216. Dual exit question..
  217. Reliable Audi Mechanic in Bergen County NJ
  218. Aftermarket wheels help
  219. Engine detailing question
  220. LT: Greatly increased fuel consumption, no CEL
  221. Coil pack revision F or G?
  222. Is this normal?
  223. 2010 Audi A4 Quattro - Oil Consumption
  224. Resonator/ muffler delete confusion
  225. Audi a4 avant which alloys?
  226. 2009 Audi Symphony wont turn on nor will screen
  227. Folding mirrors
  228. 2010 A4 2.0t Cambridge Issue?
  229. tires and rims from a Audi Q3 for Audi A4?
  230. Can anyone walk me through charging my car from underneath through the alternator?
  231. A4 Quattro Sports Diff
  232. Screen washer tank capcity.
  233. Light Pass airbag of Problem after install Multimedia Android
  234. A4 won't crank engine, brake light switch?
  235. key fob stuck/ no display,radio, mmi/parking brake malfunction
  236. B8.5 bluetooth options.
  237. [SOLVED] ABS light has came on with code 00285
  238. EE: Water in the saloon, no idea where it comes from.
  239. 2009 A4 oil level wrong
  240. Headliner Fabric ADHESIVE
  241. What is the difference with engine mount item number?
  242. 2014 A4 Bass Upgrade
  243. 2013 A4 Projects
  244. I can’t get into my car
  245. VAG Code Help
  246. Looking for advice - 2016 A4 lease buyout?
  247. AUDI A4 SOFT CLOSE CAR DOORS
  248. Side assist
  249. B8.5 Tcm update and IE tune
  250. Introducing OEM A4, S4, Allroad Post-Facelift LED Taillight Packages...
