- Audi A4 B8 2008 starter differences and starting problems
- Intake camshaft part numbers
- MMI 3g+ retrofit
- DPF oil ash problem
- Timing chain updated revision dates?
- Parasitic draw
- Rear lighting issues... need help
- 2011 A4 Stalling ?!
- Rear camera retrofit
- Audi a4 b8.5 transmission problem
- Clutch and flywheel replacement 2.0tfsi CDNC
- PVC
- Doors not locking
- AU: Audi A4 B8 VCDS Help please
- Getting the glove box aux/interface cable routed outside of the glove box?
- AU: can i use these pistons still????
- Please tell me is this normal engine movement or bad mounts?
- 2010 Audi A4 B8 Avant Clutch Bleed valve location
- AU: 1 mm chip on camshaft lobe, can I sand it??
- No Start / some dash lights / VAG no communication
- Torn CV boot
- HELP! Door not opening from inside or outside!
- A4 2013 automatic car keeps stalling on uphill
- How to haul a B8 A4 Sedan - 2024 Nissan Frontier Pro4x
- Xenon conversion
- BR: Fix Break Light Audi A4 Avant B8
- Brake pads and disks measurements
- Random Wire not Plugged in
- Buying a 68k mile 2013 A4-what to look for?
- Aux for audi chorus 2008 audi a4
- Removed dashcam now EPS/ABS fault
- Need help itdentifying parts
- 2013 A4 - P7231 Cam Adjustment Actuator B; Cylinder 3
- I messed up. Need a new piston rod.
- What wires to make the seat move?
- Fuel Composition Sensor issue
- 14 A4 B8.5 MMI works no sound (unusual issue)
- Alternator regulator replacement
- Test
- Alternator Regulator replacement
- Proximity Key-any options besides the dealer?
- FWD - Slightly wider tires on one axle OK?
- Engine Teardown - Cylinder Walls OK?
- Looking at a 2010 today, under 70k
- Catless DP and O2 spacers
- Dashboard backlight
- Avant exhaust suggestions
- Limp mode, fuel pressure low
- Help B8 transmission swap 6spd to 8spd
- Every cylinder misfire out of the blue
- 6HP Transmission Service (Reset adaptations?)
- Engine Timing Chain Service?
- EPC LIGHT / LOSS OF POWER // 2013 A4 Quattro PPlus 2.0T Gas
- Ran Out Of Fuel Now Doesn't Start - Alaska
- Bolt fell off my a4, any idea what it is?
- IE: Bolt came off my 2009 Audi a4 when taking off
- Injector seal
- VIKA HIGH PRESSURE PUMP
- Heat on one side A4 B8
- Battery during MMI update - PRETTY URGENT
- HELP!
- Audi B8 cruise control doesn't always work
- Both key fobs stopped working?
- A4 B8 2.0 CAGA - Rebuild and no start - Help please
- High fuel consumption
- 2013 a4 2.0TDI exhaust temp sensor problem
- Sedan Seats in a Coupe and vice versa?
- SE: Does my car not have MMI? Bluetooth problems.
- 2014 Audi A4 - PCV Value Question
- 2.0T reliability?
- PLEASE HELP!!
- Coolant/Temp Gauge Issue | 2013 Audi A4 P+ B8.5
- Engine issues on audi A4 B8
- Engine won’t fully turn over with pins & pin issue
- UK: Black edition MMI not working
- How do I take the sunroof control panel off
- Help Me, Looking for a Simple Android Auto/Apple CarPlay Device Without Extra Apps
- Does 2013 passenger Headlight have a fuse or relay?
- Wheels for 2013 Audi A4 premium?
- B8.5 front brake squeal, new rotirs
- A4 Avant B8( kein Facelift) Rückleuchten auf LED umrüsten
- UK: Dual Mass Flywheel + Clutch - Brands and cost?
- I need electrical help (specifically with ground wires) mods can u
- A4 b8 CVT, sudden loss of power HELP !!!
- 2012 a4 2.0T, Large can of worms
- Can you retrofit B8 facelift (2013+) onto an older 2009 avant?
- Rear lights misaligned on A4 B8 avant, what am I missing?
- UK: A4 B8 2.0 tfsi CDNC White smoke/lumpy/no throttle response
- Part Identification on Steering Rack
- IT: Tyres?
- Engine Wiring Harness
- How to setup Audi Battery Charger (1065
- IE: Oil light comes on about an hour or so into a drive
- Airbag module
- Water Pump to Oil Cooler Union
- Misfires, flashing check engine and epc
- UK: 19 Codes since rebuilding A4 B8.5 Cncd Uk Car
- Keyless Entry Issues
- Whirring Noise Clutch Pedal - New Kit installed
- Car using oil after Turbo replacement
- Camshaft sprocket wobble
- Audi blind zone sensor
- 09 A4 P0302 questions
- Odd Turbo Whistle Sound
- Cylinder misfire from time to time
- Sunroof and power windows stopped working at the same time.
- Cordless lugnut wrench - if anyone uses?
- Camshaft related error codes
- UK: A4 2013 B8 Sat Nav
- P2188 too rich at idle -- how can a beginner deal with this?
- Back right speaker blown
- EE: Anybody has the pinout for an A4 cluster?
- SE: Issue with white smoke on Audi A4 B8.5 2.0 TDI
- Best Carplay / Android Auto aftermarket kit ?
- Hide mileage from dash ?
- 2014 A4 Passenger Side Mirror Replacement
- Body mod suggestions
- Remote start installing question
- G648 sensor 4 bank 1 connector location?
- Non essential electrics not working
- RS Nav Audio Out not working despite Aux enabled
- Can’t set timing right
- A4 B8.5 Wiring Diagram
- AHD 1080p rear camera wiring
- Just bought a 2009 audi a4 Quattro 3.2 v6 and it has some problems
- 2.0TFSI Unknown 2pin connection
- Can i change my stock diverter valve without a tune
- Keyfob won't operate central locking
- Oil pressure switch and camshaft position sensor codes
- A4 B8 MMI showing wrong Audi model
- Centre console 12v sockets
- Turbo Oil Lines Replacement
- Audi A4 B8 2.0 TDI (CAGB, 2008) - RPM Surge, Battery Charging, and Hard Start Problem
- Amplifier
- A4 B8 TDI - Randomly start doesn't work
- What is the best carbon cleaner additive to use?
- 2011 Audi A4?
- 2.0 TDI CAGA - Cylinder Head Gasket
- Engine Sounds like Deisel Truck.
- DK: Help car runing weird sometimes, 2009 diesel
- A4 Gear Oil?
- diagnosing front end noise
- MMI 3G map ?
- Oil Dipstick?
- RPM fluctuate up and down in idle + motor knock
- Etc P2279
- Is there any single exit diffuser for the B8.5 A4?
- Swap adaptive suspension with regular
- Help needed, bunch of error codes
- AU: A4 B8 CVT, Help needed
- Fuel: Low pressure code
- Engine Coolant leak - Advice needed
- P0016 after timing job, need help interpreting data
- Audi a4 2014 2.0 tdi CJCD 143 bhp
- Fuel Cap tether broke
- MY: TIBAO?
- Unmatched tune between engine and transmission
- P201500 Intake manifold flap position/air flow control sensor - implausible signa
- Audi A4 2010 - MMI 3G intermittent
- Coolant Pump B Circuit wiring diagram request
- Turbo starting to fail
- B8.5 A4 CVT - delay/lag
- 2012 2.0 turbo Octane level
- USA: I own a 2016 Audi A4 AND EVERYTHING IS IN GERMAN!!! 😭😅
- Audi A4 Fuse and Relays
- Tuned wagon won't start
- CVT and Idle
- AU: Audi A4 1.8 TFSI
- A/C Condenser Replacement - Oil Required?
- A rattle when engine under loada
- Upgrading Safety Features
- NZ: 'HELP NEEDED' 2009 AUDI A4 2.0TDI MULTI AVANT FWD TRANSMISSION OPTIONS???
- Install Android head unit for Audi A4
- P2015 Error Code with Rough idle
- AC pressure sensor G395
- EPC light came on randomly, lost acceleration power
- Misfire Cylinder 3
- RS: 2012 b8 2.0 TDI 136hp
- 2013 A4 2.0 -- Fans always running: P218100 - Cooling System Performance
- Moving the oil pressure sensor
- 2011 Audi A4 quattro test pipe engine code
- 2011 Audi A4 quattro radiator fan problem
- 2014 A4 Crunching/creaking noise when driving over bump or turning
- Clips for lower rear pillar trim
- p0299 underboost error
- MMI shuts off after startup
- A4 won’t start
- Missing part of ac condenser.
- 2014 8.5 Transmission Issues
- B8.5 DRLs Not Working
- 2009 amp replacement
- A4 B8 Stiff Suspension Issue?
- CarPlay retrofit for Audi A4
- Mmi and screen on dash not working after changing battery
- Transmission issues
- RSnav s4 problem a4 b8.5 Concert
- SI: Smoke and rough reverse
- Why I think I’m rebuilding the engine in the first place
- Do I need a headlight ballast? What's happening?
- Car problems (radio turning on after cars off)
- My first Audi?
- A4 B8.5 ignition not working, no lights on dash
- Fuel cap question
- Fuel pressure too low p0087
- ZA: White smoke coming out engine bay after starting.
- Shifter Squeaking
- ZA: 2014 Audi A4 2.0 b8- oil pressure switch 3 malfunction.
- Thermostat
- SK: When locked, can is constantly waking up and drayn battery
- Just picked up the JHM Turbo
- Rear Right Door - Armrest Removal on 2016 Audi A4
- Are manual transmission gear detection sensors the same in Audi cars??
- Audi A4 Manual Diesel - Cranking but not starting after gearbox swap
- Cv or drive axle
- Is Airbag compromised?
- Transmission Issues on 2014 Audi A4
- Volt drop MMI/Amplifier issue
- B8.5 CVT Transmission
- Recommended to replace blower motor
- 2013 Audi A4 Avant S-Line MMI 3G+ Stuck on Splash Screen
- Key and Authentication System
- Center Lock
- 2009 A4 MMI and other electrical issues.
- Audi a4 b8.5 2.0 ftsi black edition Quattro cncd e888 gen 3 removal
- Control Arm replacement
- Mystery headlight issue
- Trunk lid tail lights
- Urgent Need of Mechanic
- Urgent need of help.
- PCV Hose 2015 a4
- 2012 A4: Oil Pressure issues (CAEB)
- Clutch release bearing noise, that wasnt the clutch release bearing...
- E888 gen 3 balance shafts
- IE: Audi a4 sidelights
- J393 Fault help
- B8 steering wheel upgrade to B8.5 S5 flat bottom
- Which A4 Models to avoid?
- MY: Audi a4 aç compressor
- 2009 A4 Chirping in engine bay
- Mechatronic question?
- Need help 2011 Audi a4 2.0t 6 speed
- Blowby
- Honey comb grill upgrade
- Audi a4 premium hard time starting
- 2011 A4 2.0 p0016
- 2013 Audi A4 B8 Air Con Not Working
- TIME SETTINGS / MMI SYSTEMS
- WOBBLING Vibration Dampener/ Harmonic Balancer
- UK: Audi A4 1.8 Tfsi 2008 Mechatronic ECU
