- Strange noise at 1600rpm
- Audi a4 B8.5 Mod Help
- FI: Weird clutch judder issue while car is cold
- NZ: Parasitic Draw - Problem on the LIN cable line?
- KR: Understanding the torque distribution principle of the Audi Torsen Quattro
- Help please! At a loss and not sure how to proceed
- ZA: Audi A4 2008 1.8T cranks but won’t start
- E brake Malfunction light after replacing caliper (properly)? Cross posted
- 2015 Audi A4 B8 no start, no crank, no lights on dashboard
- Help! A4B8 6mt shifter wont spring back to center
- HELP purge valve part #
- How much coolant loss is normal in B8 A4
- Help! I have an oil leak that I’m not sure where it’s coming from
- EPC Light & Fuel Pump RPM Too Low
- MINIMUM OIL LIGHT ON
- SK: Audi A4 B8 2.0 diesel - won’t start, no crank ??
- Audi a4 b8 chorus mmi change to multimedia
- UK:Looking at Audi a4 B8 with battery issues, what tests can I do to check if it just
- 2.0t Hissing after startup then stalls
- 2012 a4 b8.5 fuel problem?
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- 2013 Audi A4 headlight not working
- Water on center control consul. Car will not start, MMI suspected.
- Front end squeak - B8.5 77k miles
- Fuel tank transfer
- Coolant Leak Confusion
- Shifted into Neutral and back into drive
- Oil Level Sensor Defective At High Speeds
- AC and engine temperature fault
- HP fuel pump and unplugged oil pressure regulating valve
- using a trans swap to change clutch
- How to improve the awful default sound
- Concert MMI having AMI issues
- Why do the mice love my A4 Allroad so?
- A4 B8 symphony HELP!!
- Audi A4 B8 2.7TDI (2008)
- Undertray fastners?
- BR: A4 2011 Adaptive Shocks Replacement - Will I Have problems?
- P0171 MAF Reading images including.
- First post second
- Wireless CarPlay and Backup Camera 2013 A4 B8
- Fuel Line From Intake to HPFP
- 2.0t stalking at low speeds and very weird grinding bumpy feeling when pressing brake
- 09 A4 wipers not working.
- NO: Tonight’s game! Spot the source of my problems..
- 2011 Avant tail light help!!
- Display not working (blank screen)
- A4 Oil Consumption
- IL: Help !!!! TURBO/IN-MF.P.
- NO: Rocker arm came loose?? Help
- Replacing and coding new battery
- Keyless b8 8k
- Help please this car is driving me nuts.
- B8.5 transmission/walnut blast/coolant questions (75k miles)
- 2011 Avant B8 codes with misfire
- Activating led bar with high beams, how?!
- Fuel Delivery Problems
- Question re crank bolt torquing Process
- IE: MANNOL AF12+ MN4012-1 Antifreeze Coolant
- 2009 Audi A4 2.0t “Gearbox malfunction”
- P0016 Code A4 2010
- P0401 code insufficient air flow 3.0 TDI A4 B8 8K2
- LT: 2.0 TFSI Strange rattle noise on cold start
- 2012 Audi A4 (B8) Elecronic Steering Rack
- Rear left brake problem
- A8 B8 (Preface) Styling Upgrade Options UK (diffuser, splitter etc)
- A4 B8 2.0 tdi 2011 100kw misfiring n.3 after turbo change
- Audi A4 Quattro 2012
- 2014 A4 S-Line with MMI and no B&O Aftermarket amp install question
- Car starts and then shuts off
- Annoying leak
- Suspension Upgrade
- Question About PCV Valve
- 3rd gear grinding
- Engine heater solution 2009 A4 B8
- Bluetooth 2009 A4 B8 2.0T
- Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
- 2010 Audi A4 2.0t Tiptronic issues (only when cold)
- MMI 3G Basic + Karten Update
- 2011 A4 Hub Noise? Bearing? Brakes?
- My fog light, headlight passenger side and gear selector light not working
- Maf sensor cable location
- Ignition Lock Defective
- 2011 A4 CEL code p0506 and exhaust smells terrible
- 2009 A4 Speaker Issues
- Vossen Wheels Black Friday Starts 11/20 to 12/2 While Supplies last
- 2010 Audi A4 MMI and Air Conditioning won’t turn on
- A4 B&O stereo taking upto 30 minutes to output sound
- UK: A4 B&O stereo taking upto 30 minutes to output sound
- AU: Locked only keyfob in boot/trunk.
- 2.0T no heat, lower radiator hose cold
- Bolt missing and engine noise
- NA: NO A/C airflow on the middle dashboard vents, ONLY on the defrost and Floor vents
- BG: Fuel composition sensor in Canadian market car?
- No crank & no start - battery works just fine
- Need Help. replacing headlamp washer cover
- Only 9v in the tailgate?
- Very long crank (after sitting for 4+ hours) at cold temperatures 2011 A4
- Low-mileage 2011 A4 - worth it?
- DE: Fault code audi a4 b8 2.0 tdi 163 hp 2013
- Vacuum Hose fitting for 2011 2.0t
- TCM ECU advice needed
- Strange RPM-s and increased fuel consumption
- clock is consistently slower than cell phone
- Stripped threads in oil filter housing, help!
- Perspective Buyer
- Electric fan acting up
- Audi A4 B8 8K Power Steering and Transmission Connected?
- Bulbs
- Dashboard Tweeter Beeping
- DE: 2.0 TFSI CPMB - Rattle sound at low rpms
- UK: 2009/2010 2 LITRE QUATTRO Gearbox problem
- Is it Possible To Take Out The Electronic Lock ESL Control Module
- 2010 b8 tdi conversion: what ecu to use?
- B8.5 EPC Max revs 4000 fault
- 09 A4 Cabriolet Top
- Flex fuel?
- Avid skier needs advice on how to transport skis
- Trunk
- b8.5 concert radio not working
- any help on naming this missing piece?
- OM: Audi a4 shaking engine
- IE: License/Number Plate LED Conversion
- No power to ignition, electric system down
- Should I buy this 2010 Quattro....?
- Comparing A4 Allroad/Avant vs A7
- Considering 2012 A4 Avant - Timing/Oil Consumption Questions
- UK: Headlight issue PLEASE HELP
- Car stalls on startup (only when warmed up)
- A4 2013 Cracked CV Boots/New Axles
- Audi A4 b8 android head unit problem
- Engine code P2015
- #2 cyl not firing
- Non-starting diesel with a dashboard lightshow
- Banjo bolt oil feed line size.
- A4 B8 compression loss
- P2283 code keeps popping up
- A4 b8.5 no ac or poss coolant fans
- Just replaced waterpump/belt. Fine for a day, now dumping coolant
- P0299 Code that won’t go away. 2014 A4
- Audi A4 oil issues
- Battery coding
- Audi B8 CVT Transmission Compatibility
- Audi A4 B8 2009 MMI Screen Dark
- A4 B8 Avant 3.0tdi battery discharge
- front seat heating not working
- 2.0 tfsi gearbox problem.
- IE: Audi A4 S 2009 2.0 TSFI severe oil consumption/burning
- 2.0TDI 143 hp not getting and maintaining operating temp.
- Spyder LED headlight error
- A couple of likely silly questions
- Potential Propshaft Bearing Issue
- NO: How many Nm/hp can 2.0T handle
- Stubborn misfire at idle will not go away no matter what I do
- Winter Tire sizes?
- Battery Shutoff?
- Strange car behavior after DPF/EGR delete (video attached)
- Hard to determine what the car is worth. Any suggestions?
- Something strange happened when changing from D to R
- oil changes
- Audi A4 2009 Shifting gears
- A4 2009 Cold Air Intake
- electronic susp fault code
- A really awkward position getting my car unlocked
- Shifter Problems in a4 b8.5
- ***Newbie from Ireland - Q: regarding updating Stereo Apple CarPlay!
- 2012 audi A4 cabin vibration
- Bluetooth audio b8
- Code P0117 not clearing and fans running non stop.
- Rough Idle - Air leak around gear box bell housing
- Starter?
- Rough Idling & Misfires
- USB not supported
- A4 B8 Misfire and sputtering
- 2011 A4 Issues
- Audi A4 2009 ECU
- How to remove b8 avant roof rails
- Potential missing bolt causing oil leak
- Brake pedal goes to floor
- MMI no sound
- Drl headlight yellowing
- Canbus 19 coding with avant electric tailgate
- Car Won't Start
- Suspension upgrade
- Issues w/ Gear Selector & EPB - Car Won't Start
- Audi a4 allroad transmission acting weird.
- Traction control light permanently on
- Timing slip and bent valves
- Lower coolant hose and fan not turn on
- AMI Bluetooth problem
- A4 mmi back up camera.
- Retrofit q5 sline steering wheel in a4 b8,5
- RS: How can I connect Ipod to A4 B8.5?
- Front subframe
- Question regarding VCDS!! Gateway does not respond!
- Louder exhaust for free?
- LV: Chassis a4 b8
- Backup cam
- FORGEDLITE Wheels - 1pc Monoblock & 2pc Modular Forged Wheels - WHEEL DESIGNERS
- 2008 A4 what do I need to get Aux input
- 2010 A4 B8 2.0TDi Avant Problem
- RO: TPSM option not available in MMI
- No Blinkers, or Sunroof functions - Avant
- High-pitched noise when turning the steering wheel
- OEM 17” wheels for sale. A4 B8. $500 for all 4 OBO.
- AU: Severe Misfire
- Front oil leak
- Part check - Electric Tailgate Stricker Plate Lock And Motor Actuator
- Opinions on buying used a4 avant or a6 avant
- 2015 a4 (b8.5) engine revs to 2000 when idle
- Best performance chip?
- 2009 a4 audi
- 2014 a4 engine failure (do I have any recourse?)
- A4 stops working after being scanned
- A4 Quattro 2009 2.0T MAF Connector Replacement
- ZF8 Trans Oil/Filter Change Fill Amount
- Sunwoofer issue on Audi Sound System
- Strange sensation when shifting into second gear, manual transmission
- EE: CGLC engine injector reset
- Cener brake light went out - No power to connector
- B8.5 Stuttering/Misfire Code P030400
- Weird no crank issue
- DRL goes off when headlights on
- AUDI A4 B8.5 Colour match grill/fogs
- Front End Collision Advice
- Wheel swap from 2017 A5 to 2009 A4 B8
- Range control defective after changing headlamp bulb
- Exhaust straight pipe
- Help!! Overheating
- Timing Chain Issue A4 B8.5
- Valet Key/ Emergency Start Case
- Adding BT & music streaming to '10 Premium
- UK: White (or maybe Grey) Smoke on Audi A4 2.0 diesel Automatic
- MyAudi Iphone App. Error 'Data not Updated"
- Audi A4 Avant B8 roof racks cross use?
- Timing chain
- 2009 audi A4 2.0 Quattro power drain after battery & alternator replacement
- UK: Looking to make a diesel purchase
- AM Radio poor/no reception. FM and SAT still ok. Antenna Amplifier the problem.
- NZ: 2009 a4 audi
- Low Fuel pressure After 3k rpm
- MMI Scroll Button Repair/Replace
- Please help!! Audi won’t start after seafoam.
- Suspension on the Premium Plus '13
- New 18" Forgestar F14C Satin Bronze, Satin Black and Gloss Gold Ready to ship.
- MK: Audi A4 facelift Headlight Range Problem
- Audi A4 facelift Headlight Range Problem
- Honeycomb B8.5 Grill with the Quattro wording at the bottom
