PDA
View Full Version : A4 (B8 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. Misfire Error codes
  2. MY: audi a4 b8 2009 245/40zr18 tire pressure
  3. Static on radio speakers, issue ?
  4. DRL LED strip out on one side
  5. A4 exhaust camshaft alinment
  6. B8 or B8.5 2.0T Engine
  7. Cold air intakes
  8. Under body shields
  9. Looking at 2013 A4
  10. Whining engine vs wine. Ok to drive??
  11. Wiring Diagrams
  12. Driver left door not unlocking
  13. New ECS Carbon Fiber Radiator Support Cover!
  14. Turbo Wastegate Issue
  15. Strange metallic rattling noise in new engine??? HELP!
  16. hey guys i have a one questions,..pls reply
  17. 2011 Audi B8 cranks but won't start
  18. Navigation antenna connector location??
  19. Automatic Window Help
  20. 2012 aftermarket camera install help
  21. A4 B8 2.0T setting actuators
  22. Climate control missing from screen non mmi
  23. PRE-facelift LED tail lights for Avant
  24. 2012 A4 AC and Heat working Intermittently
  25. Buying Audi A4 - Advice?
  26. Odd But Quite Serious Problem
  27. New bulbs
  28. Memory Seat Functionality
  29. Coolant leak through wiring harness cooked ecm
  30. Parking brake malfunction
  31. Looking for some opinions/guidance on mechatronic issue- 2011 A4 B8
  32. Audi Connect pairinn issues
  33. 2008 A4 B8 losing power uphill
  34. 75k mile A4 2.0 Quattro maintenance
  35. A/C stopped working - options?
  36. 2014 A4 MMI ISSUES
  37. 2012 A4 engine noise(loud) and what’s the reason? (Video provided)
  38. 2012 A4 quattro prem plus s line pkge
  39. Increase B8 Tail Light DRL Brightness
  40. S5 Transmission wont fit A4?
  41. Addl. Key Fob ?
  42. Turning volume up, turns it down at the same time. WTH??
  43. Request picture: 20x9.5 et35 wheels
  44. New Audi A5 owner
  45. Advice and tips for new Audi A5 owner
  46. Flex Fuel: how many out there ?
  47. 2014 A4 Fuel Rich issue.
  48. Anyone using the Power Magic EZ with your dashcam?
  49. Reason for High Pitched Engine Noise?
  50. Problem with S gear
  51. Audi A4 tdi revs hanging at 1400/1500 till I stop
  52. DRL
  53. ES: 1.8 TFSI Camshaft adaptation phase position
  54. Which floormat ?
  55. Help: How to wire Fog Light Grill Cover Flowing Led Turn Signal DRL For AUDI A4 B8
  56. Rear Brake Procedure
  57. RS4 Grill
  58. Yakima Q5 Clips?
  59. Rough Idle, Sputter, Die...
  60. My needs are simple...I'm easy to please...
  61. Panoramic sunroof wont open
  62. MMI 3G High, music video problem
  63. P2293
  64. Emblems
  65. Slot on the radio
  66. Misfire P0301 Cylinder 1 solved
  67. Advice: A4 B8.5 Manual Gearbox Issues (no oil)
  68. 2014 A4 Recommended Service for 85,000 and 95,000
  69. Oil consumption
  70. Intermittent stall when accelerating from a full stop, then car doesn't start
  71. Tuning options for 2.0 T
  72. Audi Interior Light LED Kit?
  73. No maps update for my 2015 A4?
  74. 2009 Audi A4 Quattro 3.2 sluggish @ hard acceleration
  75. a little hep
  76. Bluetooth
  77. A4 8.5 2015 TFSI Transmission Fault
  78. battery drain woes, not sure what to try next
  79. B8 2012 Audi A4 Quattro major repairs question
  80. 2009 A4 either needs a rear main seal or a new engine.
  81. 2012 Audi A4 Quattro major repairs question
  82. Possible EMS reset
  83. Audi A4 (B8) Radiator Fan
  84. Rough idle no check engine lights
  85. ABS system funktion test "Not starting"
  86. AC is kinda working (but mostly not)
  87. 2013 A4 major engine issue from P0304
  88. 09 Audi A4 Paddle Shift Install
  89. Mechanic Recommendations for Western MA/NE CT/Albany
  90. Mystery Hose on front grill
  91. Europrice - New Website - New Products...
  92. Are these OK--front upper control arms
  93. Help please!! (new member)
  94. 3.0 TFSI 200 kW - Things to look for
  95. Car Won't Start!! Help!!
  96. tail lights problem
  97. Used A4 Things to consider?
  98. A4 B8 engine crankcase vent valve
  99. Buying a used A4 B8.5
  100. Replacing blown DRL on halogen headlights?
  101. Weird Coolant Leak
  102. Key fob falls out of dash.
  103. wiring tail lights needed
  104. Will it work
  105. Dashboard lights not working
  106. Part Identification - Fender Bracket?
  107. $50 off ECS Engine Street Shields + Free Shipping
  108. fan issues for Audi A4 2007 2.0T FSI
  109. heated steering wheel
  110. Driver's side headlight issue
  111. RS4 Grill on A4
  112. Shaking and idling hard
  113. DIY K03 Turbo replacement and Ebay Test Pipe A4 A5 B8 B8.5
  114. Cold Air Intake
  115. PAssenger Door can't open (even from inside)
  116. Engine locked
  117. Cam Timing Logs Help
  118. Help 2011/2013 A4 Timing Problem!
  119. 2.0T Cam Sensor testing
  120. Rough idle with TPMS Light and Stabilization light
  121. Replacing thermostat
  122. Axle bolt size issue
  123. 2009 A4 Avant 2.0T possible turbo issues
  124. Tire Replacement Question
  125. New ECS B8 Adjustable Rear Toe Arms!
  126. Faults, 03110 - Active Steering Control Module (J792) 004 - No Signal/Communication
  127. 2013 A4 engine problems
  128. A4 B8 2.0 TFSI Quattro: Strange short noise during cold start
  129. noise when braking - left side
  130. How to play music on iPhone on my B&O
  131. Coolant Issues
  132. iPhone Audio (trough AMI with USB)
  133. Engine underheating
  134. I can not unlock the doors with my remote, i only have acces to the trunk
  135. Possible New Purchase
  136. Headlights
  137. Wiring harness wisdom needed
  138. locked up engine
  139. 19 inch rs4 rims on b8 a4 235/35 or 235/40?
  140. CH: AdBlue problem
  141. HELP ME PLEASE!!!!! p2279 p0299 MISFIRE/LOW RPMS ONLY WHILE IDLE!!!!!!!!!!!!
  142. 2013 a4 p0304 code
  143. Replacing rotors?
  144. Alignment
  145. Currently stranded.. PLEASE HELP car shakes when started
  146. Electrical gremlins - transmission coolant valve => water & shorts at Engine Computer
  147. ECS B8 Billet Aluminum Control Ring Kits | Dial in the Style
  148. Streaming Music
  149. CV Boots - any quality difference OEM vs. cheap?
  150. Chirping/Squeak Noise Inside of Car
  151. Output speed sensor
  152. Driver side door issue
  153. Time to sell the 2012 Red S-Line Wagon
  154. Just saying hello
  155. a4 B8 rear door lock change guide
  156. Clicking noise and won’t start!
  157. Horn location?
  158. Minor "miss", cannot find problem!!
  159. Low Coolant, Low Oil, Engine Light, Engine Fail
  160. Auto to manual swap
  161. Audi A4 B8 Code : P1 74200
  162. Audi fault code p0111
  163. Idle Pulley Bolt and Belt Diagram
  164. Alternator Fault 2011 A4
  165. Headlights bouncing
  166. Tire Pressure warning light keeps coming on
  167. Valve Cover Gasket Replacement
  168. BT
  169. Clicking sound from power steering box
  170. 2014 oil consumption
  171. Upgrade DRL Premium Trim to Premium Plus Trim
  172. New ECS Audi B8 Chassis Engine Bay Lighting!
  173. Convertable top frozen
  174. 09 AUDI A4 QUATTRO 2.0T MISFIRE AT LOW RPMS ONLY
  175. Performance chip
  176. S4 grille on a4?
  177. 2014 a4 exhaust
  178. 2012 CAEB oil consumption
  179. Screen Mirorring
  180. Back to Audi (kinda)
  181. How do I "renew" the wiper motor on my 2012 A4?
  182. erWIN download assistance
  183. WinDOW Control A4
  184. Stuck on Audi Infotainment System A4 B8 2012
  185. Fault codes
  186. Steering Angle Sensor
  187. TORONTO BEST MECHANIC?
  188. Engine overheating
  189. Engine speed maximum RPM With EPC?!?!?
  190. Audi concert protection active message.
  191. Loss of steering assist
  192. Recall
  193. B8 A4 2009, doesn't start and I'm not sure where to go any more....
  194. 2.0 Timing Chain Tensioner
  195. Check Engine Light
  196. New Instrument cluster
  197. Possible new owner
  198. A4 B8.5 1st to 2nd up shift problem
  199. Air filter box
  200. New Audi A4 (B8) owner - Sat Nav upgrade query
  201. 2014 A4 Mobile 1 0W40
  202. Mmi
  203. 2012 A4 S-Line Stereo issue
  204. Help with fault codes
  205. High beans and interiror light not working
  206. pinch bolt question
  207. Audi A4 2018 2.0 TDI slipping
  208. EPC Light on / Low Power 2011 A4
  209. The Most Aggressive Wheel Set Up You've Seen
  210. Screenwash Alarm/Icon won't go away after refill
  211. Help needed with starting issue or is this normal
  212. Problems with my car
  213. 3-2 Transmission Downshift Clunk
  214. A4 B8 A/C problem
  215. Audi A4 B8 Facelift US to EU Tail lamp coding
  216. PLEASE HELP! CHANGE OIL COOLER AUDI A4 B8 8K2
  217. Need help to figure a hood alignment (no experience)
  218. Speaker sizes
  219. MMI 3G High issues
  220. A4 B8 Symphony headunit display stripes
  221. New owner ( potentially)
  222. Performance upgrades
  223. 2013 A4 Quattro - Front Grill Replacement (how hard?)
  224. Bluetooth inquiry
  225. Main problems with high mileage B8
  226. 09-12 AUDI A4 BODY CONTROL MODULE: 8K0 907 063 D
  227. 2013 A4, CV Joint/Boot Issues
  228. Audi A4 B8 - Rear Seat Removal
  229. B8 (8k2) parts that fit the B8 facelift (8k5)
  230. B7 or B8?
  231. TT PCV valve replaced, now leaking oil
  232. Audi b&o concert dead screen dead radio.
  233. Gear gaitor trim (chrome)
  234. Buying a Higher mileage B8
  235. PLEASE HELP WITH A PART NUMBER THERMOSTAT CONNECTOR
  236. 2008 vs 2009 cvt transmission
  237. New to Audi cars but loving it, MMI/bluetooth help
  238. oil pressure warning and no cruise control
  239. oil pressure warning and no cruise control
  240. '09 A4 Raise gas pedal
  241. Child-proof lock: System Fault!
  242. Resistance while driving on straight road and downhill
  243. 2013 Audi A4 B8 Steering Wheel Upgrade
  244. 2009 A4 engine misfire, battery, parking brake (over 17 codes from diagnostic)
  245. 2010 Audi A4 - Random Stall
  246. Trouble accelerating
  247. LED Bulbs on 2011 B8
  248. HELP! All 4 misfiring, mouse nest found!
  249. After market body kits
  250. 2013 A4 Seat Belt Ignitor resistance
