Audi A6 3.2 FSI Write Up's and HOW TO's List
This is a complete list of all the (How to) write-ups and videos I have found for the Audi A6 C6 3.2l FSI engine. I have also included a list of procedures from the ElsaWin Manuals on these vehicles. I will add to this list as I find stuff. If you have any request from the ElsaWin Manual please let me know and I will try to add what I find. Props go to all the authors and posters of each of the write up's.
Engine HOW TO’S
Carbon deposit cleaning for preparation and removal of upper intake & lower intake
3.2L FSI, How to inspect carbon deposit on intake valves and clean it - AudiWorld Forums
Belt tensioner and serpentine belt Removal
3.2L FSI, What's wrong with belt tensioner and how to replace it. Plus serpentine bel - AudiWorld Forums
Drain the coolant
3.2L FSI, How to drain and refill coolant - AudiWorld Forums
Transmission fluid change
https://www.audiworld.com/forums/a6-...fluid-2816950/
Inspect and replace HPFP (high pressure fuel pump) Cam follower
https://www.audiworld.com/forums/a6-...lower-2765010/
Interior How to's
iPod AUX USB Adapter Install Dension
https://www.audiworld.com/forums/a6-...c6v2i-2831368/
Streaming Bluetooth Music via MMI
https://www.audiworld.com/forums/a6-...a-mmi-2791080/
Video HOW TO’S
Rear Break Pads Change
Front Break Pads Change
Intake Manifold carbon clean and thermostat replacement
Upper Timing Chain Tensioners Replacement
How to replace air-con/heater air blower motor
How to change pollen filter (cabin air filter, dust filter)
How to change switches (buttons) for electric windows on drivers door
How to replace central console - MMI control, handbrake button
Where is the fuse for cigarette lighter socket
How to remove front bumper cover and headlights (clusters)
How to replace headlight bulb
Part Number LOOKUP
AUDI A6/S6 QUATTRO [A6Q] (USA) 2006
ElsaWin Manual PDF’s are listed in the attached files.
These PDF's Give you some what step by step instruction, but it also gives you the torque specs for each part.
Engine HOW TO’S
Drain the coolant
Interior How to's
Video HOW TO’S
Part Number LOOKUP
G-Can (12-07-2021)
Nice job. In my signature there is a link to a library with all of the TSBs that were issued on the C6 model. Take a look and see what Audi has to say about addressing many of the known issues on the C6.
Great Thread! Excellent DYI ....
I have a question for anyone here... I went over the procedure to remove replace thermostat and want to do mine. I noticed that my 2010 A5 3.2 FSI has a pipe that is over top of the thermostat yet under the plenum which from what I see will prevent me from removing the Thermostat (which I desperately need replace - has a cracked housing) Would anyone have information on this pipe? how to deal with it ?
I'll give the answer because I have not seen any responses. The Pipe is the Secondary Air Injection system. I was able to finish the coolant leak fix.. (Thermostat and crankcase breather leaking in valley) by simply stretching the pipe once the fuel lines were removed. This Pipe was not scene on other versions of the V6 FSI ... however the latest final year of it ...(mine LOL!) had it . I was quite relieved to have only spent under 400.$ in parts to fix it DIY> It would have cost under 100.$ If I didn't break the the breather intake pipe! which cost 290.$ and is a dealer only part.
sosick2006
11-13-2013 07:54 PM
Rick 601
4.2 V8 Discussion
04-20-2005 05:35 AM
