PDA
View Full Version : A4 (B7 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. Brake Calipers
  2. factory alarm reset
  3. Left Turn Signal/Tail Light Issue
  4. Headlight question
  5. :: ECS Tuning :: Not Too Stiff.. Not Too Soft.. Just Right...
  6. 2004 AUDI A4 1.8T SEDAN CRANKS BUT WONT START.
  7. Brake lights on while the ignition is on
  8. Evaporative System "Large Leak". OK Where?
  9. :: ECS Tuning :: Precise. Effortless. Shifts.
  10. SportShifters.com - SportShifter now available for your B7 manual!
  11. Question about Transmission Range Sensor and TCU
  12. :: ECS Tuning :: A Tune Tailored for your Audi!
  13. :: ECS Tuning :: Save $50 On JOM Coilovers! | Limited Time Only!
  14. !NEW AUDIWORLD EXCLUSIVE PROMO!
  15. Remote starter removed, now I have no sound from Radio
  16. A4 leaking coolant. Please help find and repair
  17. :: ECS Tuning :: Bring It Back To Life | Borg Warner Turbos
  18. engine coolant temperature sensor circuit high
  19. P0172 2007 Audi A4 V6 FSI
  20. A4 B7 Fans running with car off
  21. 2.0T Low Oil Pressure!
  22. Audi A4 b7 Steering
  23. 2003 Audi Quattro A4 Allroad Revs but wont move!?!?!?
  24. Strange fluid leak between driver side wheels (!?!?)
  25. :: ECS Tuning :: Timing Belt Kits + FREE Schwaben LED Pen Light! | B7 A4 2.0T
  26. 2.0 t Weather related power loss
  27. :: ECS Tuning :: The One-Two Punch! ECS GEOMET® Rotors & Exact-Fit SS Brake Lines
  28. :: ECS Tuning :: Protect Your Pan! | ECS Stree Sheilds - $40 Off!
  29. Replaced Driver Door Lock Actuator, Now the Key Won't Lock/Unlock the Car, Thoughts?
  30. :: ECS Tuning :: Emissions Service Kits | B7 A4 2.0T
  31. Radio/head unit problem
  32. :: ECS Tuning :: Head Case? | AMC Cylinder Head Components & Refresh Kits
  33. ning :: Now Available! | HRE Wheel Collection
  34. Takata airbag recall
  35. Help!
  36. :: ECS Tuning :: 034 Motorsport Collection For Your B7 A4
  37. Oil Catch Can Recommendations? Experiences?
  38. Coolant Alert w/no Heat (Replaced Thermo & Sensor Already)
  39. :: ECS Tuning :: Demand H&R | Sport Spring Kits For Your B7 A4
  40. BIRTHDAY SALE!
  41. 2007 A4 Quattro S-Line 3.2L V6
  42. Timing Belt - Did I do it right
  43. Random misfire - Where to look
  44. :: ECS Tuning :: NEW!! ECS Luft-Technik Intake System | B7 A4 2.0T
  45. new to audi and fob not working
  46. Oil filter accessible from top?
  47. Is this normal for this car?
  48. :: ECS Tuning :: aFe Power Summer Intake Rebate | B7 A4 2.0T
  49. :: ECS Tuning :: Now Available!! Podi Gauges | B7 A4 2.0T
  50. Chrome Window Trim, Not pretty
  51. Loose Hose between battery and Vacuum
  52. :: ECS Tuning :: NEW!! B7 A4 Gunsmoke Rear Bumper Reflector Film
  53. B7 2.0t motor to 1.8t
  54. :: ECS Tuning :: Save 15% On ECS Wheel Essentials | 7/6- 7/14 Only!
  55. 08 3.2 timing Chain or belt?
  56. Steering column shroud screw size
  57. Thoughts for purchasing 2008 A4, 120,000 mi.
  58. How much horsepower will tune add on 2015 A4?
  59. :: ECS Tuning :: Ignition Service Solutions | B7 A4 2.0T
  60. Trying to diagnose a P0089 (VAG P310B) code
  61. Hot rear brake disc
  62. Denver, CO area VAG COM
  63. :: ECS Tuning :: NEW!! Performance Silicone Throttle Body Hose | B7 A4 2.0T
  64. Radio on when car off
  65. Dr Color Chip
  66. :: ECS Tuning:: FREE SHIPPING ends 6/28 MIDNIGHT
  67. How to recharge AC
  68. Summer Start MEGASALE!
  69. :: ECS Tuning :: Billet Oil Filter Housing Hook-Up! | B7 A4 2.0T
  70. :: ECS Tuning :: Forge Motorsport Components | Audi B7 A4 2.0T
  71. Unitronic UniCONNECT Cable?
  72. Invest or Divest?
  73. atlanta area head gasket replacement
  74. Engine mounts
  75. :: ECS Tuning :: Time Is Ticking!| Save Up To 15% On ECS Timing Belt Kits!
  76. What type of headlights bulbs does the stock A4 B7 Come with?
  77. A4 1.8T B7 BFB Motor knocking noise on cold start
  78. :: ECS Tuning :: #SaveThePans | B7 A4 ECS Street Shield
  79. 150MPH Police Chase With Audi A4 In UK - Video
  80. Noise after new steering rack fitted .. Help !
  81. Head lights? Is it what it is .....thanks.
  82. Need help to identify a part.
  83. Fuelg gauge stuck
  84. Engine mounts 3.0 tdi cariolet
  85. 2006 3.2l Tiptronic Recode
  86. :: ECS Tuning :: Solo-Werks S1 Coilovers | Audi B7 A4
  87. :: ECS Tuning :: FSI Cam Follower Awareness Sale!!
  88. audi a4 with 200k miles
  89. 2006 Audi A4 Quattro CCM
  90. :: ECS Tuning :: RS4 Jack Pad Kit For Your Audi B7 A4
  91. 2005 Audi A4 3.2 headlight screw
  92. Loud Hissing after changing fuel injectors
  93. 2006 Audi A4 2.0T FSI S Line Special Edition
  94. Subtle knock noise when turning
  95. :: ECS Tuning :: Audi ECS Carbon Fiber Parts | Up to 25% Off!
  96. Picture of front control arms - normal doamege or screwdriver indiced?
  97. :: ECS Tuning :: Memorial Day Sale | Up to 25% Off RS Style Grilles & Alzor Wheels!
  98. New Keys
  99. FREE SHIPPING through Memorial Day!
  100. :: ECS Tuning:: Summer Prep Sale Event! | Up to 30% off your favorite brands!
  101. Running Lean after cold air intake install
  102. B7 RS4 - is Audi Premium worth it in the flesh?
  103. :: ECS Tuning :: P3Cars VIDI For Your Audi!
  104. is audi 1.9tdi bke engine same as pd
  105. Help with RNS-e Bluetooth
  106. B7 3,0tdi rear differential compatibility
  107. Cold start / rough idle / misfire on 1, 2, and 3
  108. Engine wiring harness diagram?
  109. Audi Key Reprogram if locked out of the Car
  110. Swapping the 2.0t drivetrain over to the 3.2
  111. :: ECS Tuning :: NEW!! Tow Hook License Plate Bracket Kits for your B7 A4!
  112. A/C Actually Gets Colder When Stopped
  113. P0321 - Crankshaft speed sensor repair
  114. :: ECS Tuning :: Assembled By ECS Oil Service Kit Sale- Save 10% | Audi B7 A4 2.0T
  115. BUDGET coilovers best ride quality...
  116. Steering andc Auto Box issue
  117. :: ECS Tuning :: ECS RA4 Conversion Clutch Kits | AUdi B7 A4 2.0T
  118. Intermittent smoke problem
  119. :: ECS Tuning :: Audi B7 A4 2.0T ECS Vent Pod Boost Gauges & More!
  120. Looking for 2005 A4 B7 ESP Sensor
  121. Required maintenance
  122. :: ECS Tuning :: Bentley Service Manuals & Scan Tools | Audi B7 A4
  123. 2006 Audi A4 2.0T Quattro - 109,000 miles maintenance/longevity
  124. Looking at a 06-08 2.0 Q A4
  125. :: ECS Tuning :: Virtual Car Show | Voting Has Begun!!
  126. Question about stereo compatibility
  127. Audi A4 2.0 Quattro 170bhp diesel
  128. OBD Scanner Ross-Tech So Confused
  129. NEW TO FORUM: Is this a good deal?
  130. :: ECS Tuning :: ST Suspensions Rebate Sale!
  131. car star fine when cold, it stall when hot, misfire
  132. Balance Shaft Timing 2.0tfsi
  133. :: ECS Tuning :: ECS Performance Baffled Oil Catch Can System | B7 A4 2.0T
  134. 2008 A4 FWD "Card Holder"
  135. 2007 AUDI A4, 2.0T Quattro.
  136. FREE AutoPreme Floor Mats!?
  137. Pre-wired for Automatic Headlight?
  138. Help needed asap
  139. :: ECS Tuning:: Performance Sale Event | UP To 25% OFF!
  140. Anyone have procedure for rollover protections system check ROPS
  141. How to Protect your Floor Mats (A Revolutionary Solution) - AutoPreme Update
  142. Thoughts: B7 for first car, what to watch?
  143. :: ECS Tuning :: NEW!! Front Wheel Bearing & Hub Assemblies | Audi B7 A4
  144. ***Don Nguyen | WannabeRacer.com | Vehicle Wrap - Tint - Plastidip - Custom Decals***
  145. B7 S-Line 3-piece Rear Spoiler?
  146. :: ECS Tuning :: New Looks! | Fresh Wheel Options for 2016
  147. Thule AeroBlade 53" or 47"
  148. Does anyone have thoughts on what else I might want to look into to keep this car.
  149. :: ECS Tuning :: Get Ready For Spring Brake!
  150. :: ECS Tuning :: Mesh Madness!! | Up To $50 Off 5 Days ONLY!
  151. Bluetooth Pairing?
  152. Immobilizer Problems...?
  153. A4 or 330xi?
  154. Suspension issues.
  155. ECS RA4 clutch kit?
  156. :: ECS Tuning :: Spring into power with Frankenturbo!
  157. :: ECS Tuning :: Save Up To 30% On ECS Assembled Kits | Limited Time Only!
  158. Oil leaking on drivers side of tranny
  159. Visualization with PDC
  160. Help for buttons on steering wheel
  161. Just bought my first Audi, is my turbo bad?
  162. Under boost in my Audi A4 2.0 (boost data included)
  163. Just got a B7 and I'm ready to dump it.
  164. Warning for lights on
  165. Unknown Warning Symbol
  166. APR Tuning for 2008 A4 2.0T....Should I?
  167. Question about color FSI
  168. My Audi feels heavy now can some one help?
  169. Wanna do it myself
  170. Daylights witout HID
  171. 2005 a4 won't rev over 3000 rpm
  172. Size of the front rotors on my 07 a4
  173. Heat and AC -- Heat on passenger side only
  174. Trans pressure hose leak :(
  175. :: ECS Tuning :: H&R Premium Suspension Components | Audi B6/B7 A4
  176. :: ECS Tuning :: ECS Performance Engine Mount Kit | Audi B7 A4 Quattro
  177. Same codes whenever it rains
  178. Having some problems
  179. Smoke at WOT and oil on engine cover (Pic Attached)
  180. My 2006 A4 2.0T rocks and wobbles at intersections
  181. :: ECS Tuning :: WeatherTech All Weather Floor Mats | Audi B7 A4
  182. Using tape to attach something to the dash.
  183. varying engine oil readings on dipstick
  184. Turning service lights off...
  185. :: ECS Tuning :: GEOMET® Coated Brake Rotors | Audi B7 A4 2.0T
  186. looking to purchase a 2006 A4
  187. 2006 symphony aftermarket radio issues at high volume
  188. :: ECS Tuning :: Black Forest Industries Products | Audi B7 A4
  189. 2007 A4 Trunk Wiring Diagram
  190. New owner of used Audi A4 2005
  191. License Plate Light Delima
  192. Boulder, CO area Audi mechanic recommendation
  193. :: ECS Tuning :: ECS Street Shield Aluminum Skid Plate | Audi B7 A4 2.0T
  194. MMI software update
  195. :: ECS Tuning :: ECS Carbon Fiber Mirror Caps | Audi B7 A4
  196. Squeak/Chirp Noise When Driving (VIDEO)
  197. Has anyone replaced their door latch?
  198. :: ECS Tuning :: NEW!! ECS 2-Piece Direct-Fit Brake Rotors | Audi B7 A4
  199. Clutch
  200. Low Beams
  201. :: ECS Tuning :: The Dynamic Duo | Audi B7 A4
  202. :: ECS Tuning :: NEW!! B7 A4 2.0T Kohlelaser Luft-Technik Intake
  203. 2008 Audi A4 ECU??
  204. High beam and low beam not aligning with each other
  205. Please clarify serpentine belt questions...
  206. TMC transmission control module
  207. :: ECS Tuning :: B7 A4 2.0T ECS Tuning Vent Pod Boost Gauge Kit
  208. boost surging
  209. My first gremlin of the year.
  210. Help on CEL and P0171 Fault Code
  211. Bad window switch?
  212. Good resource for preventative maintenance and common issues?
  213. Audi 2.0 Oil Comsumption
  214. Newbie needs help with misfire
  215. 2006 Audi A4 2.0t FSI Multitronic leak?
  216. Are these part interchangeable?
  217. LEDS! Reverse, Interior, License Plate - Free Shipping/Lifetime Warranty/Error Free
  218. RNS-E plastic removal keys broke during removal!
  219. Where *is* the Comfort Control Module on a B7?
  220. Went from an A4 to an A6. Was not happy. Back to A4.
  221. Where is the leak detection pump located in the car?
  222. Fuel consumption increased by 2 L/100kms
  223. 2.0 rear chain Timing
  224. Light/Rain sensor not working
  225. OEM Vs. Aftermarket Turbo
  226. B7 1.8T Head and Block Interchangeability
  227. Constant Overboost.....
  228. Can anyone tell what is wrong with my speedo?
  229. Need help identifying part! PLEASE HELP
  230. I have a A4 B7.
  231. Cannot get heat, even after replacements
  232. Wheel help, newbie!
  233. 2006 A4 2.0T Quatrro clicking noise on startup
  234. :: ECS Tuning :: 50% OFF CYBER MONDAY ONLY! Audi Ziza Master LED Kits
  235. 2006 A4 2.0T Quatrro OBD code P0008
  236. Good Price
  237. New Member and First time Audi Owner
  238. AWE Tuning Holiday Special Pricing starts... NOW. Unlock horsepower for less.
  239. Black Friday/ Cyber Monday deals from Car Parts Discount
  240. :: ECS Tuning :: 11th Annual Customer Appreciation Sale|Save up to 25%!!!!!!!
  241. Differential lock code 00280 help
  242. Confirmed: OBX B6 catbacks for 3.2
  243. :: ECS Tuning :: B7 A4 Quattro Solo-Werks S1 Coilovers
  244. Anyone replaced a center resonator?
  245. :: ECS Tuning :: Alzor Wheel Sale | Blow Out Pricing!!
  246. Buying Information
  247. A4 Q 2007 Window Switch Module (Help)
  248. :: ECS Tuning :: NEW!! ECS Wheel Spacer Fitment Kit
  249. New to forum
  250. What is wrong with my engine?
