PDA
View Full Version : A4 (B7 Platform) Discussion
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. Cleaning coolant off of coolant temp sensor?
  2. 2005 Audi A4 2.0t Quattro
  3. Coolant leak above control arm
  4. Rear brake hard line...got lucky
  5. Repairing seatback cover that fall off the seats
  6. Haya is looking for info. Front differential gear oil change
  7. Looking for Clip that holds lock-nut and adjustment nut on turbo
  8. What differential fluid to use in A4 Quattro differental
  9. Hot starting issue
  10. Lost Power....
  11. Rear view mirror fell off
  12. 2007 Avant, odd whirring/whistle noise
  13. Comparison, B2 vs B7
  14. A4 b7
  15. 2006 A4T engine stumble (help?)
  16. Replaced fuel filter, cured chugging at stop light
  17. 2006 Audi a4 3.0l Tranmission toast?
  18. No A/C and no heat, but everything else is in working order
  19. Parts: $ave an arm and a leg (and an arm)
  20. new clutch switch and still have a epc light when clutch is engaged
  21. Cooling fans not turning on
  22. Brakes dragging after master cylinde change
  23. Convertible roof
  24. Static in speaker
  25. Coolant leak at front of the engine 2006 Audi A4 1.8T b7
  26. Crank, NO Start
  27. Reverse lights help
  28. In the genera of unbelievable Audi stories this takes the cake...
  29. 2006 A4 Battery choices?
  30. Helmholtz resonator. A what?
  31. Audi A4 B7 1.9tdi Braking issue
  32. B7 A4 2.0T quattro You HAVE a catch can already
  33. Aftermarket exhaust
  34. SE: AC trouble - stuck in ECON, 00819
  35. Stange sound comming from rear of the engine
  36. 2008 A4 3.2L check engine light, long cranking P0190
  37. B7 A4 2.0T quattro "Help-yourself Articles"
  38. Grayish blue smoke 1,9 tdi
  39. LT: 2.0 TFSI BWT RPM fluctuation
  40. UK: diesel Cooling Issue/Oddity
  41. ZA: B7 diesel Altornater?
  42. A4 B7 washer pump unusual problem
  43. Help with axle shaft breaking
  44. What is this and what hose should be hooked to it?
  45. NO: 1.8T Will these injectors fit my car?
  46. UK: Front lower suspension arm removal?
  47. Wiper Arms
  48. AC issue
  49. UK: Front grill replacement
  50. How do I control the computer?
  51. 2008 A4 Random Misfire
  52. Timing belt tensioner
  53. Water leaking in behind the glove box
  54. Immobilizer
  55. P016 code
  56. Any alternatives to the stock Oil Filter Housing?
  57. Spring....a time for new springs
  58. 2007 Audi A4 B7, will start with jump and run, dies as soon as I pull off jumper cabl
  59. Coolant leak, engine won’t stsrt
  60. Power seat limited motion
  61. Relentless g247 issue
  62. RARITY HELP! A4 3.2L, 6 speed manual, titanium package, ibis white, sedan
  63. Coolant in your block? Here's my experience, and no it wasn't a head gasket!
  64. My B7 is hard to steer when stopped or at low speeds
  65. New b7 owner
  66. Audi a4 2.0 tdi b7 oil in colorant-help
  67. Code P3081 troubles
  68. PCV Delete, DIY cure to a nagging problem.
  69. Oil pressure warning
  70. Coffee grinds Like in my used oil change 2.0t 2006?
  71. TR: Aud A4 1.6 ALZ "Öldruck Fault"
  72. Replacing Engine Mounts - DIY notes, tips, and tricks.
  73. 2006 Quattro B7 Timing belt replacement
  74. 2006 audi A4 2.0 quattro pan??
  75. 1.8T Fuel Pump Relay? [316]
  76. UK: Location of N80 valve 2009 2.0 petrol?
  77. What hose is this, and recurring collant leaks
  78. Need help finding this part
  79. Rear and front brake discs and pads size
  80. Turbo problem
  81. UK: Audi a4 b7 2.0 diesel ticking noise help
  82. New 2.0 TDI Owner with questions (possibly some help)
  83. 2006 audi a4 2.0 quattro werid sound
  84. Haya needs help...engine mounts?
  85. Error Code Help
  86. 2007 A4 Vacuum Issue?
  87. With price of gas Skyrocketing, whats everyones thoughts about 87 gas in the B7?
  88. 2011 A4 TSI No Boost
  89. 2007 A4 6mt boost/timing issues
  90. Resync key
  91. B7 Cabriolet Upper Window Seals Help
  92. Audi A4 B7 BWE -06 Misfire
  93. Audi A4 3.2 V6 PCV Valve Replacement
  94. Audi A4 B7 AC no hot air? HELP
  95. Help finding part number/replacement
  96. Help! Battery died, car locked, Key does not match in door
  97. Audi A3 coolant leak on splash shield
  98. No power to drivers heated seat
  99. Lean issue upper rpm range under full load.
  100. 2007 A4 Quattro wont start
  101. Audi A4 climate control lights don’t turn on and I can’t use my heater or AC
  102. 2.0T thermostat replacement - Hey the fans came on!
  103. video of what i believe is turbo surging?
  104. CVT friction noise disappearing when gear lever is being pushed
  105. BRE Crank Sensor Location
  106. Grounding strap location
  107. EGR bolt size
  108. Hatchback/Tailgate Trim Clips
  109. Audi B7 1.8t quattro 6 speed clutch
  110. ECU cover removal?
  111. A4 b7 broken pipe
  112. 2007 A4 2.0T with engine knock
  113. Trailer hitch for 3.2 S-line
  114. 2005 A4 2.0 tfsi quattro dash/ignition problem
  115. UK: Bad repair job, water leaks - help needed!
  116. 2.0T Automatic - How can I make it shift faster?
  117. 2007 Tiptronic vs. Multitronic
  118. Need serious help
  119. Headlight information here....
  120. Upgrade headlights from Halogen to HID
  121. New vs. near vintage
  122. Expensive sounding noises
  123. B7 paddle shifter
  124. Lights flickering when starting car: b7
  125. Looking for help
  126. Help with noise
  127. Turbo suggestions
  128. What is this part?
  129. Camshaft noisy
  130. Serpentine belt is wobbly
  131. Headlight anomaly...to say the least
  132. A4 2.0T Radio issue....HELP!!!
  133. Audi a4 b7 2.5 v6 tdi engine light and esp on. Plus bad engine noise and lots of smok
  134. Acceleration noise
  135. DPF Pressure Sensor Location
  136. Can you have misfire with no CEL, I think so.
  137. A4 Avant B7 rear window open independentl of hatch?
  138. Need advice for 2008 Audi A4 2.0L Quattro
  139. Continental VikingContact 7 Ohhh baby!
  140. SI: A4 B7 QUATTRO RELIABILITY?
  141. P2293 Limp mode at highway speeds
  142. getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
  143. Washer pump weird problem
  144. Inflation Relief - Black Friday thru the end of November Sale...
  145. 2004 3.0 VVT solenoid locstion
  146. A4 2007 Issues
  147. scraping sound in when when slowing/braking...
  148. 2006 A4 2.0T - Car died at red light, won't start. Tried many things, any ideas?
  149. 2.7TDI Multitronic rattle during cold slight accelaration
  150. Torn bushings
  151. 2007 A4 2.0T, loss of boost with smoke in exhaust
  152. Rear door wont open from inside or outside.
  153. CCM replacement key fob
  154. Rain sensor alert
  155. NGK plugs shot after 500 miles!
  156. No high beams…tried swapping modules.
  157. Removal of Intake manifold on a4 b8 2.0l tfsi
  158. What do these pop-out buttons do?
  159. UK: Audi A4 Automatic Estate 2009
  160. B7 Door cap driver side
  161. Loud slap/knock noise
  162. Service! message...
  163. 2007 A4 locked me out/won’t start
  164. problem with central locking after using VCDS
  165. Replacing pvc valve in 2007 A4
  166. Multitronic, car trying to pull forward when coming to a stop
  167. MYSTERY PART QUESTION- SQUIRREL DAMAGE FOR SURE
  168. LT: Very hard vibration when in D/R gear standing 2.7 TDI Multitronic (CVT)
  169. Need secondary air pump 1.8t
  170. What is the function of this switch?
  171. What parts/hoses is these? Front right side.
  172. Damaged right front side... what parts is this?
  173. 2006 dies and get code P1857
  174. Loud tick noise
  175. Burned B7 looking for Parts
  176. Missing part
  177. Misfire cylinder 1
  178. Is a 135k mile/218k km B7 A4 worth buying?
  179. Rear CV boot leaking--no clamp?
  180. Audi A4 questions, team goh? And gecko?
  181. UK: Oil warning light?
  182. Buying a a4 DDer , yay or nay ?
  183. All brake lights out except drivers side outer bulb
  184. New around here looking for help: 2007 Audi A4
  185. Strange Startup this Morning, Blinking CEL and Rought idle....
  186. FI: 2006 brd tdi. Need help
  187. Need help diagnosing no spark issue ECM
  188. Need help diagnosing no spark issue ECM
  189. Turbo
  190. UK: TRIP COMPUTER AND CRUISE
  191. 2008 A4 cranks but doesn't quite start
  192. Hydraulic engine mount sensor wired inline with n75valve?
  193. Dealers...and cars with codes...
  194. Short cut?
  195. A4 Avant b7 relays and lift pump
  196. Enfig Bluetooth Installation...
  197. Aftermarket Pioneer double din - replacing Concert double din
  198. 3k jutter
  199. Fault codes and AC
  200. Convertible scuttle shake
  201. Have trouble
  202. Lighting errors
  203. help needed on wind deflectors
  204. A4 B7 swap to A4 B8 trunk
  205. B7 Theme music...
  206. Enfig website -- trojan?
  207. Pesky o2 ssnsor codes and intermitant randomness
  208. ZA: Trailer Light problems on A4
  209. Quick question about cluster LEDs
  210. A/C not working after G65 swap
  211. 2008 2.0T: random white smoke screen from exhaust
  212. CDC Symphony 2 hack?
  213. Replaced car Battery and CCM need remore help
  214. A/C compressor swap out
  215. UK: Total distance from a full tank?
  216. Camshaft Adjuster Housing Cover (Timing Chain Cover) Oh man, I gotta brag on this...
  217. 2008 Avant vibration in gear
  218. Which clips?....
  219. 2007 BCM HELP
  220. Front left and rear right wheels blocked.
  221. Any thoughts on Lucas?
  222. Power window switch...
  223. P2071 error code 3.2 fsi A4
  224. First Audi Purchase. TFSI S line SE
  225. 1,9 tdi issues, any ideas??
  226. 2007 A4 B7 Avant Quattro 3.2L V6 indeterminate oil leak
  227. How do I check my oil level?
  228. Noise from Glove Box. Dead battery
  229. Better Prints and diagrams with Torque specs
  230. Help! Alarm system...
  231. Little to no acceleration while driving/ Feels like stuck in gear
  232. Satellite Radio channel load failure
  233. Audi a4 seats
  234. RO: steam from oil cap/dipstick 2.0 diesel
  235. What is this part? And realllyy rough cold start.
  236. Radiator fan running wild.
  237. Timing Mark Cap Missing?
  238. Clutch or bad slavecylinder bleed ?
  239. Manual gearbox linkage variation, litle black plastic piece.
  240. Rust on the exhaust....
  241. How to choose the radio's AUX outlet?
  242. DEAD Battery NOISE from Glove Box
  243. Tank filler emergency release - where is it?
  244. All four cylinders randomly misfiring
  245. Mystery rattle found. Super service!
  246. Symphony vs Symphony II
  247. Please help!!
  248. Engine swap
  249. So it looks like my B7 A4 3.2 has a small leak in the water pump
  250. Replaced HVAC High pressure sensor & recharged w/ dye injection, still in/out of econ
