- wire route for exhaust cut out/ muffler with valve
- Engine rebuilder
- 2007 A4 2.0T In Limp mode PRNDS all lit up, car wont shift out of park
- Audi A4 B7 Grill Color Code
- 2007 A4 Avant rear wiper motor
- Oil change
- Gnarly misfiring and burning white on the plugs
- 2008 Audi a4
- AC going to Econ mode
- P2100 & P2108 Inlet Manifold Valve?
- Is this used 2008 a4 a good buy?
- Transmission and Cylinder Head Problem
- Multitronic Transmission Upshifting
- Timing Belt Service cost
- Getting codes for p0133 and p12a2
- Obtaining a spare key or keyfob
- new audi owner
- Need Help!
- seemingly unsolvable g31 map sensor CEL
- Blown timing belt...questions
- 06 Manual B7 random “hick up” while driving or at idle
- Please help, Dont know what to try anymore
- $50 off ECS Engine Street Shields + Free Shipping
- Ac problems in my 2002 a4 quattro
- 2007 A4 spark plugs
- AC g65 intermitent
- Instrument panel
- Good repair shop in Mountain View, CA that can SMOG
- Replace Coil Packs ? And P0089, ignore ?
- 3.2 FSI clutch options
- Help pls - Key FOB and SAFE Mode
- Hi, I'm new, A4 avant questions
- turbocharger waste gate adjustment
- Manual shifter lifting up.
- Upgrade front bumper
- The ECS B7 A4 2.0T Luft-Technik Front Mount Intercooler has arrived!
- Radio Wiring Harness
- 2008 A4 Cabrio Headliner Question?
- RS4 Belly Pan
- after market headlights
- Audi A4 B7 losing coolant
- Boost Pressure/MAP sensor Issue
- Mirror mount replacement
- Wiring for Trailer hitch (B7 avant)
- A4 2005 B7 shaded gear on screen
- Funk Button
- Electric problem
- Replacing color trip computer
- 2007 Audi A4?
- A/C Question
- 3 beeps from dash only while driving .
- Introducing the ECS B7 A4 2.0T 3” Downpipe And High Flow Cat
- Anyone with an A4 B7 3.0 TDI, please help!
- How to disable all bulb-out checks, for LED bulbs
- Vacuum Line ID
- Circuit Breakers
- New rims
- Xenon Headlights condensation
- Muffler Bracket
- A4 misfire
- Missing vacuum line?
- 06 A4 detonation
- Any Sort of Power
- Tail Lights Random Outage, 2006 A4 2.0T Manual
- Radiator fan fuse location
- code p0171 leaking vacuum pump
- Interior light remains on when car unlocked.
- Moisture in headlight lens
- Selling 2006 A4
- 2007 A4 cabriolet 3.2 ECU Fuel relay location
- I have a tire and wheel question for my 08 A4 Quattro
- Lots of white smoke
- Genius/idiotic idea for immo "delete"???
- Windshield wipers
- 2008 Audi a4 b7 drl's & tail lights both on same time!
- What's This Broken Part?
- How to change Driver Information Display read out. ‘06 Audi A4
- Looking for a bra
- What are these pieces?
- P1724 P1753 cvt transmission shift early
- Power seat problem
- P2404 issue 2008 audi a4
- High Idle after new valve cover gasket and PCV
- Engines
- low pressure fuel pump prime function
- 2005 A4 Camshaft Sensor Fault
- A4 DPF blocked, removed and cleaned, still causing errors
- Rear light holder/ fixing
- Telephone not working
- 0784 won’t start stumbling wants to fire
- mysterious part
- Bi-Xenon autolevelling issue
- Fans coming on. Suspect relay 219. Change my mind...
- clock spring
- Yellow Triangle
- 2.0 Fsi Need Engine mount connector cable
- A4 b7 gearbox tcm
- 2.0T ECU pinout
- Fuse or relay to kill ignition
- B7 2.0T - MAF sensor wiring diagram
- 07 B4 loud clattering from valve cover!
- 2006 Audi A4 b7 2.0tdi
- HELP! Reasons for timing jump
- B7 2.0T FSI quattro - slipping tranny - 'load signal' error
- steering wheel swap (to TTRS 8P flat bottom)
- High pressure fuel pump
- NEED PARTS
- Loud ticking noise in engine, but then went away?
- convertible top
- The B7 A4 Dual Outlet Carbon Fiber Diffuser arrived!
- Headlight flicker -Deciding what to do?
- Broken part
- Broken part
- Halogen bulb replacement? Help please
- Oil in coolant...
- Audi A4 2.0L 2008: MIL is on, car is shaking ! Help! Help!
- Board computer issue
- Powersteering pump
- All sound from tRadio, CD is gone...Suggestions?
- Newbie:06 Quattro Need Manual, Video?
- Exhaust replacement
- 6-speed Shifter Problems
- 2006 Audi A4 CCM
- LS: EPC
- 07 A4 turbo
- New ECS No Holes License Plate/Tow Hook/Camera Mount System
- Price check: 2007 A4 Quattro
- 2006 Audi A4 CCM
- wont start ?
- Failed Instrument Cluster
- 2006 A4 2.0T boost cuts/limp mode?
- 06 audi a4 quattro 2.0t jerking on acceleration
- Rear coilover install?
- Loss of bluetooth
- Help with Audi A4 B7 2.0 TFSI accelerating noise?
- Code 17536
- Headight Swap
- Audi S4 2012 stuck on neutra
- 2006 B7 A4, Revo SPS flash tuner any good?
- Information for a part number
- Lift springs for b7 a4?
- 16" vw b5.5 wheels on an '05 b7 audi a4 2.0 tsfi s-line quattro?
- Cutch Problems!
- INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
- Today Only! Solo-Werks Coilovers 10% off + $50 Rebate + Free Shipping
- Looking into a B7 A4 for new daily
- Memory Seat question
- TDI: Very long crank on cold days
- 2.0t quattro 2006 8ec lost heat in cabin
- Help - Sudden big loss in MPG
- 2008 A4 Avant TDi (B7 i think) - Window Relay location
- Coolant Flange/Heater Hose
- 6hp19a tiptronic after repair
- Some lady hit me.. is my car considered totaled?
- Aftermarket amp to factory speakers
- 3.2 S-Line rear shudder
- 2007 a4 coolant flange leaking
- Looking to buy 09 2.0T Quattro, need some insight
- 2007 2.0T wont shift into 2nd gear in Drive
- 2007 A4 3.2 oil leak
- Odd starter behavior
- Audi starting problem, Video Provided, Help needed!
- A4 b7 3.0 tdi swirl flaps
- 2.0 tfsi - Low pressure fuel pump problem
- INSTRUMENTAL CLUSTER IS MELTING
- TODAY ONLY 15% Off Liqui-Moly!!
- 2007 Audi A4 2.0 tdi won’t start can’t hear fuel pump and the scanner won’t communic
- Blend door actuators
- A/C clutch relay
- New to Audi!
- RS4 bumper...
- where is the inside adjustment headlight height
- 2008 Audi A4 2.0T FLASHING PRNDS
- Pioneer Head Unit Install Issue
- bluetooth module location - 2007 a4 avant
- Front parking sensor & folding mirror problems
- Audi A4 1.8t Quattro 2005 fault codes
- LED headlights
- Telephone module replacement/location?
- 2.0t cylinder head removal
- Lose in power
- Too much cranking: 2007 Audi A4 Quattro
- Homelink will not program
- Urgent Help
- getAudiparts.com | Genuine Audi Collection Key Rings!
- Auto headlights / stereo problem
- sudden clutch loss
- 01435 - Capteur de pression de frein 1
- A4 vacuum leak
- vibration in steering wheel and seat
- Is it normal to have oil in the breather tube?
- Sale 10% on Powerstop brakes!
- SALE! Schwaben Professional Scan Tools 10% to 40% off!
- Rear view mirror
- What if the Valve cover breather to Turbo hose is not functioning proper?
- Groaning from servo area under light braking
- Audi A4 B7 3.2l V6 Performance Mods
- Help
- New here
- A4 B7 Cabriolet - Roof only opening a few inches then stopping?
- Misfire..Smoke..HELP!
- Light/Rain detector defective
- A4 starting problem
- 2005 Audi A4 B7 MMI Question
- Blowers in the cabin blow cool when on high
- code p0445
- Steering control module “R or Q”?
- Oil Service | Oil Change | SALE save 10% for a limited time!
- Help - A4 shaking - wont go past 2,500 rpm.
- Bad carrier bearing
- 2007 Audi A4 2.0t Turbo Problems(blue smoke)
- OVERSTOCK SALE! Select Milltek Sport Exhaust on Limited Quantity Sale!
- Audi A4 2ltr tdi radiator fan issue
- SALE! B7 A4 P3 Gauges 10% off until 8/27/2018
- 2008 audi a4 2.0T Quattro Automatic Loss of power
- Tiptronic will only downshift
- is it possible to increase hp in the A4 2.0T
- Audi A4 2007 140HP S-Line mods and help
- FLASH SALE! Street Shield Skid Plates 15% off + FREE SHIPPING
- Programming Key Fob?
- SALE GSP Replacement Parts | up to 15% off | Wheel Bearings, Axles, Loaded Struts
- Audi A4 B7 2.0TDI 170PS turbo problem?
- Yes, you read correctly! We now have footwell LEDs for every single Audi model/trim o
- replace power steering pump or just pulley?
- Flash SALE! Performance Air Scoops!
- Replacing 614 70A with 40A relay for ECU
- help cant find ground 83
- Pioneer AVIC-6000NEX GPS DVD Car stereo w/audi adapters - $400
- Engine Oil Flashes
- A4 B7 Cabrio-water leak/roof inop
- Weird CVT TCM issue
- car went limp mode
- SALE SALE SALE!! JOM and FK Colilovers $350 SHIPPED
- New! Integrated Engineering Performance Tune! Flash your car in your driveway!
- Catch Can Upgrades ON SALE! 10% OFF plus FREE Shipping
- 1.8t new pcv valve stilluner alot of vacuum??
- Key does not turn steering column ignition on?
- throttle position sensor location
- Fuel Grade and Fuel Additives
- Car starts and immediately dies
- Alarm problem
- Audi A4 B7 2.0 TFSI engine oil leak
- Any on ha e flat tire issues?
- Tail light turn signal
- Turbo seised :/
- Intermittent shifting issues
- Radio won't turn on and Aircon won't turn off
- A4 2006 - Cuts out randomly
