- Fabric top separating from rear window.
- Need airbag help
- particulate filter
- Audi b7 estate b7 . Res delete pipe size needed
- Flooded ECU BOX B7
- False add?
- Car won’t start
- My A4 (B7) PRNDS/Intermittent Start/Brake light flashing
- 2008 A4 Electrical Issues?
- Positive battery harness replacement help
- Airbag light/Selt Belt sensor
- Airbag fault
- Need advice pls ! - Cam Follower + Transmission
- 3.0 TDI BKN Oil Pressure
- A/C & Heat not working. Fan blowing sporadically. Help!
- transmission / torque converter question
- A problem that no one can diagnose
- Throttle Body and TPS
- 2006 A4 B7 Fan Problems even though I changed the control module.
- Parking brake cables
- Replaced Turbo, still blowing white smoke
- Help Wipers not working
- Performance Mufflers
- High pressure fuel pump
- Code p0011
- My very own P0089 code
- B7: Cowl rain covers?
- Both swaybar bolts MISSING from 3.0TDI
- Fault P1635 esp and glow plug
- UK: 3.0tdi Nom starting
- P1292 and unstable idle missfires
- check engine diagnostic sheet audi a4 2007
- 2007 A4: Both Fog Lights Still Out - after replacing bulbs?
- Coolant flange need help and tips
- Misfire or vacuum leak .
- SE: Is there really no suitable upgrade for me? (Car purchase)
- Misfire please help
- Problems with the clutch
- RO: A4 2006 1.6 not starting or difficult when engine is cold
- PLZ HELP! 2006 audi a4 non quattro 2.0T FWD AT mounts
- 2005 b7 cel epc rough idle shuts off
- Audi A4 2006 Headlight replacement
- 2007 Audi A4 MAF sensor location?
- Vehicle Speed Sensor Wire Location
- IE: Accessing Audi A4 indicator/turn signal front bulb?
- Need help with prelim diagnosis
- EPC Trouble
- P0204 cylinder 2 misfire code... end of my rope
- APR vs RaceChip
- UK: 2.0 TDI Engine issue
- A4 B7-Whining noise in throttle body
- intermittent codes 2006 A4 3.2
- Brake Fluid
- B7 Misfires after timing chain replacement - Ran Perfect for 5 mins before misfiring
- Won’t shift past reverse
- Connector for Starter Solenoid
- 2.0 TDi Engine differences
- Motor jumped time
- Volume Issue with SAT Radio
- Bogging
- How to remove boot lock
- Audi a4 b7 wastegate help
- Audi a4 b7 Watergate help
- Bpw and bre engine difference
- No acceleration but gears slowing me down.
- 2007 A4 Cabrilet 2.0T transmission issue
- Just purchased a 07 Audi A4 2.0 I, Turbo (Manual) Need tips and Advice, Thanks!
- Speakers
- 2005 A4 Avant 3.2
- UK: AUDI A4 B7 19 TDI GEARS NOTCHY, ANY ONE HELP WITH THIS?
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- A4 avant 2.0tdi sline
- Fuel Leak
- Oil and error info for A4 B7 TDI 170HP // 2007
- Milage not displaying
- Driving PCV Valve Open Dangerous??
- Convenience module.
- Exhaust
- Steering rack compatibility question ?
- Audi A4 CD Error
- AU: Tranmission failure CVT
- HELP, Audi a4 Connector
- Oil an coolant mixing
- Flywheel problem
- How to replace sensors
- Engine issues post accident
- CVT Filter question
- 2.0T Crankshaft "Ass Problem"
- 2008 Audi A4 2.0 Turbo Kit
- 08 b7 2.0t surging at idle cam/crank correlation code
- Ticking noise from rear while driving straight
- Issues starting up
- '08 Wagon Max Liftgate Height Adjustment?
- 07 A4 2.0T issues
- Audi A4 B7 2007 TAKES LONG TIME TO CRANK
- Fuel injector upgrades
- Radiator Fan Wires
- Check Engine Light appears and disappears
- Transmission software update
- Stock Spring Rate on B7 A4
- A/C drain location on b7?
- Worth getting an intake?
- Timing chain rumours
- Just bought an 2007 A4
- 2008 A4 Right Dipped Headlight Halogen Lights
- 2007
- 2008 A4 Headlight Type & Ballast?
- Audi a4 b7 fan runs on after switch off
- SZ: A4 B7
- EPC and Traction light on no longer building boost
- USA: New Member/Need Help B7
- 2007 A4 3.2L Massive oil leak
- 2007 A4 3.2 Massive oil leak
- Water on passenger side, coming from behind/under glovebox - still stumped
- Right parking light warning need help
- Audi A4 fenders and do they fit?
- Does my 3.2 FSI engine sound normal or not?
- Boot Trunk - Rear Fog light and dipped headlight not working...
- Right side(driver) motor mount
- Passenger headlight and rear light not working after installing aftermarket tail ligh
- Clutch replacement
- Carbon Build Up Around Head by exhaust
- Need help lost keys
- Will 19" alloys of widths 8.5 and 9.5 fit a4 b7?
- EGR problems
- Rear bumper problem
- 35watt or 55watt HIDs
- Intermittent Stalling
- Full mesh RS4 style grill
- Big problem
- Fuel pump dead, can you syphon the fuel out ?
- P0016 code
- 2008 Audi A4 Info Help
- Buying Advice 2006 quattro 3.2L
- Please help me understand- 4 cylinder Oil Consumption
- Oil consumption
- New ECS B7 A4 2.0T Cat Back & Turbo Back Exhaust Systems!
- 2006 AUDI A4 B7 2.0T CVT Diesel / Petrol
- 2006 Audi A4 2.0T Quattro - Oil consumption problem
- Recommendation on Carplay unit install
- Cranks, but won't start (intermittent)
- Key FOB keeps "forgetting" - Pls Help ?
- Audi A4 Secret Compartment
- 2007 Audi A4 will not start after driving it
- 2008 Audi A4 B7 - Cranking, I smell fuel, but no start.
- Audi A4 2006 Interior Swap
- Crazy codes
- New Owner Questions
- B7 Instrument Cluster - Backlit Scales not working with Headlights OFF
- 3.2 auto common repairs / preventative maintenance?
- CAMSHAFT BROKEN IN HALF!!
- Help with 07 cabrio top part
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- Odd issue with dashboard light errors...
- Sony XAV-AX1000 integration into B7
- Engine swap. Technical question.
- No crank/No start
- 18249 - Engine Control Module / Transmission Control Module Incompatible
- Odd sticking of driver rear brakes
- Car wash triggers engine light
- Ross-Tech vcds?
- illuminated front door
- Cold Air induction kit
- Halogen Left Dipped Beam Not Working
- TPMS
- Body control module versions?
- A2007 Audi A4 B7 Sedan Fuel guage stopped and shows zero
- 2008 A4 2.0T BASE MODEL ENGINE DIES IN REVERSE
- Throttle postion sensor code, p0221
- Rear Seat Entertainment
- What Power steering fluid do I have? Color is not green it is yellow to clear. B7
- Remove EGR without removing cooling unit?
- Need help with rear upper control arm replacement
- 2008 Audi A4 b7 P0171
- A4 Multiple codes hesitation/long crank/no power
- Torque values caliper front and rear brake?
- Engine Crank wont turn by hand
- Code Help Needed
- Temp issue
- Weird AC problem
- 07 cabrio trans problem
- 2006 audi A4 3.2 wagon problems
- Hi friends i had a problem with my 07 audi a4 quattro 2.0 i changed the speedometer c
- Replacing Automatic shift kmob
- 2006 B7 A4 s-line seats in 2008 B7 A4?
- Misfires when cold
- 2006 a4 quattro 2.0t 6spd automatic transmission issue.
- audi A4 1.9 tdi
- Popping from front end
- audi a4 b7 2.0tfsi eco standart
- Audi A4 1.8T 2006 Smoke
- Audi A4 2008 B7 Bluetooth
- 2008 A4 Quatro Flex Pipe replacement
- 07 Audi A4 codes P0299, P0420, P0455
- 08 A4 Upgrades
- Help Dashboard Warning Sign
- Adaptive Headlight Question - 2009 A4 Cabrio
- HELP!!! Weird shaking from right side suspension
- Total coolant loss
- PASSENGER DOOR CONTROLS NOT WORKING AFTER DOOR PANEL SWITCH?
- 07 a4 2.0. Head gasket job problems!
- Finding Rpm/tech wire?
- GB: 2.0TDI Auto Intlet Manifold Flap again ?
- Center console replacement?
- 2006 audi A4 tire variance?
- Lost
- Exhaust Centre Section
- Ignititon housing issue - immobilizer
- Po 321 and TPI 2007067
- Exhaust noise Help
- Pulsating?
- Just pulled
- 2007 A4 Avant Stereo issue
- New to A4's / List of issues
- 2006 A4 B7 P2293 and P2294 fault codes
- High beam fuse
- Fellow audians
- hello
- Acc/Start Auth Fault Code 0010, WOn't Start
- Airbag module removal tips?
- 2008 Audi A4 Turbo, AC issue
- Low power and P0019 codes, does it need that $1,500 fix?
- Cam follower 2.0 TFSI BUL engine
- 2296 & P0174 codes
- Vibration in front end only when carrying passenger?
- Shmutz inside instrument cluster
- Lets play a game!
- Fuel efficiency
- Best place for body kits?
- Cat sensor temp
- Reprogramming key fob
- PCV valve and crankcase vacuum fix
- Metal support bar under driver's side fender?
- I'm lost head lights issue
- Juddering during acceleration
- Oil preassure problems, 2007 Audi A4 B7 2.0 TFSi
- odometer code "L3 5-6"
- Alarm sound and Door LED question
- What material is this trim?
- Ticking Sound
- Wonky Electrical issues
- A4 Quattro 3.2 sluggish @ hard acceleration
- wire route for exhaust cut out/ muffler with valve
- Engine rebuilder
- 2007 A4 2.0T In Limp mode PRNDS all lit up, car wont shift out of park
- Audi A4 B7 Grill Color Code
- 2007 A4 Avant rear wiper motor
