- Under Hood Carbon Fiber SALE!!! 10% to 15% off!!! While Supplies Last!!!
- SALE ALERT! Racingline 10% OFF
- B7 2.0 turbo issues
- "Automatic tilt-down of passenger side outside mirror"
- Audi b7 check engin P0458 P0245 P2400 P2294
- 10% off 42 Draft Designs | Exhaust, Adapters, Intakes, Catch Cans, and More!
- Radiator fan turn on for 3 seconds and shuts off. Control module and relays replaced.
- manifold glowing red near cat.
- Not going into gear when starting
- Limited Edition Carbon Fiber FSI Engine Covers!
- Flash SALE! Solo-Werks Coilovers 10% off + Free Shipping
- Oil pressure switch
- Rear defroster repair - which kit is best?
- Audi A4 b7 Steering spindle knuckle sleeve
- check engine light, code PO016
- ECU pre-programmed to VIN
- 2006 A$ Comfort Control Module
- Wastegate actuator loose / lots of play
- Timing belt on wrong position? Really need help with the position
- up to 15% off Ignition Service Kits! | Sparklers!
- Side Moulding falling apart
- 2008 audi a4 tpms module location?
- 235/45 R17
- Thoughts?
- TPMS
- 2005 audi a4 2.0t fuel/performance issues p0089
- Maxton Design select FLASH SALE 15% off until 6/29/2018
- New Alzor Wheel Styles! Starting at $499.95 a set!
- Cabrio roof mechanism problem
- genuine Audi parts ON SALE!!!
- Please help! Audi A4 2.0t 2007
- Engine Judder on Idle and Accelerating (Fault Code PO301)
- Lot of engine vibrations 2.0t
- Please help! Audi A4 2.0t 2007 (screenshots)
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- Automatic Transmission Gear Box Gasket Change
- White Smoke coming out of exhaust when accelerating?
- 10% off upgraded drivetrain mounts!
- Headlight washer problem
- FLASH SALE -- Lightweight Flywheel + Performance Clutch
- A4 2.0TDI lot of problem
- Passenger Electric Seat Not Working - need diagram
- Wheels
- Rear speakers work sometimes but not all the time
- Clunk clunk clunk
- CV /wheel bearing issue
- 2006 A4 2.0T Transmission Fluid
- Confusing misfire
- A4 sudden shut off no crank no start!!!
- Pros and cons of Audi A4 B7 TDI 2.0 version
- p0722 code
- New! Carbon Fiber Quad Tip Rear Diffuser!
- ICM ignition controle module locatiob
- Oil pressure failure
- Curious about body kits, & other noob questions!
- Street Shields Skid Plates on Sale! Free Shipping + 15% off!@!@#@!
- FIS No NAV-DVD - turn off ?
- 2006 A4 Avant Rack & Pinion
- Introducing ECS V4 Performance Brake Rotors | Free Shipping
- H&R WINBACK - A chance to get a full reimbursement on H&R coilovers!
- 2007 A4 Quattro Intermittent Starting
- FLASH SALE 25% off Schwaben Scan Tools + FREE SHIPPING
- AC not blowing out cold air?
- Ac help
- FIS and NO NAV-DVD info cancel
- dead power window
- 235/40/R19?
- Front turns that are error free and can be seen in direct sun light! Dark Amber Color
- The ECS Memorial Day Sale starts NOW!!! up to 25% off your favorite brands!
- FLASH SALE 15% off ECS Air Scoops
- FLASH SALE!! up to 15% off Cooling Refresh Kits
- Audi A4 B6
- engine noise
- Should I change CAM timing chain?
- B7 All Weather Rubber Floor Mat Sets for Under $60 shipped!
- 3.2 Timing values
- Audi A4 3.2 random cylinder misfire at low RPM
- No compression on #4 after carbon cleaning
- Vacuum line "crushing" at Vac Booster
- Coolant leak from left side of engine
- Coolant Hose
- Audi transmission adapter plate
- 2006 A4 Brochure
- Help with Updating Stereo
- Sounds like chains are being dragged
- Not changing gears down hill - automatic
- Up to 25% off CTS Performance Upgrades at ECS!
- can bus
- Car sounds like a Jet when turning off.
- 2007 A4 S Line Grill, What fits?
- FLASH SALE! Maxton Design Exterior Upgrades 15% OFF!!! | Ending 5/11/2018
- New! ECS Billet Aluminum Shift Knobs | Heavy Weight | Full Customizable Style
- 2008 audi a4 b7 engine head rebuild/damage mediation
- 2.0 coil pack update wire harness
- oil consumption solution with after effects
- 3 days only Turbo Inlet and Throttle Body hoses 10% off!
- Is the timing chain adjuster bolt on a 2006 Passat 2.0 FSI set on 15 or 73 footpound?
- B7 A4 aFe intake = get a Free Gift!
- New 2007 A4 SLine Owner with a few questions.
- New owner of 2007 A4 - Miscellaneous questions
- I have no power to the In tank fuel pump i wired to battery and it worked HELP Please
- Air intake manifold
- I'm new to this and I obviously need help
- Where has all this oil come from?
- Need A/C experts - ECON button
- SALE SALE SALE Neuspeed Performance Upgrades
- FLASH SALE Up To 15% on Timing Chain and Belt Kits
- 2006 A4 Convertible Front End Damaged Builder Questions
- 2-Day Flash SALE 15% off ECS Billet Oil Filter Housings!
- HELP!! Looking at buying an 2008 A4 S-line
- 07 A4 cluster in safe mode
- 2.0 TFSi camshaft adjuster - VERY noisy
- 07 a4 2.0t running rough
- IPOD CONNECTOR CABLE
- Hot start issues!
- getAudiparts.com | Genuine Audi LED Puddle Lights Sets!
- Shift Knob
- getAudiparts.com | Genuine OEM Audi Parts + FREE SHIPPING on Most Orders $299+!!!
- After I replaced thermostat the electric gets crazy
- P0036 O2 Sensor Bank 1 Sensor 2
- AC Compressor help
- Timing Belt and Motor Mount Repair
- A4 Cutting Off No solution Yet
- A4 Fuel Flap actuator
- Wheel Stud Conversion Sale!!! Save 15%!!!!
- Catastrophic engine failure 59 miles after timing belt replacement
- New! The ECS Luft-Technik Intake Air Scoop for your B7 A4!
- New! ECS Remote Exhaust Cutouts | Engage LOUD and quiet modes
- JHM cable
- Brass-like particles found in oil cup
- 2008 A4 Wipers and Headlights Won't Stop ... EVER
- Best Miami, FL area Audi shop?
- 2006 AUDI A4 CVT TRANSMISSION AND TCM FAILURE
- TCM ***Where is it located?
- SALE 25% OFF Alzor Wheel Sets! Starting at $337.46 a set!
- Back In Stock CUPRA R Lips!
- 2008 A4 Avant's trip computer illuminates but does not display andy information.
- 034motorsport + ECS = chance to win $100 and swag packs!
- Regular Maintenance and Replacements
- SALE ALERT! 10% off Racingline Performance Upgrades
- Bluetooth Stopped Working
- Anyone know this the specs?
- HID Bulb and Ballast Replacement help!
- roof leaks
- Oil pressure light.
- A4 b7 impact sensor schematic
- 2.0T or 3.2L V6??
- Recommended ATF
- It's ignition service time! Spark it up with us
- 20% off Schwaben Scan Tools | Up To $399.99 off!
- Strange behaviour
- Tire wear, fronts vs rears
- 2-Day Flash Sale on Schwaben Fluid Change Tools|Extractors, Power Bleeders, and MORE!
- location of a sensor
- Exhaust Pressure Sensor
- Vacuum Leak
- Headlight Switch/Knob LED/Backlight Permanently On
- Engine swap
- SALE SALE APR ECU and TCU Software is ON SALE!
- turbo rattle noise @ 2000 rpm
- 2008 A4 2.0T Quattro Anti-theft/Fuel System issues.
- For those of you with the 'bad torque converter' surging...
- Battering Running Down
- 2007 A4 crank no start
- Engine swap
- engine oil consumption
- Used Anti Theft Module
- remove a6 steering column
- High Pressure Fuel Rail Sensor Location
- Weird Noise
- 06 2.0T Engine swap
- Sale Alert! B7 A4 Catch Cans! 15% off and FREE SHIPPING
- FLASH SALE!!!! Street Shields 10% off + Free Shipping
- 01110 and 01090 CEL codes
- ECS Tuning & StopTech 2018 VW MK7.5 GTI Sweepstakes | You could take home a built car
- Rear Sway Bar Links Replacement
- Brake Booster check valve?
- Exhaust cam installation
- Q7 tcm issues
- Alzor Wheels BACK IN STOCK!!!
- Integrated Engineering TAX SALE! Make your return go further!
- Is my audi a4 a true Sline
- SALE!!! Powerflex Performance Poly Bushings!
- Starts but wont move.
- ZA: Oil Pressure warning A4 2.0 diesel
- Back In Stock!! Carbon Fiber Mirror Caps | Free Shipping
- P1743 error. Please help!!
- FLASH SALE! 5 days of 50% off Ziza Master LED kits and Free Shipping!
- Wiper problem - any help appreciated
- A4 2.0T B7 2008 Headlight Fuse location?
- Drivers Seat rear height motor not working - need help
- FLASH SALE!! ECS RA4 Clutch Conversion Kits with Lightweight Flywheel!
- SALE! up to 20% off AIR LIFT!!!
- Rebate Alert! Koni Shocks, Coilovers, and Cup Kits
- Esp not working
- FLASH SALE! up to 15% off select Schwaben Tools!!!!!!!!!!!!!!!!!
- Temp Gauge Random Up & Down / AUDI A4 B7 Diesel 2007
- Engine cut out 2007 A4 avant 2.0 tdi sline
- Help pls - rear brake light shorting out
- 2007 Audi A4 2.0T Problem
- Audi A4 transmission
- SAVE 10% on Regen5 Wheels
- New Audi Owner Research
- clicking noise behind dash on start
- QuickJack Lifts now available at ECS Tuning! Lifting made easy and mobile!
- Surging need an actual Audi tech plz
- COMMON FIX FOR P000A?
- SALE!! Black Forest Industries Performance Upgrades
- FLASH SALE! 10% OFF and get FREE SHIPPING on Solo-Werks coilovers
- Flash Sale 10% Off Select Specialty Tools From Schwaben
- SALE! up to $196 off HPA Motorsports Turbos, Big Brake Kits, and more!
- CEL AND EPC Lights
- Help!
- Audi Idling Problem
- Rust be GONE! Fertan Rust Converter
- Help Needed: Idle Noise Sputter Shake
- Performance Week! Save BIG (up to 20%) on your Favorite Performance Brands
- Purchasing a 102K a4.
- up to 20% off CTS Turbo Upgrades!
- Is this sound normal when you press the gas?
- Is a leaking sunroof drain a common problem in Audi allroads and how can the problem
- Hey all! New to this forum looking for boost gauge help
- Boost Pressure Control Valve
- compatibility
- up to 33% off Service Kits! Assembled by ECS Kits on SALE
- B7 Audi A4 with k04 upgrade pricing?
- radio coding help
- Changing steering wheel on 2018 Q7
- Buy High Mileage 2006 A4 3.2?
- engine oil
- Turbocharger questions
- 25% off Micro Jump Start Kit + Free Shipping!
- Issues with engine noise - Any ideas? Video
- P2138 and p0456
- Back In Stock ECS RA4 Conversion Clutch Kits | Free Shipping
- B7 2.0t Rough idle, stalls, no starts, EPC light
- Audi B7 key fob problems
- 2006 A4 Dip light replacement
- What's This Loud Whine?
- Brake lights stays on.
- Car vibrating
- My stock b7 hpfp doesnt even have this valve
- 2009 Audi A4 w/ 134k miles for $5500
- 06 audi a4 oil pressure starts fine then drops after 2-5 minutes less time if reved.
