PDA
View Full Version : A4 (B7 Platform) Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. 2.0 TFSI Timing Belt
  2. 2.0 T Quattro Clicking & Loss of Power
  3. LV: BPW to BRE?
  4. anti theft nut replacement?
  5. Fuel pump making whining/humming noise after fuel filter replacement
  6. LPFP Leak
  7. Crank No Start No Codes
  8. Starter replacement - any hints?
  9. low compression p0022
  10. Adaptive Lights Modification
  11. 2.0FSI Blow-By Effects
  12. SE: Audi runs badly
  13. Weird noise on acceleration
  14. BCM reprogram?
  15. NO: Audi A4 - BRD (diesel) engine - leakage from screw (at the top))
  16. 2.0t driven with flashing oil pressure light, now it won’t start
  17. Any idea
  18. Clutch problem after motor installed
  19. UK: A4 B7 2.0TDI 2006
  20. cooling fan issues
  21. A4 B7 Clock Spring question
  22. UK: PCV?
  23. ZA: Auto light and rain senor
  24. Slow Crank!!
  25. broken plastic in oil filter housing
  26. A4 B7 2.0T Tiptronic Quattro
  27. delayed shifting
  28. Camshaft Position Actuator Control Circuit Low on 2007 A4 B7 3.2 FSI
  29. A4 B7 with P12A2 and P2293
  30. Electric faults / draw
  31. 2007 Audi A4 3.2L Problem
  32. AU: Vacuum pump
  33. A4/S4 Avant B7 head unit upgrade help
  34. Coolant loss
  35. Best oil level sensor?
  36. Audi A4, 3.0 TDI Cabrio 2006 Leaking oil near the throttle actuator
  37. Rear brake line leak
  38. SI: Audi A4 B7 2007 3.0 TDI 013128 - P3348 VCDS
  39. 2021 Q5 18" wheels ok on my A4?
  40. How to tell if I need a new camshaft?
  41. Help needed with strong exhaust gas through windows into cabin
  42. Opinion on spring trunk struts
  43. NZ: Halogen to bi xenon deap
  44. Random Misfires All Cylinders, Bank 1 Running Lean 2006 2.0T
  45. Steering Angle Sensor - Defective - CODE: 00778
  46. NZ: 06 Audi A4 Bi-Xenon ( Not Adaptive ) helppppp required
  47. IN: Why is the heater core always on?
  48. Weird acceleration
  49. cam and crankshaft sensor location and what do i need to take off ?
  50. B7 A4 3.2 Ground Wire Near the Oil Filter Housing
  51. 2008audi a4 sline radio blue tooth
  52. HELP NEEDED ON SOME FAULTS
  53. Valve cover gasket
  54. Unknown connector and ground wire.
  55. Engine block ground wire
  56. Avant 3.0 TDI Rear Axle Replacement
  57. Control Arm?
  58. AU: Best cold air intake?
  59. 12v sockets issue
  60. LH Headlight Issues
  61. NZ: Coolant Temp Issue
  62. '06 Audi A4 Quattro 2.0T Engine rebuild
  63. Rear Sway Bar link install trick
  64. URGENT HELP!- Driveshaft is stuck
  65. 2006 Audi Quottro A4 SLine 3.2 Headlight Change
  66. Awful metallic spinning noise
  67. Limp Mode?
  68. Limp Mode?
  69. New TPMS's installed but not recognized, dealer stumped
  70. Potential Clutch issue? (3.2 02X)
  71. B7 xenon headlight reflectors
  72. Gearbox swap from 5 Speed to 6 Speed A4 b7
  73. Loss of power then magically fixed, fan staying on then magically fixed
  74. 2006 A4 HPFP - No Schrader Valve?
  75. Assistance with paint code-RP sticker worn
  76. Small Appearance Mods to my Avant
  77. TURBO UPGRADE
  78. Adding heated seats to an '08 A4
  79. Coolant leak
  80. 2007 A4 CABRIOLET 2.0 AUTO/REVERSE LIGHTS
  81. Leak Detection Pump Missing
  82. 2007 a4 avant quattro 2.0t b7
  83. 2006 A4 Cabrio 3.0l V6 has a coolant leak at rear of engine
  84. UK: 2008 A4: Strange problem
  85. 2003 a4 wagon Quattro avant- need fuel relay location
  86. A4 passenger door problem
  87. Audi a4 b7 transmission
  88. 2007 Audi a4 2.0T B7 rpm fluctuation almost stalls and surges
  89. 07 Audi a4 B7 I have RPM fluctuation at idle, engine surges and have a video help
  90. Digital screen new warning(?) light
  91. Clutch and flywheel labour time
  92. Horn not working properly, PLEASE HELP
  93. 2008 a4 2.0 b7 not reading transmission
  94. Engine swap
  95. Knocking sound on the back of audi a4 2007
  96. Fog lights
  97. 2006 B7 Retrofitting electric seats
  98. Clutch disk springs
  99. Getting P0299 under boost code.
  100. 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
  101. Car starts but doesnt stay running.
  102. A4 Avant Adaptive Xenon Headlight Replacement
  103. What is this? (Avant interior near grab handles)
  104. Remote Key and Seat Position Memory
  105. 2007 A4 Cabrio Stalls/Trouble Starting
  106. Opinions on PCV deletes?
  107. Bilstein suspension Kits.
  108. No warning alarms
  109. Random pipe
  110. Lights work but do not turn on.
  111. ZA: Auto light and rain senor
  112. 2006 B7 2.0T HELP!
  113. coolant leak, HELPPPPP
  114. Click when starting
  115. Help please 2008 A4
  116. MU: Issue with 1.6 litre rpm
  117. Loud grinding noise when trying to cold start? HELP
  118. R.I.P. Avant....open to suggestions
  119. Load reduction relay #
  120. Electrics
  121. Torsion values
  122. Need help anyone in sheffield or south yorkshire
  123. Plug in pvc inlet to turbo housing.
  124. Audi Concert Radio
  125. NZ: Sediment in coolant reservoir
  126. Steering control module fuse and wiring
  127. A4 B7 2.0 TDI manual - transmission problems
  128. Please help issue with steering control module and climate control
  129. Mystery Wires - RF kick panel
  130. Misfire, Rough idle, Backfire
  131. Fuel range
  132. Engine ticking noise diagnosis
  133. b7 AT hesitation
  134. Grill
  135. Wish me luck!
  136. FI: Clutch switch information
  137. N205 06F109257C Valve resistance reading needed
  138. Check engine light
  139. blow off
  140. A4 B7 strange wheels
  141. Oil filter housing leak
  142. New to me B7 Avant 6MT
  143. SRS Side Impact Sensor - Needs Programmed?
  144. Will a b8 2.0t fit into a b7 2.0t?
  145. Unknown connector in engine has oil in it
  146. Advice needed, a4 b7 2.0tdi pd170 brd injector fault
  147. Is this ticking or knocking sound normal for B7 Audi A4
  148. Replace clutch? How hard? What to do?
  149. Help Help, I think I did something wrong!
  150. Throttle problem
  151. B7 S4 Recaro Pinout
  152. Best Digital Touchscreen Head Unit in 2008 A4
  153. My cam follower technique
  154. 2007 B7 Auto Headlights?
  155. A4 - sline - 2.5 dti v6 8e2
  156. Hard start problem
  157. Xenon headlight level sensor noise
  158. Audi a4 b7 2.5 tdi problem
  159. No heat inside cabin, been chasing my tail. Help!
  160. 2.0t fsi Camshaft Adjuster Info needed
  161. Carbon cleaning intake valves - your opinion matters
  162. Which lights to replace
  163. Problem with 3.0TDI ASB. Engine revs on its own.
  164. Front bumper options?
  165. Audi navigation
  166. getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
  167. BLACK FRIDAY SALE,, SuperSprint Italy
  168. BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
  169. Misfire and ticking noise 2.0t fsi
  170. Clicking from rear quarter panel.
  171. A4 B7 Electronic engine mount decode vcds
  172. Fuel Line/Pump Issue
  173. WHAT is this connector called!!!
  174. Stuck at 1.5k RPM, Burning Oil and Stutterring?
  175. Several interior lights staying on.
  176. A4 B7 2005. ABS rear sensor modul voltage needed.
  177. Transmission output seal. Help. Can't find any tech info. Second post.
  178. 2.0t fsi Camshaft Adjuster Unit Camshaft phase regulator
  179. Code p2294 2006 a4 2.0L
  180. Dealership Issues
  181. UK: 2.0T FSI Phase position bank 1 intake -13.00KW?
  182. HELP PLEASE CAR DIED AT RED LIGHT
  183. instrument cluster pin code for replacement
  184. Rough cold starts
  185. Oil sensor location
  186. Code p2108
  187. [HELP] Cylinder - Misfire
  188. Help identifying part
  189. Help needed A4 2.0T 2007 multiple random misfire
  190. Pcv valve... replace or delete?
  191. HPFP cam follower story
  192. Headlight chimes
  193. Audi A4 2.0T 2006 flashing check engine light
  194. PRNDS all lit up :(
  195. Help needed. Can't get center diff tailpiece off.
  196. Extra help, lean air, short to ground, etc
  197. Oil pan sequence
  198. Car shakes around 2000rpms
  199. Soft Top not secure
  200. Car starts then stalls
  201. UK: Please, can someone identify this part?
  202. Transmission Replacment Coding/Programming
  203. Engine sounds under load
  204. Guys I just got the error codes from my audi a4 2.0 b7 and howly ****!
  205. PL: Answering a call without the multifunction steering wheel?
  206. New Audi A4 2.0T driver, issues (Key fob, noise, oil leak)
  207. Transmission mount help
  208. TPMS light keeps coming back, I give up
  209. Hard one: 3.2 FSI - calculations.
  210. Ordered parts from FCP Euro and taking 3 weeks to get.
  211. New to me 2007 A4 2.0t Quattro - first steps?
  212. P2002 Error
  213. Headlight bulb loose inside headlight assembly.
  214. Need wiring assistance replacing RNS-E Nav with aftermarket Andriod Auto head unit.
  215. 2003 A4 Quattro massive electrical draw with car off and key out
  216. a/c diagnosis help please
  217. Diesel lock motor
  218. 06 A4 B7 idle problem
  219. Normal B7 2.0T Engine Noise or Issues
  220. SE: Bad idle when installing LED light
  221. No internal lights and no number plate light working
  222. B7 Audi Vibration Issues CVT 2.0T
  223. Having idle issuses
  224. Error codes need some help
  225. Advice on Potential A4 Purchase?
  226. ZA: 2.0 TDI went dead but has power
  227. Cabrio top motor issues
  228. ecm issue?
  229. A4 Cabrio key fob stopped working as did central locking button, alarm won't set
  230. AMI port behind iPob dock?
  231. Audi a4 b7 2.0t loud ticking whine from engine
  232. Fuel pump relay location?
  233. Fuel pump relay location?
  234. Highest "Distance to Empty" range I've ever seen
  235. Gas Strut ends issue !!!
  236. P3102 - still safe to drive?
  237. 2007 A4 2.0L Quattro Help
  238. Fog light issue
  239. Intermittent Crank no start
  240. Reversing Light failure
  241. UK: 2.0 diesel starting issues
  242. B7 2.0tdi BRD starting issues
  243. Navigation unit in the trunk = RNS-E?
  244. SK: Cyliner compression Advice please A4 B7 2.5 TDI
  245. UK: Tunning [sic]
  246. MAF Sensor Connector.
  247. Control Arms Kit
  248. Multiple Misfires, car seems to go in and out of Limp Mode
  249. Wondering about wheel fitment for my Audi A4 B7
  250. Does steering control module need to be programmed.
