- Electric fans not operating at all
- B7 Avant value
- Headlights adjustment
- how to adjust headlights
- Engine Codes cannot be read using HEX-NET
- Audi A4 B7 Buyers guide
- Buzzing noise
- Broken Fuel Supply Quick Connect
- Will any old ECU and TCM work?
- airbag light not turning off no fault codes?
- common problems
- Changing tire
- Throttle Body Adaptation... ?
- Full LED headlights... ?
- K04 TIME
- Transmission issue. Please help.
- Engine misfires only at high rpms!!
- Intake air leak
- what modifications are good for audi a4 2006
- Tire Pressure Light Not Turning Off
- Fuse keeps blowing
- Engine Vibration and engine shuts down
- 2006 A4 3.0 Quattro Cabriolet engine swap
- 2007 A4 BWT with issues
- Problems with engine...strange sound
- Say Hello to Ava
- Folding jack to fit in case
- Air Con noise
- J2 exhaust system
- Bad turbo? '08 A4 B7
- Any help pls - wont start after changing inst cluster
- 2007 audi a3 2.0T FWD
- Fuel Cut?
- Backup Camera Power location
- :: ECS Tuning :: NEW!! Bremmen Android Multimedia System
- 2006 model Steering Rack feel ???s
- engine shake
- 3" or 2.25" for Catalytic Replacement?
- Audi B7 dual fuel tank - not equally filled
- I need parts number, Please.
- 2005.5 Audi A4 B7 Doors
- purge valve
- purge valve
- throttle hesitation.
- 06 A4 2.0T AC Condensate Drain Clog
- Car Door Not Locking Properly
- Check Engine Code: P0455 2008 Audi A4 B7
- Vagcom Result Help
- Fuel pump
- 3 spoke steering wheel
- Not seeing many cars with Xenons
- WTB: B7 A4 2.0t sedan, auto, New England
- Instrument cluster failure - LCD replacement ?
- DRL Questions
- Fuel door lock shroud bolt ??
- :: ECS Tuning :: NEW!! ECS Carbon Fiber Trunk Spoiler
- Idle Issues/ Missfire on Cyl. #2
- 2006 A4 B7 2.0T Engine Clacking Noise
- Why Audi?
- 4th Cylinder Misfire
- 07 A4 2.0T Avant Wagon
- audi a4 avant 2.0 tfsi bgb (2005) inlet cam hpfp lobe
- VAG COM: B7 Changing Language
- Anyone have a high mileage b7?
- 2008 A4 3.2 = A3 and A6 versions?
- B7 AVANT BLACK INTERIOR
- audi a4 b7 2008 alt 2.o non turbo
- Getting a 2008 A4 S-Line Convertible for FREE!
- non DRL to auto DRL
- Lack of power
- mutifunction steering wheel installation for clarion auto radio in audi a4 b7
- Oil leak after head rebuild.. HELP
- Tow bar question
- Car died after auto cross and won't run now
- A4 PRNDS-False Neutral
- spark plugs question
- B7 1.8 TFSI
- Audi A4 2.0T braking safety question
- Best Suspension for AVANT
- audi rns-e retrofit code missing
- 2004 AUDI TT
- How much can I get for my car?
- Maintenance Cost 2017
- Will the 2009 A4 front bumper fit on my 2008 A4
- New Owner
- 2006 Audi a4 2.0t A/C Not Working
- A/C ECON light stuck on
- Convertible Top Error Code
- 06 A4 2.0t Power steering fluid?
- 2007 A4 2.0t overboost P0234
- A/C Issues (HVAC Guru's please help)
- What FELL OFF my engine?!?!
- RPMs go up but Power goes down??
- 2006 trans fluidleak and loud noise
- Burning oil
- A4 failure to start after long drive and MAF issue
- Head Light Bulb
- 2005 A4 3.0 diesel with the shakes
- A4 B8 dipped lights alternating for not working
- 2007 Audi A4 manuals?
- Audi B7 2.0T engine failures, quattro, Audi uk, engine Issues,
- Whining sound coming from rear / firewall area after timing belt service
- 2009 Cabriolet Top Problems
- Purple liquid
- Cylinder Head Cover Gasket Under Timing Cover Gasket Leaking
- Misfire Cylinder 2
- HELP!!!! Diagnosis this problem.
- 3.2 HPFP DIY
- Intake camshaft seized
- Noise from Intake... thumping, then rattle (with video)
- Axle and Motor Mount Replacement? '07 A4 2.0T
- Audi A4 B7 no heat in cabin
- 2007 2.0 coolant leak
- Noob Here and to Audi's
- headlight dipped
- Takata airbags
- UK: A4 2.0 TDI 170 REMAP RECOMMENDATION / EXPERIANCE ?
- Immobilizer / key programing
- Xenon DLR sidelight out , no power to bulb + error message
- audi a4 tow hook
- Strange Fault Code
- 2006 A4 b7 2.0t air conditioning stopped working
- p2006 dtc
- engine keeps dying.
- Key
- RNS-E not seeing Blackberry
- CAE Engine
- 2006 A4 2.0T Running Rough
- 18" Wheels, what width
- Spent all day - P0688 code - dealership gave me part numbers for relays-
- "Gotchas" On A High Mileage 2008
- Intermittent engine noise after DIY engine flush and oil change
- having Mis fires when under load around 2100 rpms.
- 2012 Audi S5 4.2L V8
- 2006 Audi A4 (B7) coolant leak?
- 2007 a4 2.0t p0299 issues driving me insane..
- 3.2 Catalytic Coverter
- 08 Transmission Problems! PLEASE HELP!
- 2007 Audi A4 Quattro?
- Handbrake adjustment
- Price guidance on low mileage A4 S-Line
- Audi S4 2000 Jerks
- Oil Consumption
- Help on removing the HPFP
- Aftermarket GPS wire install/placement? Easy solutions?
- Wheel fitment
- How to Hook Up an iPhone SE to 2008 Audi A4 2.0T
- New B7, worried about potential cam chain tensioner noise (video)
- Car upshift way too early. Advise needed....
- My new 2008 Audi A4
- Code U0100 audi q7
- Location of Crankshaft Position Sensor
- Q: Audi a4 b7 2.0 tdi engine swap
- Won't start, fuel issue
- Want some opinions
- Looking to buy a A4
- New Audi owner, have a few questions, been searching for answers
- Noise from rear Differential '07 A4 quattro 2.0T
- Dealership or mechanic.... or sell it
- Halogen to Xenon: Checklist
- What are the fucions of this wire
- Help! Air coming in under pass side armrest!
- Audi fuel
- NEW OWNER: Part identification
- Weird skip in high gear
- Radiator Fans Keep Running!
- Radioator Fans Keep Running!
- Audi A4 Purchase Question...
- 2nd gear issue (when cold)
- wiper blade install and reverse light... 2006 w/3.0L
- A4 1.6 spark plugs needs changing every 2 weeks
- undercarriage pic
- Boost Control Valve question
- Question... why 3.0L not offered when....
- Looking for B7 A4, New England area
- Leftover torx bolt
- What bulb is this?
- Help me choose an Audi!
- Sounds like metal on metal grinding or possibly a bad bearing?
- Just got this B7 A4 2.0t - whatchya guys think? BM and Subaru guy, new to Audi world
- Right reverse light not working.... help
- B7 A4 3.2 Quattro
- Looking for exhaust tips
- thinking of buying a used A4 quattro
- Oil change question... '06 3.0L/ NO OIL ON DIP STICK
- Is it possible to have glow plugs on all the time for certain amount of time?
- sunroof shade slid back into roof
- NEW D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs | Interior LEDs!
- A4 w12 6.0 engine project
- Xenon flickering
- Heating/cooling
- Suspension help needed
- radiator and turbo hoses
- Brake question
- painturride
- Proud new owner of this rare gem!
- Key Fob housing change...now car wont recognize the key...immobilizer??
- Flex Pipe Repair, Which One To buy?
- A4 B7 cabriolet trunk switch
- 2007 A4 Remote Starter Inquiry
- 2008 A4 Avant 6-Speed Value
- Tranmission Replacement ?
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - January 1st - 7th, 2017***
- New user and owner need help
- Engine Pulsing 2.0T A4 QUATTRO
- Audi A4 2.0TFSI
- I think i blew my engine
- Bad turbo seals
- Garage in Seattle bodywork / suspension
- 2008 A4, RNS-E question
- Looks like unicorns are multiplying
- Audi B7 Pillar pod
- Headlights turning off unexpectedly in Auto mode
- 15%/20% off Holiday Sale - Free Shipping on all LEDs! Shop now and save!
- 07 A-4 2.0T Oil Consumption problem
- Finally found my unicorn
- B7 owners manual FREE
- A4 owners manual PDF
- Running cold
- Turbo installed incorrectly? (Naperville, IL) Might need a referral/recomm
- Slow Cranking
- !AUDI ONLINE PARTS WINTER RAFFLE!
- Replacing rear door blades, cost to paint?
- Turbo Upgrade Question 2008 A4 2.0T 6Speed
- Heavy oil smoke under accel!! SOS PLEASE HELP 9000$ in repairs not fixed still!!!
- Type of power steering fluid?
- Possibly buying a B7
- Just replaced the turbo actuator...now I've lost all boost and got P0234 code
- Audi A4 B7 2.0T swap to V8 4.2
- Manual Transmission
- WHAT DO YOU WANT TO SEE FROM A PARTS DEALER?
- Audi A4 S-Line 2.0 Turbo diesel hesitation issues
- Removing catalytic converter
- Production date by VIN?
- Oil Pressure Light Flashes then car Dies and will not start
- Hard shift into 2nd gear... Valve Body? Torque Converter?
- Dice Media Bridge
- starter relay location?
- Building a kit car with Audi parts. Need help finding a limited slip.
- Building a kit car with Audi parts. Need help finding a limited slip. Here is an ide
- connecting apple maps or google maps to 2006 a4 with bluetooth
- FOG light replacement for 2006 A4..help
- B7 Avant cargo room?
- HELP PLEASE
- Denso compressor failure
- :: GruvenParts.com Custom Billet Accessories for VW/Audi !
- Boot Latch wont lock
- Straight Pipe question
- Radio and Digital Speedometer
