- A4 2.0 Overheated and spit oil out back of motor?
- Vibrating Avant 3.2 Quattro FSI Auto
- HELP! Need to find the correct springs for my 2008 A4 DTM
- Rear speakers- no sound!
- FWD to AWD and Automatic to Manual
- Audi A4 B7 2.0 tfsi quattro stage 2 / 3 remap
- remap
- APR Performance Software Sale!!! 10% off and FREE SHIPPING!
- New A4 b7 2.0T Owner - Help Me Plan My Maintenance
- Audi engine oils
- Key fob window controls
- Why there is poping noise under my 2008 AUDI A4 after I shut it off?
- Replace Sat Radio with Bluetooth
- RNS-E 2005 A4 senior techs might help?
- A4 lost power
- New! ECS Billet Interior Hood Release Lever for your B7 A4
- New Schwaben Fender Roller! *$59.95* with Free Shipping!
- Amp Wiring Issue
- Does your car stink? Time for a new cabin filter from MANN
- 2005 Audi A4 B7 TCM replacement
- Battery being drained every night. Car shaking while pressing gas.
- HEATER CORE
- Audi A4 B7 Rough Idle
- Last Day to SAVE up to 50% on your favorite brands!
- Flash SALE up to 15% off ECS Carbon Intakes
- Flash sale! 15% off ECS Performance Baffled Oil Catch Can
- P0346,P0391
- Looking for Ind. Repair Shop - Central NJ.
- A4
- P2014 minfold issue, which part should I change?
- GOLD!!!!!!! Limited Edition Forge Diverter Valves | In Stock | Free Shipping
- Power steering fluid
- What issues does 3.2 engine have?
- LED headlight conversion
- Last day to save on over 25 of your favorite brands up to 30% off
- Mechanic in Vancouver BC?
- Brown sludge explosion under my bonnet.
- Audi B7 1.9 TDI doesn't start without starting fluid.
- P2181 and no symptoms (A4 b7)
- Electrical issues
- Save 20% on Maxton Design Exterior Upgrades!
- P0243 after replacing N75
- Massive drop in fuel economy
- up to $50 off ECS Street Shield Skid Plates!
- Heated Seats; Standards Too High or Bad Luck?
- $50 ECS Gift Card + Free Shipping on select South Bend Clutch Kits | Best Deal!!!!!!!
- RPM jump around slightly while driving
- HRE, Neuspeed, Radi8, Alzor Wheels up to 25% off!
- Buzzing sound coming from rear Right Window/Diesel Tank
- SALE 35% off Micro Jump-Start Kit Schwaben | Dead Battery Salvation | Free Shipping
- A4 diesel: losing oil
- EGR seal
- battery is drained, doors are locked
- On SALE HPA Motorsports | Sale ENDS 1/3/2018
- Free Shipping and up to 15% off P3 Gauges!!!!
- up to 15% off Drivetrain Mount Upgrades | Performance Sale Ends 1/3/18
- Audi A4 Quattro 1.8 Running Poorly
- 25% Off DINANTRONICS Sport Performance Tunes While Supplies Last
- Is your car truly luxurious without these?
- SALE 10% off Neuspeed Performance Upgrades| Tunes|Intakes|Suspension|More
- Brake vacuum pump failure symptoms?
- up to 25% off CTS Turbo Performance Upgrades
- HELP
- 10% off and Free Shipping Milltek Sport Exhaust
- 2.0T Lean at IDLE
- 2003 a4 4 B6 2.0cc
- 2007 Audi A4 1.8T starting problems
- 2007 Audi A4 2.0t 6 speed shifting problems
- B7 hp Gain?s
- 2008 Avant key keeps needing to be re-programmed
- wheel offset
- For Sale: 17" '01 S4 Wheels - $150 plus shipping
- up to 50% off your favorite brands Cyber Monday|Supersprint HRE 034 Milltek and More!
- Multitronic gear switch while moving
- Brake Swith
- Body Work
- 06 a4 avant headlights not working
- Questions bout my Audi a4 B7
- Temporarily disable alarm while on a ferry?
- 2006 A4 6 speed MT quattro
- One Day Sale! $50 off your B7 A4 ECS Street Shield!
- Annoying problem after changing interior lights to LED
- Oil Consumption 2.0T BWT - FIXED
- Save 25% on Alzor Wheels
- SALE! Up to 50% off Ziza lighting!
- Compression test
- Weird noise on below 0 start up
- Check engine light after oil change @ Midas
- Heating issues 2006. A4 2.0T quattro 140K
- 08 Audi A4
- Noise - right front wheel area
- How to run new ground for number plate light and rear fogs 2005 a4
- Engine operating temperature
- Roof rack mounting hole blocked
- P2181 Audi A4 2.0T Convertible
- ECU puts out 5V but sensor only getting 0.5V
- 38% off FSI Fuel Injectors | While Supplies Last!
- Audi A4 B7 2.0 SE automatic - belt interval
- Cold start stalls
- Engine makes Popping sound on acceleration at turbo.
- Comfort Control Module in a 07 Cabrio
- Question about engine misfire, carbon build up
- A4 B7 Heater not working
- Billowing White Exhaust Smoke on Acceleration (A4 3.2)
- Will A8 front brakes - 360mm Disks fit easily on an my B7
- Check engine light on - Audi A4 Quattro 2007
- A4 TDI S line - 2007 registered
- Auto trans b7 flex pipe removal
- Audi A4 B7 2.0 SE automatic - Oil Light
- Bentley manual (Or, can you tell me what size screw is...)?
- Crank Sensor not getting enough voltage
- Engine questions
- Idle sound
- 06 A4 headlight adjustment issue
- I messed up- Audi A4
- A4 Cab window pre-opening
- 2.0 4 cylinder ALT VVT removal/ gasket
- SACHS Performance! Now available!
- Used Audi buyer's guide
- 2006 Audi A4 Quattro knock sensor
- Coolant reservoir cracked
- 2006 Audi A4 Quattro I need pointers
- HPA Motorsports up to 11% off and FREE SHIPPING
- Knocking even with 91 premium
- Best performance chip
- A4: cooling light
- 2006 2.0t automatic transmission interchangeability
- UK: A4 2.0 TDI oil pressure light - balance shaft failure?
- 2007 Audi A4 Cabriolet center brake light warning
- rain tray leaks
- audi a4 b7 best ecu upgrade
- airbag light
- B7 or B8?
- Dinan B7 A4 Performance Upgrades
- 10% off FrankenTurbo B7 A4 2.0T turbo upgrades! Ends 10/31/2017
- where can i download a manul for seervice for audi a6 2012?
- Light switch / Follow me switch stay on after car is turned off
- up to 15% Off + Free Shipping on B7 A4 Baffled Oil Catch Can Systems|Ends 10/15/2017
- Torque Converter upgrade
- 2007 Audi A4
- B7 thermostat replacement cost
- Dorman replacement parts for your B7 A4
- Port in housing around flywheel?
- Audi B7 Tuning video! Awesome!
- B7 Audi A4 Avant - rough idle
- b7 air conditioning not working - MYSTERY!
- Oil leak from head bolt
- SALE APR Software 15% off | Ends October 31st 2017
- ECS Tuning issues?
- From NOW until 10/7/2017 save up to 10% on ECS Exact-Fit Stainless Steel Brake lines!
- Passenger side High beam not working/ flicking on (HID)
- Playing Music without wasting Gas
- Dead Audi. Help Plssss...
- FEELER: Fair price for my 2006 A4
- Bremmen Android Multimedia System for your B7 A4
- Avant Car Cover
- EGR Fault code po401
- B7 air conditioning mystery - no cold air
- Tuning A4 3.2
- Up to 33% off Oil Essentials! Drain Plugs, Oil Filter Housings, Dipsticks!
- Free Shipping on Solo-Werks Coilovers for your B7 A4!
- Unique Convertible Top Problem
- Advice pls - Turbo or PCV oil leak ?
- :: ECS Tuning :: SALE up to 25% off CTS Turbo Performance Products
- Coolant leak - trying to find part #
- New owner/member 06 A4 6 speed. Steering issue
- Trunk liner, 2007 Cabriolet
- engine will not turn,
- :: ECS Tuning :: SALE 15% OFF | Cooling Refresh Kits! | Flash Sale
- ***WannabeRacer.com | Boston and New Jersey Vinyl Wrapping Tour***
- HID Problem fix or convert to LED
- :: ECS Tuning :: In Stock | 034Motorsport Performance Upgrades
- number 3 coil replacement.
- Can you delete a code with VAGCOM
- P0299, replaced DV
- Releasing the front seats on a 2014 Audi tt
- 06' Cabrio Window Switch Issues
- :: ECS Tuning :: NEW! HPA Motorsports Uncompromising Performance
- B7 A4 S-line confusion
- p0366
- :: ECS Tuning :: NEW! GODSPEED Project Coilovers, Camber Kits, Springs, and more!
- :: ECS Tuning :: Tire Stickers | Stand Apart
- 2006 1.8T Cabrio S-Line - A few Questions
- Audi A4 no boost/power
- audi A4 avant sline 2L petrol, 2006. epc warning light
- 2005 Audi A4 3.2. What half moon seals will fit?
- White smoke under hood. Help? 2005 Audi A4 3.2 (pics)
- :: ECS Exclusive :: Molygen Next Generation Engine Oil from LIQUI MOLY
- Loss power during mild acceleration with Smoke and jerking engine
- :: ECS Tuning :: JOM Coilovers | FREE SHIPPING
- Introducing myself and my first project
- Go to first new post Anyone know what this tube is? its by the oil cap? there's no s
- warning light question
- Rain/light sensor part numbers dilema
- Audi A4 PCV valve replacement
- All Power Windows and Sunroof Not Working
- :: ECS Tuning :: SALE! Save up to 20% on ECS oil change kits | Ends 08/27/2017
- pvc fixed 2006 2.0t but still having same problems
- :: ECS Tuning :: Wheel Sale! ESM, Vorsteiner, Radi8 | Up to 15% off | Ends 08/27/2017
- synthetic oil weights
- :: ECS Tuning :: 20% off your favorite brands! Back To School sale!
- Fuel Filter
- Oil Pressure Switch install fail - 2008 A4
- Flash sale! 25% OFF LED Interior Lighting Kits! TODAY ONLY
- EPC Light On/Off - New Owner - Lots of anxiety ;P
- Timing Belt failure after less than 6 months
- Problems following Major Oil Leak
- Need some Air Conditioning help in this heat...
- ABS and ESP light in dash, unknown leakage and weird shifting
- :: ECS Tuning :: ECS Tuning Ultimate Short Shifter Kit | FREE SHIPPING
- Ignition lock not rotating all way
- 06 A4 Quattro 2.0T misfires
- :: ECS Tuning :: 10% off ECU Upgrades! | Ends August 13th, 2017
- MAJOR WIRING HARNESS REQUEST
- :: ECS Tuning :: service Made Easy for your Audi B7 A4 2.0T
- A4, 2007, 2.0T - Strange issue
- 2007 A4 3.2 quattro coolant leak under intake area
- 1.9 Tdi - oil pumping out of dipstick tube
- The left front is lower
- Can Turbo Problems lead to AMBER Low Oil Pressure light?
- New Audi Owner
- Driver side won't lock with remote key
- pcv vacuum - looking for part number (P0171 error)
- Audi A4 B7 Xenon connection
- :: ECS Tuning :: ECS Blind Spot Mirror Glass - Audi B7 A4
- A4 does not like rain
- Just bought my first audi :D
- :: ECS Tuning :: 25% OFF Alzor Wheel Clearance | Ends TONIGHT 7/31/2017
- SALE!!! 034Motorsport save 10% | Ends: 08/04/2017
- comment on Q5 oil consumtion..
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - Aug 28th - Sept 4th, 2017***
- Audi A4 Automatic 2006 stuck in drive and neutral
- A4 1.8T Almost Stalling On Break and Jolting on start
- :: ECS Tuning :: $50 off Street Shields | Ends: 07/26/2017
- How long before Takata air bags replaced?
- AC compressor dont start
- negative intake manifold pressure, oil in turbo intercooler hoses
- Audis are junk over 100,000kms says my mechanic...
- A6 3.2 not working in my A4... why not?
- Very rough
- Does any Audi S4 B5 parts fit to Audi A4 B7?
- :: ECS Tuning :: 2.0T ECS Lightweight Crank Pulley Kits
- Just bought a B7 A4, would love feed back
- 77000 2008 Audi Transmission Slipping
- Potentially buying A4 with TCM issues
- Audi a4 b7 1.8t to 2.0t engine conversion
- Starter motor wires melted together inside the harness - 08 6spd 2.0T
- New turbo not working
