- What hose is this, and recurring collant leaks
- Need help finding this part
- Rear and front brake discs and pads size
- Turbo problem
- UK: Audi a4 b7 2.0 diesel ticking noise help
- New 2.0 TDI Owner with questions (possibly some help)
- 2006 audi a4 2.0 quattro werid sound
- Haya needs help...engine mounts?
- Error Code Help
- B7 Oil Filter - Opinions, Please!
- 2007 A4 Vacuum Issue?
- With price of gas Skyrocketing, whats everyones thoughts about 87 gas in the B7?
- 2011 A4 TSI No Boost
- 2007 A4 6mt boost/timing issues
- Resync key
- B7 Cabriolet Upper Window Seals Help
- Audi A4 B7 BWE -06 Misfire
- Audi A4 3.2 V6 PCV Valve Replacement
- Audi A4 B7 AC no hot air? HELP
- Help finding part number/replacement
- Help! Battery died, car locked, Key does not match in door
- Audi A3 coolant leak on splash shield
- No power to drivers heated seat
- Lean issue upper rpm range under full load.
- 2007 A4 Quattro wont start
- Audi A4 climate control lights don’t turn on and I can’t use my heater or AC
- 2.0T thermostat replacement - Hey the fans came on!
- video of what i believe is turbo surging?
- CVT friction noise disappearing when gear lever is being pushed
- BRE Crank Sensor Location
- Grounding strap location
- EGR bolt size
- Hatchback/Tailgate Trim Clips
- Audi B7 1.8t quattro 6 speed clutch
- ECU cover removal?
- A4 b7 broken pipe
- 2007 A4 2.0T with engine knock
- Trailer hitch for 3.2 S-line
- 2005 A4 2.0 tfsi quattro dash/ignition problem
- UK: Bad repair job, water leaks - help needed!
- 2.0T Automatic - How can I make it shift faster?
- 2007 Tiptronic vs. Multitronic
- Need serious help
- Headlight information here....
- Upgrade headlights from Halogen to HID
- New vs. near vintage
- Expensive sounding noises
- B7 paddle shifter
- Lights flickering when starting car: b7
- Looking for help
- Help with noise
- Turbo suggestions
- What is this part?
- Camshaft noisy
- Serpentine belt is wobbly
- Headlight anomaly...to say the least
- A4 2.0T Radio issue....HELP!!!
- Audi a4 b7 2.5 v6 tdi engine light and esp on. Plus bad engine noise and lots of smok
- Acceleration noise
- DPF Pressure Sensor Location
- Can you have misfire with no CEL, I think so.
- A4 Avant B7 rear window open independentl of hatch?
- Need advice for 2008 Audi A4 2.0L Quattro
- Continental VikingContact 7 Ohhh baby!
- SI: A4 B7 QUATTRO RELIABILITY?
- P2293 Limp mode at highway speeds
- getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
- Washer pump weird problem
- Inflation Relief - Black Friday thru the end of November Sale...
- 2004 3.0 VVT solenoid locstion
- A4 2007 Issues
- scraping sound in when when slowing/braking...
- 2006 A4 2.0T - Car died at red light, won't start. Tried many things, any ideas?
- 2.7TDI Multitronic rattle during cold slight accelaration
- Torn bushings
- 2007 A4 2.0T, loss of boost with smoke in exhaust
- Rear door wont open from inside or outside.
- CCM replacement key fob
- Rain sensor alert
- NGK plugs shot after 500 miles!
- No high beams…tried swapping modules.
- Removal of Intake manifold on a4 b8 2.0l tfsi
- What do these pop-out buttons do?
- UK: Audi A4 Automatic Estate 2009
- B7 Door cap driver side
- Loud slap/knock noise
- Service! message...
- 2007 A4 locked me out/won’t start
- problem with central locking after using VCDS
- Replacing pvc valve in 2007 A4
- Multitronic, car trying to pull forward when coming to a stop
- MYSTERY PART QUESTION- SQUIRREL DAMAGE FOR SURE
- LT: Very hard vibration when in D/R gear standing 2.7 TDI Multitronic (CVT)
- Need secondary air pump 1.8t
- What is the function of this switch?
- What parts/hoses is these? Front right side.
- Damaged right front side... what parts is this?
- 2006 dies and get code P1857
- Loud tick noise
- Burned B7 looking for Parts
- Missing part
- Misfire cylinder 1
- Is a 135k mile/218k km B7 A4 worth buying?
- Rear CV boot leaking--no clamp?
- Audi A4 questions, team goh? And gecko?
- UK: Oil warning light?
- Buying a a4 DDer , yay or nay ?
- All brake lights out except drivers side outer bulb
- New around here looking for help: 2007 Audi A4
- Strange Startup this Morning, Blinking CEL and Rought idle....
- FI: 2006 brd tdi. Need help
- Need help diagnosing no spark issue ECM
- Turbo
- UK: TRIP COMPUTER AND CRUISE
- 2008 A4 cranks but doesn't quite start
- Hydraulic engine mount sensor wired inline with n75valve?
- Dealers...and cars with codes...
- Short cut?
- A4 Avant b7 relays and lift pump
- Enfig Bluetooth Installation...
- Aftermarket Pioneer double din - replacing Concert double din
- 3k jutter
- Fault codes and AC
- Convertible scuttle shake
- Have trouble
- Lighting errors
- help needed on wind deflectors
- A4 B7 swap to A4 B8 trunk
- B7 Theme music...
- Enfig website -- trojan?
- Pesky o2 ssnsor codes and intermitant randomness
- ZA: Trailer Light problems on A4
- Quick question about cluster LEDs
- A/C not working after G65 swap
- 2008 2.0T: random white smoke screen from exhaust
- CDC Symphony 2 hack?
- Replaced car Battery and CCM need remore help
- A/C compressor swap out
- UK: Total distance from a full tank?
- Camshaft Adjuster Housing Cover (Timing Chain Cover) Oh man, I gotta brag on this...
- 2008 Avant vibration in gear
- Which clips?....
- 2007 BCM HELP
- Front left and rear right wheels blocked.
- Any thoughts on Lucas?
- Power window switch...
- P2071 error code 3.2 fsi A4
- First Audi Purchase. TFSI S line SE
- 1,9 tdi issues, any ideas??
- 2007 A4 B7 Avant Quattro 3.2L V6 indeterminate oil leak
- How do I check my oil level?
- Noise from Glove Box. Dead battery
- Better Prints and diagrams with Torque specs
- Help! Alarm system...
- Little to no acceleration while driving/ Feels like stuck in gear
- Satellite Radio channel load failure
- Audi a4 seats
- RO: steam from oil cap/dipstick 2.0 diesel
- What is this part? And realllyy rough cold start.
- Radiator fan running wild.
- Timing Mark Cap Missing?
- Clutch or bad slavecylinder bleed ?
- Manual gearbox linkage variation, litle black plastic piece.
- Rust on the exhaust....
- How to choose the radio's AUX outlet?
- DEAD Battery NOISE from Glove Box
- Tank filler emergency release - where is it?
- All four cylinders randomly misfiring
- Mystery rattle found. Super service!
- Symphony vs Symphony II
- Please help!!
- Engine swap
- So it looks like my B7 A4 3.2 has a small leak in the water pump
- Replaced HVAC High pressure sensor & recharged w/ dye injection, still in/out of econ
- Oil in coolant res.
- 01336 (single wire mode) and 00470 (electrical error in circuit)
- Trunk will only open with key
- A4 Cabriolet 2008 LOCKED
- v6 3.0l coolant leak
- PRNDS but won't star
- Help please
- Audi Nav Plus DVD RNS-E
- Seat rise...
- Hood open/closed sensor question
- B7 A4 200k Mile Club!
- 2.0tdi Zero boost - Please help
- help with code P0089
- Window Regulator Torx Screw Replacement
- Wheel bearing replacement?
- Audi A4 b7 2.0t misfire
- Not OCD. I'm not, I'm not. Really.
- Audi a4 1.8t turbo compatibility
- Touch-up Magic
- How is your paint holding up?
- 2008 A4: Just bought my first Audi...and I have some questions
- AC oil leak FIXED. $27.
- Diesel GLOWPLUG
- Snubnose engine mount replacement ? 3.2l a4 2007
- Engine problem or flywheel?
- Climate Control Unit Question
- PT: Audi A4 several errors (all help welcome)
- Audi A4 B7 Weird A/C Issue
- Misfires with a ESP (traction) light
- Help on alternator clip ‘07 A4
- Radiator & A/C Fan Issue
- My 2008 A4 Avant thinks it's in reverse
- Blanking plate
- Reverse Park Sensor not working no warning beep
- RO: Audi A4 2.0T
- Timing belt tensioner/pulley noise
- Banjo Bolt
- Relay Diagram
- Dashboard warning lights
- How to remove camshaft on A4 V6 2.7 tdi
- Turbo breather coupler hose - $5.48
- Did the center mount brake light solder joint fix
- How much time to replace control arms?
- Engine Oil, 5W40 or 0W 40?
- Audi 2006 Cabrilet SLine Fof Light Grill
- Mirror puddle/entry lights installation
- Oil leaking
- 3.2 FSI Rod Knock?
- Replacing the Oil Filter Housing or Just The Seals
- Broken tail light, audi A4 B7 2004/05
- 00819 - AC High Pressure Sensor Issue
- Oil leak
- 2.0tfsi bul fuel injectors
- Tracking misfire problem
- A/C compressor will not kick in except the car's speed is greater than 15 km/h
- 2006 A4?
- Audi a4 b7 bluetooth adapter
- Audi engine Rattling Noise and white smoke when revving or starting from stop
- New oil pump, still no oil pressure
- Code p0346
- Where is the fuse for the radiator fan please?
- Rear brake caliper modell?
- New question
- How do I control the computer?
- Oil filter housing reload
- Tail Light
- Replaced my Trunklid this weekend, was easy!
- Power Steering very heavy - tried everything
- Rear view mirror
- Auto-dimming mirrors, CH/LH function, Auto lights function/ memory seats and mirrors
- Identify pipe unpulgged after some work please
- What’s this line connect to?
- Does anyone have experience of using Autopi and OBD2 port sniffing?
- Help whit installing the position of the valves in the pictures
- Stumble/Misfire@2200rpm 2006 B7 2.0T Quattro
