- Front PDCs acting up
- Which Transmission Do I have?
- Problem with Driver Information Display
- 0aw transmission problem
- Dead battery problem
- What cause this noise?
- Whining Noise Coming From Wheels 2015 Audi a4 Bb.5 CAED 6M
- UK: 2014 B8.5 CVT - whining noise on revs
- Test pipe cel
- Airbag clock spring replacement
- LT: Emission stickerv for CPMB
- Can water ruin my rearview mirror?
- AC pressure sensor?
- Well, emissions time again fellas...
- Audi fuel issues
- DTC Help + amp issues
- small crank no start Audi A4 2015 2.0t 6speed manual
- Flex fuel to non flex fuel
- Snapdragon665 Chip Android 13 8.8inch IPS Touch Screen with wireless Carplay Android
- UK: Audi A4 Engine - Whirring Sound
- Driver and Passenger Doors speakers and tweeters not getting any power
- Noise when Accelerating
- Transmission fluid and gear oil replacement on a 2011 A4 2.0
- 2009 Audi A4 Front door speakers not working
- Rattling noise from the dual mass flywheel. Gearbox issues?
- Fuel problems?
- MMI 3G OEM Spalsh screens
- Timing Chain Noise, I Think Not, but What?
- 2009 a4 2.0t oil level sensor reloacement?
- Normal wear on front brake Discs?
- Bad Sound out of Audi A4 B8.5
- DIY Custom Headlights / Taillights
- UK: Where can i get a working dipstick?
- P2015 & P0201 P0203 P0204 due to Injector Harness?
- Woke up to Warnings.
- 10 plate A4 not running up to temp
- 2016 A4 Quattro : Stabilisation control (ESC) fault! See owner's manual
- My timing chain broke on my 2011 A4
- Question on touch up paint
- 2009 A4 3.2 Quattro potential issues
- Intermittent ABS/ESP fault.
- Help - Intermittent Lean Bank 1
- Driveshaft Causing Vibration while accelerating?
- How to wire front camera to aftermarket head unit
- Which cable is the woofer cable
- Lost drive going up ramp
- Chirping/whistling alarm coming from 2011 A4
- Should I keep or trade my 2016 A4 at 90k miles?
- 2011 A4 Sedan Red on Black 90k Miles, not running: Buy?
- Carplay Interface and Android Screen for Audi A4 B8
- 2014 Audi A4 engine?
- Rotary scraping noise from N/S whilst accelerating
- RO: A4 B8 2008 (02261 - Data Medium Defective)
- Significant error codes causing LARGE issues
- Eng shuts down intermittently
- UK: P256300 code on AUDI A4 B8 Engine CAGA
- Audi A4 B8.5 (8K9) Service Light Message appears constantly after reset
- Transmission Issues on 2014 Audi A4
- A4 B8 allroad wagon premium plus MMI update
- Upgrades and Mod questions
- Recommended backup cams for 2009 A4 2.0T?
- Automatic headlights DIY
- Random dying on cold start
- 2013 Audi A4 Quattro Premium
- Audi A4 B8 Avant 2014
- Bluetooth and radio failure fix
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- Audi A4 B8 Audi Chorus upgrade
- AMI port not working
- 2014 Audi A4 oil brand
- BR: A4. 2.0 TFSI - 2011 - Falhando somente com o ar condicionado ligado
- 2015 Audi A4 2.0l tdi ultra
- rear right window swtich can't roll up the window
- Front Strut Mount A4 B8 ECD vs Non-ECD difference
- New Forgedlite TF Series 1pc Forged Monoblock - Custom Made for your Audi
- I’m looking to purchase
- Audi a4 Sline Avant Oil Consumption
- Help/Advice for my 2013 Audi A4
- MMX Wheels 1P 2P 3P & 4P Forged Aluminum Wheels Master Distributor Wheel Designers
- Brake Calipers
- A4 tdi no start after changing fuel regulator switch
- Audi A4 B8, no codes, crank but won't start
- Advice needed for upgrading car's audio system
- YE: Audi 2011 A4 2.0T white smoke from exhaust pipe
- service manual
- A4 B8 Engine Rebuild Cylinder Bore question
- ccm handbrake module fuse issue confused
- B8 Audi a4 headlights flickering
- Here’s a dealer maintenance Quote
- Any idea how much the repair could cost?
- Oil Level
- Failed engine replaced - what other things may go wrong?
- 2014 A4 transmission question.
- Rebuilding engine - what else is worth replacing this deep?
- Idle surge HELP
- AU: Suggestions for Cold Air Intake?
- Is this tire okay after puling out small nail
- 2014 A4 Quattro 2.0L needs new motor. Fun Options?
- UK: Bonnet not showing when open on Dash (low oil add 1L)
- 2011 A4 B8 - Need timing chains and have questions
- Powered Mirror Wiring - Mirror Tap Radar Detector Install
- Vibration
- Audi a4 b8 fuel rail/system pressure
- A4 B8.5 Intermittent starting Issues
- B8.5 Has 4 Fuel Related Error Codes
- '08 Audi A4 slams into 1st and reverse when stationary, stalls when stopping
- Rear left door sometimes not opening from outside
- Engine won't even turn by hand
- Issues with 2 dealers inspecting same car
- Audi A4 door lock issues
- 2011 A 4 Malfunction Indicator Lamp
- Audi AUX problem
- Audi AUX problem
- A4 B8 clutch reset
- MMi Sh!t the bed
- Re: 2012 A4 B8- Camshaft sensor connector wire colors
- Source for new AGM H8 battery?
- Multiple Misfires - help!
- VCDS Log
- What is the function of the Engine Crankcase Breather Hose?
- B8 facelift CNHA 2.0 140kw heating
- MMI 3G High HNAV K0133-3 usa software
- Audi A4 B8 AV audio set-top box HS-1100KR1V2
- Stiff gearbox
- ABS-TPMS Malfunction-Limp Mode-No Speedometer-EPC
- Radio and Display Screen not working!
- Proposed Class Action suit
- Rear Door Locks - both now not opening from outside
- Persisting Rough Idle and Vibrations After Engine Mount Replacement with Lemforder
- UK: MMI buttons, cd and steering wheel buttons not illuminating
- UK: A4 B8 MMI Screen Vertical Lines Even After Replacement
- Exhaust Sound and underboosting.
- Can Anyone Help?!?
- 2011 B8 Avant Cranks but will not start (sometimes) runs fine other times - Fuel ??
- B8.5 steering fault?
- 2011 Audi A4 quattro rear door lock
- 2011 A4 digital speedometer
- Ambient lighting install - door control modules 12v pinout A4 B8(B8.5)
- 2016 A4 Front End Replacement with 2012 S4 Parts
- 2016 Audi A4 S-Line engine swap
- Same noise after wheel bearing replacement
- Engine swap
- Engine replacement recommendations
- Top end power loss, o2, muffler delete? 5th gear for 130mph
- iD Forged 17"- 20" Japanese Inspired 1pc Forged Wheels
- UK: Flat Battery, shut bonnet
- HW on display question.
- Engine coding issues
- Intermittent Wiper Issue
- EPC MIL codes A4 B8
- start up rough
- Misfire Issues
- Ami/ headunit upgrades
- Help! Clicking from front wheel, when up on axle stands sound from middle
- 2013 A4 B8 no power issue
- EPC light with mystery problem.
- Misfire mystery.
- P0011, P0327, P0341 - 11 A4….related?
- Shaking and misfiring on first ignition
- P200200 bank 1 dpf below threshold
- LV: question
- 2010 A4 Owners Manuals - Free to a good home
- P246F Audi A4 B8 2.0 2012 TDI EGT SENSOR BANK 1 SENSOR 4 URGENT HELP
- Allroad Engine Failure at 65k miles
- 2012 Audi A4 Avant timing chain question, 79,500 miles
- Water system A4 B8
- Front and rear door speaker replacement along with back sub
- Stiff brake pedal
- Electrical Problem
- 2010 Audi A4 B8 - Steering Kunckle Taper Bushing
- Pads and rotor replacement - right parts & questions
- Transmission replacement?
- Audi B8 Grab Handle springs
- Audi A4 P0016 Code after Intsalling new chain and doing head
- Coming home without light sensor
- p0341, p2279, multiple engine misfire codes, low oil pressure warning and car cuts of
- A4 B8 steering rack replacement
- Indications of a recent Transmission Fluid Change?
- 2015 allroad started using oil at 76K miles
- Vibration when Cruise Control brakes downhill.
- Audi a4 weird noise
- Missfire under load cylinder 2
- Audi A4 8K0 awd or no?
- Bent AC line
- Green Screen menu, aftermarket navi
- No heat + exhaust gasses in coolant
- Broken power folding mirror motor?
- BCM issues?
- Oil Pressure sensor install?
- Suspension fault
- A4 B8 TFSI Fuel Injector metal clip holder
- A4 B8 Intermittent Starting issue
- 2009 3.2L Timing Chain
- HELP: AMI Bluetooth and Microphone Interface (09’ A4 Quattro B8)
- Knocking sound from the front suspension
- Unknown connectors! Help!
- Light Switch
- A4 - rotational vibrating noise
- 2009 Avant camera installation
- A4 Oil Consumption repair/audi care warranty
- Long Block Engine code, Engine Serial Number
- Audi a4 bcm problem
- Help
- Audi A4 Avant B8 Terminal 30A/30B voltage
- A4 B8 SOUNDS like over revving but isnt!?
- Engine mounts bad?
- SE: 2.0 tdi Oil pump drive
- 2012 Avant wheel offset question.
- Magnetic Camshaft adjuster connector pins
- 2012 A4 Avant shocks
- Need advice!
- A4 MMi version info struggle
- Door lock pins
- Oil press gauge wiring?
- Cant open driver door from outside
- coolant temp sensor connector P/N B8
- SE: Remove oil pan 2.0 tdi?
- BG: A4 B8 auto hold problem
- Change Diff Fluids?
- Ticking noise from engine
- 09 A4 Avant B&O speakers - No Sound
- 2015 A4 Quattro - Fluid Service
- Audi A4 B8 2.0 TDI 2009 CAGA Fuel consumption problem
- Audi A4 b8 2010 - 2 Litre TDI - Rough Idle - Pulsing
- Troubleshooting MMI 3G
- Audi A4 B8 stalled after cold shift on incline
- Program key fob without physical key?
- UK: 2.0 TDI CAGA ENGINE - Replace Valves - HELP Please
- Audi a4 b8 avant problem with rear wheel bearing
- A4 B8 code 01518
- Weird popping sound on b8 1.8 tfsi 2008
- Heat not working
- HELP - Adapting ESCL after Engine/Transmission swap
- B8.5 3.0 tdi inconsistent alternator
- A4 quattro Vibration from the centre of the car
- Audi A4 B8.5, turn indicator stopped flashing and unable to be turned off.
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- 2012 Audi a4 ko4 turbo/engine rebuild
- BG: TPMS and Eipers fluid tank lamps
- Lock chirp and interior lock indicator light
- Yellow engine light + possible oil leak,"?
- Potential new to me audi
- Erratic idle when engine is warm strong gas smell dumping in oil
- Help me understand S-line
- ES: Oil in cylinder #4 - 1.8 tfsi
- A4 b8 xenon headlight problem
- Engine does not start but belt spins.
- Audi a4 2014 tfsi CDNC engine
- B8 MFSW station change
