- GR: rear wiper-servise position?
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- 2019 Allroad A4 FOB question
- AR: Audi A4 B8 Allroad 2.0Tfsi Fan problem
- 2013 A4 allroad jerking
- 2014-2015 Allroad purchase
- RS: New Audi owner with huge problems, TDI
- Minor Rear end 2021 A4 - worth repairing? Got very high quote..
- Power Steering control Module failure
- USA: Naive question and a replacement part!
- getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- UK: Car chucking but not losing power going on 14 months
- Left Low Beam Headlight - 2014 A4 Quattro
- 2010 Audi A4 2.0T, Quattro (B8): Fuel Injector leak & Compression Testing
- Reboot MMI
- 2013 Audi Allroaad dyi brake job video
- SE: Excessive oil consumption 2.0 TDI
- Audi a4 b8.5 1.8 tfsi body (vs) B8.5 3.0T V6 Body
- IE: Audi A4 headlight bulbs colour?
- 2013 A4 Quattro Premium Plus Tuning
- American message board members.....
- Stains/chemical spill on the fender flare, can it be restored?
- Greetings from SuperSprint Italy
- allroad headlight leveling
- 2016 Allroad - Engine Rattle?
- 2015 Allroad completely dead! Help :(
- Error on MMI update: Media and Nav out of order
- 2013 A4 Premium Plus, purchase?
- 2014 Audi AR w/80K miles?
- Check Engine Light
- Groaning Noise
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- 2014 Map Options? (New Owner )
- 2014 Allroad BT calls issue
- Engine auto-turnoff when opening the door.
- Just bought my first Audi...
- 2022 Launch Vagcom scan tool
- Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
- A4 B8 2009 Oil Leak & Serpentine belt snap
- Another Audi added
- Heated Steering Wheel Retrofit
- MMI not showing ( mirrors fold problem )
- NL: A4 Allroad B8 P164B00
- Allroad Front Rear Lower Control Arm Bolt Removal Problem
- 2013 allroad oil level shows no info on oil level
- Front and Rear Caliper Torque Specs
- Bluetooth module
- 2015 AR w/175k
- Valet Key/ Emergency Start Case
- Info on liftgate replacement cost
- 2022 A4 prestige same as A5?
- 2014 Audi A4 is leaking coolant and not overheating
- Steering Judder help!!
- Audi A4 2014 2.0 T EXCESSIVE oil consumption
- About to pull the trigger on this wheel and tire set... Thoughts?
- Help with Misfire on Cyl 4
- Black goo on side of engine
- getAudiparts.com | NEW Genuine Audi Dynamic Center Caps Sets!!
- Question about 2015 allroad 93K miles
- Flywheel and clutch replacement
- Steering doesn't want to stay on center
- Codes Thrown - Specific Circumstance
- 100k Maint, poly bushings?
- 2016 Allroad Coolant Tank leak
- 2014 allroad Auto window not working
- Looking for Allroad looking for groups advice.
- Audi A4 Allroad 2012 MMI fault
- How to get bluetooth music
- 2013 Audi A4 Allroad?
- Water in footwell
- Brake bulb not working after changing to a new bulb
- 2009 Audi A4 B8 - No dash and no ignition no start.
- 2016 Allroad \side view mirror issue
- Catching up (maintainence question)
- Pet Barrier for 2020 A4 Allroad
- getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
- Roof Rack Windscreen Options
- 2014 Audi a4 Allroad: emergency brake light on and car won’t turn on
- UK: Oil level check?
- Electrical issue 2014 Avant
- getAudiparts.com | Genuine Audi Floor Mats Sets!
- 2014 Allroad window issue
- PL: largest All Terrain tire size possbile?
- 2014 A4 B8 allroad 158K miles = new engine
- more oil consumption....
- Steering rack extended warranty
- ‘13 allroad
- 2014 A4 keyless entry antenna location
- 2013 allroad suspension
- OBDeleven Coding for Brake Pad Sensor
- Unable to lock/unlock car from myAudi app.
- getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
- AdBlue 0miles now wont start! HELP
- How to Tune-up your Audi A4/s4 b8/b8.5
- A4 Allroad 2012- a few bugs?
- B8 Allroad 2.0 TFSI 225 S-Tronic - Adaptive Damping?
- I might as well introduce myself.
- 2014 Premium allroad cruise control ....brakes or transmission on LONG downhill?
- 2015 AR Prem Plus w Tech & Sports Value?
- Audi A4 S-Line Front End Ticking Noise
- AWE Black Friday 2020
- A4 Hitch installation and bike rack.
- Higher Mileage Allroad worth it?
- 2013 A4 iPhone adapter
- Trailer hitch wiring
- 2010 audi a4 140,000ks
- ZA: 2013 Consistent engine idle issue when car stops
- Who did not replace the timing chain and tensioner?
- Left headlight high beam all the time
- S5 Steering wheel into A4-Allroad?
- Service Due Reset
- Introducing OEM Folding Mirror Packages...
- Windshield Replacement
- New Allroad owner
- IT: aiuto per acquisto asseto/ammortizzatori
- FR: A4 3.0 all road 2011 RHD to LHD
- Prices paid for used 2014-2015 Premium Plus
- 2014 allroad purchase advice
- Having trouble starting engine
- Dynamic side mirror turn signals 2013 allroad
- 2015 Allroad - 41k Miles, P0236 That Audi Can't Fix
- 2015 Allroad Burning Oil
- Oil Consumption anyone?
- Need weel math help...
- AUX input
- 2013 Audi A4 Wagon motor issues
- Oiled media: This helped my Audi A4 b8.5 run better
- Allroad Towing capacity
- B8.5 Allroad Content! Lowered riding on 20" RS5 Black Optic Wheels
- A4 2020 sedan set time
- solowerks and wheels installed
- NL: Enabling folding mirrors in green menu?
- Key window opening and closing setting
- 2014 Audi Allroad Engine Fault Code
- Timing Chain/AoA/Recall
- We Build Faster. Shorter lead times on AWE Exhausts.
- 2020 Allroad
- GB: Audi a4 avant b8 2009 few little problems
- My Audi frequently notifies Oil is low but I can’t visibly seem to see any leaks
- 2014 Allroad issues to watch for before purchase?
- AWE's Annual Holiday Special Pricing Event Starts Now.
- 2014 - 2016 Allroad
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- Audi A4 not recognizing when it’s in park. Key stuck in ignition
- AWE BLACK FRIDAY 2019 STARTS NOW.
- Front lower curved control arm wearing or bad?
- 2013 Allroad - High Oil Consumption
- Seattle area repair recommendation?
- '14 B8 allroad - stalling and HPFP
- Delay in shift from Drive to Park
- Best Audi year, engine and model?
- i'm korean. i need your help~ (a4 b8.5 alram horn)
- '14 allroad on a 600 mile road trip to Waterfest...
- breakpads and rotor suggestion
- '13 allroad - Replacing blown DRL?
- Power to heated O2 sensor
- Key programming
- 2019 Allroads availability
- Ring / Spring Inside Gas Cap?
- Fuel Filter and Pump 2013 ALLROAD, Flex fuel
- P 2293 2013 ALLROAD
- 2015 Audi A4 quattro premium plus - General question
- 2013 Allroad / broken wires @ tailgate hinge...
- High Mileage - 160k
- Rolled over 50k miles yesterday, so did an oil change
- Am I missing something
- $430 later, my less than 50k mile '14 has a new LF wheel bearing...
- 2014 Audi A4 Quattro - US to Euro taillights
- Need: Best Low Cost Upgrade for Base Headlights
- OUTLAW ALLROAD THE BUILD
- CV Joint
- Headlight aiming
- AWE Annual Holiday Special Pricing Event
- Not impressed in the least - got backed into yesterday... :(
- 2013 Allroad is misfiring
- INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
- Europrice.us Black Friday Deals are almost here...
- Please help! Need the name of this part.
- New to Forum, New to Audi!
- 45,000 mile oil change + air filter
- Two Extended Warrentys from Audi
- 2015 Allroad
- getAudiparts.com | Genuine Audi Collection Key Rings!
- Air bag and adaptive headlight warnings on dash
- Maxton A4 lip fit the mallroad?
- Audi Roofbox
- 2009 A4 sline
- Yes, you read correctly! We now have footwell LEDs for every single Audi model/trim o
- 2013 A4 Turn Signal Issues
- Performance Tuner
- 2013 Audi Allroad... VCDS Scan, my next headache adventure
- Carbon Buildup - S4 3.0 SC
- The case of the missing Allroad
- Looking at putting on a grams 70mm throttle body on
- Oil pump audi a4 09
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- Replacement Air Filter? - 3.0 Quattro
- 35k mile service recommendation for $2,580. Is this normal?
- getAudiparts.com | Genuine Audi LED Puddle Lights Sets!
- getAudiparts.com | Genuine OEM Audi Parts + FREE SHIPPING on Most Orders $299+!!!
- Cant see my fuel usage
- Help deciding
- Best place to sell my 18” OEM S-line wheels
- Newbie Audi Owner Extended Warranty??
- Electric Seat Motor & Switch
- Hot Dang, Deep Wells -- Spark Plug Socket Recommendation...
- 2013 Allroad 18' vs 19' Wheels
- Strange knocking from passenger / rear over sharp bumps
- Extended Warranty Recommendations
- Gain a peace of mind by protecting your vehicle’s interior
- 2008 Audi A4 2.0T Quattro
- Is your car truly luxurious without these?
- Received my recall notice for Aux heater
- Brake job cost? Indy vs. Dealer?
- Question about the red LEDS in the dome light assembly
- Winter mode - engage!
- RS style pedals?
- Lean Running '15 allroad - Need Expert Help
- Reverse Light and Ground Wire Color 2015 A4
- transmission oddity
- Check out our LED upgrades
- Pirelli Cinturato P7 A/S Plus Tires
- MAJOR COOLANT LOSS
- Disappointing MPG on TDO Tronic (175bhp)
- Bluetooth Options?
- ***WannabeRacer.com | Boston and New Jersey Vinyl Wrapping Tour***
- Looking for wheel package
- AudiWorld's latest project car- a B85 allroad..
- Driver's window auto-down stopped working, fixed...
- picked up a new to me '14 Premium.. Ibis White on black
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - Aug 28th - Sept 4th, 2017***
- Gray Interior
- Any real change from 2014 to 2016?
- NGK spark plugs
- New tires for my Allroad
- heavy vibration on hard acceleration
- Thinking About an Allroad
- Extended Warranty
- Painting Cladding in Aftermarket?
- Anyone with 19" or 20" wheels AND stock suspension?
- New to me allroad and sport package w/o black headliner
- Audi A4 Limousine 1.8 TfSi Pro Line Error Codes
- Carpet floormats
- Phatnoise in 2012 A4 AllRoad with MMI 3G
- Google Earth display in Canada
- audi quatro tyre wear ?
