PDA
View Full Version : Inline-5 Discussion
Pages : 1 [2] 3
  1. PA: parting out 90' 2.3L non-quattro
  2. Anyone have a 10v NG throttle body for sale??
  3. New Inline 5 TDI Bluetec engine.
  4. Tensioner Bolt Broke.........
  5. Compatability ???
  6. 20vt 3b
  7. Not Charging
  8. RS2 turbo or K26?
  9. 20vt problems! need advice
  10. 3B Valve Guide Question
  11. Eurovan "Big Block" question
  12. my 200 has a hard start help please
  13. 92 S4 Stripped plug hole in head>>>HELP!
  14. EFI possibilities on the 2.2 litre motor
  15. 20V water manifold alternative options?
  16. Visited 034 motorsport last week, headed over to Laguna Seca with them for the Audi Event (vids)
  17. Looking for some experience with a 10VT rebuild...
  18. 10V motor
  19. I have to ask
  20. Differences in short block assemblies between MC1 MC2 and AAN ?
  21. opportunity to swap
  22. stock boost for 200 sedan
  23. forged pistons
  24. oil leak after doing timing belt 4000s
  25. 91 Help
  26. 86 4kq NON turbo Fuel adjustment amps 19.95mA unable to adjust
  27. Anyone got a lead on a reasonably priced 3B or AAN in the NE?
  28. 7A 20v sensors?
  29. loud fan-like noise when rev-ing once car is warm (not fan clutch)
  30. Bleeding clutch cylinder
  31. I know its prob a repost but why didn audi ever mass produce the 25v head?
  32. low voltage to fuel pump?
  33. heat sensor help please 1988 80Q
  34. EFI swap
  35. Parting Out 86 5000 TQW?
  36. Is there any sort of FAQ diff website, or anyone wana school me....
  37. 87 5000 fuel system
  38. need advice on removing starter from '88 90 Q i have searched the fourm and no luck
  39. listen to this s2 snow drift
  40. (Cross thread) Does anyone know if a JT Head will bolt up to an AAF/ACU Block
  41. 5000CS Turbo - Cables, Wires, Etc. Need Help!
  42. Large-Bore MAF now running on a 20v 7A engine!
  43. CNC'd 20v intake flanges
  44. 10v to 20v
  45. Posted back on the 3rd looking for this. Found it, not sure if you've all
  46. Question about NF engine code...
  47. Newly Acquired 1988 5K TQ...info and helping hints?
  48. Chipped AAN I5 20VT with wiring becoming available soon
  49. Entire 2.3 from 89,audi 90Q, UT
  50. Need new engine
  51. Help, anyone have the link to the video of Javad's 80 on track with a
  52. 1991 200TQ 20v - missing ring gear teeth
  53. Audi 90 20v Parting Out
  54. Aumento de potencia
  55. hey guys i got an oddball engine for you
  56. mc2 swap wiring questions
  57. 2.2L Internals question
  58. audi 90 1990 20v question
  59. New 20v owner!!! Questions!
  60. 200 Vaccuum hoses HELP PLEASE!
  61. Will stock turbo ('93 UrS4) bolt up to RS2 Manifold? Driveability issues and other RS2 questions...
  62. Differential Pressure Regulator question
  63. help with 1991 audi 90
  64. Rebuilding 20VT engine.... I'm new in this forum and know nothing about this engine...
  65. how bad are these? pulled the head and!!!!! fixable?????
  66. Head gasket work
  67. 2.3L 10V ALTERNATOR BRACKET NEEDED!
  68. Help with t. belt change on 1990 2.3 lit. 10v engine
  69. 88 audi 5000 cs quattro
  70. 88 audi 5000cs quattro
  71. Good compression for a 7a ??
  72. 200TQ 10v Chip Options
  73. what type of motor comes in a 88 5000cs quattro is it a 10v 20v?
  74. 88 5000cs quattro will not stay running if rpms drop[ under 1500
  75. Clearance or Interference Engine?
  76. 10v 6th injector mod?
  77. trying to ID a 10v
  78. Audi 90 - Do oil and water mix?
  79. JT-interference or not.............
  80. MAC 14 wiring harness question
  81. air filter location
  82. Tuning options for 10v I5? STFA....not a whole lot of luck
  83. Performance Clutch Options??
  84. I5 (NG) - Which way does distributor/rotor turn?
  85. Large-bore MAF conversion for the 7A 20v (x-post)
  86. MAF testing on 7A
  87. Best chipset for stock 1994 S4
  88. ECU Response
  89. Long Term Engine Storage
  90. Return of the 5 cylinder.
  91. idler pulley/roller
  92. I desperatly need an expansion tank for my '83 URQ
  93. Best Spark Plugs for 10V engine no turbo
  94. Sad, orphaned Bentley manual needs a 5000 to love.
  95. New Audi Parts !!!
  96. thermostat on 87 audi 4000qcs
  97. X-Post: TAP Stage II Chip Upgrade For Sale
  98. EGR Valve
  99. 92' S4 Q will not re-start
  100. Fuel/Air mix issues on 10v 200
  101. CQ 7A fan issue
  102. 7a piston rings
  103. All parts for 90 Sedan 20vQ for sale
  104. Anybody got Javad's email address..I cannot find it. Thanks
  105. opinions about bypass vlave's on 3b's
  106. Audi Expo 2006 - Come be a part of history again!
  107. looking for a blau-sport 272 cam...
  108. 83 URQ turbo removal and install
  109. RS2ing the 3B: running problem solved
  110. I5 Guys, Advice on Swap!
  111. RS2ing the 3B: running problem (long)
  112. Audi Expo 2006 - It's coming!!!!
  113. 3B, AAN, or 7A(compression dropped) for Coupe? and Why?
  114. Is converting 10v to 20v an easy task or a real SOB? Is it recommended?
  115. what are the pros and cons between the 20v and the 10v for the I-5
  116. loss and gain rpm
  117. Hydraulic lifter noise
  118. Do any of you guys have an MC2 flywheel laying around you'd want to get rid of?
  119. Just wondering if it is possible,
  120. Help...Non starting 1988 Audi 90 Quattro. ECU, Fuel Distributor?????
  121. CIS question, anyone?
  122. 10v coolant question
  123. AAR engine spec?
  124. Its alive!!! X-Post
  125. 10vT complete motor assy. for sale . 4kq or CGT bolt-in
  126. It breathes!!! X-Post
  127. Forged insides???
  128. 5cyl 20vt motor
  129. CIS question
  130. unsteady idle and vaccuum
  131. Audi 5000 Turbo Quattro Performance??
  132. Word of warning on TB changes for 20V engines....
  133. Torque Steer reduction in CGT with turbo
  134. 20v problem plz help
  135. Upgraded alternator - which one fits?
  136. Coil
  137. Having difficulty with timing belt on AAN
  138. Audi Expo 2006 - June 24th
  139. what's the most power a 10v 5cyl turbo can make .. stock hardware mostly (internals and turbo) ?
  140. trying to find out what head this is from....
  141. X-post 10v N/A Ng engine q-s TIA
  142. 20v intake flange finished
  143. 20V 2.6 Quattro Coupe Turbo Conversion
  144. A1crankshaft
  145. 2.3 NG - can't get it running after changing injector seals.
  146. 10vt, and 20vt idle difference...
  147. Engine problems
  148. Need a quick lesson please
  149. dropping c/r on an NG....
  150. so i am thinking of getting a mc1 or mc2 engine for my 4k where should i look for a
  151. NF performance - ddg "You need a cam BAD!" (or anyone else)
  152. engine light
  153. Which timing belt/components?
  154. Need advice on what might be wrong with my friends Ur-q
  155. JE pistons
  156. any info on supercharger setup that may work for a 7A coupe?
  157. found out what that ugly noise was (unusal I5!)...
  158. Audi 200 flywheel/clutch into Audi 4000 turbo?
  159. Inline 7
  160. Need advice on what clutch to use for turbo swap
  161. oil temp reach 130'c!!
  162. Looking for a machine shop in Chicago area for head rebuild...
  163. '93 S4, 206K miles, not making power til 2k rpm, what would you all suggest to remedy this?
  164. no power above 4,800 rpms...any ideas?
  165. Anyone have a dyno for a stock or lightly moded 7a...
  166. 7a intake runners???
  167. Valve cover gasket for a 7A, question
  168. Are some exhaust gaskets bigger then others??
  169. Anyone know where to source 20v n/a tubular headers?
  170. C.R of 20v head on MC2 bottom end ?
  171. Port and polish question...
  172. mc tune up
  173. Diesel 5-cyl?
  174. We here at the I5 Developement forum are slow yet we advance towards I5 supremacy.
  175. who sells good mild to mid cams for the 20v
  176. Anyone used Engine Analyser Pro for I5 20V?
  177. Anyone built 20V 2.5 N/A yet ??
  178. Now this is how you represent 25 yrs of quattro
  179. turbo 5 into B5 A4?
  180. AEM Update... X-Post
  181. Cheaper way to do a 20vt swap
  182. Audi 100 engine
  183. What type of standalone management do you guys run?
  184. hesitation in 1st
  185. NG performance
  186. FUEL LINES
  187. Fuel Distributor Frequency Valve Adjustment?
  188. Possible?
  189. Audi 100 2.3 Fueling Problem
  190. does anyone have an mc2 fuel dizzy they dont want?
  191. where to buy JE pistons?
  192. What's the difference between a 3B & AAN engine?
  193. Anyone have a busted NG head ?
  194. question about megasquirt on mc, and tps sensor
  195. anyone ever do a k24/k26 hybrid?
  196. Bigger radiator for 4KSQ Turbo conversion?
  197. I5 20vt EM..............
  198. Hey Koop, saw this thread you replied to awhile ago...
  199. 90Q turbo guys, did you use the stock radiator?
  200. Looking for an Exhaust Manifold for a 20VT Engine
  201. I CANNOT BELIEVE I JUST GOT TO DRIVE AN AUDI SPORT QUATTRO!!! (pics added)
  202. 5k 10v turbo into '90 CQ
  203. Does anyone know the compatibility of the MC-2 and a CQ flywheel...
  204. Somebody on here posted about removing their A/C from their B3 car. Interested in selling the parts?
  205. 5th Annual Audi Expo - Schedule:
  206. mod wise:pro's and con's of 10v vs 20v?
  207. 9 days 'til Audi Expo! - Have we heard from you ?
  208. Why did the 20v I5 turbo have such a short run?
  209. holy moly
  210. Fixing Lifter Clacking
  211. what does it mean when i rev and then it drop below idle rite after and stalls
  212. my MC1 to 4000q swap update
  213. paging uberaudi, email or IM me
  214. Just a follow up about my block question
  215. MC1 + Coupe GT = fun!
  216. Sponge's 91 200tq 20vt crazy mofo turbo project
  217. Anyone had a NG or other 10v head rebuilt? How much was it?
  218. 90q turbo conversion flywheel questions..
  219. Looking for a spare MAC-14 if anyone gots one...
  220. Compared to an MC swap in a 4kq, How much difference with an MC into a CQ?
  221. This is driving my NUTSSSSSSS HELP PLEASEEE TECH GUYS
  222. Five Cylinder Audi Quattro Wanted (still)
  223. MAC11 computer/harness with MC-2 engine..
  224. Engine blocks....
  225. 7a tubular exhaust headers...
  226. What turbo should I get ? RS2 or K24?
  227. 5th Annual Audi Expo - Come be a part of history again!
  228. Injector Cross Ref. ?
  229. anyone turboed a 7A?
  230. i want to remove my A/C can anyone tell me how hard this is?..
  231. 20V turbo question>>>
  232. K24 vs K26 turbo
  233. I need quicker spool up in first gear....in my 885KCST Auto...
  234. what is the difference between the 5 cylinder crank shafts?
  235. does anybody have the specs on a 10V turbo cam
  236. Tubular Manifold and GT 35 R Installation... LONG X-Post
  237. sort of a broad ? regarding 20v's
  238. Question about RS2 injectors
  239. 20vT bolt up to FWD audi tranny?
  240. is there a FAQ on the different 5-cylinder engines? Used the search but no success
  241. KX block on boost...?
  242. 85 CoupeGT won't rev over 2k after warm up
  243. 5th Annual Audi Expo! - It's coming!!!
  244. Is it possible that font end hit could bend an end of a crank, where the pulley mounts on?
  245. 20vT wiring diagrams..
  246. 10vT engine swap for B3 90 1989 20vQ
  247. Question regarding engine mounts x-post from the 4000 forums- <DDG>
  248. I'm going through Motorgeek withdrawals...
  249. Vancouver Audi meet - Apr 23rd
  250. 93 Eurovan head options
