PDA
View Full Version : Inline-5 Discussion
Pages : [1] 2 3
  1. 1986 CGT surging/cutting out under load
  2. JT to a 01E swap question
  3. Urquattro 6speed conversion
  4. Swaping fuel injection
  5. 2.3 NG compression ratio increse question?
  6. 2018 TTRS P2015 code
  7. 7a pistons in an NG engine
  8. Need info dump
  9. 86 Audi 4000 Quattro engine cuts out during driving
  10. Audi coupe got special build
  11. 2.2 10v with 2.0 16v vw efi system??
  12. Audi 90 b3 2.3L 10v inline 5 possible broken cam
  13. Need help with a build idea. (10v)
  14. Inline 5 swap 944
  15. What are engine sizes for old Audi 5 cylinder engines?
  16. help identifying my ECU Pin-Out,
  17. Audi S2 3B camshaft jounals
  18. Audi 100 C3 2.2 KZ engine sensors placement
  19. Audi 90 Quattro transmission noise.
  20. Audi engine codes and part numbers
  21. Metallic sound above 2500rpm when warmed up
  22. Installed new lifters, still ticking
  23. Serious backfire, shaking idle, engine goes out??
  24. 1987 mc1 turbo cuts out on accel
  25. 92 Audi 80 B4 Hard start
  26. Aan melted head
  27. 87 5000cs starter removal
  28. Need help getting a 2.2 Turbo swap running
  29. Parting out audi 90 1990 quattro 20v tornado red
  30. 10v to 20v Swap
  31. 4000S quattro hard to shift. Please help!
  32. bad fuel pump?
  33. Help, my 91 audi 80 keeps dying
  34. Torque Specs??
  35. 1991 200TQ Alternator issues
  36. low compression?
  37. 2.2 Turbo - newbie - versions, block, limits
  38. NEED HELP WITH COUPE GT!
  39. 1985 5000 KH turbo
  40. 4000CS 07K Swap
  41. Air Intake Pipe Repair
  42. fist post and tech question....
  43. BPR6EIX vs. BP6ET in Turbo MC2 2.2 engine??
  44. clutch-problems
  45. best l5 for kit car
  46. Help...running extremely rich
  47. Spark plug and wire options for 10v turbo
  48. engine swap
  49. Hello all, in need of help with the control pressure regulator
  50. interference engine?
  51. Audi I5 In a Lancia Delta.
  52. Have question about Audi Grille Please Help!
  53. injector question
  54. 20V power steering system capacity?
  55. help!!!!
  56. 2.3l Turbo Conversion: Possible or No?
  57. 2.5L AAF better exhaust manifold
  58. Audi 5000 turbo on LPG, more boost
  59. Oil Pressure Gauge
  60. 1990 audi 100 just won't run right
  61. Audi 10 Valve Header
  62. 1988 90 misfire (tips on replace plugs/wires/distributor)
  63. 2.3 distributer can't get it out heeeelp
  64. 20v swap
  65. Audi 100 1990 NF engine cold start issues
  66. engine won't start
  67. 1985 4000S Quattro running poorly
  68. 1990 Audi CQ Running Rich
  69. Nasty motor problem
  70. WANTED: Audi Coupe 2.22L Motor (KX)
  71. b2 motor question
  72. Need help...weird ticking from intake manifold/
  73. inline 5 20valve motor
  74. s4 crankshaft
  75. 1989 100 valve clearance
  76. KW 5 cylinder engine block
  77. Help What Did She Do???
  78. 1991 2.3L valve tip height question....
  79. 4K turbo thoughts and ideas. Digifant conversion, turbo NA I5 engine.
  80. APTuning/APR December to Remember Holiday sale!!!
  81. 4K Q turbo swap
  82. Location of check valve on 1988 B3 please...
  83. pulsing idle NG engine
  84. 1990 Audi Coupe Quattro Project
  85. i5 swap?
  86. 86 4kq timing belt, h2o pump hints
  87. aan interference.. how bad??
  88. 710N Diverter Valve
  89. Will an 81 2.1L head fit on an 85 2.2?
  90. 1990 100 Head Ticking Like Crazy
  91. Audi R5 20v 7A einzeldrosselklappen.
  92. Real boost only above (exactly) 4000 rpm?
  93. Interest in 2.5l Eurovan Shortblock
  94. *Revo Technik continues to expand its authorized tuning network with 4 new dealers.*
  95. Fuel pumps
  96. I need a vacuum diagram
  97. Importing Audi RS2
  98. Idle Up and Down
  99. What else could appear to be a rear main seal leak?
  100. Stebro exhaust for S6
  101. Inline 5
  102. 85 GT Coupe
  103. 100 Starter
  104. Anybody here know where I can see pics or spec's on the new 5cylinder engine...
  105. anyone have any experience w/ NGK pfr6q in an MC?
  106. 86 Coupe GT Timing belt
  107. 7A Troubles!!! HELP!
  108. GT Turbo group buy happening on the UrS forum, figured some of you might want in!
  109. Feeler For 10V (and 20V?) Vac Pump Block Off Plate...
  110. Went to go Seafoam my car today (20v question)
  111. would a bypassed FPR on an MC2 (1989 200) cause damage?
  112. Detonation damage in a '93 Eurovan 2.5L engine Update
  113. Clutch Pedal on 20v Turbo
  114. 10vt upgrade.
  115. Car Loans
  116. Exhaust manifold options for Eurovan?
  117. Detonation damage in a '93 Eurovan 2.5L engine
  118. Firing order question
  119. Hi! I have problem with idle after going past 3000rpm it drops to 0rpm and stalls!?
  120. WTB: Used pistons for a '93 Eurovan AAF engine
  121. Fast Idle on '91 2.3 Liter 5cyl Fuel Injected
  122. 85 GT Coupe Exhaust Manifold
  123. Best Place to Buy 20v/20vt
  124. Head Swap 10v/20v
  125. 20v gettin there
  126. 2.3 10v Running lumpy
  127. Trying to sell a 1998 (81,000 miles) A4 V5 1.8 T (cloth, premium sound, 5 speed Manual)
  128. does anybody know of an all wheel dyno in the MA, RI area?
  129. valve cover gaskets 7A
  130. cylinder head 10v
  131. Is there anyone here with experience rebuilding a 7A?
  132. 91' 90q20v 7A Help
  133. MAF to turbo inlet hose
  134. anyone have a short block they want to part with?
  135. can i get as much info as possible on the k24 turbo, the good and bad and overall specs
  136. Was just given an '89 Quattro Sedan with the NA 10v
  137. What is a running AAN engine/harness worth?
  138. Inline 5
  139. '89 200 10v head job...valve cover gasket?
  140. 2.5 vs 2.2 ??
  141. brake booster 1994 s4
  142. Will this chipset work for my car?
  143. 034Motorsports Campaigns the 20vt in the Castrol Top Shop Challenge. Results inside....
  144. AAR 2.3 timing
  145. how can i connect air/fuel ratio gauge to 3B 20vt, i got one wire from gauge?
  146. 3B DISTRIBUTOR IS NOW OBSOLETE AND NLA
  147. anyone know a good resource to get a full engine gasket kit for a 3b?
  148. Timing Belt Flapping in the wind like my jewelry w/ out a jock strap while running.
  149. mods=bad idea :)
  150. Two piece exhaust manifold MC2
  151. Jonas, you on here?
  152. urs4 k26-to4 CHIPPING???????
  153. exhaust question, need help
  154. help
  155. removing K24
  156. smoke on boost!!!
  157. Spewing oil from passenger front....Cooler?
  158. TURBO HELP!!!
  159. Need Help...
  160. 2.3 10v ideas
  161. 2.5 AUDI PETROL 5cyl SIEMENS SIMOS NO HT !!
  162. i know i know it, but what is the '91 20vt engine code?
  163. 1990 Audi 200 Turbo - Inexplicable oil pressure drop after idling
  164. posted this on the 200 forum too, but, were all '91 200TQ wagons 20V motors??
  165. NG upgrades of engine swaps for 87.5 special build coupe
  166. are RS2 intake manifold a direct fit onto a 7a?
  167. Hollowing out cat on '91 20v...
  168. In/Hg Vac reading where should it be?
  169. 95 S6 won't run
  170. New 20v Exhaust Recommendations
  171. programmable ECU
  172. any tips on the removal of the turbo manifold on a '88 5000CS Q?
  173. cross model compatibility
  174. Quick Question
  175. changing water pump 91 Audi- non-quatro
  176. 20V Oil Pressure Sensor
  177. 7a 3b cams
  178. Coolant warning light.
  179. Repair harnass for multi function temp sensor?
  180. Looking for a 7A Valve Cover..
  181. 20v Fuel Lines
  182. 20v Fuel Injector Help!!!
  183. [POLL] Going to redesign, maintain, and update 20v.org >>> need some opinions on new domain
  184. will garret gt35r fit the RS2 manifold???
  185. stalling out in gear, but idles great
  186. Anyone got any handy tips for putting a 2.2L Turbo from a 5000csq into an 80q?
  187. anyone in the central jersey area have the crank locking tool 2084 i could borrow?
  188. Minor Engine Problem
  189. Dark Coolant
  190. Strange 'No Start' after timing belt change
  191. Noob Question... 3B vs AAN
  192. KE-Jetronic III Potentiometer of Air mass meter for Audi NG, AAR 2.3l
  193. HELP!! Massive fuel from single injector during fuel pump start
  194. intermittent very low rough idle...
  195. 1991 Quattro 20V Anti-theft system won't let me jump start
  196. lean and misses at low rpm
  197. fuel dizzy leaking slightly on 87 5kt
  198. Inline 5 in new TTRS
  199. Install a cone air filter on '90 Coupe 7A engine
  200. Service Interval for 91 100 inline 5 timing belt change?
  201. What is a '91 20V turbo engine worth with about 100K miles?
  202. Engine weight inquiry?
  203. on top or on bottom? urs4 stage1+ 2bennett chips
  204. How to remove threaded piece from engine block (oilfilter thread)
  205. inline 5 220k motor still need premium gas?
  206. An SL Engine?????
  207. Is the NG head a direct bolt on to my KX motor?
  208. 7A Engine Oil Cooler Sandwich plate
  209. Hey Nate.. or max.. or dan..... @ 034... (7A Turbo Update?)
  210. What should the maximum rpms reached on a 10v motor?
  211. Paging : Alex@Europrice ...
  212. testing
  213. KX motor update any ideas?
  214. '85 4000S Q hose connection
  215. KX motor wont rev past 3800-4000 RPM, imput please.
  216. FS: Part out on a 875000cs WAGON
  217. anyone have a good shape KX head?
  218. WE and JT head swap
  219. in need of a cheap WG
  220. engine head swap
  221. Audi #2079, #2084 tools + fuel filter on ebay
  222. Looking for a wrecked '95 S6 or...........
  223. ISO audi 200tq or similar project <1000
  224. Car won't charge battery and won't take a jump? Help Please!
  225. hello, need a little help with my MC-1 K-26 Turbo assembly ***Solved***
  226. Central Locking Failure
  227. DIY 20 V T timing belt replacement
  228. where are best places to buy stage 1 chip for AAN 20vt? TIA
  229. engine parts swap
  230. Car not running issues..
  231. APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
  232. AAN swap mated to an 016 (4kq) tranny; What clutch to use?
  233. 10v turbo
  234. I need help with car accelerating by itself.
  235. Low oil pressure sensor location?
  236. 10v turbo in a 4000Q
  237. 1990 200 quatro inline 5
  238. 7a manifold
  239. Audi 100 Quattro spuders at start up HELP!!
  240. Oh where oh where could that ECU you be?...
  241. 2.5 5 cylinder from Eurovan
  242. carb on an 86 CGT???
  243. Can the engine from my 86 4kcsq handle forced induction?
  244. mc1 oem replacement parts
  245. For Sale: '90 90q20v Turbo, AAN'd, RS2'd and much more...
  246. slave cylinder removal
  247. NG and 7A crank pulleys the same?
  248. engine swap question
  249. rollcall to the gurus here : i needs some input regarding a standalone system kit
  250. Any ideas?
