View Full Version : VAG-COM Discussion
- How do you do a TBA in a B6 and B5 A4 ?
- Is there a block to look at to see if the N75 valve is going bad? TIA
- Line in volume from CDC plug: Canthis be done by VAG?
- What are the Meas. Blocks for..............
- Dashboard replacement/. Is it possible?
- Planning to upgrade Win ME to XP. Should I deactivate Vag-Com?
- Do I need to register VAG-COM to read engine block 032?
- HELP FOR CD CHANGER
- Vag tool to see which wheels are ABSing...
- how do i check if the MAF is ok (what RPM and what g/s should be)
- vag-com & tranny fluid temperature
- what is the code # for air intake temp (i.e. post-intercooler) when using climate control display...
- Need help interpreting ODB-II code on 1996 A4
- 17539 - O2S: B2 S1: Internal Resistance too High 35-10 - - - Intermittent
- Vag com problem....
- DLRs: Can this be done with VAGCOM ?
- Could you please tell me what is code "P0456" for? TIA
- Can I change the units of my mileage display...
- question about recoding intrument panel and getting login password....
- Help! Vag-com DTC 01318
- Can I Vag-com program my car for bigger wheels?
- MAXIMUM PRESURE EXCHEDEED
- Can someone explain what resetting engine readiness codes do and which ones should be reset...
- so I logged 005 and saved it but it is a pf file, how do I convert it to excel?
- Vag-Com ..."Com port ok, adapter status 3"
- Measuring block label for ATF fluid temp?
- NE1 have an idea what this is: 16826 Evap Emissions Control System: small leak Intermitten 35-10
- Does anyone know if there is a code to activate an option that would....
- Is there a way to SEARCH the VAG-Com forum?
- Help! Where are the measuring blocks for Oil Temp & Specified/Actual Boost?
- How do I get the Fog lights to stay on>>>>
- Okay, so when I clear the codes....
- Brake & Gas Issue
- Anyone know if its possible to use VAG-Com or VWtool to check mileage??
- Audi TT - Catalyst System problem
- Coding of Steering Wheel (VAG-Com)
- Help with re- occuring DTC
- Is the USB interface worth the extra $$$?
- looking for a list of all possible faults... (m)
- Added Window code now auto door look does not work
- bentley CD and VAR tool
- VAG-com in UK
- Problem with xenons left rear sensor
- Question on stopping the low water spray for window alarm on a 2000 A4
- Where can I find a list of all measuring blocks?
- English units in VAG-COM
- question for Andy at Ross-Tech
- help...the dealer VAG mod the auto lock feature on my car but loss the remote window feature...
- VAGcom Question about VW
- o2 sensor - low voltage readings (logs inside)
- VAG module 46 (Central Convenience) on a 2003
- so i have a Passat ECU in my car & want to code it for my A4
- Does anyone have ETKA 6 running?
- engine problems but no codes in '91 CQ
- Running the ABS pump
- So I plug in my HEX-COM.
- Block 120 Instructions
- "Butt Dyno" Instructions
- Fuel Trim Information (Running Rich or Lean?)
- I've seen some people do kind of "Dyno" with their HEX-COM.. How?
- What do I recode to activate ABS? Cruise control?
- ecu swap help...
- Just got my HEX-COM :) One question for airbags...
- is there a way to reset fuel trim measurements in block 032?
- can I vag the instument cluster lights to come on like the S4's w/o headlights on?
- Tire size
- Homelink not working. With a VAG, could I get a code or I have no choice other than going to the dlr
- Stuff I want done to my 2002 A6...
- Anyone here know much about the MAC-02V2 ECU for the later Urquattros?
- New to HEX-COM, how to get rid of this message?
- Readiness code
- Can One Adjust Idle Speed with VAG-COM?
- Can anyone explain these features for the B6 A4 Central Convenience control module recode?
- My diag port. Where is it on 90 V8Q?
- VAG-COM Activation...
- VAG-com question
- A week ago I had one coil pack fail and it was replaced by the dealer. This week, my 2001 TT 225QR
- I just lowered my car my xenons are now wacked
- can you get security codes for radio with vag-com?
- Paging Uwe!
- Changing FM frequency step (from USA to Europe) on OEM Audi radios with VAG-COM? ...
- Great New Forum, Maybe Now we can get an answer to the imfamous b6 question?
- Dell Latitude C400/Vag Com problems
- VAG-COM assistance please for 2003 1.8T QMS (m)
- speaking of the quatech card, is there any way to force x1 mode...
- will the quatech serial port adapter work with the hex-com?
- Most comprehensive site for VAG-COM q's?
- VAG Help
- OBD-II problem
- VAG in UK
- Can you read boost with vag com on a 96 a4 1.8tqm and how do you do it? Thanks
- just got my hex-com, question about fault codes
- What fun mods can you use the VAG-tool to do on a 98.5 A4
- is there a list of all the known blocks to log.
- Any plans for a PDA compatible vagcom?
- woah, this is new....... great idea!
- please help guys,need advice
- Can't open VAG program
- How to pull codes on '92 S4?
- soft code for brake pad wear sensor?
- Upgrade from Twin Com to Hex Com?
- Auto Trans Basic Settings/Adaptation on DBW
- Can you use the Ross-tech VAG-COM's data logging feature to extrapolate 0-60 or 1/4mile times? TIA
- Getting SKC
- One more question for today. Is it possible to adjust/disable the volume of the warning "beep"?
- VW Jetta - Up/Down Window control w/Remote...possible?
- Considering purchasing VAG-COM
- Can anyone explain the calculated/spec'd MAF value from datablock 211?
- 02 Bose Stereo EQ
- which vag-com should i get?
- Difference between 02 A4 Avant and Sedan? When changing the instrument lights
- Vag Code Needed
- Possible to change default of ESP to "off" ('03-1.8T) ?
- anyone try different software coding for allroad suspension? (need workshop code,ideas what it is?)
- Ok I have to recode my chipped ecu from a non ESP car to being a car with ESP...
- vag-com and concert h/u question..
- Has anyone used....
- Has anyone on any Platform been able to change which shift program your Tiptronic has
- Rich or lean how do I tell....
- I have the VAG-COM for my '01 S4. Will this work on a 2000 VW Jetta or do I need different software?
- VAG-COM 303.1 released
- Help: Which measuring block to look at for engine temp. reading? ...
- Speedometer accuracy
- a6 2.4 nearly cutting out when setling back to idle
- ? about engine codes, blink codes, trouble codes
- Turn signal blinker
- Tweak trip computer?
- What does the Auto Trans Basic Settings trick do?
- Who can supply me a VAG COM in the UK?
- I have a problem with My 2003. The car keeps re-setting itself....
- New VAG-COM Beta!
- Help with re- occuring DTC's
- I'm sure this has been asked but I've yet to see an answer....
- 16805-warm-up cat below threshhold,bank1
- What exactly will a VAG-COM do for my '02 s6
- Anyone ever make a fairly comprehensive list of basic settings?
- How/Where to change Tip code on S4 2.7T?
- what's the real story with Mac compatibility? Will it ever happen?
- Can someone explain to me what this means..
- Sweet - I rec'd my Vag over the weekend...
- DTC 17547 & 17545 Long Term Fuel Trim Add.Fuel:Bank2 System too Rich
- Will my Ross-Tech Twin-Com Interface work with a GM if I have the correct Software?
- Is there any benifit to having the Bentley manual on disk?
- Any opinions on the VAG A4 to A6 200hp engine re-code? IMO it works. Still looking for Euro A6 5-sp
- Need Help translating DTC 16985........
- Anybody here from Socal?
- Nice forum guys...Any VAG-COM owners around White Marsh, MD that could hook me up with a session?
- A few questions
- If VAG-COM plugs in on OBDII compliant vehicles then
- If I'm measuring block 050 and it says A/C Compressor OFF, is it safe to assume
- 2 things about this forum
- Hey Uwe, did the yahoo group list stop? I dont get anymore emails.
- this is awesome! great forum!
- Is there a site....
- DIY Vag.com Tool
- Unlisted Measurement Blocks?
- A list of useful VAG-com links, at least for A6....
- Here is a link to the Measuring Blocks list at Ross-Tech
- Can VAG-COM be used to recalibrate the speedo after a wheel/tire size upgrade? Or is that
- So has anyone got the skinny on getting the Bently cd to run without the cd?
- Tranny code 00000 on 99.5 A4. Can this be recoded?
- I have the OBDtool.com connector and I'm using the non-registered versions of VAG-COM. I use it on
- Insurance "flood car" diagnostics
- Steering wheel Tip Buttons
- how accurate is vag-com torque measuring block (120)
- Neat... new forum
- cool!
- Does the HEX-COM allow a higher sampling rate than ISO-COM?
- Just got a spare ECU, how do I go about recoding it?
- isnt there a list of what can be done with the vag com, ie. auto lock doors,
- And dont forget the Vag-Com Lookup Database
- Here is a link to find what problems your vag-com tells you your car has.
- 02' a4 k-line question on this rad new forum
- Brand new forum!
