PDA
View Full Version : VAG-COM Discussion
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. Vag Com in Buffalo, NY
  2. Changing radio frequency US > EU with VagCom
  3. VAS PC?
  4. Can't get VAG-COM to talk to urS4
  5. New owner of 2010 Q7 SLine CPO
  6. VAG-COM for NAVI MENU Q3
  7. NEED TO SELL V6 4mo, have one nagging ABS fault! CAN YOU HELP PLEASE?
  8. VAG questions for S6...
  9. CVT Relearn Procedure, I dont know what to try next :(
  10. Checking O2 sensors
  11. 09: Cent. Elect. no long coding for ADS configuration
  12. 2003 A4 3.0 Fault Codes & advice
  13. 2000 A6 can't read any modules? after minor wreck
  14. Testing for a bad cat
  15. Any one selling a ross tech cable
  16. Misfire on all Cylinders
  17. Vag-Com Data after changing HPFP cam follower
  18. Procedure for finding vacuum leaks
  19. Another VCDS Newbie
  20. Power locks blinking and clicking, fuse 39
  21. Long coding
  22. Exhaust help!
  23. Vag Com in St. Louis?
  24. Fog lights and high beams on at same time
  25. Customize Coming Home / Leaving Home lights?
  26. Vag Com Services in MA
  27. nyc
  28. OBD II diagnostic port not functioning
  29. No Sirius Band-only AM/FM on MMI Q5
  30. Vag-Com Mods for hire (SF Bay Area)?
  31. A8/D3 Auto Transmission Recoding
  32. Help me get my menus back in MMI
  33. MOST issues? (Optical network)
  34. ScanXL Pro and VAG-COM
  35. Problem: 55 xenon range can not be reached
  36. cannot select car set up from mmi
  37. Advanced Key: disabling "Turn off ignition before leaving car" message & chime?
  38. Help with VAG COM
  39. "No Response from Controller" Help
  40. Request for security access code for module 53 : Parking Brake
  41. Vag-com engine>measuring block
  42. Fault Codes - help
  43. Recoding after battery change on A8?
  44. My VCDS readings. Info please
  45. VAG COM in Northern Virginia
  46. Q5 - reset stronic
  47. Audi Q5 Auto gearbox controller
  48. A4 2.0t engine sputters then turns off
  49. D4 A8 fault codes
  50. Fault Code in C6/4F A6 - Memory Seats
  51. Can someone please recommend some diagnostic Tool for my work shop?
  52. 99' A4 B5 tranny recode quection?
  53. Vag-com PA
  54. no response from controller HELP!!!
  55. vag com codes help-radio shuts off
  56. 2010 City Golf Vag-Com help.
  57. Ventilated seats
  58. New Comer questions!
  59. Euro Parking Lights 2012 C7
  60. Confused by TPMS code, anyone help?
  61. VCDS on Mac
  62. Changing Bulb Tail Lights To LED's
  63. A6 4G questions
  64. [REQ] Program Code for 76 Parking Assist - 4D / 2000 A8 D2
  65. ELSAWin - where's VAG Diagnostics section for Audi A3 8P?
  66. SoCal Vag-COM
  67. 2003 Audi A8 parking brake error code help
  68. Need VAGCOM read in south
  69. 04 Allroad 4.2 - Multiple code Help
  70. RNS-E, telling it is on dif continent.. Secret shortcut?
  71. seat belt warning/max speed
  72. 06 A8 4E vcds faults - level, xm
  73. NorCal VAG COM
  74. Injector code upgrade
  75. 98 A4 Codes Help
  76. adaptive headlight defective
  77. Vag-Com in Greenville, SC?
  78. New VAG-COM Owner Here
  79. 99 A6 issue
  80. Audi B6 fuel level sensors 1 & 2: Which is which?
  81. help for a new user of VCDS
  82. I think I bought the D3 the Army tested their EMP weapons on...
  83. disable TPMS with VAG-COM
  84. audi wiring harness repair kit
  85. A6 B4 17 Instrument Cluster
  86. Most problem
  87. Doors audi tt Error
  88. Service Due! even after RSI
  89. How to change Audi A6 mileage
  90. Audi A4/RS4 Bi Xenon to Bi Xenon with AFS retrofit
  91. Problem with my MMI for A6 C6
  92. Single reading Audi 2.8 -1992
  93. O2 sensor bad?
  94. Bentley manual, adaption & coding?
  95. auto folding mirrors
  96. Audi Drive Select & VAG-COM
  97. 2006 C6A6 4.2 first scan results
  98. Ross-Tech has a Job Opening for a Technical Support Specialist
  99. 2004 A8L First Scan Results
  100. 2012 Audi Q7 - Trying to set Window / Roof Up/Down via Remote
  101. Digital Speed Reading
  102. TPMS Frequency change ?
  103. Aux Heater Error Code.
  104. 2010 Audi TT
  105. 2012 S4 disable 1-tap "comfort blinking"?
  106. New Battery
  107. ecm relay circuit open audi a4
  108. audi a4 2001
  109. Left Hand Drive Problem
  110. Audi Electronic Service Information System
  111. D3 A8 Key Remote Issues
  112. B8 S4 Measuring blocks for VCDS 11.11
  113. Need Help Coding for Towing Package
  114. Q7 scan
  115. Missing MMI Menus
  116. Unitialized control module message
  117. ETA re PDF manual for VCDS release 11.11
  118. B8 S4 - Adaptative Error when doing vagcom tweaks
  119. A8 D3 heated mfsw w/paddles, coding and module?
  120. Heater Controls Mixed Up
  121. Electrical Issues?
  122. Serious issues with vag com, brakes and hvac
  123. Do mods void warranty?
  124. B8 A4/S4-- measuring blocks (IDC, A/F)
  125. Help my LED cannot work
  126. VAG COM near Wilmington DE, Philadelphia PA area (19711 zip)
  127. Please help
  128. window control with remote- 2011 TTS
  129. Group 17 Chanel 3 Consumption Adaptation Error
  130. Having trouble with TBA on my 99 30v..
  131. D4 A8 Service Reset
  132. abs bleeding not working
  133. issues with drivers with vcds 11, please help uwe
  134. Error Scan VCDS adr 46 - help me - please
  135. Need a read in Jackson, MS
  136. which vagcom do I buy?
  137. Trying to code a key... 46-Central Conv. reports "no response from controller"
  138. VAGCOM in MN, Twin Cities area
  139. 2001 A8 D2 Xenon adjustment error
  140. Where do I find Boot Camp???
  141. Help with Vag-Com recoding
  142. New owner help with trouble codes
  143. A8 coding help please
  144. X-Post: VAG-COM needed in Philly area!
  145. '06 A8 New Owner - AutoScan
  146. Airbag Module Coding C6 A6
  147. Fault codes found on A4 b6
  148. VCDS lite ABS system
  149. Warning about VAG-COM programming guidelines on OOOO-A3 site
  150. Q7 MMI system is dead, ran codes
  151. Anyone here in Central/Northern NJ, NYC/Westchester with VAG-COM, HEX+CAN USB?
  152. serious issues w sirius reception
  153. brakelight strobe; NAV entry on the fly for B8
  154. Trouble upgrading firmware
  155. troubleshooting 2002 B5 S4 heat issues
  156. 06 Jetta 2.5 CEL blinking
  157. Use VCDS to find CAN identifier?
  158. VCDS / Vagcom fault 03041 - Audi A4
  159. Help with VAG-COM : Sluggish Performance
  160. Anyone near Tacoma, WA have Vag-com
  161. VAG-COM in NC
  162. Did anyone here use VGA unlock MMI before?
  163. no response from controller- ABS+AIR BAG+ !
  164. Unable to code factory-new Bosch 5.7 ABS
  165. Boost Gauge
  166. Looking for vag-com in southern california
  167. 2012 A5 P2400 code?
  168. S6 V8 2000 VCDS label file problem
  169. Adaptive Headlight Failure
  170. Satellite Radio Measuring Blocks
  171. Really need help/advice--EPC and CEL
  172. Read airbag codes '90 80Q?
  173. A6-C6 Window Regulator Adaptation
  174. Unable to measure MAF
  175. A8 Level Control
  176. PROGRAMING REAR TAIL LIGHT TO EUROPEAN SPEC
  177. Beta 11.8 question
  178. VCDS coding for Cruise Control '11 Q5
  179. B8 A4/S4 ... any interesting VagCom options?
  180. 1999 A6 TCU REPLACED. CODE??
  181. Need help in chicagoland
  182. No auto scan on RS4
  183. Active steering no basic setting
  184. Help needed on a 2234 - Right Headlight power output stage - error
  185. Vag 01221 airbag 179 fault
  186. Adaptive Light Failure on 2006 A8 - scan included
  187. Can I run the leak detection pump with version 311?
  188. NYC VAG COM
  189. 99 A6Q 2.8l V6 AHA N33 Injector Short To Positive
  190. help!!!
  191. New Airbag Woes
  192. Roof Electronics
  193. Help with some AQJ S6 V8 codes
  194. TPMS battery life measuring block
  195. VCDS with my 2012 A4 2.0 ?
  196. Why can't I change service interval?
  197. Activating Cruise Control
  198. Help - Fault Code - 00712
  199. Testing my Daughter's VW
  200. Monitoring the CAN Bus using a VAG-COM V704
  201. What is this HVAC magnetic clutch thing?
  202. borrow / rent vag-com Columbus Ohio
  203. RossTech VagCom applications for A4 Roof ECu
  204. Auto Unlock with key removal on 2007 RS4
  205. active steering and ross tech
  206. MMI 3G problem
  207. wiring/ecu problem
  208. audi a8 quatro
  209. any way to use vag-com to change ambient temperature displayed?
  210. how to test LCD display outside of car
  211. D4 A8 Platform Info
  212. vcds 11.3 issues
  213. auto gearbox flashing lights on dash
  214. Serial to USB adapter
  215. Can I manually reset an Airbag light without a VAGCOM?
  216. D4-A8 Compatability
  217. Air Bag fault
  218. AUDI A6 3.0TDI BMK HELP
  219. Vag-Com 10.6 cannot connect to 2006 MKV
  220. Vag com: cannot access Door Elect module (52) - no response from controller
  221. self ECU tune????
  222. OMG, WHATS GOING ON,,, DEAD CAR OR THEFT ATTEMPT
  223. Media Player - MP3 Changer error
  224. VAG-COM Software Install Under Wine on FC13
  225. Weird Audi TT CLM Errors. My Roadster thinks it's a coupe
  226. Audi S5 AFS headlight programming
  227. A6 Gateway Module Install? Programming? Help please!
  228. Do I have to mate my new TCM to the ECM?
  229. Data logging - time between speeds
  230. Audi a6 2005 head ligh
  231. A6 2.5TDi Quatrro Est 2000W Starting problem
  232. 2006 A3 (8P) brake light problem
  233. 2003 A4 Avant Alarm Problem
  234. Rookie at vag-com
  235. Lowering Adaptive Air suspension on Audi A6 C6 with vag com
  236. B8 S4 Alarm
  237. Problems with 402 Suspension Mod for 2004 Allroad
  238. how do u know which vag-com cable is required for q7?
  239. too many communications error
  240. programming of q7 after towbar installation
  241. VAG-COM question
  242. removal of sidelights q7
  243. Misfire diagnosis
  244. Major key programming problems; 99 C5 A6
  245. Vag Com In san Diego Area!
  246. Hex Scanner 1995 S6
  247. Vag read out ; can anyoneoffer help
  248. Testing shift solenoids
  249. Can't access ABS or Airbag Controllers...HELP!!
  250. Unable to access modules after one use
