PDA
View Full Version : VAG-COM Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. Where is the port on the new A3's?
  2. vag noobie question
  3. What kind of radar detector should I buy?
  4. Looking to purchase a VAGCOM but not sure which one to buy??
  5. Practical Experience Recoding D3 A8's?
  6. A4 2007
  7. 7.04 update won't Autoscan
  8. The Elusive 01119 - Gear Recognition Signal (Intermittent) ABS DTC.
  9. how do adjust xenons?
  10. Is it me or ross-tech site is down?
  11. comfort control module
  12. Fault code No. 3 CYL Open Circuit..........Help!!!
  13. fast blinking of turn signals
  14. Help disabling seatbelt chime on 04 allroad
  15. Instrument Cluster and Immobilizer issues in 2002 A6
  16. Get these two codes after cluster swap, any help appreciated
  17. Can you program keys with Vag-com?
  18. Turn off delay - Short to ground. A6q 98 avant
  19. code readers
  20. is it possible to lift or remove speed limit?
  21. Help needed on 2.7t forum
  22. Anyone know how I can change kmpg and euro time back to US specs....
  23. Remote Key Programming Question
  24. Adjusting adaptive bi-xenons to dip right instead of left?
  25. workshop coding of abs computer?
  26. I want vag-com but,
  27. B7 RS 4 Fogs w/Parking lights coding?
  28. coding key with Vag-com - MY2003
  29. Isn't misfire recognition supposed to be activated 100% of the time?
  30. How can I uninstall VAG COM from my laptop. I get an error and it stops uninstalling...
  31. hi i need help with this one BTW new vag owner
  32. MODE BUTTON ON STEERING WHEEL CODING
  33. Is there any difference between HEX-USB (without CAN) and the current KEY-USB cable?
  34. Assistance needed recoding ABS module and bleeding brake system
  35. Anyone in New Jersey with Ross-Tech software that can recode my tranny?
  36. Vag com
  37. B7 Driving School Function - Change km/h to mph?
  38. I have a 2006 a4 2.0t and would like to know how to reset the fuel adaptations
  39. Problems with A4
  40. Q7 Fault - Any Ideas?
  41. wierd connection problem...i can connect fine to some modules but not others.
  42. Help with engine fault code
  43. Help with scan results B5 A4 please...
  44. Ross-tech Key-USB cable: "Not connected to car" error message.
  45. update ECU
  46. Should i get a Cable do i need it?
  47. Need some help. I'm at a total loss for these misfire codes I've been getting for 6 months!
  48. Anybody know how I can change kmpg mpg and the euro time etc back to US specs?
  49. Help on diagnosing Engine and Auto Trans fault codes
  50. Help on diagnostic Tip VB Solenoids or up shifting Problems.
  51. Is it possible to pull a log of recent VAG-COM activity?
  52. Can I recode the TCU in a C5 A6 3.0
  53. Output Tests: Error: Function Not Available
  54. Can't achieve near-100% wastegate duty cycle
  55. KEY-USB and '06 A3
  56. is it possible to re-code the memory seats on 1999 A6 (details within)
  57. car running rough. going to VAG this weekend (long).....
  58. Is it normal that I cannot access Module 01-Engine on my B7 3.2?
  59. Just came from the Ross-Tech site... Which VAG-COM to get?
  60. Fuel injector open circuit
  61. xpost to b5: softcoding for 2000 a4 tip
  62. J1850 protocol and VAS 5051
  63. VAG-COM lost connection while checking ATF level
  64. Exploring vag com a little more and have some questions...
  65. Got email about VAGCAN tool. Something about " can change the mileages"
  66. Need some help troubleshooting brake problems.
  67. Was attempting to change to "Old-style Tiptronic" but....
  68. airbag errors help pls
  69. Airbag DTC Assistance
  70. Instuments - 17 > adaptation - 10 > Channel 46. What does this value represent?
  71. will KEY-USB work properly in my 04 s4, also do i need to register it, im buying a used one.
  72. Allroad VAG test
  73. Updated link: Problems with MAF, Intake
  74. First SCAN! Audi A6 4.2v8 2001 Tip
  75. VAG and Vista (USB)
  76. Update on prior post regarding A/C mode idle speed kick-up..'03 1.8T A4
  77. Looking to pick-up a VAG-COM cable from Ross-Tech, need some tips on what to get.
  78. P1122? What is going on here, O2 sensor?
  79. USB vs Serial Vag Com Cable?
  80. Is there a way to upgrade...
  81. What exactly does the "Rest of the World" setting change on the central electronics on a b6 S4?
  82. What kind of PDAs can you run VAG-COM on?
  83. Need help interpreting this for an 99 A6 Avant
  84. Can i recode my 2000 a4 1.8tq tip, to this so called sports mode or does it already have?
  85. Cart before the horse maybe, but
  86. 2002 TT window will not go up after door is shut. Can I reset with Vag-Com?
  87. Car stalling, surging when hot, no power intermiten EXPERIENCED GURUS HELP PLEASE( kinda long)
  88. VAG-COM Release 704 Now Available!
  89. need software
  90. Intake Camshaft Contr.Circ.,Bank2 Short to B+ 17943, save me $1800 i will paypal $20
  91. New Vag Com Owner need help on using all the options web site maybe?
  92. Uwe: I didnt expect to find a picture of you on YoMomma
  93. What do you think of these readings.
  94. what blocks should I log to find a bouncing boost issue? also, the car goes into a soft limp mode
  95. Is there any way to have the ESP default to off when car is started?
  96. Can I use a Ross-Tech USB cable for EVOscan software?
  97. Can someone tell me if these block 115 graphs are normal?
  98. Rooling back driven km
  99. 2001 S4-Windows Vista-have cable..what all do i need?
  100. One Click Unlocking B7 A4
  101. Vag-Com rookie here. Can someone help a brother out?
  102. Just picked up the ross-tech usb cable and software...
  103. VAG-COM / HEX-CAN USB and Vista under Bootcamp | help!
  104. A4 - how to interpret coding for steering wheel module 16
  105. Need some DTC help, already searched the archives.
  106. 16706 Engine Speed Sensor G28 No Signal - bad?
  107. Finally got VAG-COM, some help needed
  108. Just got VAG-COM and CEL on same day - Need help with fault code
  109. Is Vag-com version 312 alright?
  110. Bump: Service light reset:
  111. Need to log in as a shop - How?
  112. i am so confused. can N E one tell me how to do auto-lock above 10mph, and put music back on my.....
  113. Replaced FOB battery: Do I need my VAG-COM to recode/adapt the FOB? B7 A4
  114. Have a 2001 Audi S4 and a laptop with usb and serial... what cable and software do I need...>>
  115. Procedure to test MAF for functionality in 2.8 V6 ?
  116. anyone running vag com hex+can and software with intel mac and parallels?
  117. Stange code after replacing cluster... Need help...
  118. What is the difference between USB KKL VAG-COM for 409.1 and HEX-USB-CAN VAG-COM FOR 607.3?
  119. Help with codes pls...
  120. Recurring Airbag Code...
  121. earlier post re evaporative emission system
  122. Seeking assistance with a common error message but...
  123. How can I change my service indicator light to come on in 5000 mile intervals instead of 7500?
  124. Tranny problems, new to vag-com. No DTC's showing. How do I set up to check tranny while driving.
  125. need help coding abs for 2001.5 s4
  126. S4 Start-Up Screen Adaptation?
  127. Thinking of getting Vag-COM
  128. Yikes, had a rough drive home tonight. What do you make of this VAGCOM scan?
  129. RNS + XM install = VAG Faults...help
  130. 1998 A6 2.8 Airbag light
  131. Just got my HEX-USB+CAN. Need some help interpreting a code.
  132. what does this code mean?
  133. Why would VAG be unable to connect to air bag control module
  134. help reading logs please
  135. anyone in the chicago suburbs willing to help me disable the imobilizer?
  136. 01794 - Control Module Incorrect Chassis (VIN) Number
  137. xpost: I've got an original ISO:COM adapter. Is it worth me upgrading to HEX-USB+CAN?
  138. What's your favorite VAG-COM adjustment?
  139. P1338 Camshaft sensor code error - voltage to sensor is 11.3v - is that too high?
  140. Re-Coding One Click Opening on an A3
  141. Help with readiness codes (and YES, I've driven it enough)
  142. Need help with Load Calculation Cross Check: Implausible Value code
  143. Help with Kufatec Speech Input Control Module
  144. Ohh come on!!!
  145. Is there any data logging or interface speed advantage between the USB
  146. VAG-COM on a 2001 Nissan Frontier
  147. I haven't tried it yet, but I assume that I can get the part number of a Tip module through the
  148. Possible to turn off the signal and city lights when headlights are on?
  149. Is there a number to add or subtract to take away the double windshield wiper swipe...
  150. help with evap emission control code
  151. how do I check cars Altenator charge rate with vag
  152. Something nice I didn't know about Ross-Tech..
  153. Fuel Injectors
  154. Vag Com compatible cords on ebay?
  155. TPMS Disable...Anyone in N VA with VAG Willing to Assist?
  156. Can you soft code a 2000-2002 tip S4 ecu to work on a 2000 c5/a6 2.7t tip?
  157. Windows / Sunroof open close from key fob
  158. So I upgraded my Vagcom and now I have some problems.
  159. HELP with Codes
  160. Is it posssible to read boost with VAG on A4 B6 BEX? (-)
  161. How can i check my car timing with the vag
  162. Beta 702.0 question
  163. Blue Screen Problems
  164. Xenon leveling system error - not the usual "how do I aim" or "error after lowering" issue
  165. Beta 702.0 is now available!
  166. aftermarket interface
  167. Are The Audi Shop Vag systems capable of diagnosing a controller that isn't responding?
  168. Can TPMS on the Q7 be disabled by the same means as on the C6 A6?
  169. AUDI Basic settings
  170. Radio Controller Not found? ...Headlights don't work?
  171. 16804 - Catalyst System; Bank 1: Efficiency Below Threshold P0420 - 002 - Lower Limit Exceeded
  172. Satellite Radio code?
  173. Instrument lighting adjustable?
  174. Is there a Newbie site for VAG COM for block #'s and directions on changing stuff?
  175. 315lbs-ft? is that correct?
  176. rns-d / vag adaptation...
  177. code for pausing wipers while spraying washer fluid?
  178. Noob vag owner
  179. if i buy a used HEX-USB+CAN do i need to register it for it to work, or do i need to register ......
  180. Computer info
  181. I need a J1979 standard table...
  182. I am a very satisfied VAG COM owner/user. I have a question regarding my security system.
  183. speedometer and vag-com question...
  184. Can I get my ISO-COM to work with a USB adapter?
  185. Is it possible for VAG-COM to increase the top speed limit?
  186. I just got these codes!
  187. Audi A4 Concert Radio stuck in DIAG and no controller available ?
  188. Can i turn off my daylight running lights with my VAG for a 2000 Audi A4 1.8tqTIP
  189. Newbie to Vag-Com looking for tweaks.
  190. TWIN USB interface, anyone got it to work with Lemmiwinks? I've read the FAQ's at Ross-Tech about
  191. Vag-com software & drivers, will it work with Vista?
  192. Having trouble finding ch 62 adaptation guidelines on wiki.....
  193. driver door warning
  194. b5 rs4 vag question...
  195. Adjusting Fuel Gauge / Sender
  196. Hi, needs help with another fault code!
  197. Hi, help with Adaptive headlight fault code please.
  198. Anyone do the TV/DVD unlock
  199. m/s^2 = 24.325 can someone please explain how to understand this?
  200. Looking for a link to listing of local who have VAG-Com as I would like to see how it works before
  201. Vag-Com and Acura
  202. Noob - Reset learned automatic/tip transmission tendencies
  203. I appear (I am Spanish)
  204. 99.5 k04 A4 running rich (bad gas mileage)and need help
  205. Need Help: Reload Firmware on TT ABS controller?
  206. Strange radio fault.
  207. S4 Alarm help
  208. Login Codes for A3?
  209. How do you log boost readings for C5/4B? 2000 A6 2.7T
  210. Day Time Running lights on a 2000 A6? Is this possible, if so anybody know the code?
  211. New to vag-com....
  212. New Vag-Com USB Woes
  213. Vag adjustment for my ride
  214. Vag-Com 3.11 Vista workaround.
  215. VAG codes for 2007 A4 2.0 Cabriolet
  216. Vag-com logging
  217. Anyone which font under the Window's settings governs the size of the font...
  218. TPMS Testing
  219. Turbo timer vs remote locks...
  220. Air Bag Control Module Coding
  221. Vag can't access the following
  222. rs4 Airbag Light
  223. Success VAGging my car today. VAG noobs read on! I have a few Q's too..
  224. Should I get VAG-COM?
  225. Vag-Com question
  226. Instrument Cluster and Radio Question
  227. can i use a key-usb interfave on a 2004 audi s4. or so i need the +CAN version. thank you
  228. Radio Symphony II don't wakeup and don't illuminate
  229. bank 2 is missing..
  230. Is there a way to test the turbo output of my car?
  231. I have 00 A6 2.7T 6 speed. What do I buy to acquire diagnostic capability? How much?
  232. Kick down switch status
  233. can vag-com be used to test if a heater blower motor is bad?
  234. Audi A3 8P - 00323 - Vehicle Inclination Sensor (G384)
  235. "Can't sync Baud Rate" problem...
  236. Reset Service Interval Indicator - Is the procedure complete / correct
  237. Audi TT Haldex check?
  238. Intermittent K-line connection to RNS-E
  239. Headlight adjustment help
  240. Help With Some Codes
  241. VAG-COM unable to communicate with Airbag Module, no warning light.
  242. Help with codes A4 BT
  243. Resolution
  244. Measuring Block 32 B6 S4, what do the four values represent ? TIA
  245. adaptation value help
  246. Help..How to change front bumper side marker brightness (O6 A3 2.0t)
  247. Can't do Throttle body adaptation. Fault Code will not clear (kinda long)
  248. 18080 coolant fan control 1 : open or short to ground p1672 -004-
  249. Got codes - need help
  250. Converting CA car to US?
