PDA
View Full Version : VAG-COM Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28
  1. Buying Vag system Canada Ross vs OBD tool HELP!!
  2. What should be the correct airbag control module software coding for this car?
  3. 98.5 A4, can I turn off instrument panel lights that are default always on?
  4. ISO 9141-2
  5. my old computer died downloaded vag-com onto new one.....
  6. Was thinking about getting Hex-Com for "turbo" mode.. but..
  7. Without trying, what will be the code if you left your gas cap unscrewed?
  8. What is system too lean mean?
  9. Radio coding in UK A6
  10. How do I get the labels to appear? I have a 2000 S4 6spd.
  11. timing belt tensioner
  12. red light on the hex-com plug
  13. I can't get the Ross-Tech software to work. :/ Yes, it's registered. (m)
  14. Soft code for tail lights
  15. Has anyone ever had their ECU box letter change on them?
  16. VAG COM Software Question, can anyone help me?
  17. all windows wound down 2 inches some time after i locked car with remote...
  18. anyone crack the code between the stereo and the center of thie instrument cluster?
  19. is Ross-Tech k-line only
  20. Weird groaning noise as turbo spools up 3200-3500 rpm
  21. Atlanta VAG people
  22. Diagnostic connector
  23. '01 Allroad with 117K showing 3 codes.
  24. Airbag light
  25. Will I have issues if I want to do the remote windows recoding w/ an aftermarket head unit?
  26. MY2000 A4 1.8T, Code 01273, Fresh Air Blower...
  27. Is it possible to recode a B box ecu to a L box ecu?
  28. 03: ABS Brakes Fault Code
  29. Need login code (people on road need help).
  30. Door Chime - A8 D3 Yr 04
  31. Cheapest solution for VAG cable and software?
  32. Manual for 04 S4 has no codes
  33. Who here has played with VAG adaptation blocks?
  34. Could battery replacement cause my fault codes?
  35. Vag-Com connection problems
  36. Tiptronic recoding to "Old Stragety on the ECM"...
  37. Can someone tell me...
  38. Recoding door locks- - -
  39. need to clear climate control faults, can I do this w/ obd tool?...
  40. DTC 17584 Bank 1:O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
  41. How to get remote windows for new A8
  42. HELP!!! Trying to recode an ECU with VAG-COM
  43. How decent is the shareware version of the vag-com software?
  44. D3 A8L Auto-Trans (02) coding - X-Post A8L (D3)
  45. VAG in CT
  46. Tech said he was locked out (m)...
  47. Just when I start to relax and enjoy the ride my baby Biatch slaps me with.....
  48. Please I need help fast!?
  49. Vag-com and vw passat airbag controller module
  50. Can someone help with this Specific Code?
  51. Can Someone tell me what these fault codes mean?
  52. Vagcom code 17963: Negative Deviation
  53. Is Vag Com software compatible with Apple OS X?
  54. O2 Sensor B1 S2 was changed, Check Engine Light still coming on HELP!
  55. Service Reminder
  56. How do I find VAG codes in a Bently CD?
  57. vagcom and obd2 connector
  58. Getting Cylinder misfire errors, can someone tell me what is goin on?
  59. Can I do a B6 S4 DBW adaptive throttle reset with Beta 0.81?
  60. Retaining Readiness Codes
  61. Can you have the Actual speed displayed on the climate control console between the speed o and tach?
  62. lamda reading, have some questions.....
  63. code error
  64. is there a measuring block for oil pressure?
  65. Can the shareware version of Vag-com clear fault codes?
  66. Just tried my VAG tool for the 1st time today, so as a newbie, what does..
  67. Tiny single-board computer
  68. Problem using "04 Basic Setting"
  69. Is the "trade-in" deal still available if I want to upgrade from my ISO-COM to the HEX-COM ???
  70. DIGITAL SPEED DISPLAY ON CLIMATE CONTROL
  71. Quick-How do i change the instrument cluster back to MILES instead of KILO's?
  72. Need Vag serial interface cable
  73. fault code 18017... Crash Shut-Down Activated -- Can someone please shed some light on this?
  74. ABS controler fault 01203
  75. A6 Key Fob Window Problem
  76. Is the concensus for DTC "17536 long term fuel trim mult. Bank 1 system too lean"
  77. When will the Serial Connection KEY-COM (229.00) be available again
  78. I need help... About fault code...
  79. 17965 Positive Deviation, HELP!!!!!!
  80. Does anyone know which O2 sensor this is?
  81. What do these codes tell you...
  82. Service interval set at 8100 miles
  83. D3 A8L Sucsess!! And a little info...
  84. Air/Fuel Ratio Chart
  85. need a little help..
  86. Trouble changing concert 2 headunit to Bose.
  87. VAG-COM detect wrong immobilizer
  88. VAG-COM for sale
  89. Climate control recoding
  90. A4 B6 instrument lightning
  91. ProDiag vs VAG-COM
  92. Is there a way to break down the control module coding
  93. Question about HEX vs KEY
  94. 2001 A4 can't connect to vag-com
  95. Service Reset
  96. B6 speedo accuracy adjustment?
  97. VAG com wont work
  98. VAG-COM version to PocketPC
  99. VAS 5051 Hard disk
  100. Help, car suddenly died while driving - VAG fault code 01383
  101. Help with Coding for headlights B6 S4.. Headlights are now on whenever car is running...
  102. Coding 2004.5 A4 for RDW lighting questions
  103. DTC P1570 17978
  104. How to know if my car is chipped?
  105. Need help diagnosing code P0106
  106. Giac X-Chip Swap
  107. will the central convenience codes on the link...
  108. OK, I did the FAQ and the searches, but am still lost. I have this VAG-COM, and a 2001 TT (K ECU) ,
  109. VW VAG-COM compatible with B5 A4?...
  110. x post
  111. are there codes for the 05's?(A4's)...............
  112. adjusting auto-off sensitivity of rear defroster on 2005 A8?
  113. Is it possible to read MAF Voltage on the B5 S4. Uwe / Andy?
  114. I currently have VWTool w/necessary hardware, i.e., laptop and cable.. If I wanted to upgrade...
  115. 06A 906 019BQ
  116. How do I program remote windows for '02 A6 4.2?
  117. Which OS would be better for a laptop for VAGCom?
  118. then I run vag-com should I turn the car engine on or it should be turned of?
  119. urgent help: fault code 18017... Crash Shut-Down Activated
  120. Looking for the "engineering" address-word list and function/meaning
  121. Is it possible to change the lower heating/air conditioning temperature limit using ....
  122. UWE: Does logging more than one block affect time accuracy in any way?
  123. Trying to trouble shoot central locking system. HELP
  124. Shareware VAG-COM; can't "test" successfully...
  125. upgrading to a full version of an older release
  126. 1998 audi quattro
  127. DTC's and MAF logged.... numbers seem bad can't get a real answer by searching. Really I've
  128. VAG-COM and ABS Brake Bleeding?...
  129. DTC(diagnostic trouble codes)
  130. want to do my self but don't know how
  131. LOGIN CODE requested
  132. Vag Trouble.. Can someone please help????
  133. ECU/Immobilizer Problems - HELP!!!!
  134. is it possible to make the back windows go all the way down?
  135. Unable to access 55 headlamp range B6 S4
  136. XPost - GIAC Chip issue...
  137. DE-Bose Concert Stereo
  138. 00032 Tip Recode Q?
  139. Xenon Headlights
  140. "in 1" in 2" problems!
  141. Looking to get vag com
  142. Etka getting error message 144 when trying to look for parts?
  143. Anyone in Baltimore have Vag for an 04 A4?
  144. 16502: Engine coolant Temperature Circuit -G62: High [Sporatic] >>>
  145. P1137 (OBDII) on 2001 TT 225
  146. Using VAG to enable Fogs w/o lowbeams
  147. Getting DTC code #17356 and going into LIMP
  148. I'm getting a missfire on #3, varies between 2-3 on the reading.What exactly is that block reading..
  149. Can't connect to all of the control modules of my new (03) allroad...
  150. 2.7T Fault Codes
  151. cylinder 1 misfire and cant find problem please read. long
  152. Ajusting Fuel Delivered by injectors via VAG
  153. Vag Scope
  154. auto-check system
  155. Keyboard control while logging?
  156. Can Someone tell me what these codes mean?
  157. DTCs help
  158. Three weeks left in the Audi Club raffle!
  159. code PO421?
  160. Anyone know what to recode to adjust the interior motion sensor sensitivity on a TT?
  161. for 2003 A4 1.8T, is it possible to change setting to enable hi & low beams + fogs?
  162. Does my Vag-com need to be re-registered?
  163. ECU modification Nissan Murano
  164. I have a 2002 a4 1.8t quattro 5 sp man want to vag-com my windows
  165. 1999VW VG Code 17951
  166. what exactly is a vag-com
  167. just got VAG-COM
  168. B6 S4 codes help please?
  169. one push unlock
  170. wishlist for 2005 A8, disabling annoying traits (x-posted to D3)
  171. Is there VAG software that will work on an iPAQ???
  172. Install ECM w/o VAG?
  173. VAG-COM demands PIN CODE(5 digit) for changing values. Where can I get it ? TNX
  174. Chip Pedigree Question...I have a beautiful Santorin Blue '00
  175. Problems aligning xenon ecodes with VAG-COM
  176. I have DTC #18089. I STFA and only found other people wanting to know what it means...
  177. Need Vag---
  178. How does this MTM Stage 3 data log look to you all....
  179. Turning off Motion Sensor
  180. A8 Service Indicator won't reset with VAG-COM
  181. Check Engine Light
  182. Just made a VAG appointment...
  183. How do i take check the ABS light off with a VAG tool?? Any special procedure??
  184. park light & fog light ON, headlight OFF. how do i do that?
  185. lookin for a vag-com
  186. diag for '00 A6 and '01 Chrysler
  187. Can Hex-Com do DTM stuff?
  188. XPOST from A6 forum...VAGCOM and brakes - help appreciated
  189. Can someone tell me what the following DTC mean ?P1131, 16486 & 17861
  190. anyone know if 97 A4 1.8t must be Vaged "reset" after T-Belt
  191. Where to fix DTCs 17536, 17538, 17551?
  192. radio reads 'safe' and won't work. . .anybody know
  193. ABS and VAG
  194. Transmission Problem DTC 00652
  195. New to VAG...have a few questions...
  196. killed 2 Ignition Control Modules in a week--need help, a new ECU and another module
  197. Is Dyment's CD different than Bentley's CD Repair Manual?
  198. Code to De-Bose-ify Concert Radio
  199. checking continuity from ecu to pos, need help
  200. Will VAG show me boost? Not used to not seeing that gage!
  201. Fault code vag.com
  202. VAG won't connect to my '99 A4 - what's wrong?
  203. Possible to VAG-COM pad sensor wear indicator on '02 S6 instrument panel off?
  204. EuroDezigns 6000k Headlights...any info?
  205. stopping MMI screen from popping up and displaying warning every time car starts?
  206. Traded 00s4 for 04AR - what is with the seatbelt chime?
  207. Reimaging my laptop- do I need a new registration number?.....
  208. HELP Pls: When running logs, why would my laptop repeatedly
  209. Is it possible to shut off the warning for broken bulb?
  210. Anyone know if speed limiter can be removed with VAG-COM?
  211. Wierd VAG-COM Problem
  212. '95 S6 OBD-I to OBD-II VAG-COM problem
  213. How are the new HEX-USB+CAN cables marked?
  214. Anyone can translate this code for me from VAG COM?
  215. any way to re-code the spare ecu to work with my car?
  216. I have a com based vagtool, any way to adopt it to usb?
  217. Tech assistance requested for enclosed DTC's...
  218. If I clear a CEL,will it show up again if the problem is still active,or is it ignored from then on?
  219. Control Module access problems with Allroad...
  220. DC Area VAG User
  221. 7-digit SKC request from dealer. Options?
  222. cluster recodeing
  223. Auto Trans oil temp?
  224. Bleeding brakes and booster
  225. Getting Vag-Com...
  226. Is it possible to change the trip computer display.
  227. VAG to check radio in A4?
  228. Code to negate brake sensor light?
  229. Ross-tech or someone else, please help!
  230. So if my Diagnostic port isnt in the place it should be where is it?
  231. Air Fuel Chart - Take 2!! Can someone help please??
  232. Can anyone tell me if this is a normal reading (engine timing)?
  233. pcmcia serial cards redux
  234. Logging of data and DTC...
  235. Fuel tank read error.
  236. i just need the VAG software, anyone selling?
  237. Vag com for Palm or pocket pc
  238. 95 Audi 90 Q
  239. What is Vag-Scope...
  240. Anyone here in Central Mass? (hudson/marlboro area)
  241. A/C problems
  242. ECU recode question...
  243. What happened to Ross-Tech home page? I couldn't get in!
  244. Central Lock base code for RS4
  245. X post from B5. Can someone help me diagnose this code? TIA
  246. Need help, secondary air injection code 16795 on a 2.8, mechanic can't find anything
  247. does any one know what code #01423 in a TT mean
  248. Sorry for the noob ? but where do I look to find out...
  249. Need help from the great and powerful vagcom brains
  250. Allroad - 402 Modification Help!
