PDA
View Full Version : VAG-COM Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28
  1. unlocking the BOSE Gamma from SAFE mode
  2. Has anyone tried to recode the steering wheel???
  3. Door Control Module - Old fault or ongoing problem?
  4. Is it safe to use a ISO-9141 connector that has the ground pin broken off?
  5. HELP with ESP after steering wheel swap
  6. check engine light ...scaned and code 17547 fuel trim: bank 2(add) system too rich
  7. Short question regarding my Passat 1,8t AEB motor
  8. Need some help with 16684 and 16685 codes
  9. allroad VAG-COM anomoly
  10. Changing text in 05 start-up screen
  11. help with coding locks and windows of B6 A4
  12. I still can't clear the engine codes!!!(see 16th post down) This is what I have...
  13. no response from contriller
  14. KEY-USB Physical Interface Questions.
  15. "no response from controller" when accessing Module 08 - HVAC on 03 Passat 1.8t
  16. vag come to reset LN1 code. anybody done this before?
  17. is there a way have vag-com show if the temp gauge is accurate? or something.. :)
  18. VAG-COM License and Aftermarket Cable Question.
  19. When I try to pull up the codes it says to many communications error and if I start the car it works
  20. With a Vag-com or equiv. can you program the window buttons to work with key out?
  21. On Board Iagnostics Question
  22. 00792 AC Pressure Switch F129 open or short to ground, any idea how can I fix it or what to look for
  23. OBD II functionality....
  24. VAG-COM discovery of mine...
  25. DB9 connector strain relief broke on my twin-com & along with 4 inside wires
  26. Light Detection Sensor fault
  27. Recirculate Air w/o turning on AC Compressor
  28. Why can't I clear the engine fault codes with my vag-com......
  29. Alarm malfunction
  30. I can't recode the module of '05 A4 with Beta 212-2?
  31. Repost, "Radio Code"
  32. 18010 - Power Supply Terminal 30: Voltage too Low -- got code need help
  33. CAN gateway coding ?
  34. 00792 - AC Pressure Switch (F129) 21-10-Open or Short to Ground-Intermittent...Please HELP
  35. AT filter change and vag-com
  36. Vag-Com Noob
  37. Cant read transmission module
  38. whining gearbox
  39. Need code to do fog light mod......
  40. Any reason why i cant recode a 1998 2.8 a4 Tiptronic?
  41. Immobilizer problems ('03 A4)
  42. How to turn off interior motion sensor, 1998 A4
  43. Immobilzer codes
  44. Temp gauge slightly over 90 when temp is 90. Is there adjustment?
  45. HVAC no connection to ECU fault in 2002 TT? Something to worry about?
  46. Airbag DTC...
  47. Consumption is less than reality
  48. Will "402 mod" work on A8 (D3)?
  49. radio code and key number
  50. VAG COM noob question about 2002 VW W8 Passat codes...
  51. Redundant Question about VAG
  52. How do I change the sensitivity of the interior alarm.....if the sunroof is open and the wind blows
  53. Possible to change sensitivity of auto-recirc via VAG-COM? Maybe I have a sensitive nose, but there
  54. tcu part number
  55. Where can i get a Key made?
  56. is block 03 the correct block to monitor overall timing advance in the engine?
  57. Does N-E-1 know where is ignition fuse or relay, or clutch safety relay, pls. read there is more...
  58. VAG TOOL
  59. VAG COM questions
  60. Problem reading engine controller
  61. 2.8 12v Overheating
  62. I remember seeing information on changing the illumination setting of the instrument cluster, but...
  63. vag-com+can options?
  64. logging throttle angle and throttle pedal?
  65. Instrument Cluster
  66. anyone running prodiag on a treo?
  67. XPOST in B5 forum: DTCs 16395, 16706
  68. If running on stock wheels, how accurate is the speed measured by Block 005?
  69. Searched and came up dry. Getting the headlight adjustment warning light after adjusting the
  70. Horrible running, multiple DTC's, New to VAG
  71. 01177 - Engine Control Unit ---- 37-00 - Faulty
  72. Error codes
  73. Car not found? 2000 A4 with vagcom key-usb
  74. I just pulled some VAG codes...Would appreciate any insight on what might be causing them...
  75. Can VAG-COM be used while the car is turned on?
  76. Could someone tell me the Soft. Coding of the module 03-ABS
  77. USB or Serial (Ross-tech site makes me feel USB is less reliable)
  78. Control Module not coded? help
  79. Extinguishing the Pad Wear Sensor light after BBK- - >
  80. ABS problem 2001 S4
  81. Sunroof problem (could it be ECU related?)
  82. Uwe, is it safe to clear Air Bags on a '01.5 Golf 1.8T? Is there a list of safe cars to check?
  83. Possible to use the vag to correct for tire size and speedo differences?
  84. 18048 - Internal Contr. Module (EEPROM) Error
  85. Pittsburgh
  86. Hi guys, I just picked up ProDiag for my Palm, and I'm looking for general info on how to...
  87. Blocks on '92-'95.5 S4/6 (AAN)...
  88. Radio & Navigation Modules: Too Many Communications Errors to Continue
  89. help with codes pls
  90. Oil & Service reminders - 1999 A4 1.8T
  91. What are the pin-outs & wire colors for the serial connector to computer?
  92. Recoded central locks, now 1 week later windows with the remote won't work.....
  93. help with DTC 17538
  94. A Few Vag Codes - Need Help
  95. Found ABS module internal memory error
  96. Thanks Bruce for getting me started with the new VAG-COM tool....
  97. Error codes seen when ABS controller is failing?
  98. 000526 error - Audi A8
  99. can a automatic S4 instrument cluster be re-coded to manual?
  100. B6 and Key-Com... problems
  101. 2004 A6: Windows up/down with remote
  102. B7 A4 code for turning off seatbelt chime
  103. VAG-COM question, need advice from users!!
  104. Central Locking Pump failure
  105. Help: RNS-E on A4 B7 and tire pressure display
  106. Where are the TT VAGCOM codes?
  107. 5th Annual Audi Expo - Schedule:
  108. Anyone in Northern NJ wanna help me out...
  109. I've searched and... I think I know what the problem is but...
  110. Oil service reset & interval change 1999 A4?
  111. OBD II Diagnostic Tool
  112. 100 C4 quirks
  113. Is it possible to turn airbag off (passanger side) with Vag-Com - A6 2.5 tdi avant -01?
  114. What could cause a Main Relay Fault?
  115. vag com functionality
  116. bought full vag version, but having problems.....
  117. anyone know if the rearview mirror can be recoded to display the outside temp?
  118. VAG COM won't connect (I know, you've heard this before...)
  119. Best OBD2 software to get that works with Key-Com??
  120. What can I log to determine if a fuel/air problem is causing my symptoms?
  121. '89 Audi 80...
  122. 9 days 'til Audi Expo! - Have we heard from you ?
  123. DTC help please - airbag related
  124. VAG 504-1 Problem - Doesn't Save Logs - My Previous Version (404-1) Did - As Does Version 505-1 Beta
  125. STFA archives but having trouble. Hex-Can Usb and virtual serial port for Lemmiwinks.
  126. 1995 Audi 90 ODBII, how do i read the output of the Coolant Temp Sensor?
  127. Help with code
  128. Where do I go in the vag program to code windows and door locks to the remote key fob?
  129. Is ECStuning a authorized VAG-COM dealer?
  130. Can I use VAGtool cable to do OBDII diagnostics on other vehicle?
  131. Connection issues?
  132. New to obd2/ vag operation...advice please
  133. Unable to communiate with certain modules on my 02 allroad
  134. Xpost from S4 forum: Need help with first CEL at 69k miles.
  135. Blocks to log for IAT and Engine Speed
  136. Anyone in the ORLANDO FL area feel like helping me out with Some lean codes...I need to use a vag
  137. Cruise Control Retro-fit on A3 AP
  138. my software won't work on the new A3, am I missing something?
  139. do these vag logs mean i have a bad O2 sensor?
  140. Vag-Com wont recognize RNS-E
  141. Just did my first VAG scan on my car. Are these codes anything i should be concerned about?
  142. need help bad
  143. Interchangeable Ecu's ?
  144. VAG-COM wont recognize interface
  145. Need help determining immobilizer version
  146. Vag won't connect to my car!?!....
  147. Paging Uwe : When will the Key-USB be back in stock?
  148. Still a connection problem
  149. installation cd for VAS 5052 - Audi
  150. fault code 17956 "boost regulator Valve n75: open circuit"
  151. Door "Safe" function, doors won't "de-safe".
  152. 2 VAG questions: Have an R32 and I was wondering if it's possible to VAG toggle off
  153. Can I test my oil pressure with a VAG? and If I can how do I do it and..
  154. First VAGcom run
  155. Connection problems S4 4,2 -94
  156. help with codes
  157. Foglight Modules/Codes
  158. Service light + error code after upgrade to 504-1
  159. B5 - A4 - Tiptronic - Fault / but no Fault
  160. ATF level of CVT
  161. VAG in Boulder (will trade beer)
  162. "port ok" but "interface not found"
  163. I have a 2001 TT, Do i need to get the HEX-USB+CAN or is the KEY-USB ok?
  164. Need some A/C help here...
  165. Is it possible to trade up from KEY-USB to HEX-USB+CAN?
  166. check engine codes
  167. Can the radio and temp display on my B5 S4 be disabled via Vag?
  168. is there a 'one-touch' remote window recode
  169. Switch to stock on GIAC??
  170. unable to connect to control module 09
  171. 2004 A4 Service Interval
  172. Warm AC on 2001 A4, anyone know about the data banks?
  173. Any documentation on correct values for common problems?
  174. Connection Problem!!!
  175. 5th Annual Audi Expo - Come be a part of history again!
  176. Xpost - need help with codes for Cruise Control.
  177. Hey Uwe...any thoughts on someday making a product for Porsche?
  178. Service reminder reset question
  179. VAG-COM tool in Chicago
  180. anyone know how to bypass immobiliser 2? i just put a 1.8t in my corrado and ....
  181. Is it possible to screw your ECU up by using a VAG COM device?
  182. S4 99, hex-com, concert radio: stopped connecting after two years?
  183. I just bought a Phaeton - How do I VAG it?
  184. I lost all of my keys for my 02 TT, I try the new key and my car runs for 3sec...
  185. Problem A3 Engine ECU
  186. New VAG-Com user question.
  187. VAG-COM Help!
  188. Fault Code Explanation
  189. Paging: Andy & Company @ Ross Tech...Touareg question
  190. Oil pressure gauge vs. oil pressure warnig light
  191. Recurring Fault Code
  192. Ebay Auction
  193. Is there a way to VAG the recirculate button ON all the time on the air conditioner?
  194. RE: Need to rent VAG (obd 1) tool for 1hour in San Diego area ASAP.
  195. which cable for '02 A6?
  196. ECU swap question...
  197. odometer/trip out after cluster removal...
  198. Release 311-2 w/ Serial dumb cable, will it work on a 1997 Porsche C4S?
  199. Climate control temperature range? Changeable?
  200. HLP: Interface Status: 3 …quot; Not Found or Not Ready ?!
  201. New cluster.. No NAV. VAG Error
  202. Please help!! Fuel injector Duty Cycle what group do I log? need to check if it is runningat maximum
  203. RE: 2000-1 VW airbag module bug. Does the 2000 Audi TT share the same controller/bug? Thx!
  204. Reseting the Tiptronic to 6spd.
  205. Problems adjusting Xenon Range on 2004 B6 1.8T
  206. New VAG COM user with a couple of questions...
  207. update on an old post - still need help - is UnoDosTresQuattro still out there?
  208. Andy thanks for the help
  209. Noob question: When logging, is it common to get No Fault Found or DTC not supported by controller
  210. block 062: throttle valve1, throttle valve2, accel pedal1, accel pedal2
  211. ISO-COM and USB to Serial?
  212. Kinda OT: List of Coding options for '03 Jetta GLI? Sis just bought one. TIA :)
  213. nav display in cluster?
  214. VAG tool for B7 A4
  215. how acurate is figuring hp and tq logging block 120?
  216. Any risk of deploy aribag when messing with ECU?
  217. vas 5052
  218. Do I need to recode my replacement airbag ECU?
  219. Airbag value decoding (B7 S4)
  220. Code help am I reading this right...What to do...
  221. log deciphering... and takers?
  222. Airbag ECU toast?
  223. 18089 - Contr. unit programming not finished 35-00
  224. Block 119 translation help needed ...
  225. Engine Warning Light
  226. Where to find Codes for auto-up Windows on a B6 A4 and B5 S4, also....
  227. HELP!!!
  228. Receiving an error attempting to test Parktronic. It worked before I adapted anything, but after
  229. Can't communicate with module 02-Auto Transmission
  230. B5 Tip recode
  231. Brake Booster/Master Cylinder
  232. Anyone in Calgary with a Vag-Com?
  233. Change radio's on/off behavior with Vag-com?
  234. maf reading on 2001 a6 2.7 biturbo needed
  235. CD Changer not working with my RNS-E?
  236. Engine -> Measuring Blocks -> Block 003 is labelled incorrectly
  237. Need help diagnosing a problem
  238. Is it possible to make the tranny in auto mode be more sporty?
  239. My "information center" instant MPG readout is usually over 20 MPG when stopped. Why?
  240. New to system trying to figure out if I wantto buy...have trial version but I can't utilize it...
  241. Does anyone know if VAG com will work with the ECUx cable?
  242. Need Help - Cannot get Anything to Work
  243. 402 Mod Help Please!! Control Position Not Learned...?
  244. Repeated severe misfire, no CEL
  245. engine/ boost surging
  246. Swapped out ECU for an APR one and now getting code: 18057-
  247. any chance of vag-com ever being able to log more blocks at once and sample faster?
  248. X-Post-ish. Allroad with suspension height imbalance, 402 VAG changes not sticking.
  249. DTC help please...
  250. Where to buy the vag com licence and cable??
