View Full Version : VAG-COM Discussion
- audi q7 diagnostic
- VAG-COM in NJ
- im new, please help..what is Vag-Com?
- Suspension Settings on MMI - missing.
- Vag-Com San Jose
- Vag-Com cable in Nashville, TN
- Vag-com for beer! Fairfield CT
- Auto Windscreen Wiper Activation
- reset sri to 10k interval
- VAG-COM in RI
- Should I Click the VCDS Version Update Button?
- Immokicks in now and then. Dash/ECU mismatch?
- Which vag unit to buy?
- D gear display on '11 TTS?
- O2 Post cats readings blank, nothing
- New Bose Amp or Control Module???
- Need Help. Where to Go To pay for VAG-COM Mods
- 2002 B6 1.8T quattro - HVAC codes and clicking noise
- Backup Camera Calibration
- 2002MY Audi A3 1.8T - Terminal 30 problem
- Which measuring blocks to log? O2 sensors
- correct interface cable advice and purchase
- Setting readiness - O2 sensor tests and engine speed
- VCDS measuring block value vs. bentley Threshold value
- Q7 Trans coding getting Error 7F
- VCDS 12.10.3 Auto Scan function doesn't work correctly
- 01561-LR Door Can't Unlock...But it Does
- Ross Tech
- Gear number indicator on A5 Prestige
- key fob programming questions d3/s8
- MMI 3G...any way to enable gear number indicator next to D or S?
- XPost: Turning off RS5 Throttle Blips
- Ease of use?
- TPMS frequency issues.
- rns-e wont accept adaption
- VAG-COM in Santa Monica/Los Angeles
- VAG COM Beaumont Port Arthur Texas area
- Vag Com in the Waterbury, CT Area?
- A6 C7 Maint Indicator Reset
- Fault Code 01437 - 2012 Q7 Suspension Error
- Unplugged some modules-fault 01794 perform vehicle data learning, b6/S4
- Vag com in Los Angeles area (silverlake)
- Looking for cable advice
- vag com pin reader
- Remote operation of windows, up OK down No
- VAG-COM In Northern VA
- Anyone with a VAG-COM in Denver/Boulder, CO?
- VAG-COM ERRORS
- 08 TT changes, WA State(left coast)
- Vag-Com in Chicago Area
- 2014 Q5 coding help?
- VCDS EPB Control Module Error
- Anyone with a VAG- COM in Columbia,SC
- Found Vag Com in Kent
- 2013 audi A6 VAG COM
- Memory seat Help Please!!!!
- Can VCDS test-run the suspension air pump?
- 2013 S4 VAG-COM / MMI+ missing options?
- NAV default
- Vag-Com Error Codes
- My Scan
- Soft Coding VS Long Coding
- A6 1.8Q (ADR) 1996 - Vagcom results
- New to VAGCOM
- Graph tool for VCDS logs
- How long does it take to clear codes?
- I have to replace a start module in
- Vag Com in Connecticut
- VAG/COM request Exeter NH
- turbo controller read out and put on a new one?
- MMI 3G Clock
- New with VCDS experience
- Engine mount Solenoid and misfire
- 2013 S5 Comfort Turn Signals (cycles) Change
- A/C stuck in "econ"
- Fault Code Removal
- Completely stumped
- Looking for someone with Vag-Com in Kent
- SRI longer than 365 days
- TPMS Help needed in Pennsylvania
- Missing [ON/OFF/NEXT] Button missing in Basic Settings
- 18256 lonely code :/
- Door sensors keyless entry fault code
- A6 (C7) DIS logo
- Coding to disable speaker check of DSP Amp
- Reno vag com help
- adaptation woes.
- VAG-COM Codes
- Rain sensor off coding for Q5?
- Coding for shifter paddles
- Need help programing code for imobilizer
- VAg COm mods/ How to program/ list what you have
- Questions, questions, questions.
- D4 A8 level suspension
- Can VAG-COM do ABS/ESP module adaptation for '12 Q5?
- Adaptation Error
- Vag Com shows units in km not miles
- Street View
- vag com
- Seat Symmetry
- Requesting Headlight level sensor code interpretation
- VAG-COM + RaspberryPI + Arduino + Sensors...
- coming/leaving home retrofit
- scale and pointer illumination adaptation won't work
- Coming / Leaving home lights on C5
- Fuel injector electrical malfunction detected again 8 weeks after replacing. Ideas???
- B6 A4 3.0 Fault Codes.... Help please???
- 2001 Audi S8 Error Codes ??
- New A7 Mods
- anyone with vag com in tampa fl
- S5 facelift tail light coding NAR to RoW
- brake switch implausible signal
- Q7 DRL Mod
- Vag-com for setting up voice command
- Aux vent 2g no heat
- Torque (Torque Pro) OBD II phone app?
- generic OBDii software using Ross Tech interface
- Bucking in 3rd gear, audi a6 1997
- What is your advice about Vag-Com?
- Vag-com error
- Assistance with reading report from Audi Dealer
- Error Clearing Airbag Code
- Evaporator Temp Sensor Faulty?
- Is it possible to add or delete control modules?
- VAG-COM or VAD newbie dumb question
- Jukebox Import of Audio CD
- Newbie to VAG COM question................
- 2005 A6 independant fog light and MMI hidden menu?
- Seat Belt Warning Alarm
- Codes for Voice Operation - 09 A4 Cab
- I dont think anyone will figure this out...
- VAG COM in Chicago?
- Back in an Audi again.. VAG COM questions
- Issue when running an Auto-Scan
- Auto HVAC Fault code
- '06 A6 3.2 camshaft position sensor code
- Help!Gear selector display off
- Anyone with Vag Com in Houston?
- ABS/Traction Control/Parking Brake Issue!
- Audi A8 3.2 4E abs coding
- Vag-com'ed for Hitch and Lines dissappeared
- No ABS or ESP
- My VAG-COM readings. Need help
- Vag Com in Buffalo, NY
- Changing radio frequency US > EU with VagCom
- VAS PC?
- Can't get VAG-COM to talk to urS4
- New owner of 2010 Q7 SLine CPO
- VAG-COM for NAVI MENU Q3
- NEED TO SELL V6 4mo, have one nagging ABS fault! CAN YOU HELP PLEASE?
- VAG questions for S6...
- CVT Relearn Procedure, I dont know what to try next :(
- Checking O2 sensors
- 09: Cent. Elect. no long coding for ADS configuration
- 2003 A4 3.0 Fault Codes & advice
- 2000 A6 can't read any modules? after minor wreck
- Testing for a bad cat
- Any one selling a ross tech cable
- Misfire on all Cylinders
- Vag-Com Data after changing HPFP cam follower
- Procedure for finding vacuum leaks
- Another VCDS Newbie
- Power locks blinking and clicking, fuse 39
- Long coding
- Exhaust help!
- Vag Com in St. Louis?
- Fog lights and high beams on at same time
- Customize Coming Home / Leaving Home lights?
- Vag Com Services in MA
- nyc
- OBD II diagnostic port not functioning
- No Sirius Band-only AM/FM on MMI Q5
- Vag-Com Mods for hire (SF Bay Area)?
- A8/D3 Auto Transmission Recoding
- Help me get my menus back in MMI
- MOST issues? (Optical network)
- ScanXL Pro and VAG-COM
- Problem: 55 xenon range can not be reached
- cannot select car set up from mmi
- Advanced Key: disabling "Turn off ignition before leaving car" message & chime?
- Help with VAG COM
- "No Response from Controller" Help
- Request for security access code for module 53 : Parking Brake
- Vag-com engine>measuring block
- Fault Codes - help
- Recoding after battery change on A8?
- My VCDS readings. Info please
- VAG COM in Northern Virginia
- Q5 - reset stronic
- Audi Q5 Auto gearbox controller
- A4 2.0t engine sputters then turns off
- D4 A8 fault codes
- Fault Code in C6/4F A6 - Memory Seats
- Can someone please recommend some diagnostic Tool for my work shop?
- 99' A4 B5 tranny recode quection?
- Vag-com PA
- no response from controller HELP!!!
- vag com codes help-radio shuts off
- 2010 City Golf Vag-Com help.
- Ventilated seats
- New Comer questions!
- Euro Parking Lights 2012 C7
- Confused by TPMS code, anyone help?
- VCDS on Mac
- Changing Bulb Tail Lights To LED's
- A6 4G questions
- [REQ] Program Code for 76 Parking Assist - 4D / 2000 A8 D2
- ELSAWin - where's VAG Diagnostics section for Audi A3 8P?
- SoCal Vag-COM
- 2003 Audi A8 parking brake error code help
- Need VAGCOM read in south
- 04 Allroad 4.2 - Multiple code Help
- RNS-E, telling it is on dif continent.. Secret shortcut?
- seat belt warning/max speed
- 06 A8 4E vcds faults - level, xm
- NorCal VAG COM
- Injector code upgrade
- 98 A4 Codes Help
- adaptive headlight defective
- Vag-Com in Greenville, SC?
- New VAG-COM Owner Here
- 99 A6 issue
- Audi B6 fuel level sensors 1 & 2: Which is which?
- help for a new user of VCDS
- I think I bought the D3 the Army tested their EMP weapons on...
- disable TPMS with VAG-COM
- audi wiring harness repair kit
- A6 B4 17 Instrument Cluster
- Most problem
- Doors audi tt Error
- Service Due! even after RSI
- How to change Audi A6 mileage
- Audi A4/RS4 Bi Xenon to Bi Xenon with AFS retrofit
- Problem with my MMI for A6 C6
- Single reading Audi 2.8 -1992
- O2 sensor bad?
- Bentley manual, adaption & coding?
- auto folding mirrors
- Audi Drive Select & VAG-COM
- 2006 C6A6 4.2 first scan results
- Ross-Tech has a Job Opening for a Technical Support Specialist
- 2004 A8L First Scan Results
- 2012 Audi Q7 - Trying to set Window / Roof Up/Down via Remote
- Digital Speed Reading
- TPMS Frequency change ?
- Aux Heater Error Code.
- 2010 Audi TT
- 2012 S4 disable 1-tap "comfort blinking"?
- New Battery
