PDA
View Full Version : VAG-COM Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28
  1. A4 Odometer problem
  2. my computer still works?
  3. Which vehicle speed is correct? ...
  4. ok i tried STFA with no success, where can i buy ETKA 6?
  5. I'm using a MAX-COM with a USB-Serial adapter since my laptop doesn't have a serial port
  6. Speed signal
  7. Recode MAF? (or tranny?)
  8. noobie here too
  9. noob question...
  10. Airbag light is on in B5 Passat. Can I use VAG COM to find the problem?
  11. hey guys, if you car is over heating will it send a code to the ECU? if so what would it look like?
  12. I want to purchase the VAG-COM tool but have a few questions..
  13. v409.1 and 311.2 problems.
  14. DRL via VAG with US A4 (8E)....which lights will activate? Low Beams? Low Beams and tail? Or ???
  15. News story on CELs in general shows a VAG-COM in use on an A6.
  16. Possible to log IAT out of AAN (urS4/S6) motor?
  17. 2001 A4 2.8 with camshaft control malfunction, code 17927
  18. Camshaft Sensor Problem
  19. meas. Block 77 & 138
  20. 16506 Throttle Position Sensor Signal Too Low
  21. B6 A4, 2003 A4 1.8T code
  22. burnt out bulb indicator is on steady
  23. Just got a new car.....
  24. Getting interface status = 0, VAG-COM via USB v409.1 on 2000 S4.
  25. Newb vag/APR chip problem, throwing cels...
  26. DIY VAG wont communicate / Interface not ready
  27. searched but can't find block to log mph. Would like to see 0-60 and 0-100 times.
  28. VAG-COM Login Function 11 question
  29. steady ESP light and DTC 00526
  30. searched with no luck....one touch windows up for passenger window or all?
  31. Is there a way to VAG the auto lights on feature....
  32. How do I change 1998 A8 dash temp change from C To F also temp reading in heater controls
  33. saratoga NY area VAG COM?
  34. X-post: Help! My ecu isn't adpating my fuel trims
  35. Upgrading Twin USB cable and 3XX.XX software...
  36. Novice in trouble!
  37. Tiptronic recodeing on Audi S4(B6) problem
  38. lemmiwinks
  39. Source for basic OBD-ii cable ???
  40. OK, one more question... Is there a way of VAGing OFF the auto dim mirrors feature? Car is a B6 S4.
  41. Is this a cause for concern? Car is an RS6 if that matters any. Was told no biggie, but I'm having
  42. help newbie
  43. ABS Cross post from B5 S4 forum
  44. check engine light for catalytic converter
  45. 2001 A6 2.7t will not interface with vag-com....
  46. How to get rid of the seat belt chime?...2000 A4
  47. Should I replace the ECU??
  48. Hood sensor switch electrical cable was severed and alarm not arming
  49. newbe question
  50. Problem Connecting ProDiag to 2004 AllRoad...(on a Treo600)
  51. Engine module login code (europe)
  52. Anyone have a VAG-COM in San Diego/Orange County area?
  53. Group 30 O2s Ctrl
  54. Trying to recode Tip
  55. 0991 (lights) and 01367 (locking system leak)
  56. Will vag-com diagnose onstar problems? not many audis have it but mine is having problems
  57. A few codes to be explained
  58. DRL via VAG?
  59. Help with my Car and what i have seen while doing VAG logging.
  60. Ok, so this is a tiny bit off-topic (since it's not "VAG" related)... but can I use my HEX-USB
  61. Suggestions for disabling annoying seat belt chime in '04 B6 S4???
  62. VAG 00032 won't stick
  63. Of No Horn Sound, Loosing Codes and Other Inconveniences
  64. Vag'd my 2000 S4, got a central locking code....cleared it
  65. Got a CEL: Code 17544 & 18010
  66. Is there a way to keep the radio on
  67. Identify socket type GIAC uses?
  68. Vag the following codes b/c airbag light is on
  69. DTC 00797 Sunlight photo sensor (G107)
  70. X-post from S4 forum: ABS controller help!
  71. Help with fault code 16684, "Random Multiple Cylinder Misfire"
  72. Whether there are here users VAG-CHECK??
  73. Need help with ECU & Immo
  74. Need help with codes. Yes, I'm a noob.
  75. x-post stereo problems
  76. need help with some engine codes A4 (B5)
  77. Code 17965 HELP!
  78. Clearing airbag codes
  79. 18021 MIL Control Circuit Open or Short to Plus
  80. ODBtool cable vs Ross-Tech cable
  81. Can't find LBL file
  82. Hello!
  83. Question on ignition angle!!!!
  84. difference (in software) between vag-com ver. 311.2 & 409.1
  85. Pulled these codes, what are they and what do i do?
  86. Help - 2004 S4 VAG codes?
  87. Air Bad light came on... Need help
  88. 17536 - Fuel Trim: Bank 1 (Mult): System too Lean
  89. Why does my central locking module lose coding?
  90. Looking for someone with a VAG in sacramento area for help with my ar...
  91. O2 codes
  92. What kind of cool things can I re-program in my 97 A4?
  93. NewB Ques: Buying cable on e-bay vs Ross-Tech
  94. Looking to get VAG com but want to be able to do logging, etc....
  95. Check Turbo
  96. OBDII engineers wanted.
  97. VAG-COM help
  98. Noob question, adaptation chan. 62
  99. 7 digit security code :: Anybody been able to retreive this for the immobilizer?
  100. Measurement blocks for Audi S4 92?
  101. Will VAG toold measure the brake fluid level and...
  102. Serial to USB
  103. Tuning and Logging VAG Values...
  104. Serial Vag-Com Cable + ODB Software for Toyota?
  105. Vag codes
  106. VAG-noob question here...very easy I hope...just received my Key-com in the mail...
  107. Lemmiwinks and the instrument cluster fuse
  108. Another help thread.....car wont start
  109. Does anyone know how to even begin to troubleshoot this fault for a 2002 A4
  110. Warning Brake Light
  111. bought a used VAG-COM cable but it's serial and my laptop doesn't have a serial port...
  112. Does anyone know what this fault is for a 2002 A4 >>>>
  113. Newbie looking to Access Keyless Locking Feature
  114. Newbie needs advice to get into VAG for 2004 Allroad
  115. A6 2.4 v6 5v 1998 non start (55000 miles)
  116. No boost, what blocks to check?
  117. Unable to connect to Airbag module with VAG-COM?
  118. Daytime Running Light?
  119. 01 Jetta remote matching problem. Can only add one remote??
  120. Is there a way to read the coolant temp with a Vag?
  121. Audi S4 codes: D1217
  122. 96 a4 12v v6 FW auto tranny question for Ross Tech
  123. some minor problems ... :)
  124. Can I use a Bentley Diagnostics device to recode my car for
  125. unable to do basic setting for automatic trany
  126. cliamte control display flashing and blowing only warm air????
  127. Unable to Connect to the Airbag Controller?
  128. I changed to an aftermarket headunit on my A4(B5). Now, I'm not able to Vag the car.
  129. Race-Tech DL1 Data Logger
  130. Changed Lock Code; now trunk button no good
  131. What VAG-COM things can I do on my new A6 ?
  132. 1st cell phone with built in Car Diagnostic function
  133. vag com brake bleeding
  134. random thought: so Uwe, can you tell us whats going on in your skunkworks?
  135. Help - '00 TT turns over, will not start. Can't access Engine Module via VAG...
  136. Question regarding vag diagnostic after check engine light went on..
  137. problem with onboard diagnostic system A6 2.8
  138. Repost, still having problems. 1993 90 2.8v6 mms200
  139. Shareware Version. To Decode all DTCs
  140. Measured Group 000 and found these
  141. question about how to get a serial number
  142. Brake Wear Warning Disabling - Confused about code found
  143. Can anyone help me out. Codes inside.
  144. Att: Andy got a Vag question
  145. 96 a4 12v fwd . no Vag codes but car only goes in reverse
  146. Immo 2 - 4 digit code plus strange Xtra field
  147. n00b questions
  148. Service Minder change
  149. Can I swap the steering wheel radio only controls for radio/phone controls?
  150. I need to replace an airbag controller, ? about copying software...and I did briefly STF.
  151. Immobilizer Programming (STF and still not clear)
  152. Uwe & Co.; you guys know anything about this device installed by Audi or VW?
  153. anyone have this code before?
  154. Anyone use a thinkpad T30/40 series for VAG?
  155. Is there any program like lemmiwinks that works with a 98 A6?
  156. Uwe and Andy...Thanks for the help today.
  157. I'm trying to access the Cruise control module on a 97 A6
  158. Lemmiwinks problems
  159. Need some help with VAG COM results.
  160. Butt dyno help
  161. Software limp problem (cont.)
  162. REPOST: Car to USB cable. Where can I get one? ?
  163. Logged block 115 on 2003 a4 1.8t APR 1+ ver 2.0
  164. Anyone want to rent their VAG-COM to me?
  165. How do I re-enable the oil service reminder
  166. Just got rid of my ProDiag - hated it. About to order Key-Com and was going to download...
  167. vagcom wont work on some cars
  168. ECU question....Electronic experts opinion wanted...
  169. Car to USB cable(for my new ECU X) anybody have an extra for less than 99 bucks?
  170. Use HEX-COM with Palm V in generic OBD-II mode?
  171. cross post - VAG gas gauge adjustment help, anyone?
  172. Same codes for A4 and S4?
  173. Having trouble eliminating the brake pad warning icon from the trip computer.
  174. Anybody has VAG in Atlanta, Emory Area, and willing to try Mod on my 98 A6? Will appreciate it!!!
  175. Software Date Code or Version?
  176. vag com question
  177. anybody come up with a trip computer mpg correction factor for A4 k04 kits?
  178. Anyone know what these fault codes mean?
  179. Do I really need the HEX-USB?
  180. My '00 2.7 has an after-market turbo timer....more
  181. List of codes
  182. 1998.5 1.8t...what procedure would i perform with vag-com to
  183. buying used cable and software, is 311.2 good enough?
  184. Help! (Read Fault Codes on 99+ Audi in Boston Area)
  185. When I remove the key all acesssory power is gone, it used to stay on till a door was opened..
  186. What is the code/how do I do it: turn off the ringing sound when the door is open and any lights...
  187. Keep throwing this code, might have to do with my car not reaching full boost...
  188. Where can I go to find the following.
  189. Instruments for B5 S4 - Brake wear indicator, et. al.
  190. searched, but just too much out there to make sense of for a vag noob like me
  191. Who Can help me with the following codes???
  192. VAG for fogs with parking lights on '04 S4??
  193. Recoding Tiptronic
  194. I want to get rid of my secondary air pump system on my 00 A4. Any way I can recode the computer...
  195. What are the best things you people have done with your VAG's?
  196. anyone with codes for upgrades for a 00 a4 2.8??? thanks.
  197. Trying to use my USB HEX Twin COM cable as a USB Serial Port
  198. no live data
  199. Bose stereo question
  200. is there anything like lemmiwinks/vag for bmw/mini?...for a friend
  201. Uwe Question on Upgrading from OBDTool
  202. Shareware Vag-com limitations
  203. ...need to know if a tranny can be recoded and a general vag question
  204. how do i do the tip recode on a 98 a6q the 00032 code...
  205. Why no support for "pre-modern" interfaces in the latest version?
  206. Does this block 02 data look correct? Trying to diagnose richness issue.
  207. interface
  208. Need info on this CEL Code I have: P0118
  209. Anyone knows how can I disable rear glass alarm sensors via Vag-Com on 2003 AR?
  210. System Rich / MAF Saga Part 2.... Ran Some Tests.
  211. will a new ross-tech cable work with other software????.....
  212. SRI A4 2002
  213. what are the causes of this (exclude the coolant sensor cause I have replaced 3 times)
  214. Help.. Car doors do not lock or open. Code 01367......
  215. HELP ... Anyone know where I can get the ECU soft coding for a 2001 A6 2.7t ?
  216. my MAF is F-ail-ed ?
  217. VAG-COM questions (I'm a new Audi owner)
  218. Problems with vacuum and fuel trim
  219. Anyone know if the Ebay OBDII-RS232 diagnostic works?
  220. Can VAG-COM be used to adjust timing and or boost, or do I need Lemmiwinks for this?
  221. Would running lean caused a misfire in the cylinders?
  222. 2000 VW Jetta, dual k-lines or not? I don't *think* it is but...
  223. Conflicting Errors???? Rich and Lean?
  224. Airbag Light on!!
  225. ross-tech shareware vs. full?
  226. Help with codes.....
  227. Uwe or Andy: are the USB interface cables sold separate from the software?
  228. does anyone have a Hex-USB+CAN that they would trade for a Hex-Com+CAN...
  229. baud rate questions / auto vs fixed
  230. The men of Ross-Tech to the rescue?
  231. What is it that Ross-tech guys do on this forum?
  232. ROSS-TECH vs. EBAY
  233. My CEL reset itself!
  234. 8d reprogram the radio so it doesnt turn itself off with the ignition
  235. Continuously getting the same 2 fault codes!
  236. Can you reset the fault while the car is running?
  237. Do I need a VAG-Com?
  238. Is it worth getting the hex-com for a 98 a4?
  239. Ok, i have a vag-com system with the Hex-can adapter...
  240. Can someone take some time and plz expalin wats this VAG COM thing is??
  241. HELP!!! Recoding ECU is not cooperating....
  242. I am very saddened to inform everyone that John S. passed away this past Tuesday...
  243. New Vag-com user question
  244. Is there a trick to make the climate control system operate completely manual when not in Auto mode?
  245. Is it possible to disable the low fuel and other warning "beeps"?
  246. I need a little help figuring out what some codes mean.
  247. DRL's with stock dash lights??
  248. Is throttle ever "Full Throttle"?
  249. Can VAG-COM shows current oil pressure?
  250. Would using a Lucas gas stabilizer can caused misfire code?
