PDA
View Full Version : VAG-COM Discussion
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. Andy & Co....Ordered today w/FedEx 2 day..Can it ship Wed please?? GTG on Sat my place..Thnx..
  2. Any way to turn off license plate "light out" warning with vag-com?
  3. Help please....
  4. Is there a way to turn OFF the feature where the car turns ON the overhead lights when i turn off...
  5. Does the VCDS have any way of removing Component Protection?
  6. Anyone using an Asus PC? Just talked to Andy and did not want to bother him again<more>
  7. What could the repair shop's computer diagnostic have done?
  8. Need a little help: "005 - No or Incorrect Basic Setting / Adaptation"
  9. Symphony II+ Coding - Is there more to be unearthed?
  10. Ross-Tech Vag?
  11. ODBII and VAG-COM readings.
  12. Measuring Block 32 - AHA engine ('98 A4 V6 30V)
  13. How turn off brake wear sensor warning on instrument cluster?
  14. Help with fault found
  15. "free" VAG-COM
  16. Is there a way to get real TPMS on an A6 (instead of the idiot light)?
  17. NAV + Airbag: Internal Control Module Error?
  18. Code 17584 - bank 1 lambda correction downstream catalyst: limit attained
  19. Immo 3 issues
  20. "CAN: Not Ready" Message
  21. VAGCOM Service Reminder blackout with VCDS ver. 805
  22. VAG-com in Waukesha/Milwaukee area?
  23. Vag-Com in MOntreal
  24. P1409 (Tank Ventilation Valve Circ. Electrical Malfunction 17817
  25. What exactly does setting Adapt Ch 01 to 00 do on a 2001 ECU? What are the factory defaults?
  26. What does this mean..."18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage D"....
  27. Problem coding the instrument module????
  28. Vag-com download issue
  29. Need help with codes misfire 2.7T please help!
  30. Need help please with analysis of logs, RE: P1127
  31. error code P1612 on my Audi TT AWP
  32. Error code 01336 From radio
  33. Vag com codes what do they mean
  34. A4 2003 1.8T QU Central Locking No Response from Controller
  35. Cannot perform ECU output tests!
  36. Low requested boost, what can cause it?
  37. MIL on no codes readiness passed
  38. Can a Ford PWM cable be used on an A8
  39. New to VAG-COM
  40. Vag Com-OBD-Acura
  41. Musical VAG-COM serial numbers
  42. VAG-COM Can''t clear all DTC with ebay cable??? Help!!!
  43. Redline tested my MAF, could anything else be the cause of bad readings?
  44. remote key fob adapt help plz!
  45. no response from controller - ABS/Brakes modules
  46. Secondary air injection system Leak test
  47. Anyone know if I can use my VAG COM cable to scan a 2000 Ford Contour?
  48. 2000 A6 2.7T Nav Not Working Nothing Displayed on Info Display AirBag Light Wont Eras
  49. Now I'm confused - possible MAF code, MAF replaced
  50. new to vag
  51. Grrr... Air conditioner stopped working yesterday...
  52. Audi A4 (8E-B6): 1) Instrument coding, 2) Trip Computer and Cruise Control fitting
  53. VAG-COM vs. VAD Mobile?
  54. Will the new 805 Label files work with 405 software??
  55. level control sensor help
  56. Difficulty disabling Seat belt Chime on 2006 A4 B7 3.2
  57. Is there a way to disable the Auto Lock of the car.. Not the speed based one..
  58. 1999 Audi A6 2.8 Quattro 93k miles CEL Help P0441 and P0445
  59. Auto HVAC - Not able to read
  60. did search need to disable TPMS in 2008 A3 TIA
  61. Need some help with Vag-Com
  62. HVAC Basic Settings
  63. recoding central locks [35] - is the AW tech article still valid for a C5 S6?
  64. groups 26 and 27 on VAG 409.XX?
  65. Running out of things to replace, still getting a code.. Getting a consistant 17549 - ......
  66. Thanks to Uwe and entire Ross-Tech team, it made our used car buying experience very sound...
  67. Need help interpreting log data
  68. Any way to have log files saved to diff directory then Installed_directory:\Ross-Tech\VCDS\Logs\ ?
  69. Is it possible to get information about which dealer serviced my car last
  70. Cross-post: My latest check engine light problem from STP cleaner?
  71. How to adaptations for instrument cluster (B5 A4) please!
  72. Kudos to the folks at Ross-Tech...
  73. Need help with central locking recode gone wrong
  74. Swapped instrument cluster, now no radio info in center display...
  75. Lexus automobiles and VAG-COM
  76. Steering angle sensor calibration issues with Vag com
  77. Throwing a code, need some help..P1128
  78. Gas gauge not reading full after fill up
  79. Can I use my Vag-Com to temporarily turn off ABS? My ABS controller is messed up, and
  80. BT issue
  81. Can't run ABS pump with VCDS 805.0 or VAG-COM 704.1
  82. VC on a OBD-II Car
  83. Why does VCDS 805.0 keep prompting me to install it each time I reboot?
  84. Please help with VAG-COM and activation of a new key...
  85. x-post from the TT forum: Need help with a CEL - 17584 (P1176)
  86. Where to look to buy second hand (other than e-bay)?
  87. Uwe? Andy? Theresias? Anyone?
  88. What's changed in the newest version?
  89. Need Help! - A6 2.7t with AWE RSK04 kit - Logging block 115 & 119
  90. Need Help! Keep getting no response from controller. I have a HEX-USB...
  91. Any way of changing the 10,000 mile Service reminder to 7,500?? X Post
  92. old vag.com owner with new vag car....(cable question within)
  93. Post overhaul codes help (VAG-COM Rocks!)
  94. Any way of changing the 10,000 mile Service reminder to 7,500??
  95. Surging/Throttle Issues in chip mode. Have Vag codes. Need HELP!
  96. New To me Ross Tech Vag... Q's within..
  97. New VAG User
  98. Fault Code on 2007 A8 4.2 TDI (D3)
  99. vag com on audi tt
  100. Couple codes and CEL is on.
  101. 12 Hour Clock
  102. Help with some codes...
  103. VCDS 805 Manual - Availability?
  104. A4 B5 Alarm coding
  105. HP/TQ numbers from Vag com?
  106. VAG COM problem
  107. Lable file update?
  108. is it possible to see the boost pressure through the VAG?
  109. Reprogramming key remotes with Immo III
  110. i cant seem to get vagcom to connect to the car
  111. A3 Concert II+ satellite tuner install
  112. Q re reading readiness codes for 1996 and 1997 12V 2.8L engines
  113. Question on Vag Com Hex USB cable and Bentley CD manual?
  114. Which Blocks to Scan (Coolant, Thermostat, etc)
  115. Can VAG-COM change Audi A4 (B5) not to require 91 octane fuel?
  116. Buy my car - seriously.
  117. Tried recoding so my doors lock at 10mph, and windows roll up with remote... code won't save
  118. If third gear pulls are troublesome for data logging would second gear pulls up a hill be better...
  119. Air/fuel ratios with vag-com?
  120. What to buy????
  121. HEX-COM vs. KEY-COM
  122. Trying to cycle ABS, but keep on getting "No response from controller" message
  123. VAGCOM borrow in upstate new york (Ithaca)
  124. Headlight Range Control Defective - 2004 A4 with Xenons
  125. just got my new vag cable. I'm trying to recode my trans module 05 S4 to hold gears any help
  126. Any way to test for a dying turbo with VAG-COM?
  127. Anyone have a VAG-COM for sale?
  128. Bentley Official Factory Repair Manual
  129. My Vag results any help why car wont start?
  130. instructions for 00 passat sought: any help here?
  131. Help with my fault codes... Please :)
  132. Cruise Control module for B5 1998 Audi A4?
  133. Vag-com users
  134. BT puck adaptation settings
  135. air bag coding 05 A6 C6 4.2L
  136. Is anyone else having problems getting their vagcom to work on Vista O/S?
  137. Does 'Rain Closing' coding work on the Mk2 TT?
  138. Help on KEY FOB Window control and DRL? My setting was 0423997 and i changed it to 0424125
  139. Audi A5, Amplifier, Long coding
  140. vag codes for the MK2 TT
  141. i down loaded the beta version so i could see how the long code helper works. Everything ran well..
  142. VAGCOM model number for allroad is A6 .......................?
  143. Is there a way to recode the ESP/ABS/EDL so that all electr aids are disabled except for ABS?
  144. no start 1996 audi cabriolet
  145. Will VAG-COM Hex-Can unit work for 1995 Jetta VR6 with OBD1?
  146. Got vag-com running under ubuntu linux and virtualbox
  147. Fault code: 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
  148. Need VAG-COM help in Columbus, OH
  149. New to AW
  150. Cleared DTC's - False Positives
  151. B6 Fog light codes?
  152. Headlight out of range error - can I disable the level sensors using the vag-com?
  153. Vag-Com help with some codes...
  154. anybody with vag-com in the los angeles/SFV area i will pay!!!
  155. P0430 with VAG-SCOPE Output
  156. Two years and still don't have the naviagtion on the cluster (FIS)...help
  157. New cable / Nissan / USB
  158. Ok, I just ordered my package and am hoping to play with it tomorrow. Is there a way that i could
  159. 1999 Audi A6 Check Engine Light P0455 and P0441
  160. What, if any, modifications to Mag-ride are available via VAG-COM?
  161. What voltage should the 02 sensors read when checking them w/ a VAG
  162. OBD II location for VAG-COM on 2007 RS4
  163. Stupid Q - Can VAG-COM check engine compression instead of doing it manually with comp gauge?
  164. Airbag error 01219 decode.
  165. VAG-COM and VAS5051 crossreference help
  166. Engine Code 16500 / Coolant Sensor Circuit
  167. How do I vent/fill the front airbags using VAG-COM?
  168. Is there a discount code for forums members to purchase the tool and repair cd?
  169. New VAG-COM interface - Thanks Ross-Tech
  170. Basic VAG-COM questions...
  171. Defective bulb recognition delete?
  172. Airbag question...
  173. Just pull out some code from my car.
  174. Question: Need help why Ext Temp is not displaying
  175. Can't find the codes on wiki ross-tech
  176. 18034 - Powertrain Data Bus: Missing Message from TCU
  177. fault code question
  178. Whats the problem? instrument cluster or fuel sensor
  179. A4 / S4 B6/B7 Cab Seat Controller Coding
  180. Stalling On Start Trouble Continues -- Codes Included
  181. What are some cool things I can do with teh VAG-COM?
  182. Cannot connect to 93 100 airbag
  183. Troubleshooting help needed: High rpm, full load miss
  184. VAG-Cable with other OBDII interfaces
  185. Getting at the turn signal flasher relay on an A6 with wood trim
  186. bay area vag-com help
  187. Need help!!! Car not seen by VAG tool
  188. What The F#$%! Need help with my set up
  189. Lambda Control stuck at 1.00
  190. Side lights and voice
  191. HEX-CAN interface was working but now has interface status=-1...
  192. auxillary emissions control?
  193. I've seen a list of VAG-COM owners by region but I know not where. Here or...
  194. Audi A3 autoscan results, help appreciated with codes
  195. Can't find the interface
  196. Starter field-winding strap to voltage readings
  197. How to disable TPMS in a 2008 A4?
  198. Any help with this code?
  199. Front or Rear O2?
  200. 1998 Audi A4 - need Airbag controller recode number
  201. 16558/P0174-System too lean, bank 2. But NO irregular behaviour (edited).
  202. Newbie- needs reassurance
  203. 02 VW Cabrio 2.0L codes...
  204. B6 1.8TQS - Help with Codes
  205. Need suggestions for CHEAP laptop to run VAG only....Thanks...
  206. Remote Key Matching
  207. Cant' figure this one out. Can someone help?
  208. Redir Fail!
  209. Need some Vag/Vista help...
  210. A6 SDS?
  211. My Key-USB is not working, and burning the fuse. Is there anything simple I
  212. Can I Test The Fuel Pump Amp Load, Rpm or Overall Performance?
  213. Crank no start
  214. I understand it that the VAG Tool will work only on one PC, if I am getting a new Laptop in a month
  215. I have a friend that upgraded fron Halogen to Xenon Ecodes on an A3
  216. Vagcom For Nissan Maxima 2000
  217. VAG noobie here... What does it mean? RS4 4.2V8
  218. Is it possible to see why a code wont take? (Tip recode to 00012)
  219. 00771 causing inaccurate fuel guage
  220. DTC 17584 Thoughts?
  221. Saw the ross-tech A4 on the Merritt yesterday morning
  222. VagCom different than OpenOdb - which one is right?
  223. Anyone ever have an O2 sensor start working again?
  224. Are there any VAG experts in the Folsom, CA area who could teach me more than just how to read codes
  225. Audi Allroad
  226. Is it possible to read/clear the DTC's from an intelligent key wirelessly?
  227. which version of VAG COM for a 96 TDI passat?
  228. faster way to find module killing bus?
  229. Which Vag com 2001 A8L
  230. One Key is now not working
  231. '04 S4 Instrument Illumination
  232. Car Will Not start!. Audi S4 01 6sp.
  233. Just received my cable...not sure if it's right?
  234. airbag dtc 65535
  235. Oil Level Display - Where is it?
  236. Can somebody in DC area please reset my "service" indicator light?
  237. Can I Change Automatic to Shift With Thumb Paddles While in D? Using
  238. Need help,DTC 16725 P0341228 What does this mean and
  239. Andy/Uwe with the release of the iPhone SDK, is there any plan to create...
  240. Trying to save a 1997 a4. Lots of codes. New to audi'. Need help.
  241. Just got a flashing CEL and loss of power on an entrance ramp. Codes were clean...
  242. Is there a vag faq? i would like to read and reasrch more about it.
  243. If my battery is "DEAD" , will I not beable to "jump" start using cables - just want to confirm
  244. audi s4 2002 b5 i need to buy a spare key can i use vag to program my car to detect the immobiliser?
  245. Reversed Jump Cables, now Vag-com cannot connect
  246. Misfiring codes, any way to know if it's plugs or coilpack? or something else?
  247. Is the VAG-COM cable for the Q7 the same as the RS4?
  248. Can Vagcom do Immobilization stuff for the new key?
  249. Engine Coolant Temp. Sensor (G62): Signal too High
  250. asking VAG guru and rosstech reps.
