PDA
View Full Version : VAG-COM Discussion
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. 2001 Audi tt a little assistance please
  2. VCDS 19 Can Gateway security acces code
  3. 2.0 issues
  4. 2006 A3 wont start after shorting a wire
  5. 2013 Audi A6 Security Code - Parking Brake?
  6. Factory VCDS Values - 2013 A6 (Central Electrics)
  7. VAG-COM in Hendersonville, TN Area
  8. Coding a left headlight control module
  9. DTC codes on 2018 S5 SB
  10. Recording Bosch 5.3 ABS Unit
  11. Vagcom code reader
  12. Tech question, more ODIS than VCDS...
  13. I need a new blower on my Q5 2012, right?
  14. XENON Headlight connector 14 PIN wiring conf. for Q5 2015 to retrofit NON AFS --> AFS
  15. VAG Com - capabilities thread
  16. 2013 A7: Service Reminder Interval (SRI) reset
  17. VAG_COM in San Mateo - Available
  18. BEM/BMS Battery Coding Reverse Engineering
  19. Obd2 scanner link error
  20. MMI 3GP green menu goes wrong
  21. NEED a remote coder from Europe. Virtual Cockpit installed PFL A3
  22. Liftgate works via vag-com only
  23. Left rear window regulator
  24. Mmi problem
  25. VAG-COM general inquiry
  26. HELP: B5 Parking Lights on Driver Side F&R not working!
  27. Audi a3 2001 8L 1,9TDI
  28. Audi Q5 8R chassi key programing
  29. Reset Battery Adaptation on 6 month old battery?
  30. Vag-Com in central NJ ?
  31. testing post cat O2 sensors via VCDS?
  32. audi q7 4m svm code foe headlight
  33. Audi A5 2010 2.0 TFSI (CDNB) engine fault codes
  34. Any VAG-COM in So-Cal? Will pay cash.
  35. Belt tensioner igniter problem Audi A3 8L
  36. Dynamic Turn Signals 2019 Q7?
  37. VCDS in San Diego,CA
  38. Major Electronic Fault
  39. MMI2 settings reset. No login
  40. CAN BUS Powertrain location on RS3
  41. Replaced Climate Control Panel
  42. Help with S7 Air Suspension Fault
  43. Am I able to change this in the MMI?
  44. Electrical symbol Help
  45. Help
  46. Available VAG-COM in St. Louis, MO!
  47. Vag-Com VCDS
  48. CCM replaced, but...
  49. How do I get started with VAG-COM? Tutorial?
  50. Need to get into hidden green menu to enable aux
  51. a6 access start modlue locked up steering wheel
  52. 2004 audi a8 4.2
  53. Unlock doors when shift into Park? ('13 Q5)
  54. Fold in side mirrors 2003 RS6 C5
  55. No Power Windows or interior lights need diagram
  56. No Power Windows or interior li vj jts
  57. No Power Windows or interior li vj jts
  58. A6 c6 Beep on unlock
  59. Locate ECU for 1995 Cabriolet
  60. Can VAG COM 409-1 with VCDS-Lite work on C7 models?
  61. 2010 Audi A4 2.0 USA No crank questions
  62. Need help with my vag com on A8
  63. Fault code 154624 vcds audi a6 c7
  64. EGR testing with VCDS - valve only opens a tiny bit!!!
  65. Intermittent AC failure
  66. KDataScope-best log viewer available?
  67. calibrating a sunroof with missing settings?
  68. abs
  69. Manual gearbox replacement, do i need coding?
  70. Posibility adjust interior bulb light ignition off
  71. Electronic steering rack coding
  72. Vcds coding puddles Audi Q7
  73. 2 OBD2 devices trough splitter ( safe ?? )
  74. tcm coding
  75. Frozen MMI - Three button restart won't resolve it.
  76. AC not working 00532 code
  77. 2015 a3
  78. Multiple Codes
  79. 2010 Q5 Satellite Band Disappearance
  80. Clustrer/ECU/IMMO problem
  81. OBDEleven and my sunroof
  82. A4 b6 driver door anomalies
  83. 2014 Audi A4 B8 grayed out driver assist menus
  84. Service due 2011
  85. Low compression/no copmression on audi a4 quattro 2007
  86. Audi tech weenies in Seattle
  87. dpf
  88. Hi there!!! weird issue.... no vin un databases... no data... ni unit or serial...
  89. A3 8V Rear Door Illumination Problem
  90. Starting issues 01672 Main Relay Load S6
  91. My new to me 2012 A7 had the Hidden MMI available
  92. ECU backup help
  93. P0491 P0492 Insufficient Air flow
  94. ABS G201 , Audi A3 2005 questions before ordering repair kit
  95. A4 B8 new steering column - High beam problem
  96. Dead MMI on B8 RS4 (2013) UK
  97. High beam fault Audi A4 B9
  98. A6 C6 electric supply problem, what could be the cause?
  99. Vag Com wouldn't connect to 3.0TDI A6 Allroad
  100. Coding a new non-VAG battery?
  101. MMI System
  102. Boost Specified < 400mbars - FTW?
  103. 2009 A8L faults and strange behavior
  104. pdc
  105. 2008 audi a4 s-line aftermarket led problem. HELP ME OUT THANKS!!!
  106. Windshiled wiper problems.
  107. UK origin A4 2.0 Avant TDi Auto Need code help
  108. Adaptive cruise control
  109. Audi Drive Select - adding after delivery
  110. Audi A8 MMI issues VCDS Help
  111. No power to dash
  112. A6 C5 Wont start, no OBD II signal. Help please!
  113. Sport View in Virtual Cockpit
  114. Recommendation for a vag com reader
  115. B6 halogen to OEM Xenon coding question?
  116. Logging to Help Diagnose 3.0T Excessive Fuel in Oil Issue
  117. Coding help control module incorrectly coded-tdb
  118. Act. for Ext. Noise, Fault 0005 - Incorrect Vehicle Type
  119. Houston Vag-Com
  120. Houston Vag-Com
  121. VW no communication between VCDS and 44 steering assist on Golf5
  122. Is the parking sensor sensitivity adjustable?
  123. Considering this 2007 A8L
  124. Looked at 2007 A8L today, screen was stuck up!
  125. ANy way to adjust Bluetooth in call volume with VAGCOM
  126. Looking for a Manual Transmission Audi Starter Push Button electrical diagram
  127. Audi TT faults and blower motor question
  128. FTP in Audi A6 2010?
  129. Boston VAG COM
  130. My VW Passat
  131. A6 2.0 TDI 2006 Blower fix
  132. Audi A6 C6 BPP - DPF Replacement not working
  133. vcds lite
  134. Minivag 505
  135. S4 B8 front and rear washer not working and error code 00926
  136. Audi A6 C5 4.2 suspension module
  137. Audi A4 USA to EU
  138. 18082 - Powertrain Data Bus: Implausible Message from Instrument Cluster
  139. 2012 A6 Heated Seat
  140. 2010 audi Q7 Codding bosch battery
  141. 2018 RS3 Lane change assist code, unable to clear it.
  142. Audi s5 rear brakes change without a battery charger.
  143. Which VAG-COM to buy
  144. ECU puts out 5V but sensor only getting 0.5V
  145. AFS error 02627 ( V318 ) and 02233 (J667) - Audi A6 07
  146. Status: Cannot be reached 1100 (cant find any solution)
  147. Recoding B8 A4 BCM
  148. 2008 VW TOUREG ECU SWAP
  149. Board computer question
  150. vcds??
  151. Scrolling bytes in long coding
  152. Audi 1.8T 2003 - Wipers Horn Indicator Windows Sunroof all stopped working!
  153. 2003 Audi a4 1.8T
  154. 05 A4 - Help!! disabling bulb out alert
  155. Need help on swapping broken CCM !! And Symptoms
  156. HID leveling fault on a Skoda Octavia
  157. Error code 00665
  158. Error code 00665
  159. VCDS error when attempting to clear code - 2001 Audi TT
  160. 016 enable / disabled
  161. Key fob working but not working 2008 A4
  162. WTB VCDS For 2000 Audi A6 C5
  163. DPF Remaining Life ?
  164. VW-Group module problems!
  165. 2009 A4 00778 - Steering Angle Sensor (G85) 014 Defective
  166. Communication error Audi TT 2008 2.0
  167. 1998 A6- intermittent a/c, ABS and tachometer
  168. Can't find brake controller 2008 Audi TT
  169. a4b6 2001
  170. Brake lights stuck on
  171. Audi A8 jump start problems
  172. Disable start/stop B9 A5 SB
  173. Front Park Assist Sensors
  174. Need CAN BUS wiring expert, to tell me if this will work to add memory seats to Q3
  175. Warranty after APR ECU upgrade
  176. Other steps for enabling Hidden Menu on C7 S6 in USA?
  177. TT MK1 Cluster Swap
  178. MMI optical view Park assist A4 B8
  179. Electrical faults
  180. Is the HEX-NET worth it for a single vehicle?
  181. Can I add colour to the ambient lighting?
  182. Tuned ECU swap MY15-GTI to MY15-A3
  183. VCDS lite can't find ports
  184. Change Logging
  185. RPM engine rev limits
  186. check engine light
  187. Las Vegas or California tech people?
  188. Bank1: cmp sensor(g40)/speed sensor (g28)
  189. Ignition sensor problems
  190. Help clearing Service due indicator
  191. 2004 A4 1.8 Turbo, flashing PRND gears on dash
  192. Audi Smartphone Interface
  193. I bought a used 2010 Q5 3.3L. I have an engine code for MAF
  194. S5 unresponsive to key, camera glitch, and garage opener
  195. Audi A4 2.0T 2005 model
  196. 2018 S4 "blinker sweep" - turning off dumb US square?
  197. OBD11 &EOBD code reader issues A6 4.2 C5
  198. Auto close with rain sensor obd11?
  199. Does VAG-COM HEX+CAN work with Audi 2018 Q5?
  200. Comfort Turn Signal
  201. TTRS monitoring haldex fluid temperature
  202. VCDS or VAG COM in Eastbourne
  203. VCDS-New Faults Found After Clearing of DTCs
  204. VCDS slooooow after update
  205. 2012 A4 EEPROM FAILURE
  206. VAG in socal OC
  207. 2007 Allroad TDI Quattro ECU
  208. Air bag
  209. How did you guys start with VAG COM?
  210. Air Bag
  211. a6 4f 2010 no long coding disappear
  212. auto level headlights
  213. auto level headlights
  214. changing instrument language
  215. 2006 audi a6 drive cycle
  216. VW Passat 2.0 TDi 2009 Won't Start, Keeps Turning No DTCs
  217. Audi A4 99 problems.
  218. Concert to MMI 3G plus upgrade
  219. lots of codes
  220. 2017 Audi S3 Virtual Cockpit VCDS mods to RS3 spec
  221. Window lift motor, Driver side.
  222. Audi rns-e retrofit to a4 2005 code problem
  223. Problem with coding after replace Motorola fixed instalation with Bluethoot module
  224. 02E DSG learned values; resetting or recalibrating?
  225. VCDS... which set-up? 09 Q7 and 13 Q5
  226. New To Audi and Their Systems
  227. Anyone with a VCDS in the Seattle area?
  228. A4 comfort control module
  229. a4 b8 rad fan testing with vag com
  230. SUPER CHEAP VAG COM ALTERNATIVE
  231. Audi q3 ambient temperature sensor
  232. vw passat dsg gearbox
  233. audi A6 blower motor not running
  234. 2014 Q7 - Help with a few odd VCDS mods (if possible)...
  235. i have problem with my audi a8 d3 2003
  236. Help with remote opening windows
  237. Vag com
  238. Help with VCDS Autoscan Results
  239. used part gateway data bus reprogramming
  240. Q5 gear box
  241. Fault found after coolant pump recall
  242. VAG-K+CAN
  243. PepBoys scam???
  244. Audi a4 B8 with Audi a4 B9 steering wheel
  245. 07 Audi A6 check engine light! HeLp DeCoDe!
  246. Help: Computer randomly resetting all the time
  247. workshop manual
  248. Vcds coders
  249. A4 1.8T B6 Struggling to go forward on D
  250. Compass pointing wrong way
