View Full Version : VAG-COM Discussion
- C6-A6. Is there a way to turn on/off the active cornering lights with Vag-Com?
- Suggestions on what these O2 errors mean (scan error enclosed)?
- A3 8P Windows Recoding question
- CEL - VAG COM results posted in message. Any suggestions
- CAN Gateway recode help?
- What is a ZUG 219?
- Where do i find vag info in the bentley repair manual?
- What does a label file do for you?
- Sirius Tuner
- Jason, you didn't hook up the VAG to the A6 did you?
- Potential fix for seat back memory issues
- swapped ecu / how do i recode it from manual to tip
- CAN gateway. New coding help ??
- how do I get VAG-com to work with my iBook? what programmes do I need?
- Faults Codes Found...
- Do I need to reset the readiness code for the engine check
- Help diagnosing codes.
- A little confused after reading... Will this cable work on 98 A4 and a 02 A6 2.7t?
- How do you turn off the door chime on a B5 S4 with VAG-COM?
- Vag com login.....how
- Help please w/ airbag control module code 65535
- Vag com login problem...
- Just orded a vagcom, have some qs.
- Label file for '03 A6 Engine Module 8E0 909 559 E
- Need help with a couple codes, 00600, 00800
- 2000 VW Golf GL Errors 00652 & 01192
- Is it possible to disable the passenger airbag light on 07 RS4?
- Hardware question - which cable is needed
- Any VAG COM help available in South Jersey/Philly areas? Check Engine light came on today. Thanks
- Help with Scan
- P0174
- VAG-COM Fault Codes....need help understanding what is causing CEL:
- Very strange problem - CAN-BUS communication error
- How to use lemmiwinks to help look at A/F ratios?
- Just ordered Vag-Com
- I guess I'm the first one with this Code....
- Can someone from ross-tech give me some insight here?
- Just what can this VAG-COM thing do for me?
- HVAC recoding - A4 - 98.5 - V6
- A8 2004 Phone Activation
- Ross-Tech is moving!
- Old Style MSFW with Tip - Coding for Allroad
- P1545 clearing
- I have a Sym II radio from a 02 Allroad in my B5 - Can anyone tell
- 1990 V8 workability
- Seat memory not working at all in 99 A6 Avant
- guy emailed me and ask for my help, but dont know how to do this. could anyone help me?
- Need Help with Central Electronics Coding
- Question re: testing ABS controller
- Yaw Sensor Reset
- Audi RS6 - Error's - Car will not start
- is it possible to use an OLDER version of Vag-Com to work with off-brand interfaces
- can't install vag-com using USB interface adapter
- Intake Air Temp. sender fault
- What ever happened with the Gallardo research?
- RS4 Brake Wear Indicator
- Any way to adjust the Low Fuel Warning Beep threshold?
- Need help with codes pulled at Advanced Auto:
- Need some help. I just did Valve Cover & CAM Position Tensioner gasket and now I got 16727 code
- Code 16486 - MAF problem - getting 0 g/s
- VAG-COM hacks?
- Question regarding the 402 calibration on the allroad
- Fogs + Automatic Headlights?
- code 17819
- Version 704.1 is a little sticky
- Help with interpreting VAG codes
- Do the old bentley CD's work with Windows Vista?
- Heard you could..... Please read
- Couple codes Help please... On my 01.5 S4 Tip Thanks!
- VAG-COM conflict with GPS
- Any way to force the ECU to re-run the readiness tests using vag-com?
- Random/Multiple Cylinder Misfire CEL
- 2004 A8 Transmission recoding
- VW Golf 2000 2.0 Which Vag Com Cable?
- Vag-Com on daughters Nissan . Compatible ,never showed code but CEL went out.
- Upgrade Dongle question for Andy
- VAG COM and CEL light on
- I have D3 A8 with advanced key, one original key, and VAG-COM. Can I add a second key myself?
- Generic VAG-com vs: OBDII ?
- 1997 A4 scan Q Red light on Hex-Com light. Where to look?
- Please Help with Mk3 Golf DTC Codes for Trans
- Address 63 and 73 What are they?
- Need confirmation from VAG experts: only the dealer can marry a immobilizer ECU to a car, correct?
- Need help with some Auto trans codes
- sticky accelerator
- 2007 Audi A4 Cabriolet - Euro Light VAG Code
- Help with data chart...
- Rought Idle and new sounds... (2000 A6 2.7T Stg3)
- Need some help with Audi A3 and ABS.
- Need help with the codes...
- Need Help:: Multiple Codes Causing Limp Mode (1.8T)
- Help with codes
- Airbag light
- 1994 Audi Cab - Flakey VAG-COM Communication -
- A6 2007 with HEX-USB autoscan does not work (rel 704.1)
- Tranny recode 00032 not working...
- Coding help: 08 TT Roadster (8J) and Remote Roof Open?
- Is it normal for ABS controller to lose communication with VAG-COM during driving?
- Is this a **genuine ** Ross Tech VAG-COM?
- Any ideas why I cannot access adaptation channels 05-08 of the Engine module on my...
- RS4 RSN-E Favorites
- ABS/ESP VAG Problem
- ECU + VAG = 18012 (Help)
- Please add Porsche to RossTech!!
- Error: 18161 46F1 P1753? Tiptronic F189 Unplausibles Signal
- I need to check CEL codes on Volvo S40. I have RossTech VAGCOM
- question about Vag-com compatibility with Audi TT airbag controllers
- Two power related codes: 18010 and 00668
- 2002 B6 A4Q apparent can bus issue autoscan inside
- Paging Andy@Ross-Tech... What is the advantage of paying
- Airbag code recode. Searched archives and got few results
- timing question
- Oddness with selected electronics on '04 A8L
- Air bag light, vag com cant communicate with controller, using shareware version
- question about programming new remote key
- 94 90s Airbag light came on.. Vag-Com won't scan airbag.
- Haldex communication errors... need some help!
- Engine management warning lamp
- VAGCOM
- Cannot connect to Module 55 (Xenon Range) * pls help !
- sorry if dumb ques. the vag doesn't supply power throught the usb
- misfire detected...
- can you soft code a 2001 b5 ecu 170hp to work on a 2004 b6 ecu 170hp?
- Seeking SE Michigan VAG-COM for B7 A4 HELP
- Did search but can't find why Faults created by "Alarm triggered by Luggage
- 16684 & 16686
- Clearing CEL to pass smog
- Where is J533 ("Data Bus On Board Diagnostic Interface") ?
- Code questions for 2005 A8L. What codes modules and codes should i be using to
- transmission issues: 18034 - Powertrain Data Bus: Missing Message from TCU
- 2008 TT and VAG Coding?
- 704.1 hangs on XP, works fine on Vista..Need help.
- APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
- Does the ECU store a code for engine over-revving? Meaning that if you mis-shift...
- Which Groups in measuring blocks will tell me if seat module (36) is commanding the seat motors ?
- What's wrong with my transmission control module?
- Engine and Vag adaption channel info
- Is there recode/adaptation for the boost sensor? (2.7T)
- Computer bug?
- Need help with ABS and ESP lights 02 a4 1.8t NYC area
- Anyone in Colorado Springs with Vag-Com this weekend???
- any1 wanna tell me wat these codes mean?
- Can Vag-Com tell me whats wrong with my 6MT A6 tranny?
- 02 or cat..still trying to diagnose
- VAG COM communication problem or ecu problem?
- On a 2001 Audi with the AWM engine is there a way to read the
- Label file for 98 A8 D2 climate control, anybody ?
- eBahn and download content vs. CDROM
- Measuring block 32???
- Can Vag Com tell me if the Driver Seat Module (36) is commanding the seat motors ?
- 02 or cat issue..what logs to run?
- Which ECMs are codable for a 2000 A4 2.8 TipQuattro?
- Alarm going off-codes below-Help!
- ABS Encoding
- 4D0 907 551 _____ : What does the SUFFIX refer to?
- Help with a TT code please
- Can VAG-COM do advanced testing on the Memory Seat Control Module?
- Car doesn't know the doors are open
- Great...VAG faults... What might they indicate?
- What Vag Com Code?
- Memory Driver Power Seat Dead
- Greetings. I'm trying to determine if I have a TB sensor issue....
- will getting a vag replace getting the sps for revo software?
- FYI: OBD-II port will not function correctly if you added another port and have something plugged in
- What does DTC's means?
- how do i look at knock on a 98.5 a4 30 2.8 with vag-com?
- Need help: all of a sudden, my TT won't connect to scanner
- HELP! I am Having trouble resetting my Service indicator. ...
- need some help
- A4 B5, where to change code for transmission for auto transmission on my manual car
- does the "view readiness" option for the engine work?
- Firmware Update Error
- ECU Recoding Inquiry
- I scanned my car because my coolant temp sensor light was on and this is what I got...
- Anyone with VAG in NJ..................
- S4, with new engine, idles rough on restart...
- Airbag light again
- Latest scan from my 02 B6
- what are pins 1 and 5 for on the OBD port?
- Anyone got a VAG in / near Savannah, GA? (desperate)
- vagcom version 704.1 fault code 01562 (door lock)
- Accelelaration Tests - How accurate are they?
- EPC Light on (Camshaft Adjuster)
- Solenoid short to plus code
- Reading fuel pressure
- airbag light
- Bad Airbag Controller?
- Help with a code...
- Need to buy a vag com, but need it to work well with vista..
- Airbag light on
- Group 032... on a 98 A4 1.8T Q
- Needing O2 Sensor Edumencation -- Chicago A6 4.2 50v V8 - Any assistance appreciated . . .
- VAG-COM will only detect vehicle if car is started...
- USB HEX COM and CAN data
- Can you have 2 OBDII ports in a car?
- anyone located in Augusta GA w/ VAGCOM?
- No fuel
- Code P0513
- My vag com results and logs HELP!
- STFA and VAGd pulled 17963 - Charge Pressure: Maximum Limit Exceeded
- Fuse 14
- After VAG I have an Xenon Not Adjusted DTC - help please . . .
- KEY-COM with PCMCIA serial adapter possible???
- LEMMWINKS ( BAD ECU RESPONSE)
- vag-com question on a 93 urs4
- Code keys for remote window closing etc on '00 S4 what is the procedure w/ VAG?
- Remote control matching issues
- My VAG cable gets stuck sometimes..and needs some minor force to pull out is there a solution 2 fix?
- Thanks AW and Vag Com
- Power Outlet Question (cross post with AR forum)
- Connect directly to ecu?
- VAG-COM Directory... I've seen that on here but can't remember where...
- Can't change timing setting...
- looking for a vag-com code.
- considering vag-com for 03 A6- but want "future flexibility" for a
- HID leveling sensor
- Airbag fault code A4 B7
- Q7 CAN Gateway (19) Coding Info
- Whats the difference between "Modern Serial" and "Twin USB" interfaces?
- Ebay: Genuine Ross-Tech VAG-COM with KEY-USB Interface
- Ross Tech at TT-Central in STL next week?
- Probably Silly and Ill Be Patronized but what is the difference Between Vag Coms
- Big thanks to Ross-Tech!!!
- Does anyone with a USB HEX COM want to trade for my SERIAL HEX COM?
- Help with changing Concert radio to support LINE-OUT
- Calling all Audi Techs!
- Fault Codes Found!
- Help doing catalytic converter test with VAG-COM
- Xenon headlamp adjustment procedure?
- Planning on getting a new laptop but it won't have serial to support my Hex. Is there a reliable...
- Vag-Com interface
- programming remote key 2001 quattra TT
- anybody has a ross tech cable for sale?
- Does anyone know how to turn the DRL and Citylights together using Vag-Com?
- VAG-COM or another OBD II scanner?
- Enabling headlamp indicator on the dash, halogen equipped B7
- Avg. Injection period readings....pls help.
- Fault Codes Help
- Audi A6 TDi stalling
- DTC 16805: Warm up catalyst; Bank 1: Efficiency below threshold. Is this a bad cat converter?
- Audi TT180QC VAG code needed for tank sensor
- What blocks check for cylinder misfires for a 2005 b6 s4?
- How do I completely remove VAGCOM from my system?
- 03 s8 fog light mod
- S8 Start Screen
- new coding won't save...
- 2002 1.8t in limp mode...is this code the Mass air flow sensor?
- Bleeding...
- Dealer cooperation with coding
- Help with 4 codes needed please....
