PDA
View Full Version : VAG-COM Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28
  1. Ok, buying a VAG
  2. Question about block 006 on TT
  3. Problems with Trottlebody alignment
  4. Read values of the Engine Speed sensor (G28)
  5. Can I find out what my radio code is with the VAG-COM?
  6. Anyone with a VAG tool in the Bay Area (No-Cal)?
  7. AUDI A4 Diagnostic problems
  8. can some one translate this for me?
  9. Shut off
  10. Calibrate Fuel Consumption with VAG-COM
  11. can I access my Gamma Bose thru my C4's OBD port?
  12. Error Code3
  13. Can the Hex-Com+CAN interface monitor data packets on the CAN bus?
  14. going to be VAGing the car this weekend
  15. Can I use my ISO-COM/VAG-COM to check turbo boost in real time?
  16. INT-2 on Cluster Display....How do I reset?
  17. Help: car just dies at idle... and trouble starting
  18. any special codes?????
  19. Cant connect to the CLC Module..
  20. 97 auto a4 tba problems
  21. VAG part no. according to Vag-Com?
  22. Make a "vag-com" for Porsches!
  23. Swap mile to kilometer
  24. Need some help with a code! I'm on the A6 board and this question is better suited for here.
  25. Anyone here from Ft. Lauderdale?
  26. help interpreting fault codes
  27. Uwe any price yet on Hex-com upgrade....
  28. Need some help w/ codes. TIA
  29. I just bought a VAG tool used and it is supposedly an older model. Need help.
  30. passat electrical problem
  31. Intake Manifold Pressure Error
  32. Can anyone tell me all the coding options in module 09 (Electronics Ctrl.) for a 2002 A4 1.8TQMS
  33. Does anyone have CAN codes (address and data) for multi-function steering...
  34. When i get my VAG-COM will i be able to program it so the doors will lock after 5 mph? TIA
  35. Fault codes
  36. 99 1.8 Turbo 5spd - Electical Issues
  37. Transmission Control Module
  38. European Engine/Drivetrain Codes
  39. 2004 All Road VAG help needed ...
  40. Does a serial VAG COM work with the B6 A4?
  41. I got the Bentley CD for my 2002 A4 1.8T
  42. What does the HEX-USB-CAN do differently than the HEX-USB did?
  43. Anyone here using Vag check
  44. Vag-Com in Twin Cities
  45. San Francisco, CA
  46. Diagnose ABS control module with Vag-Com?
  47. Has anyone with an 04 A4 figured out how to disable the seatbelt warning chime yet ???
  48. vag 16955 break switch circuit: malfunction
  49. Help - Resetting Air Bag Light....
  50. faulty powertrain data bus? what does that mean?
  51. Unusual VAG numbers after air-intake install?
  52. Uwe or Andy
  53. Need codes to activate cruise control...02 S4...
  54. Check engine light is on and Vag-com register a 16502...
  55. 2004 Northeast Audi Event -- June 25th & 26th
  56. Partial Vag-Com Communication
  57. anyone reset their service intervals with pro diag?
  58. Use Vag-Com to calibrate replaced longitudinal acc sensor?
  59. Disabling modules of instrument cluster.
  60. I just cleared an airbag code, if the problem occurs will the light come on again?
  61. Xenon Plus DRL codes?
  62. Any way to change the 3 blinks to 6 blinks (turn signal) for '03 A4?
  63. Help needed: Self induced TBA/Throttle Body Cleaning Errors?
  64. CEL came on today and vag-com wont connect to any controller except the radio
  65. Do I need to recod ethe ECU after I unplug and plug it back in? I recode it before
  66. hi, any one have a used vag com for 97 audi a6 for sale/
  67. Help with Alarm
  68. airbag light
  69. Oil Pressure and VAGing
  70. Somebody bought a VAG-Com for $160 on eBay. I don't think they knew what they were doing.
  71. 1996 A6q A/C
  72. VAG-COM; cured my airbag light problem
  73. New airbox - now throwing codes 16486, 17536 and 01314
  74. Any of you guys know how to code my stereo back to Bose?
  75. help with using VAG to adjusting distance to oil service...
  76. VAG tool question> Exactly what does the VAG1115 tool look like....
  77. does a 2000 a4 with xenon have dual k lines?
  78. S4 alarm tone
  79. VAG-COM
  80. Wierd VAG Problem
  81. Anyone with a Vag live near Rochester, NY?
  82. Stupid question: Where's the Vag port location for a 1993 S4??
  83. HELP, check engine light :(
  84. NEED HELP - VAG Program Issue?
  85. upgrade firmware?
  86. Coupe Quattro?
  87. Uwe, is there anyway to log 2 values not in the same measuring block?
  88. I just went from Euros back to crappy stock headlamps - the light looks sickly
  89. Car Computer
  90. Got new laptop and doesnt have serial port for vag, I need an adapter, but where can I get one??
  91. tried to change the instrument language today and couldn't log into 17 on my 2000a4
  92. error on tba for dbw...
  93. Anyone here near Toronto Ontario Canada With a VAG??
  94. Bi-xenon upgrade on A4 -03
  95. Do I need to reflash????
  96. Blocks134,004,006,118, all have intake temp. Is it the sensor post IC but b4 intake mani?
  97. When using vagscope is there a way to record the peak boost value...
  98. different modes for rs-232 serial connection...
  99. Ross-Tech software upgrade Q...
  100. HELP ! Multiple cel came in dash today... Any idea? Vag results inside
  101. Any way to change the computer readout on the dash?
  102. Uwe or Andy, are you guys here yet?
  103. ran a scan today on a 92 100cs and couldnt access 01
  104. Question on upgrading from Release 311.2 to 404.0 under XP ...
  105. what do these mean?
  106. What are the top 5 or 6 common VAG codes that everyone performs?
  107. Does anybody in Northern NJ have a VAG i can borrow or use with you here?
  108. tried to code my auto-up windows
  109. How can I reset the "service" on the dash computer...
  110. Membership to the "official" VAG-Com group - how long???
  111. usually take a long time to get activation code for software?...
  112. Trouble connecting to engine, 93 90, iso-com.
  113. Can I disable the brake light malfunction light with vag?
  114. Any one in Miami Florida wanna help me out with Some vag Codes for my 2003 a4?
  115. Does anyone think this method for adjusting the trip computer will work on the A4?
  116. 99 Passat 1.8 17544 code?
  117. UPDATE: problem with doors locking automatically
  118. For a 1996 A4, With Vag-Com can you .....
  119. 2004.5 AUTO WINDOWS HOW????
  120. POLL: those with odbtool.com and a 2003-2004 AUDI any problems? next any others connector to look
  121. Andy, when will a vag-com be avaiable for BMW?
  122. ROSS-TECH you have any HEX_USB that someone returned and I can get the 20% discount?
  123. '91 passat codes
  124. Output test to check boost?
  125. Anyone know how to test the Ignition Control Module with a VAG-com?
  126. 2004.5 Passat VAG Questions
  127. could anybody help me with this fault code please TIA
  128. If I'm running VAG, can I use The Bently CD at the same time?
  129. here a good link for vag-codes
  130. Anyone selling their setup?
  131. ABS Coding and Poor Brake Performance?
  132. This radio codes seems to be comming back all the time...
  133. Just came back from dealer after 2 days trouble shooting starting prob
  134. CEL light
  135. HELP! My S4 is throwing a bunch of codes!
  136. can jetta or passat program remote windows up&down?what's the code for it?
  137. what's the code for remote window up&down and autolock door at 10mph for B6S4
  138. Anyone in S.W. Denver w/ a vag-com?
  139. can't synch baud rate
  140. Dont buy anything from(Motodyne)
  141. Noob here...is there a master list of all the nifty things that can be coded on my '02 A4...?
  142. Label file for 4A0-907-551? 93 S4
  143. can some VAG-com pro take a look at this
  144. Can anyone give me some advice on getting VAG SCOPE to work?
  145. Vag-Check and Pocket PC
  146. bordcomputer
  147. Need TachoPro
  148. 2000 Audi S4 Radio Problem
  149. 1999 A6 - Can't connect to HVAC
  150. Taking VAG to the next level
  151. New "Component Protection" for 2004 - Andy are you aware of this??
  152. can someone tell me the code on a b6 to have all the doors unlock
  153. Coding Radio Concert
  154. D2 A8/S8 brake pad wear indicator
  155. I couldn't find any information regarding Twin-com b6 s4 compatibility
  156. Cross-post: Original stock audi radio died, and now vag com won't connect either
  157. Upgrading VAG Tool - Purchase Outright option
  158. com issues on thinkpad i series 1400
  159. X-post from A4: Can you help me out with some VAG codes? TIA
  160. anyone know about adaptation with the TPMS system and the vag com?
  161. A few vag-com questions
  162. 402 mod...help!
  163. trying to remote windows code in 04 allroad with no success- I've tried...
  164. B6 A4 ECU swap questions
  165. Measuring block list
  166. S3 Central locking, Window Close
  167. hey uwe or andy, got a question for ya regarding vag-com and vas 5051
  168. Hey Andy! Any idea on when the Bentley A6 CDs will be in?
  169. Codes on my A64.2
  170. Removing window "pinch" control feature?.?.?.
  171. reseting xenon back to factory specs...
  172. Does Ross-Tech Vag-com Coparable with European version AUDI?
  173. typo in block 033? shouldnt it be "Voltage B2S1" instead of "B1S1" twice
  174. 2004 A8 L CAN Interface....
  175. Airbag Control module incorrectly Coded, can i recode with same code?
  176. O2 Sensor Failure Help!
  177. i was wondering how to
  178. Roll odometer forward
  179. for those who have 225 TT and VAG.....
  180. cartechsolutions.com interface
  181. Newbie Q's: Auto Transmission: Setting Timing Retard During Shifting
  182. Dumb n00b question
  183. 96 A4 Signal,Climate Control, and Part of the Instrument Cluster Goes out Intermittantly
  184. what RossTech Vag-Com can do but most other cable vendor cannot do?
  185. Noob ? Is block 115 what I use to check my turbos? Anything else? TIA
  186. Question on "BUTT DYNO 6"
  187. Scanned my car yesterday with VAG-COM and presented the following codes...>>>
  188. Software for kilometrage rollback
  189. I searched, but just to make sure....
  190. Does VAG-COM
  191. For the tranny of 04' A4 1.8T, my HEX-COM only can work by "Force HEX Dumb" !!!
  192. Q for Ross-Tech - I cannot open block 115?
  193. Will VAG COM work on anything other then a VAG car?
  194. problems recoding a tip car for sport shifting
  195. Just got an older laptop and docking station...next step..
  196. 2004 Northeast Audi Summer Event Info/Registration/Forums/Site is up!
  197. Other sources of USB cable for VAG-COM besides Ross-Tech? ...
  198. Ok I am an idiot.
  199. URGENT: in the middle of recoding ecu!!
  200. Problem with my actual boost readings...
  201. WTB: VAG-COM cable
  202. ECU swap woes
  203. I'm new to VAC software. Could someone shed some light of these codes I'm getting?
  204. Vag-Com, read volts from Lambda
  205. 97 vag auto probs
  206. Vag-Com to auto lock when remove key in A6?
  207. Xpost: VAG error
  208. 8do 907 559 ecu ?
  209. specified vs actual boost (ch115) - lag and peak after, whining noise
  210. Interface status = 3 when trying to check engine fault codes....
  211. anyone selling a pre-loved interface??
  212. Vag-Com longitudinal sensor configuration problems?
  213. 17964 charge pressure STFA it seems to be a discrepancy with boost levels this is the only code ...
  214. A8 instrument cluster information question
  215. Is there any information on the voltage range and their meanings for the knock sensors? b5 a4 1.8t
  216. n00b question. Which is better? HEX-COM or HEX-USB? Site makes it seem that HEX-COM is. Differences?
  217. CEL 17695 turbocharger bypass valve open
  218. Re-coding ECU
  219. Questions about using my VAG-COM during a dyno pull...
  220. Connection varification
  221. Setting Service Interval Problems!!! Ross-Tech Help??
  222. Is there a way to setup the VAG-com software so the gauges would display automatically?
  223. cluster lights through VAG-COM?
  224. can anyone verify that Vag-com can do a component test on 92 100 tranny
  225. PIN/SKC numbers
  226. When HP and TQ are calculated with the vag, is it considered wheel or crank? TIA
  227. Movement sensor keeps setting off alarm -- any fix?
  228. Just got a vag-com! How do I reset the throttle on a B6 S4?
  229. Can you check the R134a level/pressure with a Vag?
  230. logging MAF and timing question..
  231. "vagging" for fog lights... again...
  232. Need info about A3 computer please
  233. Need some info about a specific Code. 17544, what it could it be?
  234. Not starting a pissing match here...
  235. How to do this with VAG-COM, basic settings for longitudinal acceleration sensor?
  236. Does any body know about this code? (m)
  237. Can the brake servo be actuated with Vag-com for bleeding the brake lines on a 2001 225 TTQ?
  238. Uwe, Andy, or any other Ross experts: Is there an COM-Port emulator for my HEX-USB??? (more)
  239. 02 Jetta 1.8t auto ???
  240. after running auto-scan cel, epc and battery light are on
  241. 2 Fault Codes - 16795 & 17522 - 2001.5 1.8TQ - GIAC chipped w/ exhaust...
  242. Looking for VAG COM in Orange County CA - please e-mail me
  243. Increased Sampling Rate for HEX-USB
  244. Any codes for 04 1.8t to change lock, window settings etc? Thanks
  245. ABS, p-code 01279, clues anyone?
  246. WOT 1st2nd3rd Max engine load is 149%. What does this mean? <M>
  247. x-post. Anyone ever use a Toshiba e755 or e740 to run VAG-check Software with OBD tool?
  248. X-post from S4 Forum. VAG pros- does this mean I have a boost leak?
  249. "Service !" light... anyone know how to turn off on 2000 A8 ? I'm stumped ! thanks
  250. VAg codes....please help
