View Full Version : 2.0T FSI Discussion
- 2006 A4 2.0T rough idle
- HPFP plastic broke
- audi 2011 tts oil change
- Starter Replacement B8 a5 (2010) 2.0L T
- RPM bouncing
- HELP: 2009 Audi A3 2.0T Shudders with light acceleration
- 2007 TFSI 2.0T Audi - Cylinder 1&3 Pressure Test
- Another Oil consumption question
- Race Chip on A4
- Timing Belt
- Grind Going into 3rd Gear
- How big is coolant tank
- 2011 q5 2.0T engine coolant sensor location
- Help, coolant levels
- Help needed! Q5 RPM bouncing up and down
- Misfires after new plugs/coils/turbo/MAF/Cat/Airfiilter
- Engine whistle between +0 and +5 psi boost
- crankshaft part number
- Intermittent knocking noise driving me mad!
- Oilpan removal
- HELP with fuel line connector
- S3 engine cover on A3
- Leak in Air Intake System and Turbo Underboost
- How did they get 252hp?
- Trouble with transmission P0706
- 2005 Audi A4 2.0t dtm problems
- P0302 cylinder 2 missfire
- A/C won't work
- Audi wont start
- 2009 Audi A4 P2015 Code
- What to replace?
- Starter replacement 2007 a4 2.0 fsi
- CAUTION tfsi owners
- B8 A4 Quattro 2.0T Engine for 2012 Facelift vs 2013 onwards.
- Help with a 2007 A3
- 2007 Audi a4 2.0t Multiple things Wrong
- Need help
- Cam follower
- Audi Trouble Need Help
- 2.0T Engine light and EPC light
- Engine light on
- 2010 Audi A4 2.0t misfire
- Identifying 2.0T FSI Turbo Oil Feed/Return Lines *Oil Leak*
- Whining noise associated with RPM Help!!!
- Problems with 2009 Audi A4 Quattro
- Main Cel - codes P0171 , P0442 , P0456
- Vacuum Pump Install Help
- 2.0t fsI oil windage tray
- Asking for help, pcv issue again
- How to install new timing chain on 2.0T TFSI engine (2009 Audi A4)
- 2011 a4 relay location
- Is Audi cheating on "oil consumption test" on 2.0TFSI?
- Audi A3 with serious problems?
- Boost leak, need help.
- Starter
- Catch can or pcv delete
- 2010 Audi A3 2.0T Engine- Ignition Coil
- 2013 Audi A4 Reverse Lag
- Heater issues
- Is 06H 103 373 J and 06H 103 373 K compatible?
- What turbo does the 2009 Audi A4 2.0T have?
- Will 2008 Cylinder Head Gasket Set Fit 2009 A4?
- Need help on misfire..
- what is this part called?
- 2006 A4 quattro gas line fuel pump to fuel filter
- Stolen Air Duct
- 2007 removed engine but won't turn
- How is the timing chain involved when replacing a crank seal
- B8 A4 weird idle issue
- Help! A4 2.0T won't start!
- Trouble removing oil filter
- DO I REALLY HAVE TO REPLACE ENTIRE TURBO UNIT OVER FAULTY WASTEGATE VALVE??!
- Stock Timing belt brand
- Anyone Get Oil Consumption Problem Fixed Under Legal Settlement?
- Audi A4 B8 8K 2.0 TFSI - Engine Repair, what do you think?
- NJ: Audi 2.0T OIL CONSUMPTION ?
- Please help! Audi TT MK2 2008 - Possible Vacuum Pump Leak - MIL ON
- overboosting
- Hesitation
- Engine noise
- Does this cylinder wear look normal?
- 2010 A4 replaced Pistons and rings. Now failed ignition cool?
- Oil leaking around valve cover
- Chugging
- timing belt
- General 2.0T Questions
- oil change intervals for 2.0T TT?
- difference between auto and manual trans motor swap
- Dipstick and MMI oil discrepancy
- port and polish
- b7 sline bul engine lack of power Help!
- 2007 audi a4
- 2009 A4 Quattro misfire
- Cooling fan issue
- need help 2.0tfsi
- All Cylinders Misfiring
- 2005 Audi A4 2.0T Quattro Rear Driver Side Wheel
- Balance Shaft
- Change of pistons and rings due to oil issue
- Noob technical question: S3 engine differences from "normal" 2.0T?
- OIL PRESSURE - красная масленка
- new turbo leaking oil
- What years consume oil?
- Please help with p0321 code
- is my matrix blocked??
- 2.0TFSI ccta cylinder 1 misfire and rough ride. Odd details in post.
- coolant temperature sensor
- CAI and Exhaust Upgrades to 8j tt 2007
- Coil pack replacement as part of regular maintenance?
- Whining noise from A5 2010 2.0 TFSI
- Please help! Engine clicking
- Misfire with no obvious cause
- Shaking and Smoking
- Quatro Drive
- new car blowby query 2.0T
- Oil Drain gasket size?
- High pressure fuel pump fail
- Can I use a typical non euro 5W30 synthetic in my car?
- Help! A4 has no power.
- crack/ hole back of head on side opposite vacum pump 2006 A4 2.0t
- P2015 2x; advice request
- Please help!! Audi A4 2.0T
- P0299 code on a 2009 A4
- Safe to drive with code P0238 (Turbo boost sensor A circuit high)?
- NEWer 2013-2014 have the same OIL Consumption problem!!!!???
- 2010 fsi needs more pep
- ECT problem
- Cooling Fan Replacement
- P2015 2.0L TFSI
- upgrade info
- Help with Engine light please
- Reliability of 07 2.0T with Revo Stage 1 Upgrade
- GOO
- Swap B8 Auto Transmission for Manual or S-Tronic?
- PURE Motorsport | Go Fast Bits DV+
- 2.0t upgrades (im new to 2wd's)
- 2.0T turbo question
- 2.0 T Oil leak question
- Driver Motorsport K04+ dyno results
- A4 2007 2.0 T lack of power when accelerating
- Oil Consumption
- Is there a real difference between 2013 and 2014 2.0 TFSI engine ? 211HP vs 220HP ?
- :: ECS Tuning :: Schwaben European Essentials Tool Sets!!
- Please help I need an advice ASAP ( a4 quattro 2.0 2005)
- :: ECS Tuning :: Pentosin - Superior Fluids For Your Audi
- Temp sensor on 2.0 tfsi engine
- Help! 2.0fsi idle problems
- New to Audi World with 2007 A4 2.0T Quattro!
- :: ECS Tuning :: FSI Cam Follower Replacement DIY!!
- Bad mpg, hissing noise, lacking power
- B7 Cabriolet Aux Fan Control Unit + Fan
- engine bet help
- :: ECS Tuning :: New Pig® Mat & Dispenser Combo Pack!!
- cam chain tentioner
- Cooling Fan Issues
- How can I tell if a thermostat is original?
- Removing Plastic Cover to Tape off Grille?
- 2009 A6 2.0T Engine
- oil consumption
- 2.0T thermostat replacement
- :: ECS Tuning :: D.I.Y - VIN Decoding!
- 06 a4 2.0t t-stat
- engine would not start
- Intermittent idle/revs issues
- boost problem
- Audi a3 ecu epc error
- Looking to buy 2006 A4 2.0 S-Line
- :: ECS Tuning :: Schwaben Tools - Back In Stock!!!
- :: ECS Tuning :: B7 A4 2.0T Intake Options!!
- '11 AUDI A5 Quattro - Tiptronic Trans Downshifts
- Screaming noise come from engine
- 2006 A4 2.0T Q Diagnostic Codes
- Oil Level Sensor
- Rebuilt / buy new engine? Suggestions please...
- 2006 A4 plug/coil check engine light
- Drain Plug Size on 2012 2.0T ??
- '09 2.0T reliable??
- total compression loss
- :: ECS Tuning :: 2.0T Pierburg Upgraded Diverter Valves!!
- 2.0 T FSI improvements/revisions
- 2.0 Turbo
- 2011 A4 - loss of RPM and hesitation on accelleration
- Oil pump chain failure - new engine coming.
- auto led light,DRL auto led light,hid xenon kits.
- coilover question
- 2012 A5
- Oil Analysis - 2011 Q5 2.0TFSI - Castrol SLX Prof. LL03 5W30
- Best clamps to use when replacing N80 valve?
- Audi a5 2.0 tfsi rebuild 500hp
- 06 2.0T FSI oil leak
- vibrating machine is not stable when in position N or P.
- "surging" engine at speed
- A4 revs fine, but sputters under a load
- Looking for CAI for my B7 2.0 a4?
- Plug time, what type?
- HYDE16 Reviews Dimple® Magnetic Drain Plugs and Black Hole Magnets
- GIAC or APR or ? for 2011 Audi Q5 2.0T
- What power steering fluid do I use?
- APTuning Now a Castrol Dealer - December Specials Inside - Free Stuff!!
- APTuning Black Friday Weekend Sale - Custom Euro Plates - APR - United Motorsport
- 2009 a4 quattro ignition problems at 70k miles- HELP
- Find me an answer
- All Carbonio Carbon Fiber Intake Systems Currently In Stock and On Sale at APTuning!!
- looking for an intake
- 2.0T question
- HYDE16 Reviews Southbend’s Latest Volkwagen / Audi “Silent Design” Clutch Kit – Stage
- a3 2.0 dsg timing belt
- 2007 A4 2.0 TFSI Quattro, timing chain or belt?
- APTuning End of Summer Service Specials - Timing Belts, & Alignments!!!!
- Unitronic Group Buy
- Anyone done Spark Plug replacement on 2.0T?
- Misled and Deceived by AOA
- 2.0T FSI automatic vs manual
- Flutter noise at around 3k RPM
- Finally!!!! $Recall
- Strange Open / Exposed Port On My 2.0T Block
- APR Summer Sales Event, Now Happening at APTuning!!!!
- 2011 2.0T DIY oil change
- 2.0T FSI miss fires when stationary!! ??
- 2.0T FSI or 2.0 TFSI or 2.0 TSI
- 2.0T 06 A3 Broken Oil Filter Canister
- What is this label?
- Audi a3 chip tuning issue
- 2005 AUDI A4 2.0 012555
- BSH PCV fix question
- 2011 APR ECU Upgrade Now Available at APTuning!!!
- Anyone done an oil change?
- upgrades?
- Excessive oil consumption with 2.0T engine
- APTuning New Years Timing Belt Install Special for Virtually all VW/Audi Models!!!!
- APTuning/APR December to Remember Holiday sale!!!
- Coolant temperature sensor
- The new Audi A5 2.0TFSI APR turbo kit "Longitudinal B8 2.0 TFSI S3 K04 Conversion"
- Oil filter on 2010 2.0T
- 6 Speed Manual Transmission Assembly
- Oil change on my 2.0T
- 2005 SUZUKI GSXR750K5 ANNIVERSARY SPECIAL NEW
- Ignition coils gone on A4 2.0T 2007
- magnetic dampers audi A5
- High octane? Really?
- Car won't start, told it may be the N80 Valve
- Revo Technik Spring Sale Marth 27th - April 11th 2010
- VW AUDI 2.0T FSI COMPLETE CYLINDER HEAD ONLY 5,000 MILES
- Now Available- APR Flashing for 2010, 2.0T VW & Audi at APTuning!!
- 2.0T FSI Cluth replacement?
- Upgraded FSI Fuel Pump Drive
- APR diverter valve, How to install on 2.0T FSI?
- APTuning/APR Holiday Sale Has Begun, Nov. 23rd-Dec. 31st!!!
