PDA
View Full Version : 2.0T FSI Discussion
Pages : 1 [2] 3 4 5
  1. Epc, CEL & ESP no start
  2. First time poster – 2012 A3 – Coolant confusion
  3. Wastegate fixed...maybe
  4. P0030 diagnostic code
  5. Broken rocker arm - how to replace?
  6. A4 B8 Rich condition
  7. AUDI 2014 A6. 2.0 TFSI Not Starting
  8. Audi A5 2.0 TFSI - Error: P0016
  9. Valve seals are possibly bad at 140k miles
  10. Performance Add-ons
  11. Q5: A Possibly New 2.0T Oil Consumption Issue?
  12. 2009 Audi A4 Quattro 2.0 Turbo (CAEB engine code)
  13. Passat: Someone please help! 2.0t fsi
  14. B9 A4 2.0 Build - Need advice
  15. Help Please! anyone...
  16. ZF 8hp servicing on 2.0tfsi Q5
  17. UK: 2.0 fsi engine code differences?
  18. 2.0T warming up - clicking sound when revs go down (Audi Q5 2019)
  19. B7 2008 Audi A4 2.0 runs rough Need Advice
  20. Oil pressure warning
  21. Is Prolong engine (oil) treatment a good idea?
  22. 2013 Audi A4 Quattro B8 2.0L TFSI sputter during acceleration
  23. APR stage 3 file gone wrong (limp mode) P11AC and P11B0
  24. 2007 audi a4 2. Turbo wont go into reverse
  25. 2007 audi a4 2. Turbo wont go into reverseWasn't
  26. 2.0 TFSI water pump recall
  27. 2006 Audi A3 Balance Shaft Alinement
  28. A5 cabrio 2.0 tfsi quattro
  29. 2.0 TFSI free play in inlet camshaft hub/sprocket
  30. What are all the common faults on this motor?
  31. Non-start condition. Scanned vehicle, multiple DTCs (EVAP N80, ECM relay...)
  32. A3 Tfsi problem?
  33. CNC Diverter valve upgrade + DV valve VTA spacer
  34. CTS Oil Catch Can system REVIEW
  35. Missing MAP sensor?
  36. Seemingly related ignition and valve timing issue
  37. Parking Brake, TPMS, Stability Control lights all on at once!
  38. 2012 Q5 valve cover gasket diy help
  39. 2010 2.0T FSI Cam Adjuster Rattle Cold
  40. 2010 2.0T FSI engine rattle
  41. 2010 AUDI A5 OIL LEAK
  42. Coolant expansion tank- sensor connector?
  43. NO VOLTAGE AT FCM
  44. Replacing turbo
  45. SI: A4 TFSI engine wiring?
  46. A4 TFSI automatic gearbox
  47. 2.0T TFSI injector electric plug broken
  48. Question for high performance builders.
  49. Audi s3 jerking
  50. Exhaust Valve Carbon Buildup / Blown Valve
  51. Magnetic camshaft adjuster seal replacement, now misfiring. Help! Help?
  52. audi TT 2.0 TFSI misfire at EXACTLY 3500rpm
  53. Small copper particles noticed in oil discard pan
  54. Random misfire p0300 and p0303
  55. Few questions about some issues on my B8...
  56. Valve cover gasket leak
  57. 2007 A3 2.0T Big red brake symbol in display won’t start
  58. 2006 A3 2.0 TFSI won't start, lots of codes
  59. 2.0T Piston replacement or new engine
  60. 2.0 TSFI Oil consumption help
  61. 2013 A6 2.0T Slight Misfire...really annoying.
  62. 2.0T - 4 cylinder engine oil consumption
  63. DSG tranny whine?
  64. Flexfuel Engine Differences
  65. Coil pack boots ripped when changing plugs
  66. Car making strange sounds
  67. Misfires
  68. 2012 a4 2.0 tfsi Engine Assembly torque specs requested.
  69. 2012 A4 2.0 transmission not functioning
  70. Reset oil interval on early change? have Audi Care
  71. differences between 16 and 18 CPMB?
  72. Engine noise after timing/pump change
  73. DTC P2279/P0068
  74. 2018 2.0L TFSI
  75. Engine problems after timing chain replacement
  76. A5 Head 06h 103 373 j
  77. Wheel/rim fitment ?
  78. Clunking noise when turning, giving gas and releasing the clutch form a full stop
  79. 2.0T (CPMB) ideal oils
  80. Engine light p0017
  81. Ideal Oil Consumption 2.0 TFSI
  82. Seeking advice for used A5 2.0T engine oil problem.
  83. Coolant Hose Leak Transmission Radiator Outlet hose 2008 Audi TT MKII 2.0
  84. 2015 2.0 TFSI (155kw) engine huge fuel consumption after engine swap
  85. 2010 Audi A4 2.0T Quattro (B8) FTSI - Fuel System Priming
  86. Missfire underload coils and timing belt changed
  87. Audi Fuel Additive every 3,000 miles?
  88. Please help me to deal with g31 on 2.0 tfsi after run over deep puddle
  89. Turbocharger Boost Solenoid
  90. Timing chain issue
  91. 2.0t FSI--Cylinder head bolts....& washers?
  92. Need a long block for my 09 Audi A4 2.0 Quattro [B8]
  93. Difference between 2.0T (40 tfsi vs 45 tfsi)
  94. B7 2.0t BWE swap to other bolt on?
  95. Buying non-running A4 B7... lots of codes
  96. 2.0 TFSI random misfire
  97. 2007 A4 loss of Power
  98. Will it work
  99. 2.0t fsi knock sensor location
  100. 2013 A4 Valve Cover Replacement
  101. Missfire under load lack of power replaced all coils
  102. 2009 AUDI A4 Quattro 2.0 P0171, P2279 Codes
  103. First oil change - 10 months in the lot, should I change the oil?
  104. 2007 A4 B7 Stalls when hot
  105. 2013 A4 Oil Cap Seal Crack
  106. 2008 a4 1.8tfsi ticking noise
  107. 2012 Audi A4 Allroad 2.0 TFSI - oil odd thing!
  108. K03 turbo manifold problem
  109. 2007 AUDI A4 2.0T
  110. Engine fault codes fuel performance and o2 sensor
  111. oil leak
  112. decarbonizing by filling cylinder via spark plug hole?
  113. 2013 2.0t Failure
  114. Engine overhaul
  115. A6 A3 FSI 2.0 (BVY Engine)
  116. Made some changes, now cruise control is jittery on inclines...
  117. 2009 Audi A4 code P0243 Turbocharger Wastegate Solenoid "A"
  118. 06 A4 Frustrations!!!! STUMPED!!!
  119. DIY Questions
  120. P2293 & Engine 02838
  121. T10252 Camshaft locking tool
  122. Engine Rebuild Questions
  123. 2.0 camshaft retainer installation
  124. Fluids, Filters, and Things to Maintain
  125. 6-speed problems
  126. Help! Need Detective work on Blown Engine 2010 B8 68K miles - Trashed by renter
  127. poor idle/black smoke
  128. Victim of After Run Coolant Recall with Fire
  129. 2015 Audi Q5 CPMB 2.0T +20% LT Adaptation of Mixture Help Please
  130. 2015 Audi Q5 shaky idle when cold and in "D" stopped.
  131. 2.0 tfsi timing chains replacement
  132. New guy dumb mistake
  133. Rock and Hard Place.. Send Help..P0420 Code
  134. 2010 Audi A5 starting/idling issues
  135. Audi A3 2.0 t quatro 2010 engine shudders
  136. 2.0TFSI CAEB Rough Idle, Misfire Etc
  137. Coolant temp sensor
  138. P0171 System Lean Bank 1
  139. Code p0011 help please
  140. Need help! Bad flywheel or clutch?
  141. Successful engine swap! CAEB TO CPMB
  142. OEM Dipstick part number?
  143. GE: 2013 CAEB engine
  144. 2.0 TFSI Compression Values
  145. Intake carbon cleaning for 2006 A3
  146. 2.0 engine swap (from
  147. Car is overheating but temp gauge never moves
  148. TFSI Engine Blows water pump every 6months
  149. 2008 a4 2.0t stumble/ missfire on acc
  150. timing marks
  151. Engine intense shaking on idle + check engine light
  152. Could you explain the difference between 2012 and 2013 2.0 tfsi engines?
  153. A4 jerky acceleration after being parked uphill
  154. Ticking / clicking / pinging noise? 2013 Q5.
  155. Engine
  156. 2.0 TFSI Weird Misfire/Black Plugs
  157. Possible Camshaft Group 93 Issue
  158. Q5 TFSI 2.0 Turbo Engine Change
  159. Misfires after 3 hours only, then doesn’t stop
  160. 2012 audi a4 quattro issue
  161. Helpp Audi a4 2.0t 2005
  162. Does oil consumption issue affect newer models?
  163. Advice where is the OIL LEAK onto the top of the bell housing
  164. Oil Burn Rebuild Followed by Under Boost
  165. Converting from b8 to b8.5 HELP
  166. Allroad timing chain
  167. Can someone help me with codes P0456, P0442 and P2101
  168. coil packs
  169. Scores on exhaust cam lobes.
  170. Need some opinions on blown engine..
  171. Fitting B8.5 s tronic transmission into B8
  172. Engine swap
  173. check engine light!
  174. Fuel pump noise solution?
  175. oil light 2.0T low psi
  176. Coolant Leak and Oil pouring out any help?
  177. Loss Of Power
  178. Failed seal in new Turbo leading to Failed Cam on Cylinder Head?
  179. 2009 Audi A3 Nightmare
  180. How to Change the Oil in an A3 2.0TFSI
  181. Bad cat on 2.0 tfsi?
  182. Transmission replacement options
  183. Coolant Leak 2005 B7 A4 2.0t
  184. Removing Audi Q5 Engine - Help
  185. 2015 Audi A3 high mileage
  186. Low fuel pressure sensor faulty?
  187. Audi A4 B7 Rough Idle
  188. Fuel filter location
  189. Help really badly
  190. Noisy tensioner?
  191. No pressure and very little heat
  192. Help with heat
  193. Audi detuning their engines?
  194. 07 A4 Quattro 2.0T
  195. Bad shudder
  196. Where to get part specs and diagrams
  197. Another Misfire story
  198. Car shakes
  199. Stock engine
  200. Very little heat
  201. Can you rebuild q5 Turbos?
  202. Oil pressure valve/sensor
  203. 2.0T Hole Melted Through Intake...IDEAS???
  204. Valve cover bolt leaking?
  205. convert my audi a3 to lpg?
  206. Oil cap
  207. P2099 underboost turbo error
  208. A6, C7 - 2.0 Litre Engine Block Heater
  209. when does the turbo kick in?
  210. fuel pressure regulator 2 performance
  211. 2011 A4 Oil Consumption Issue - Fix quote
  212. Help please when I'm stopped my AC goes hot
  213. 2018 2.0 Litre Oil Capacity
  214. 2005 S4 Burning Oil. Had valve cover and pcv changed still burning oil quart 500
  215. Could someone help me ID this part?
  216. Valve cover lines??!?!?!?!
  217. oil consumption
  218. 2011 Q5 misfire problem
  219. Rear coil springs for 2009 A4 Quattro Avant
  220. 2007 2.0 fsi Audi A4 quattro
  221. High Mileage A3 Purchase
  222. Looking at buying a 2009 A4 need help
  223. 2010 A5 2.0T engine failure Replacement cost??
  224. 2008 audi a4 2.0t had my oil pump replaced now getting a p0299
  225. Stumped
  226. 2007 Audi A4 Turbo Replacement Problem
  227. Help! My Audi A3 won't start anymore - Fuse issue...?
  228. Location of Power Steering Reservoir 2014 Q5
  229. Audi b7 2.0t block 93 vag-com test
  230. Any body do a DIY Timing belt W/P? on 2.0
  231. RPM fluctuation
  232. Problem starting my A4 B8
  233. 2013 A4 B8 2.0T - Check Engine Light ??
  234. Oxygen sensor voltage
  235. Where to get diverter valve for a4 b7?
  236. Clearance questions
  237. DIY: B7 A4 Motor Mounts
  238. P0420 help please.....
  239. Need a shop near san diego
  240. P0234 code and no boost
  241. 07 audi A4 2.0t white smoke
  242. 2.0T - still misfires when colder
  243. A4 B8 Codes P0300-P0304 and P2279 Help
  244. 2010 A5 TSI - timing chain tensioner replacement
  245. Hard Start for 2011 Q5 2.0T
  246. intake cam failure
  247. Audi A3 2007 2.0T Engine dying at low rpm, EPC and Engine malfunction light on
  248. Radiator Fans Will Not Turn Off
  249. Need help tracking down Evap CEL cause
  250. Fuel tank
