View Full Version : 12v V6 Discussion
- Missile Man!
- how do I tell if timing is off
- 17's
- help needed
- changed vacuum lines today and now the idle seems rough.
- Jretal, Mr.D, mori + all the amazing individuals -- Read this...
- X-Post on 9080 Forum about Mance Mounts Report...
- Well, I said goodbye to my 12V yesterday.
- OK SeaFoam update....
- Need some more help regarding my A/C....
- Magnaflow rejected by another shop
- 1996 downpipe/cat problem
- Ordered a PLX M-300 this afternoon:)
- A/C NOT WORKING!!! please read.........
- Mr.D, Got a gasket for that throttle body? : )
- Hi are our cars NOS-able (ricer question)
- Which vac line do i pour Sea Foam in?
- Tire question . . buy 2 or 4?
- Is there a way to stop the air from coming on each time i....>>
- Can anyone help?
- Help with stalling '94 90
- Ok now the the windows stuck down
- A6 brake change
- cylinder head reinstallation
- overheating prob!!
- Programing remote
- Little help from those A4 owners without heated seats...
- Need Chassis Number
- Im thinkin of trading in my car...hmm What should i do with ALL THESE MODS???
- X-post on my 90
- Still have a few items available...
- (X-post) After a 5+ month wait you old-timers will appreciate what I got today...
- Crack on top of airbox.
- whats up everyone.
- Block 32 readings
- Does anyone have any parts for sale (XTB, S2/3 hose, etc.)?
- What is the valve cover screw(bolt) size??
- Interesting discovery
- Cheapie VW 02 sensors = signal too high on my AFC
- Muffler - Magnaflow 5x8 Oval universal?
- how do i take the air inlet box off the TB
- How long do you have to crank it for?
- im putting my s2 hose kit, and xtb on now...
- A little problem with the RPM
- FS: not much response from the audio forum, but anyone need a CD changer? from my 96 A4
- Car doesnt start.. Not much spark.
- Timing Belt for the V6 /...
- Well back to stock...
- need cursory opinion on issue before this weekend's inspection....
- Tough sh!t need your opinion?
- Wagon Trunk Trim Removal for A6 Wagon 98-12V
- Score, TDL headers, thank you Mr. D
- It's just sooo ugly!
- '95 V6 deceleration backfiring
- ATTN Mr D
- Here are pix of my P/S leak... from what I can tell it should be piece 10
- Duh, where can I find my engine code? 1994 TIA
- got an email this morning from some moto&%$# guy..
- reman MAF for 12v'er ......repost maybe??
- I had my heads ported polished about two years ago-- have a question, in retrospect:
- Oil sign keeps showing up and so does the check engine light
- Champion products...
- A6 98 Wagon 12V----PS/Steering Lock/Trunk Lock
- ASR warning light
- Engine Swap? - Opinions wanted....
- Gauging interest on some 12V items/mods I **may** have for sale... <edit>
- Who's done the head porting workshop?
- I think i want a throttle body. I need to talk to Mance, right?
- How much do you think?
- breather hose problems
- Supercharging - Performance modding
- I know this is an engine forum, but you guys seem to be the most technically knowledgable
- Missile Man!
- Found the source of my P/S leak...
- Timing adjustment question.
- Ahhh, the sattisfaction of hearing the bolt...
- Cruise Control Module
- Vag-Com in northbay? Napa?
- Anyone intersted in a H-sport front sway bar? HUGE 35mm front bar.
- Goodbye A4...
- My timing map
- Stupid poll time!!!!!!! Haven't done one of these in a VERY long time.
- DIY munched valve mod.
- morbid man...
- i need power, so i need help.
- How do I replace vacuum hoses??
- xtb
- Repost, Engine Speed Sensor G28 ???
- PROCEDURE to program 2 button remotes
- ported TBs, polished manifolds etc...what's the result ?
- Throws himself on the mercy of the 12V forum.........
- 1PissedOff90......Are you still pissed at me?
- wiring diagram
- Look what i bought ^_^
- Here's the story on that Hitachi ECU with better programming...
- A little off-topic, but....
- Max ignition advance
- So the oil leak I saw and thought to be my valley pan gasket might not be engine oil :-\
- sunday drive
- Has anyone figured out how to nix the rev limiter yet??
- i am now also 1PissedOf4000csquattro
- anyone megasquirt a 12v?
- i ask for cam specs and no one knows anythig, but everyone seems to be an oil expert =]
- What is oil?
- Ok Mori (MITOG)... see what you've done!?! Now fix it!! ;-)
- What oill too usee ahhh!!
- Not an oil forum but,
- I'm confused.....Who's Mance? Is he the parts designer?
- parts
- I got lucky guys
- need cam specs, clutch suggestion
- Anyone have opinions on Castrol Syntec 10-30? I live in California but should I go to 5-40 Mobil 1?
- What is a good price for a BRAKE FLUID FULSH?...97 A4 2.8 12v...and...
- Unstable idle at start up
- This is NOT an oil forum
- Seafoam Cleaner...
- starting
- Mr.D or OnePissedOff90, any other with exp. AR tranny mount ?'s
- Does anyone know what models the DCS auto tranny is found in?
- Since I know no one drinks here... Happy St. Patty's Day!!!!
- upgrading/repairing front end questions...
- Oil recommendations from Mori....
- In need of your help MikTip. Where did you get the cone filter..
- Will One valve cover do both sides or are they side centric?I got two of the same today.HELP!
- I have a question about the oil for my car, 1993 100s...
- Things noticed during my oil change today....
- What is the correct oil pressure for a 12v?...
- 12V popping noise
- Opinions on new Mobil 1 15,000 mile oil??
- Polyeurothane snub mount from Ubernugen, any feedback?
- A6 wagon trunk door.
- Need Help: Problems after I changed out my timing belt
- Hose kit questions!
- Need Parts
- Thermostat issues
- Is it possible to clean out the engine with seafoam using a method similar to this on the 12V?
- Looks like Murderdyne might have another victim...
- Hi guys. I have a Delta radio in my 97' A8 and I need help....
- Selling car need to sell some parts
- STFA and would like to confirm that the Special TB from 97/98 ..
- MAF Cover
- My flywheel setup.
- Instrument Cluster illumination
- '97 A6 Avant getting not-toooo-great MPG - any ideas?
- Questions about TB tensioner pulley:
- Trouble shooting question...Missing. Need suggestions (kinda long)
- Any ideas on ICV-like symptoms now?
- G62 Engine Temp Sensor
- Hey, I don't post in this forum often, but I need some help
- do our keys have immobilizer chips?
- anyone have a DIY sheet on how to change a strut for a 95 a6
- 90 12v problem, help!!
- Car wont start A6 wagon 1998 12V
- Oh man, I tried to warn him.
- Carbon cleaning and new coolant tank cap made a big difference on my car.
- ICV cleaning help...what kinda clip is that on the connector below the lowest bolt??....
- I was having a good day until......camshaft bolt broke
- Best place to get a clutch and flywheel?
- Will stock S4(2000) SUSPENSION work?
- First oil change time - bringing it in, but I'd like to know...
- fan clutch change on a 96
- Someone here said he was using Fuel Power -- who was it?
- Can anyone tell me the differences between the
- 1pissedoff90.....Did you get my e-mail on 3/2?
- Suspension shock+spring install question (X-post from A4 Forum)
- Should hit 200K this week.......probably Thursday or Friday....
- My A4 hit 69,000 tonight
- Magnaflow question....
- not sure if this a mod,upgrade or just a cheap fix...
- O RING size from plenum to TB
- Remus Universal WTF!!!!!!!!!! AHHHHH F*CK!!!!!
- Well I may be bidding farewell to the illustrious 12v group...
- Any reason a 97 A4 IM would not work on a 95 90? Thx.
- will a AAH cam work with my 95 A6q.......
- Ok just bought the cam bar and crank pin, anyone have instructions on how to use them?
- Cam shaft upgrade question
- 490 to change timing belt and 120 for plugs? (just for service!)
- Well, I wasnt feeling courageous enough to do my EGR valve cleaning and valley pan gasket swap, so I
- Check out this strange throttle body...
- EGR mod question
- World of Hurt...
- A few things for sale off my 12V
- A thing of beauty . . .
- So I'm trying to clean my EGR valve. What do you guys use to take off the throttle body, the hex
- Having vibration/shudder problems.
- anyone know how to use a timing belt timer?
- www.spiralmax.com
- Stock bumper aerodynamic practicality question....
- exhaust
- Welcome to this edition of the 12v Money Pit
- FMracer#23, did reinstalling the screen fix your problem?
- 1pissedoff90. Is your engine going into a car for street use?
- FYI, Search Engine Maintenance....
- JWG, I have a couple questions regarding your rings
- is there any advantage to cleaning out the throtel body
- will a velocity stack work with a performance intake system
- Tierod or Control arm problem??
- Mr. D here are some pics of my old tranny mounts, sorry it took me so long to respond.
- Cross Post: 93 V6 still overheating - Need Expert Suggestions
- Why is it when i search for velocity stack or VS on 12v forum i cant find anything?
- Hey Mori, had a quick question on install procedures for tie rods, going to install the
- Does anybody have the part number for the EGR temperature sensor? (AFC)
- Did i do something wrong.....questions
- Any recommendations for an A/F gauge that's fairly accurate and costs less than $150?
- S3 MAF
- has anyone seen the Motodyne.com site
- first the horn, and now the airbag????
- how hard is it to instal a new throttel body ....
- ok i need some help
- Evil Air Intake? What's the problem?
- JE Recall....
- MaxLife 10w-30 synthetic is ACEA A3/vw502 approved according to the label
- Thanks Mr. D....
- The rattling noise issue is resolved -- I'm so ashamed!
- My 90 has 198K on the clock. Too old/tired to modify?
- 5 speed transmission.
- OK.....the car is finally fixed and I'm ready to start mods...
- FEI....1of718 is also Supertourer
- 1pissedoff90....Stebro IS mandrel bent
- Audi has again given "normally aspirated" a good name . . .
- FYI, I've updated my classified ad & lowered the $$$
- Are snowman16, qpilot, & Odelay still around?
- Unmodded A4 v6...first mod suggestions?
- Ant 12v What is your AIM?
- Can some one hook me up with a pic of where the Intake Air Temperature sensor is?
- Anyone in the L.A. area? Need help ASAP!
- What is the Valve Seals size on the 12v?
- Cleaning the MAF sensor. Actually, MAF sensors in general...
- After my recent thermostat/timing debacle I've noticed...
- anyone ever replaced one of the catalytic converters? how much? is there an alternative fix?..
- Electric Fan
- X-post... lil help with flex joints
- Flywheel questions...
- 1PissedOff90, did you ever flow test the ported/polished AFC exhaust manifolds you made?
- Xpost: Weird clicking/clunking noise. pleeeease help.....(already searched)
- Where are you guys getting EFKs from?
- I don't think Hack loves us anymore
- It's official
- Mori where do i get Rotella 5w40 from?
- Mance, don't know how far you've gotten on your engine build but i wanted to ask u...
- RAWR! based ball sized dent on my right fender!
- holy $hit these TDL headers are gonna cost a lot to get installed!!!
- Mobil M1 5W-40 T&SUV -- used oil analysis results
- Got the EFK installed, thoughts on bypassing a/c comp.
- Mori! This is for you! ;O)
- Help me find an exhaust
- I thought I posted this the other day...
- Just got done installing the Allroad transmission mounts, my impressions . . .
- How many liters of anti-freeze?
- How do you remove fan clutch? in the middle of EFK
