PDA
View Full Version : 12v V6 Discussion
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. Update loss of power.. pulled codes..HELP
  2. How big can the 2.8L go?
  3. Hey guys it's been a while... I'm back for a little while and have a PITA question...Long story...
  4. Car is burning/leaking a lot of oil
  5. CEL/new cone filter set up..gonna install a O-ring...question.....
  6. can anyone tell me the Bypass Valve Opening Pressure(Bar) for a Wix 1393 oil filter?
  7. so the valve cover Allan head bolts ate to be tightened to 10 Nm (7 ft lb)..but in what order?
  8. hey LUX or anyone- referring to your reply about the vac res mod several posts down.......
  9. Mance, ygm.
  10. could the plenum not being fully seated cause accel problems?
  11. ok new problem.. xpost..
  12. 12v.org needs a password now??? Who had 12v.org saved to a .PFD??
  13. So ive got a idea to solve the small throttle body prob on our motors that is pretty different......
  14. trying to get pics to post so heres an attempt
  15. In need of some help.
  16. whats the name of this part & where does ..
  17. Got mad suck yo!
  18. Electric fan Wiring.
  19. Anybody around Boston willing to loan me some tools?
  20. Fuel line leaking, where to get replacement?
  21. Well boys and girls - I gave the ol' head bolts a 1/8 turn...
  22. Kind of Funny
  23. Anyone have a source for the two check valves in the valley pan?
  24. Paging jgullam YGM..
  25. Lets Play a Game called "See how much power my automatic tranny can handle before it ends"
  26. when you replace the im should you use rtv in the gasket too like in the spots..
  27. ok i cant figure out where this goes?
  28. here are pics (some of you requested) of my somewhat rediculous filter mod....
  29. Long Shot, but does anyone have a spare AFC upper oil pan they would donate or sell for cheap?
  30. i cant figure out where the egr temp sensor plug goes back into?96 a4
  31. hopefully someone can shed light on my situation...... Every so often now, when I shift into first..
  32. I do not know much about power stearing/hydrulic lines so I have a question
  33. what are the bolts for steering pump that mount ...
  34. cooling fans
  35. anyone in the West Michigan that has the Mance setup. xtb, S3 MAF?
  36. Does anyone know how to identify an aah or afc...
  37. So im making a custom intake and im thinking of using this corvette throttle body and converting it
  38. V6 Fuel Rail Thread Pitch
  39. update on previous post
  40. anyone have any mance's parts that are up for sale/.
  41. One last try...
  42. Here's a couple of pictures of what I worked on last week. (Thanks Mance)
  43. How easy is it to replace the valve cover gaskets on the 12v?
  44. Breather hose route.. from cam covers to?
  45. an update on the noise and needing some advice
  46. Question on 4-wire oxygen sensor heater circuit resistance
  47. Transmission upgrade suggestions or advice? I want to buy a manual tranny and a 12v motor will pay $
  48. anyone know where I can find a good engine.
  49. power steering noise??
  50. anyone have pics to go with the breather hose mod?
  51. green ground wire on starter harness where does it go?
  52. ECU schematic help
  53. Any word on those filters Joe@Axis ??
  54. Do I have to VAG my TB after and XTB install?
  55. Need some help on a noise thats driving me crazy.
  56. EGR to I.M. bolt question...
  57. Doh! I need timing belt advice!
  58. Will a 30V exhaust fit a 12V?
  59. freshly polished, painted, clearcoated & ready for assembly
  60. My 12v woes... Damaged exhaust, need advice.
  61. Timing Belt Tools
  62. Question about Timing belt kits. More like need recommendations.
  63. what are the bolts that hold the starter in?
  64. X post reference G 00200 PS fluid...
  65. Odelay, Did you do a write-up when you fixed your stuck sunroof?
  66. please help anyone
  67. Re: Would putting in racing fuel (100 octane) into a stock engine do any good or bad stuff to it?
  68. What RPM does your car idle at?
  69. Will this fit on a 94 90cs fwd AAH?
  70. After I pulled the EGR off, I found a burned up harness, need some input
  71. Can someone give me the skinny on where Mance is?
  72. Ive just now encountered the worst P.I.T.A.! drilling roll pins out of the block.
  73. Forum Search Broken ... Engine overheating looking for usual suspects
  74. a alternate 02 sensor for audi
  75. Is it possible to lighten my ps pulley by mysef?
  76. Anyone here have the pull to get me into SEMA in Vegas? Email me:
  77. More information on my EGR complete delete:
  78. anyone parting out?? need a valve cover or 2. for a 97 A4.
  79. does anyone have spark plug wire set they want to sell me?
  80. Does mance still make those snub mounts?
  81. not completed yet but been cleaning my 12v
  82. Is Mori still around? I have some Blackstone Labs info. for him.
  83. So is 12v.org down for good?
  84. APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
  85. check engine light after valley pan gasket rem/rep
  86. Paging onej1701 Are you lurking around here?
  87. More details on my old engine noise post
  88. Catamount90 did you ever get dimensions for the cam tool??
  89. Inducing Code 2411, Intro...
  90. How do I get the EGR off and out so I can clean it?
  91. sdb90, YGM
  92. Does anybody know where I can get a crankshaft key or part # for one?
  93. who is it that wanted that throttle body?? I got a extra one....or 3...
  94. Any SoCal folks with access to Bulldozer cleaner? Email me:
  95. So, IF it is possible to replace upper CAs w/o taking out the strut assembly, I won't need to do ...
  96. Questions and Answers: Cylinder Heads, Porting, Compression Ratios, etc...
  97. valley pan exposed, but now anther question
  98. car stalling on the way home when not in gear is the problem maybe gas?
  99. Plans for cam holding tool
  100. Cam Holding Tool
  101. Oye. Getting set to replace some bent valves / TB. Are new head bolts worth getting? What about...
  102. anyone know a good place to get flap sanders (for a I.M. workshop)
  103. Paging Luxus Panzer: Where have you bought the OzzyJuice degreaser ?
  104. valley pan gasket
  105. Need help ASAP - would like to finish replacing oil pressure switch tonight
  106. car cranks but wil not start up
  107. Is it possible to replace upper control arms (front and rear) with out taking out the whole shock
  108. I have a Audi A6 Quattro 1996 I blowed the head gasket but I need to replace the thermostat too
  109. more CAM QUESTIONS for turboed 2.8 12v
  110. Any got an extra Velocity Stack they wanna get rid of?
  111. hey V6TOM, its kind of hard to pm you for cams when you dont have your email available
  112. possible ignition timing fix=more hp just brain storming. read and tell me what you think.
  113. $100/1hp is a thing of the past, I turboed my 2.8 12v for $1200 and gained 78 whp might make a kit
  114. Anybody run an Odyssey PC680MJT or PC925MJT battery?
  115. something for you guys to laugh at...
  116. for everyone who is running a cone..
  117. What's the best way to dislodge stuck oil pans?
  118. D$*N you mance I need an 800hp 12v where are you I have $$$$ and frustrationsddpidilsdhsfhldshi
  119. SO frustrated, does any one have the schrick cams for our motor?finally found a seller but they were
  120. So i have came to the conclusion...
  121. Timing Belt help.
  122. the clean and the dirty...
  123. with the EGR mod could you just cap off the EGR passage and remove the EGR?
  124. OK...supposing I was going to instal a (or multiple) gauges in my 90...
  125. can you buy rebuilt starters vs new how much did you pay for your last starter?
  126. one more...please
  127. Help
  128. Vin location on engine?
  129. Calling all valley pan experts...
  130. My auto club just got this new fancy "bio/Green" parts cleaner......
  131. I have to vent..
  132. did the EGR mod today and have a question..
  133. Alright guys need some help to re-distribute mances parts of the totaled 12v.
  134. thanks again to austinado16 and LagoB lue for the documentation and help
  135. Throttle Position Sensor codes
  136. Anybody got a parts car?
  137. Cleaning Injectors: Is Seafoam more effective added to gas or through vacuum hose?
  138. so I am trying to build a setuo for cleaning my injectors....question for choice of solvent..
  139. i need advice on my code..
  140. I would like some opinions or answers.
  141. first gear vibrations when i let off the gas
  142. Irratic dash temp reading
  143. Stage 2 ecu upgrade relooked
  144. hey LgoBlue!!! and others, regarding previous thread on EGR F/V......
  145. is it safe to actuate your ISV with a 9V batt?
  146. so i had a problem with my starter..
  147. stage 2 ecu upgrade
  148. has anyone heard of TM Tuning
  149. I need to replace a leaking flex pipe on my A4, is it 2.5 or 2.25 in diameter? TIA
  150. oxygen sensor reading query- if I get a resistance reading of 0.5
  151. I would like opinions/advice on the following...
  152. HELP! I now understand that.....
  153. It's time..
  154. Regarding a previous post by CKNYoC about replacing cam seals.....
  155. I've read either Rapid Fire 9 or NGK for plugs, but what about wires??
  156. The 12v is totaled..Just wanted to say thanks to everyone for the years of help and 12v knowledge...
  157. Engine swap ??
  158. off car injector cleaning services, any recommendations?
  159. Need Help ASAP Please - (Power Steering Problem)
  160. WOOOOO..
  161. does this hose look safe?
  162. I put some new plugs in today. Pics of old ones
  163. is there any way to jumper the fuel pump on?
  164. Parting out my 90, having enough fun trying to keep my a4 road worthy, need anything?
  165. New MAF project...
  166. Can anyone help?
  167. anyone got before and after pictures of the metal that the injector spray hits in the heads removed
  168. so I did some fiddleing with my intake today.
  169. XPOST - Need help with Center Support bearing R&R.
  170. will the engine still run if the primary coil tests bad?
  171. Dirty pics of my cams at 173k...
  172. code 2411 re-visited...
  173. I URGENTLY NEED A NEW RADIATOR!!!!!
  174. any ideas for removing stripped allen screw? it is set back a bit, so vice grips = no. TIA.
  175. suction pump
  176. Looks like I'm screwed - Parting my 96
  177. To fix a leaking rear cam seal, I just need to remove the rear most cam holder and pop the seal off?
  178. x-post: Help with exhaust manifold.
  179. transmission mounts... Buying new ones, there's 2 right? (sold individually)
  180. How to remove the starter?
  181. 12v tuning
  182. x-post, not specifically 12v relevant) but weird drivetrain on my 12v :(
  183. After all of this I still have a rough idle!
  184. Superchrged 12v
  185. live in VA... .Its frggin August... and temp on my cluster is reading neg. 24 deg.
  186. Fan clutch
  187. sillicone straight pieces?
  188. Decent condition 12v motor on ebay...
  189. ! urgent Need some reasurrence that I did not mess up (timing belt job)
  190. Oil leak becomes massive blowby
  191. How do you go about cleaning the ISV?
  192. Oxygen sensor query..
  193. I was intrigued to read about 4AudiQ's injector choice...
  194. HEY....1995Qsport
  195. what do you guys pay for AC delco rapid fire #9 plugs at your FLAPS?
  196. Central locking and alarm no worky - long...
  197. well I guess the ram air gods have spoken....
  198. Grrrrr, everyone expecting induction parts to ship from me today...
  199. some questions regarding modding a stock air box and its intake velocity stack..
  200. Mance (and others) whats is your opinion on modding a sleeved TB ?
  201. All my 12V induction pieces are sold except a few being retained for potential warranty needs...
  202. Anyone have an extra Mance XTB laying around?
  203. paging sdb90..
  204. Whats the best way to run a wire from my battery to the trunk?
  205. Oil seepage around front crankshaft seal. Soliciting suggestions.
  206. 94 100cs v6 engine quits at road speed
  207. Mance
  208. gauge cluster went out today during lunch. 1996 A4QM 2.8
  209. Burninating oil.
  210. 12V Intake Manifold Porting
  211. Resetting keyless entry
  212. best way to take out air from the coolant system..
  213. JWG: any further updates on the parts?
  214. Anyone have a picture of the AFC motor accessory belt routing? TIA
  215. Mance, do you still got pictures of your CAI on the B490Q ?
  216. can anyone tell me why this bolt is like this???
  217. ECU MMS100 4A0 906 266 Info
  218. Anyone know where I can find an AAH engine block?
  219. very rough idle!
  220. whats the best oil to use and what grade?
  221. making your engine run cooler...
  222. A/C question - car runs hot sometimes...
  223. The final word on ECT color
  224. dies anyone here have anything to add??....Reference Allroad tranny mount install.
  225. 1995 90Q 12V ECU CHIPING
  226. Replaced ECT - 2 codes now P1101 P1106 HELP! I have to work!!
  227. injectors for b4 12v
  228. Hi pitched noise coming from engine under full throttle
  229. anyone in the MD/DC/Va area have a set of 12v timing belt tools that I may borrow?
  230. I need a part number...
  231. x-post from the 80/90/CQ forum.....looking for some pictures.
  232. so i just got my intake manifold back from the blasters..
  233. does mance still sell parts or sell them through someone or?
  234. pictures?
  235. what size of tap (it is a tap right?) to clean up the threads for the T.B. mounting screws??
  236. I am gonna drill holes in the bottom half of this extra air box....what size holes does everyone...
  237. 4AudiQ, for you...
  238. magasquirt
  239. '95 A6 Idle and Acceleration Problems
  240. Greddy Emanage Ultimate
  241. Warning to all who installed BAW Tie Rod Ends!! (Mori and PearlA4)
  242. This might be a dumb question, but is there a coating on the exhaust valves?
  243. Are the Allroad Injectors compatible with AAH/AFC fuel rail/connectors/IM receptacles?
  244. Sig......
  245. I've heard Mance say...
  246. bently
  247. I'm about to start on a new project with the 12V and have a quick question...
  248. does anyone have an engine layout diagram of my 2.6 v6 A4 engine?
  249. Pics of MAF mod?
  250. new clutch installed 4months ago..getting a bad shudder now
