View Full Version : 12v V6 Discussion
- hey...sorry to bother you guys...but this should be a quick question to answer
- OK, I got the following codes:
- Can someone identify the brand of this water pump?
- Removal was not a success with the posidrive tool
- what effect will too large a spark plug gap have ?
- Thought you guys might find it interesting that the new water pump I got is made by Meyle. . .
- I'm screwed :o(
- a4
- coolant temp problem
- Regarding installation of a new ECU
- Question on Cold air intakes
- Repost "Radio Code"
- Mr. D....Do you remeber the highway you were on through W. VA with all the Giant wind Energy fans?..
- P0605 internal control module ROM error
- Bearing noise in the belts area ?
- 1996 A4 2.8 How much ATF / coolant ?
- Well, I just failed miserably at removing the A/C compressor....
- does a new valve cover gasket need any sealant
- Final cost: Timing belt and associated crap, including serpentine belt and coolant flush $470 - :)
- Hey Mori... figured you'd like to hear this...
- How do these spark plugs look?
- Thinking out loud…turbo, boost, and squeezing out every ounce of oomph on the cheap
- Anyone find pagid blue rear pads for the A4. Are they worth it in the rear?
- New User - Plans for Upgrades and Service at 120k miles
- Gutted my muffler for the hell of it.
- Does Mance still make snub mounts?
- help my buddy has a A90 and want some mods
- Self Study Programme No.128: Crankcase Ventillation...
- Mori and jretal, remember this post, just a month and a half ago?
- It's going to be a fun Saturday. Ordered the Timing Belt stuff and Water Pump as well as an Oil Pump
- Need help with mysterious electrical port...
- Aaaaaarrrrrrrrrrggggggggggggggg!!!!!! I've got coolant leaking from somewhere (again)...
- where the sun dont shine
- Out with the old in with the new(er)...
- thoughts
- turn signal
- Decisions, decisions....
- Replaced coolant tank now coolant light continually flashes
- Anyone know if the electric fans are supposed to stay on after shutoff if the engine's hot? My...
- so I changed my left front bearing, the horrible loud noise has gone away but I hear a faint bearing
- I've come to the conclusion that my 12V and Audi days are numbered
- Are there any tricks to removing exhaust studs?
- Cat issue and flex tube
- poor running when hot and a/c UuuUUuuu
- I am almost positive it was R. Hack that called me about the S/C on ebay.
- HELP!!!!!!!
- Justin how did you get that bolt off the Fuel rilter band? ...
- I've been working on my engine recently and have a few questions....
- Just did the Magnaflow rear muffler today, will soon post pics (and maybe a sound bite for Mori!)
- metal popping or ticking sound coming from left front, and only when I'm on the throttle, any ideas?
- MagnaFlow High-Flow Catalytic Converters
- Well, good news! The seller of my car opened an auto repair shop, and offered to do the timing belt
- I don't have to have an empty tank or close a valve before changing the fuel filter do I?
- OT.... Some pics of removing a 93 Mercedes 300sd deisel engine... OT
- Mori, here is something for you...
- Great day Not.. The guy with the Motodyne supercharger wants to sue me.
- where is my EGR temp sensor??
- paging Mr.D-'97 A4q 12v !!!
- Anyone got a spare upper oil pan? I need the one for the 2.8L AFC engine.
- got it out...thanks all
- anyone help with Intake manifold removal?
- Anyone used 034efi on a 12v before? I've been considering it for a while now...
- Took these pics for you guys.
- Does N-E-1 know where is ignition fuse or relay, or clutch safety relay, pls. read there is more...
- Apexi S-AFC Select
- 2.8 12v Overheating
- Where does the air conditioner unit drip condensed water in our cars...
- Good meeting Mr. D last week....
- Used 87 octane- DOH! Is 12 OZ of octane booster enough or do I need more?
- big ambitions
- From 3 to 1 prongs - replaced my plugs today!
- I'm curious, what are the advantages of the silicone hose kits? Is this for better flow to the TB?
- selling my car on ebay tomorrow ...
- To Mr.D-12valve0turbos
- Anyone here from the Mid-Atlantic area? MD/VA/DC/PA
- Turned 210K last week.....
- Off Topic...Good deal on 12v Impact wrench...I was sceptical too...
- TAP TB & Cone Kit..
- ABS ALERT - Audi is now selling the electronic control module seperate from the ABS Pump
- OK, Northeast guys .. You may want to read this...
- OwDee EhFore is one hell of a guy. . .
- I'm hoping to change my control arms and wheel bearing this weekend, u think autozone has the 3287a
- I have the heads off, at 180k miles. Should I go ahead and do the rings too?
- Which accessories can you see with the hood up?
- Justin, don't forget to reg for WGI....check the new sig!
- whats the best ecu year wise i should look for for an aah engine that i am..
- Left taillight lens on trunk broken by mechanic. Anyone have a spare for 1994 90? Thanks much.
- Mr.D: Did you use stainless steel tubing...
- Some info on leakdown testing
- Hey Michael, I think I have some money already in my Paypal account so we should be good. YGM
- Drove the car for the first time in two months.. Kinda slow :/
- which maf is ok for the diy maf (metal chunk remover :p)
- is CRP a good wheel bearing to buy or should I just stick with SKF(OEM)?
- Hey Justin. other Auto-Xers...questions about results from last week..
- Couple pics of the dirty car...
- IM update, Justin, I think this will be much better than doing it myself....
- Does anyone know which temp sensor the A/C reads to check whether or not it is safe to turn on?
- Is my starter starting to go??
- Smoke from exhaust on acceleration, plus grey residue in exhaust pipes
- I want to remove all my temp sensors from my CC head! I hear there's a harness...
- tap1 offers chip for 12v upto 22hp...hot air ?
- ECT for sale
- Bilsteins , Koni or ?
- Intake Manifold Polishing How-To
- Rough Idle and Missfires
- Pics to follow..
- Repost, She lives.
- i know you guys get giddy over throttle bodies...i noticed one is on ebay
- What's the word on the velocity stacks and the M.MAF's?
- Big weekend for the 12v's last weekend.
- Driver side upper control arms and left sway bar "c" link
- AC Delco rapid fire 9's.......
- are the 'hamburg technic' brand legit control arms?
- Other stuff I got...
- HAPPY 190,000 miles!!!
- Car hesitations on low rpm
- The guy selling the S/C on ebay sent me this...
- Noise under hard acceleration
- Mr. D.
- CD Player Upgrade?
- oil cooler gasket replacement
- mmm.......shiney :o)
- anybody ever have the seats in their A4 redone with Katzins or another company?
- Anyone need anything for their 12v?...
- Accessory belt after electric fan conversion on 97 a4 2.8
- 5th Annual Audi Expo - Schedule:
- I'm almost scared to ask, but...
- Rear Calpier Carrier bolt
- Hose
- OK so I LOVE my AUDI again now...Auto-X results....
- I'm done with Auto R/X (Mance, this one's for you)
- Is the green can of PS fluid the only stuff to use...or is there an equivelent at autozone etc?
- The wrong well to tell if your front seats are real leather
- Tire Pressures for auto-X...anybody have advice, was thinking 40psi all around...
- x post for a small Q
- Need to find a new home for this...
- Strange noises from my rear end....
- Rattle near cat only in gear and at stop? Shot Cats or Heat Shield?
- X-post from 80/90....
- Cooling Problem: Stumped and need help
- If anybody finds oil that meets VW 504.00, you can use it
- 9 days 'til Audi Expo! - Have we heard from you ?
- So I don't think I'll be doing any launches this sunday...
- Can someone tell me which wheel bearing I need according to this post?
- Burned cat converter
- Anyone going to see Stassis @ LimeRock next weekend?
- so when putting a 12v engine in a 4k do i need all the parts or better ..
- How to remove rusted in rear abs sensor?
- s4 stasis (street) c/o on a a4 ?
- heres a couple pics of the 12v aah i just got
- Do you want 1996 A6 Bilstein/H&R suspension really cheap?
- Off topic: newest addition to garage. And no, I didn't upgrade to a new A3 or A4.
- How much vacuum do our engines draw under deceleration?
- Must be getting late. I just bid 14999.99 on that S/C.
- Paging Mr. D or any other PC guru
- Anyone know of a middle of the road 312mm rotor...
- is the throttle body.. different on a auto vs a manual?
- what all do i need to put in a 86 4kcsquattro to get an aah engine to run well in it.
- Well, I still have the 12v, for now, but I have a tech issue...
- Test drove s2000 lol...
- New MAF, new plugs and car still wont start after seafoaming. Anyone has any tips or suggestions?
- Kansas city area GTG this Wed at the Blue moose
- to put this aah 12v v6 into a 4k i need all the wiring for a aah engine too
- Motodyne Supercharger Resale, FYI
- Tips for starter install on V6 12v AFC? TIA.
- any ideas of what i might have issues with putting a aah 12v in a 86 4kcsq
- Starter
- Is this real?
- Cost of a new MAF? and would a bad maf keep your car from starting?
- If anybody knows where to find a plastic syringe with at least 2 oz capacity, please let me know
- House cleaning...I have some working used cluster bulbs left...
- Any sea foam users in southern cali area...
- MAF, Tuning Questions
- Fuel Filter Recomendations? What size crush washers do I need?
- somebody please verify these ACDelco plugs for me...
- X-Post, Hack manages to make a supercharged B6 S4 run less horsepower than a stock car.
- Cheap Antenna Masts
- IR keyless System
- 2005 Jaguar S & X types
- Climate Control compatibility issue?
- Just got a sweet deal on new tires...Highest ranked dry traction tires from tirerack..(OFF TOPIC)
- Original price for S3 TB???
- Where can I buy a Coolant Temp Sensor for my A4?
- Hey where do I go about finding something to tiedown/secure my Battery for SOLO2 stuff?
- EVAP purge valve, new or used?
- 1PissedOff90, did you get my email?
- Gas Milage with Mance Mods..................
- I have these codes from my climate control, but I don't know what they mean or do...A/C not working
- Question about ACDelco Rapid Fire 9's...
- wife and the hand-brake
- Thought you guys might enjoy... P/S rack + allroad mounts + a bunch of other odds and ends...
- Repost, anyone looking for an Auto Transmission (Cabriolet)
- Regarding those links to the oil board, which may or may not work (EXPLANATION)
- any thoughts of either of these engine stands?
- so a great friend just picked up my new old 12v engine and its an aah..
- Should I even try and Launch my car at the autocross?...
- De cating
- Checking for correct timing and car sounding rough.....
- How and where do I disconnect the brake booster vac line to run seaform through the engine?
- Anyone know what the AFC downpipe 3 bolt flange pattern size is? Please help.
- I have an extra TAP throttle body
- Changed ECT sensor and mpg increased.
- Mr. MikTip, the 9s continue to amaze. Lots of power and better m.p.g. -will keep you posted.
- FREE 12valve Motor in Dallas Tx.
- OFF TOPIC...Here is a link to the A4 Ultrasport tunned by STaSIS and APR ...
- JWG, please check in!
- Need help again with the rebuild . . . paging AAH owners . . .
- MikTip to the courtesy phone!
- Be careful kiddies - Hack is back. ;)
- Different types of head bolts/sockets
- Okay, I'll show one ARX-related photo
- Parting out a few parts off the venerable UrA4
- 24 mpg
- need halp, this is getting old...
- Attn Mori: Did you know Audi recently upped the oil filter by-pass valve pressure specification?
- Improving the 12v
- Quick question/survey....
- Ok car sounds like it's "missing". Only code is an EGR malfuntction...
- 2.6 ABC Info gathering
- Starter update...And coolant flushing questions
- Compression and Leakdown Test Results....
- Mori, have you ever anylized/tested Royal purple oils?...
- Question - About my suspension?
- There is a conspiracy lurking the highways of America today...
- ETKA help . . . washer reservoirs for B5 A4 1.8t, S4, RS4 differ from B5 A4 2.8's?
- Oxygen sensors brands
- ot so i am tring to decide on wether to drive my a4 or my wifes new jeep when we go the black hills
- Based on my pics below, what's involved in replacing the oil pump? Special tools?
- My Memorial Day project (BWW). . .
- XTB/SXTB vs TAP TB
- Intake on ebay compared to lltek???????
- When it rains it pours... noticed this weekend when my dad started my car that a poof of smoke comes
- Throttle body
- Rapidfire 9s are in and pretty awesome! Improved idle, smoother running and more responsive. More-
- Reminiscing - Hi everyone! (BWW)
- No vacuum to EGR valve
- Garage cleaning... I still have an Intake Manifold if anyone is interested in the IM P+P Workshop.
- What do you think of this die grinder for the IM workshop?
- Mori ~ sigh ~ another oil question
- EGR mod question
- Failed emissions (UK) - how to fix ?
- Air Intake!!!!
- Proper F*cked? Engine maybe trouble! HELP~!
- Parts diagram or help figuring out what a part is
- Just got owned by a mazda 6.......how embarassing. I got on the pkwy first and he's behind me and
- Little help please. Anyone know how to get the white female clip off the starter..
- Whats everyones planns this weekend?
- 5th Annual Audi Expo - Come be a part of history again!
- Auto-RX is having a special until 5/31, $4 off a bottle. Input code ARXNS.
- mori, YGM @ EL. Also...
