PDA
View Full Version : 12v V6 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. I think I need a bigger mallet
  2. how much does the 12V V6 engine weigh?
  3. Is there any interest for an aluminum (lightweight, hopefully) PS/altentator/cam sprocket pulley?
  4. Used Parts value?
  5. If a little Ram-air is good......Is 2x larger better (will I have any issues?)..
  6. OT - When looking for a truck or SUV is an auto the
  7. Im buying new koni shocks 2day, as long its for a 2wd car, it dsnt matter if its 1.8t or 2.8 right?
  8. Ignition Coil and Crank Signal Question
  9. Okay, final questions about my thermo symptons - want to pull the trigger this weekend
  10. Yesterdays projects.
  11. Thanks, guy at Shell...
  12. Anybody know what size tubing will fit over the caliper bleeder nipples?
  13. Haha my dad is gonna lower my car for me instead of tint! I need your guys help....... (read inside)
  14. Does anyone have an Etka view of the rear-left
  15. creaks and groans...is there anyway to tighten the body frame?
  16. Is it true that i would get more power from stock air fox, the my cone set up right now?
  17. Engine tray question
  18. Brake bleeding / pressure question - kinda long.
  19. Before I get in there is this the ABS sensor???....
  20. 12v Forum Top Posters for 2004 . . .
  21. increasing feul delivery
  22. TDL Racing???
  23. Resistor Mod????????????
  24. Help with wiring up an ABS switch :) Anyone have a clue?
  25. Paging MikTip
  26. bumpy accelerating
  27. Question regarding suspension system maintenance
  28. How much modding have you guys been able to get away with in CA with smog requirements?
  29. AM reception issue & tinted film on rear window/antenna
  30. Bouncy fuel needle? -- Possible cause of the problem
  31. Stumble under Load
  32. Mance, Miktip, anyone else can you help with this one?
  33. 12V connecting rods
  34. Looking at direct fire systems (1PissedOff90) What is meant by even fire?
  35. Paging 1pissedOff90, or any experts around here
  36. An interesting discovery I stumbled on to this morning...
  37. Just wanted to wish everyone a safe and happy New Years!
  38. Got my front Wheel bearing done...Now I have ABS-Brake Lights on?!?!?!?!
  39. Need help with oil cooler repair
  40. X-Post (Dyno's by state)
  41. need some mods for my car
  42. Hey Pissed-Off One!
  43. x-post - cone filter cannister/CAI system question
  44. I have to replace my head gaskets!!!!
  45. I need help finding these parts! HELP NEEDED
  46. NEED HELP NOW!!! Are all 1996 A4 engines the AFC?
  47. how many here have P&P IM and/or Head
  48. X-post, headers for V6, what kind of HP?
  49. Anyone needed valve job from "natural" wear?
  50. Mahle to make more than oil filters?
  51. Wow!
  52. NGK Plugs...
  53. Timing Belt Write-Up?
  54. Can I just cut the sensor wire on my New Paget Blue pads before install??
  55. 1PissedOff90 could you post this pic again please
  56. For those always looking for 5W-40 oil options
  57. Merry Christmas everyone!!!
  58. x-post: H&R S4 coilovers installed
  59. Gonna tint the windows monday, my car is black but has the chrome around the windows, should i tint?
  60. AAH Head Plan Coming Together
  61. Paging Jestnomen
  62. A8 supposely Motodyned Supercharger
  63. anyone used the h&r race springs vs the H&R sport springs..
  64. 30V injectors?
  65. abs light coming on
  66. new custom clutch kit and LWFW
  67. What do you guys think of my new sig?
  68. Have a merry Christmas, Hack!
  69. Power steering problems
  70. Regarding declining fuel quality
  71. Gonna need some new spark plugs, what do u guys recomend? where can i get them, should i get wires..
  72. What is an ECT, because i smell gas when i start up my car, or maybe its a leak?
  73. Got my results back from my mechanic!
  74. rain=cel=gas smell
  75. A6 front brakes?
  76. Powersteering hose leak any suggestion's on finding it?
  77. rear brakes are rubbing.
  78. Since I have decided to take some time off in january...
  79. spark plug pics
  80. I was talking to mike @ new demensions in san jose, he said a chip might be coming for the 12v......
  81. I know it might be a dumb question, but if i want to lower my car why cant i just buy springs....
  82. Where on the passenger front door is the switch for the courtesy light when opening/closing door?
  83. Anyone know if you have to Get the B6 A4 3.0 Rear brake brackets from a dealer?? Only solid Rotors?
  84. x post: New O2's, not spliced, throwing codes....
  85. I need help finding some parts!!!
  86. Need an s4 bumper, or an rs4 bumper, know where i can get one? or any 1 sellin theirs?(black prfbly)
  87. For those of you who know my current plight...
  88. I have to do my brakes -- need some advice
  89. Anyone interested in a S2 hose kit, or a TAP1 TB
  90. Quick Quiz
  91. Alu pulley set. I know some one was asking the other day. Ebay$$
  92. Resonator question for Mance
  93. Have any of you guys run a bottle of sea foam through your engine right before changing the oil?
  94. Anyone here looking to sell their S3 hose kit?
  95. New O2 sensors
  96. Anyone try the cheapper Die grinder Mance sug. For the IM workshop?? Impressions?
  97. Part ID
  98. Quattrospeed offline?
  99. T-question
  100. Do you need a press for Front wheel bearing install...
  101. Stock Resonator
  102. Not sure if this is a problem or not...
  103. I have a K&N Panel filter from my A4. Anyone want it? E-mail me.
  104. audi swaps
  105. sxtb!!!
  106. 96 keyless entry question.
  107. I lost my "audi" jelly bean emblem on my fender.... :*(
  108. What's the difference between when your car has black valve covers or silver?
  109. Paging Mance Hush vs Stock resonator
  110. My last auto-x results...
  111. IM switchover parts?
  112. I saw a white Chevy Cavilier this morning with plates "MCLRN F 1".
  113. I switched back to the Beru Ultra-X UFX5.6
  114. O2 sensors arrived, but...
  115. Die grinder Q's for IM. & So I Finally replaced My Plat 4+'s....In a word, CRAP...
  116. OT.. this is OT... OT post everyone....
  117. I was at races last night and didn't do as well as i wanted, HELP I NEED EXAUST!
  118. Any of you guys know where in NJ was Motodyne located?
  119. I'm getting rid of my DynoRad if anyone wants it. E-mail me... *SOLD*
  120. 97 Keyless entry into a 96
  121. sig test
  122. Question about RCE injectors.....
  123. CATALYTIC CONVERTERs removal question
  124. Hey guy's i'm a newbie to the 12v forums, but i need some help.
  125. 60k mile service without warranty :$
  126. Did you see the name of the new motorgeek.com forum?
  127. WOW!!! Found a real live SUPERCHARGER...Motodyne has gone Plastic!!! ; )
  128. Maybe you guys can help...
  129. Size of the stock crank pulley?
  130. Will I get any noticable Break Bias change if I upgrade the front only?....
  131. Does anyone have an aluminum flywheel on their 12v?
  132. Easiest way to remove egr valve?
  133. Please tell me this is a AAH engine!!! and I have something to play with over Christmas!!...
  134. CA Somg test experience
  135. Engine Air CFM
  136. boring out a TB
  137. New oil dipstick gasket
  138. Jretal, I saw your old post about your time at the Glen...
  139. So my intrument cluster is "Fading". It goes from no red faded to Normal Lf to Rt?...
  140. Can any of you guys help out this question for the Mech Oil Pressure Gauge?
  141. Spark plug comparo -- better late than never
  142. Recommended Parts Motor 90 2.8L
  143. Bought another car today!
  144. ebay tie rod pics, they look okay to me, we will see once I install them this weekend
  145. Any Audi techs online? (x-post)
  146. Please help...4 Faults thrown
  147. paging Mr Buntcake...
  148. Mance did you sell that RSXTB yet?
  149. Stage 3 MAF owners...
  150. concerning motodyne supercharger
  151. To anybody who uses a cone intake....
  152. Any guess on what the IM plenum volume is?
  153. Mr. D - what are your impressions of the new Falken GR Beta FK-451s?
  154. bored throttle body
  155. Squeeky clutch pedal
  156. throttle adaptation?
  157. Is there anyway to turbo a 12v?
  158. Whats the S3 MAF flow?
  159. Needing some chipped or not used 90 headlight lens' for a few weeks...
  160. ATTN: Robert C. Hack (this is long)
  161. PLEASE HELP
  162. I found a S6 steering wheel w/ a blown bag for $25.00
  163. Suspension gremlins . . . .
  164. one very very rare RSXTB available for sale at less than half price...
  165. Threw a Code today
  166. wheels for sell
  167. Brake lines?
  168. Where can I get Beru Ultra-X plugs...I've finally had enough of the 4+ plat.
  169. Yet another Deer incident!
  170. Has anyone seen steering rack rebuild kits???
  171. vacuum hose from BMW
  172. Will the standard 5 spoke 16" wheels accept 225s?
  173. I miss Mance's posts...
  174. did someone delete hack's post about the SC?
  175. 16" OEM rims with new low profile rubber.
  176. n80 valve
  177. Thermostat Options
  178. hello
  179. Anyone in LA area want XTB?
  180. Anybody want/need my Stage3 MAF and Stage3 Intake?
  181. Noob 12v work accomplished, hooray! Questions though...
  182. You guys'll think this is cool/manly of me:
  183. o2 sensor check engine light = Bank1 too slow? Threw the same code
  184. My 12 valve back on the road [BWW]
  185. Changing the Valley pan gasket.. Anything else I should change while im at it.
  186. First problem, I am having trouble finding the coolant drain plug on the engine block.
  187. egr valve and alternator probs...
  188. Question about changing t-stat.
  189. Coolant circuit capacity without heater - 2.8 12V
  190. Really good article about using a lightweight crank pulley
  191. Anyone have the video of the 12v supercharger?
  192. PES Supercharger Fitting
  193. O2 sensor search = to much info couldn't find what I need
  194. CEL light on VAGed it but don't know the code?
  195. Happy Holidays guys, there's finally a recall on the control arms. I made my appointment today =)
  196. Changing ignition wires today, should I disconnect the battery while doing the work?
  197. 12v to 30v
  198. thought it interesting about the new a6..the wet braking function
  199. Can we take a vote to ban Robert C. Hack
  200. Can anybody give me the general run down on changing a thermostat.
  201. electric turbocharger
  202. Coke Bottle Mod (for those who care)...
  203. Would an FMU work?
  204. AC Compressor
  205. Anybody have an actual pic of the cranck position sensor on the engine...
  206. Whats the best oil to use 92' 100CS???
  207. Where is the radiator drain bolt on a 96 A4. I am trying to flush my coolant, but I can't find
  208. i have been thinking of getting a 95 S6 for my second car anythoughts? .....
  209. Where do you guys purchase your oil?
  210. How much actual coolant do I need to do a full system flush?
  211. Preliminary info for those interested in TotalSeal Piston Rings on OEM Pistons . . .
  212. What a difference a day makes...
  213. Mr.D, where did you buy your wheels??
  214. Any of you guys pull the cig lighter socket out of the ashtray assembly?
  215. Looks Like the Hack is Back
  216. leaking Trans axle CB boot
  217. Will this cluster from the Euro S4 work in our B4 90's ?
  218. To those that have had the intake manifold off...
  219. Exhaust manifold removal...
  220. They deleted my OT post instead of just marking it OT... grrrrr.
  221. Will there be any sign if my waterpump is failing.
  222. oh boy...
  223. Fuse Diagram for '95 90 Q
  224. Panda pellets
  225. Oil consumption is now steady at 0.6 qt/1k mi
  226. 12v or 30v how can i tell
  227. Wanna see something interesting? Another WAAAY OT....
  228. Wich Hitachi ECU has this part number ?
  229. hey mori...
  230. Way off topic... but I have a 2000 Expedition that just broke 90k...
  231. Oh no, They do exist!
  232. **EDIT**I posted a couple of days ago about my car getting hot...
  233. Do I risk damage if I use a 16" spare with 17" S4 stock wheels?
  234. I'm looking at an ebay intake kit
  235. Newbie: 93 12v - Can't get bleed to work - need help!
  236. AAH & AFC Engine codes & timing belt/water pump kits
  237. Mance, just wanted to say, "Thanks again!"
  238. Oil Loss, Please Help.......
  239. bently pic of intake system?
  240. Mance, a few head workshop questions.....
  241. Why is the ignition stage module in the Intake?
  242. how hard is it to change motor mounts
  243. Alright, those of you who pulled out your ash tray assemblies... need a lil help
  244. Coolant Temp Sensor
  245. Auto to tip?
  246. oil temperature
  247. KINGSBORNE/BERU Spark plug wires
  248. Getting an EGR code...
  249. Car stalled 9 times on my way to class
  250. ne1 got a current ETKA?
