View Full Version : 12v V6 Discussion
- Oil light on at start-up only for a couple minutes, low oil pressure or bad sensor?
- I'm getting a ton of emails related to my vacuum gauge posting yesterday asking "how to do it"...
- Injector clocking... any benefit to clocking injectors to aide spray pattern down intake runner?
- So... on the bored MAFs... which sensors are being used? Stock 471As?
- is this a good/valid test for vacuum leaks?
- V-Belt Problem Solved
- Mance did you ever test the s3 hose kit on the 30v?
- valve cover sealing discussion.....
- How often you AW's replace the camshaft seal on their 12v's?
- what is this FVCKIN BALLS with V-Cover bolts as of late.
- noticed today oil temp gauge not working properly...
- Hi-Flow Airbox Workshop Part 3: Airbox Lid, O-ring sealing, Hi-Flo VS outlet and RS3MAF mods...
- TDL Headers on the bed...
- how well does the 12V stock intake VS in the air box flow.....
- Someone have found a canadian source for these VS or similar?
- AAH into a AFC car, Swap heads?
- what happened to the update??
- Question about 2.8L Timing Belt Procedure
- V-Belt or Accesory Belt Broke but I have a dilemma.
- Valve Cover Gaskets gone bad..
- I can not find loctite 272 (high temp) anywhere where I live...I could find this tho...
- Hi-Flow Airbox workshop; Part 2 Conclusion...
- my personal I.M. job is almost done.
- Hi-Flow Airbox Workshop Part 2 Continued...
- I'm looking for the B5 airbox workshop. But the search doesn't bring anything up.
- Hi-Flo Airbox Workshop Part 2 Continued; The products involved....
- robotic toy technology allows easier aluminum intake manifold passage-way re-finishing...
- Part 2; Hi-Flo Airbox Workshop or this is where I send everyone running for the hills...
- I installed a fan clutch off ebay, it sounds pretty loud and seems to always be on, is this normal?
- Part 1: Hi-Flo Airbox workshop...
- Clutch life - How many miles did you get on the original?
- I feel that when we click the engine at the top it should do something like the kitten on the....
- Anyone here gotten a hole in their exhaust?
- Few questions-Topic: Valve Cover Gaskets
- new vb forum...notyet....
- power steering pump
- Help me with my new Audi 96 A4 sputtering issues, bad idle, and no power ...
- Latest word on ecu chipping...?
- Hmm. I think I have a problem...
- Tis a shame when you have to purchase something for $132 (shipping inclusive)...
- feeler s3 hose kit
- ECU identification
- Part number request: oil cooler o-ring.
- loctite 242 good enough for Butterfly valve screws on upper I.M??
- Im on way out to buy a wrench...what size are my 02 sensors?? 23mm?
- 1996 A4 Quattro - overheats. Thoughts?
- Thanks Mance! Got my TBs today. Can't wait to install!
- Pre emptive Friday Picture post......I thought I would go first.
- Anyone have a photo of an original S3 hose kit installed that fits under the engine cover?
- feeler, what would everyone say to a pic of them self with car for picture Friday?
- Cheers to friens that we have never met, but friends none the less
- I can't compete to be among the most knowledgeable on these forums, but thanks....
- I'm going to say this just this last time then I'm done with it...
- please help me with my timing issue
- No fault codes but the some gauges just are not working, Help!!!
- Seal Conditioners - questions on use for other non-engine parts
- Air filter change helped gas milage more than I expected.
- want:
- Any suggestions on Power Steering fluid?
- who else installed their SXTB+ and what other mods do you have?
- Anyone placeing a order form autohausAZ in the near future??
- Installed my OMFGtb+ Today and,,,
- Anyone have a spare valley pan gasket (new)? Trying to avoid the stealer...
- Hey nothing, Drop me an email please
- Paging justin
- I maybe naive but what possible modifications (If any) Are available for my Audi a4 2.6 p reg?
- Vacuum Problem
- Question on antifreeze
- I'm sitting on a lot of pre-made 12V induction parts right now...
- MAF conversion
- the pull in 5th gear has never been so...
- i have 2 x 078 MAfs, can mine be modified?
- Happy end of fathers day to all of you fathers and grandfathers!!
- The latest RS3 MAF production run passed the 500 mark...
- 12v.org down, hope its not offline for good, anyone know?
- installed SXTB+ last night and also adjusted throttle cable..
- 1993 90CS, - Alternate belt routing, (12v.org down), Sent longer belt.
- Sequential Turbo Question:
- can anyone tell me where I might be leaking massive amounts of oil from......
- Here's a little curiosity no one will have ever seen yet it's in EVERY MAF housing ever cast...
- riddle me this 12v forum... how can my coolant go from green... to this :(
- so just seafoam'd my 95Q for the first time since my Trip computer install
- thanks Mance, you rock dude. (screws)
- Vag Com - compatibility, favorites?
- Set of Stasis Equal Length Headers - Anyone want?
- What's the difference in engines pre or post VIN 129647?
- just ordered my intake hoses.. Thanks for the link Mance
- Wahhoo 3G iPhone for $199!
- I need 2 B4 owners to test the new hi-flow airbox velocity stack...
- SXTB+
- misfire
- The latest hands-free installation is "tango uniform"...
- Universal Oxygen Sensors question
- direct-fire, anyone??
- I have to say thanksto CrazyCab for a good auto to manual swap post a few down and i have a new sig
- So after replacing wires, plugs, I swapped injectors and my misfire has moved. It is possible to
- Thanks for all the help I figured out the problem the small wastegate inside the throttle body had
- still best place for 90 degree silicone hoses?
- who was it here that had some of the 3mm Butterfly screws for upper I.M. for me????
- Got my hands on a Passport G-timer this afternoon.
- Something I think everyone can agree on (sensitive) :)
- PSA; Next week I'll start the last "planned" RS3MAF production run of '08...
- so what is the diff between a hvrs and the standard recovery sleeve..
- after owning my 90Q for about 4 months now i finally got it out on the open road for some 3 digit
- Funny noise from my EGR vacuum valve... lil help
- Thinkin about getting a 93 90 CS for daily commute..what to watch out for?
- pulley question for Mance, or others:
- Catalitic Problems A4 1997 V6 Sedan
- Ok fixed the breather hose now it is idling high 3000rpm what should i check for next?
- check out this dyno run. 2500hp, back tires smoking on rollers. not a 12v, but neat none the less
- Part #'s for the to black plastic tubes that go from the valve covers to the black throttle body on
- Re: 034 Motorsports Chip-Tuned '93 12V 90Q Sport
- Auto to Manual conversion?
- Well finally finished my winter project
- (UPDATE) Ok, iphone integration w/hands-free is installed in car and working...
- who has gotten their S+ installed yet? how many S+ were actually made in the last run?
- can the Fuel Pressure Regulator on my 12V's be removed and cleaned out?
- Parts suggested for clutch replacement
- Interesting for the greenies.
- '93 90CS, automatic :( Need help!
- Timing belt tool (camshaft pulley holder) for 12V V6 B5 - $75
- Intake Manifold removal procedure
- stop the presses. heres the best thing since sliced bread.
- best place to puchase some nology spark plug wires??
- favorite mod. poll
- Came across this...
- Still have misfire in cyl #3, running lean bank 1, and i had random misfire; any ideas? The shop i
- who's makin light cam sprokets?? cant find em fer the 12v
- Ratteling noise at idle
- EDIGREG, package arrived..Thanks
- Misfire in cyl 3 and rotten egg smell. Is my cat shot?
- VAP..need assistance please.
- Is the B5 12v modifiable
- Timing belt
- ouch!! i just added up all the receipts from the last 60 days. ive spent over 5k on my car in
- SXTB+ Installation impressions.....
- ive done a lot of reading in the archives about cams, valves, and head work in general.
- ok here you go..
- performance beyond
- Some installation notes about the latest batch of SXTB+ throttle bodies...
- Damn it.....why do all the cool engines have to have wierd cranks and firing patterns....
- Flippin valve cover gaskets..
- silli question.
- 12v Powered..
- Vacaum line question. I did the EGR clean this weekend
- Teaser Drag B5:
- In need of a set of coilpacks... anybody got a used set FS?
- after pondering this for quite some time i must ask the question.
- 9:47pm and they're done... every damn one of em! All that remains to do...
- heres how i cut my airbox VS
- Arghhh I'm close, so close...
- Got some new *bling* for the grill
- 12v Valve spring compressor
- 12valve Performance Parts
- Initial 034 12v chipsets, details inside:
- after filling my gas tank up today i was going to see how many miles i could get..
- Would running an AAH oil filter harm and AFC egine?
- If The 034 Chip works out I can finally buy this shirt!
- as my I.M. workshop is almost done, a question or 2 arises...
- any New developments in the 12v development forum?
- Not a Uber rare service manual, but interesting....
- Egr temp sensor?
- i used this stuff to fill in the areas of the airbox between the vs. its bad ass
- Any update on the 034MOTORSPORT chip?
- Paging EDIGREG, YGM
- Dos Quattros...
- Discussion: since my foot is always on the floor, why do I need a primary and secondary venturi???
- 4" airbox inlet upgrade..
- I know its too late for Mance's run, but I'm selling an "S" TB
- I want 18" swings.
- cyli headz landed today, grazie mille ed : )
- Transmission Pan and Bolts, 96 A4 Quatroo 5 speed auto
- well it sounds like i am running with out my exhaust now..
- A little Engine Brite and a tune up...
- Cross Thread: Where can I find replacement instrument bulbs for my HVAC?
- Need help with codes/suggestions
- I have some 12valve stuff available. Email me off list..
- STFA...Valve Cover gasket part number
- Stupid question.....Changed the oil on my A4
- help with oil burning smell (after doing the usual AAH fixes)
- I'm going to get back into the SXTB production run this week...
- Swedish wrecking yards / auto salvage yards
- Got some 12V parts gonna post on AudiFans....
- is my clutch slipping?
- The rarest B4/AAH/AFC hard-copy service manual in the world...
- Does anyone know our odd fire angle in degrees?
- timing belt tension pulley
- copper head gaskets
- torque spec for oil retention/check valve under the pan valley?
- what is the name of the lower fatter hose coming off of the coolant reservoir??
- X-Post on Oil Analysis M1 5w-40 - Attention Mori - you may be interested
- any reccomendations on places to get bilstein sports? im having a time finding
- am i the only one that feels pain and jealousy everytime i browse the s2 forum??
- A/C compressor shot in my 1996 A4Q, any way to tell without pulling it if it is a Zexel or Denso?...
- Hesitation/miss pt.3 including Pics!!
- "hypermiling" the 12v V6
- 1995 A6 Avant
- Who's selling this one?
- Update on misfire/hesitation.
- has anyone mounted their battery in the trunk here? seems like a good idea
- Intermitant engine light turning on, is there a way to check the error codes?
- HVRS
- 4 better gas mileage should I replace O2 sensors even if no code.
- The 034MOTORSPORT clock is ticking.
- Sage timing belt advice
- Cheapest headbolt source?
- Light throttle Hesistation/Miss?!
- (4) kumho ecsta 225/50/15's and oe audi alloys. anybody want'em??
- Ok, I'm getting better. I got 2 hours in yesterday and am shooting for 3 more today...
- 12v Chip, apparently 034 says they can do it.
- Planing to replace the OEM Flywheel w/a "street-able" mid-weight one during looming clutch job...
- aah heads on afc block?
- a reasonable way to spend 2k
- I've got a MAF sensor
- Mance, are back to the land of the living? I think you got me sick. :-(
- What goes in this hole?
- ok, heres a sillii question: assuming the afc EM's flow right around 400 cfm polished, and
- Bored at work...Here's some pics...
- Anyone have a source for the timing belt tools?
- Check my classified ad ... link inside ...
- Ok, here's the deal on me. Just got home from seeing my doctor...
- For Sale - One Off Super Charger Manifold
- i have two spare intake manifolds (cleaned w/ bulldozer) for sale.
- 272 Discussion and some more cam related stuff...
- So how is our Guru doing? I hope the smell of cutting fluid and
- I had a spark plug jump out of the cylinder head over the weekend ...
- OT:smoked some douchbag in a 04 (i think) Passat today...I didnt even want to race him......
- Mance, would you mind reposting the pic of the TB's side by side?
- New ISV w/ New problems?
- Upper sump seal replacement
- Update: Big Valves are running!
- Jretal YGM.
- I put my stock intake back on this weekend. It feels soooo slooooooow.
- recirculating again!........................................migh t be wanting an HVRS soon....
- part # for oil pressure relief valves from the head cylinders
- Ok, I'm slowly coming around. I got 2 hours work in today but I'm very shakey...
- so i finally had a first hand experience with a "fake turbo blow off".
- Attn: VAPp
- my vacuum hose mounts
- aftermarket air feul?
- someone clear this up for me: I think that the filters I have had for some time now (on my valve
- Need input: True Dual Exhaust
- If you wanna tune your fuel map w/ hitachi...
- does anyone have a set of AFC heads for sale? i dont care what condition they are
- installed my ported IM today.. while the manifold was off i ported the injector paths and gasket
- MUHAHAHAHAHAHA...........
- Mance ygm
- other than myself who else still is shipping..
- mileage per tank poll
- has anyone sent out their injectors for cleaning? where? thanx......
