PDA
View Full Version : 12v V6 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. ECT Sensor cost
  2. so I got me a new ISV and I was wondering...
  3. is this a 1995 100 or 200 with a 12V?
  4. O2 sensor replacement help needed
  5. Location of and replacement of ECT
  6. Break In Secrets for engines..................
  7. Car Wont Start
  8. 1993 2.8 12V injectors: Peak and hold OR saturated type ?
  9. Can I use the stock intake hose with a S3 MAF?
  10. Curious.. info about the 12v needed!
  11. Water Drain Valve in Plenum Chamber?
  12. page for Jretal
  13. stupid eletric question if I wire is supposed to have 5k ohm.....
  14. Easiest way to do a radiator flush
  15. O2 sensor A/F meter operation question
  16. O2 sensor signal wire question
  17. thermostat replacement without timing belt...advise wanted
  18. what is the ohm value for the spark plug wires on a 12V.....
  19. Exhaust question
  20. how does one remove a broken exhaust stud?
  21. Fuel Question
  22. Lowering Springs on my 2.8
  23. will a intake manifold ISV and Throttle body form a 95 or 96 200 or a6(car is de-baged in wreckers)
  24. Really dumb cat back question.. *flame suit on*
  25. Did you guys see this S8 crash at a track?
  26. I've accidently deleted Mance's workshop on the 12v Cylinder Head P&P.... someone still have it?
  27. good product/method to clean up alluminum??
  28. What does everyone think about putting this on my car?
  29. JWG, I forgot to mention one thing
  30. Does the V6 12V have variable valve timing?
  31. Oil Weight
  32. Humdrum but expensive maintenance on high mileage vehicle . . .
  33. No heat!!
  34. Hi guys! ;)
  35. power stearing pump/belt bad, loud buzzing noise when turning, okay to drive 45 miles to get fixed?
  36. One bad secondary injection valve - it wont hold a vaccum.
  37. Mori . . . Another oil question.
  38. port huron/northern detroit area 12v'ers....help!
  39. Help Im only getting about 20 MPG I was getting around 28
  40. spark plug gap
  41. Timing belt tech....
  42. PLEASE HELP ME PEOPLE!!!!!!! weird noise coming from engine, just started.. im scared
  43. New Exhaust
  44. exhaust
  45. Please don't judge me ;-)
  46. just wondering
  47. xpost: replacing the lower oil pan or oil pan gasket
  48. "Fuel injector circuit electrical malfunction" code for all 6 cylinders!!
  49. so you guys are ok with the universal Magnaflow Cats on ebay?
  50. Schrick Cams
  51. Questions about the V6 12V over the 1.8t in terms of reliability....FLAME SUIT ON...
  52. AFTERMARKET STEREO + INSPECTION
  53. Hyrdaulic mineral oil for power steering ...
  54. Quick simple yes or no fitment
  55. ignition problem
  56. I heve been searching for pics of peoples ram air set ups and they all seem to be old red X's
  57. time to change the timing belt..I have few questions
  58. Mobil 1 ESP Formula 5W-40
  59. I forgot how well an ignition upgrade felt..
  60. Alright, I'm making myself at home in this section, and it's time for another question...
  61. Thinking of doing an intake setup......
  62. So I need a new exhaust on the ol' 12v 96 A4Q...
  63. torque speck for the 3 bolts on the ISV please???
  64. Anybody know what model Ferrari this is? I could hear his exhaust note over my Zeppelin...
  65. Mori, what are you thoughts on Royal Purple?
  66. Questions about mods, and oil analysis.
  67. Help on filling AC refrigerant.
  68. Interesting porting infos...
  69. Audi - 1 // Maxima - 0 ;]
  70. Exhaust "sptting" issue ...
  71. Engine Coolant Temp Issue Part 2
  72. Inlet manifold bolting question
  73. can these tranny. mounts be used on a b4 chassis
  74. MAF swapping question
  75. Cold Air Intake?
  76. Anyone put a supercharger on a 12v Quattro?
  77. Anyone else ever had problems with a bad Fuel Gauge/sensor...Right after 13gal fill
  78. 3 wire maf, what's the diff in putting a small VS on sensor vs adjusting pot to run rich ?
  79. Lookie what I got!
  80. Idle dropping out and occasionally stalling
  81. What are your gaps for the AC Delco #9's???
  82. Long time no post...but I know where to get help when I need it!
  83. True dual exhaust system suggestions
  84. center electrode material: Silver! they are expensive. any of you think they are worth a try?
  85. 4 to 3 wire maf question
  86. Turbo 2.8 12v (yes its possible)
  87. Magnaflow exhaust
  88. Instrument lights
  89. S3 VS question...
  90. Rough idle and CEL after s3 install
  91. How do I make my 2.8liter V6 12V have more power? needed badly
  92. cold air
  93. Any place to purchase mobil 1 0w50 or 5w50?
  94. s3 help #2
  95. s3 intake help
  96. Severe Oil Leak
  97. Motor not starting
  98. emmisions test and fuel line antifreeze question...
  99. Oil analysis reports, post em if you got em.
  100. no coolant in oil, no oil in coolant...
  101. I am trying to figure out my EGR insufficient flow.
  102. My A4
  103. Cams for the 2.8 12V?
  104. Just got S4 HFC from APR and OEMS4 Catback system (96a4qm)
  105. Questions about 12v V6 compatibility...
  106. Tip fluid and EFK conversion
  107. Make some noise for Mobil 1!
  108. Exhaust delema...
  109. Hey guys, where's the EGR temp sensor on a 93 100s?
  110. exhaust upgrade!!
  111. paging austinado16: YGM
  112. Thermostat went bad. Any particular brand I should get?
  113. Wheel bearings longevity ?
  114. Manufacturer of A/C evaporator ( 8D1 820 103F )
  115. Weird Starter Trouble
  116. Hey everyone! Motorcycle question for you...
  117. Is the sensor below the throttle body a temperature sensor?
  118. Has anyone tried two vw aba intake manifolds?
  119. how long (time or # of miles) until CELs come up?
  120. B5 S4 rear sway bar on an AFC Code B5...opinions?
  121. Torque spec on the crankshaft pully center bolt? 95 90Q
  122. with all this talk about air intakes and such, is anyone planning on going to a dyno soon?
  123. Heater Core Vaccum
  124. intake question..
  125. so my rotors are really rusted on. i saw a guy use a press to pop them off to do the wheel bearings
  126. oil pressure warning light
  127. Idling rich and pulsing with new injectors ....
  128. NEED SOME HELP!!!
  129. Looking for this
  130. hard start due to EGR valve..now what
  131. PCV hoses are brittle and cracked.
  132. Does the outside temp. sensor play a role in fuel mapping?
  133. Repair or Replace ACF '95 A6Q
  134. rough idle from exhaust leak or EGR cel?
  135. Top of Airbox sensors? Just wondering
  136. Well guys...after a long absence from the forums, I'm back....
  137. Temp gauge not working
  138. I changed the
  139. So, Intense Performance sent me the BigMouth! Not that I didn't leave 4 voice mails, and...
  140. ICV Rubber mount problems....
  141. Torquing heat bolts best after IM install or before?
  142. Thermostat without bleed valve
  143. 1996 A4 2.8 12valve CHIP
  144. Gasket identification please ...
  145. Audiforums Airbox mod
  146. What types of SS brake lines are people using...Do they require any work or are they direct fit?
  147. Hey Justin couple pre track question for you...Plus looks like I'm in the Yellow group.
  148. Was socket tool do I need for head bolts on a AFC 2.8L A4 '97?
  149. Buying a Used hose for my AC
  150. can you remove plenium with removing IM on a4 2.8L AFC?
  151. Help me find best vacuum line to feed seafoam through to get to the most cylinders...
  152. Loss of power high reving engine
  153. Homemade camshaft / crankshaft holding / locking tools?
  154. Oh boy. Replaced oil pan, now major woes appear... (Oil indicator near trip meter)
  155. O2 sensor install question...
  156. Don't I need to hone the cylinder?
  157. HELP: I need a crankshaft main bearing cap from an AAH 12v V6.
  158. Longshot, but does any have an s3 recovery sleeve they want to part with?
  159. Pulled my MAF screen today...anyone got an extra screw? :-P
  160. Noisy Valves?
  161. Oil leaking on the timing belt?
  162. Help on AC Evaporator P/N options (A4 1996 2.8 FWD)
  163. Need best $ on Rear O2 sensor...can I do better than $100 for direct fit.Do I need the special tool?
  164. Anyone else been trying to reach IntensePerformance.com?
  165. Can't get the oil pickup unit off during oil pan replacement...
  166. does any one know what this (circled red) is right by the IM, thanks
  167. I have read how the 12v ECU can't be chipped or modified but I found
  168. How many horses do the 2.8 have??
  169. "Test Only" station smog check (in CA -- your state may have other regulations)
  170. S3 MAF and smog...
  171. AC Problem, Please help
  172. New Audi Parts
  173. Oil pump & oil pan gasket replacement with part numbers and other info
  174. VAGCOM (Brake) Question
  175. car dead. need help.
  176. AC problems sucks... and a general battery question
  177. Timing belt change
  178. suspension woes
  179. what is a max healthy oil temp for the AAH engine ?
  180. Jretal you are running lltek CAI with S3 MAF .... Question ....
  181. Thoughts on LLTek CAI vs. Stock airbox/VelocityStack/Mann filter vs. "UrS4's CAI"
  182. looking for a bit more power and to clear up some confusion
  183. ok. a little help hear with the power steering hoses.
  184. Looking for just a bit more power
  185. MAF modification
  186. Found a local shop to P&P my intake manifold, anyone know if Mance found another way....
  187. supercharger for my 12v v6
  188. Locating Tdc on my 1996 Audi Cab engine code AFC
  189. is replacing one o2 sensor (pre-cat) a bad idea?
  190. Will be replacing my oil pan soon...have a couple of questions, have STFA...
  191. Exhaust Suggestions
  192. Oil leak hell continues aka: Leaking oil pump gasket
  193. oil temp sender location for AFC 12v PLEASE!!
  194. Noobee with possible headgasket oil leak
  195. I got a leak coming from my radiator on the lower right side if u were facing the car.
  196. Anyone have a good condition spare oil pan laying around that I could buy? Spotted a leak in mine
  197. Mori, any study available on oil filters?
  198. Anybody have any advice on 4-5 point harness's for track events...Need to keep my shoulders back...
  199. Doing the thermostat.....<dont take off that T-belt>
  200. Cats are acting up,
  201. woot! Got her back, she runs like a dream! Damn, I can't wait til the clutch is run in....
  202. Help! Mass Air Flow Sensor
  203. Does anyone have a write-up for replaceing a FPR?? i've S'dTFA with no luck =(
  204. Engine coolant temp sensor location
  205. Have to change evaporator... what else ?
  206. Idle problems (Help)
  207. Stock Speaker Amp questions?
  208. Bad ignition switch?
  209. Can anyone help OR have MR D's rear subframe re-inforcement pics?
  210. Has anybody seen this?
  211. Bentley
  212. Installed Allroad mounts today in my B5.
  213. Engine spec help
  214. aah blockw/crank and pistons up for grabs
  215. performance chip
  216. add one more to the stand alone scoreboard
  217. Can anyone suggest some good aftermarket injectors for our engines....
  218. The old Girl hit 120K and within 3 days the trip Computer totally crapped out...Is there a write up?
  219. Looking for alum. valve covers if anyone has some lying around. My POS plastic ones are cracking!
  220. Anyone have Mr. D's Allroad mount conversion writeup saved on harddrive?
  221. hey mance I have a dumb/ignorant cam timing question...
  222. Installed the bored TB last night, how she moves! The fact that it's not...
  223. need v6 12v engine!help out
  224. fuel gauge not working?
  225. Sad wittle water pump...
  226. Mance, how does 150cc injector and 5bar FPR goes?
  227. Finally! The goodies are goin in!!!!
  228. so where are you guys buying your AC delco #9???
  229. 1992 audi 80 B4 2.8 12v questions
  230. AAH intake manifold mods + flowbench #
  231. mbando, how about a follow-up post?
  232. In need of 3242 and 3243 seattle, puyallup area.
  233. Vacuum problem
  234. 12v 2.8L v6 a6 quattro wagon. turbo/super charger options?
  235. Shokan: X-Post
  236. where are the audi techs on here? please reply NO Spark! no power to coil
  237. some stuff in the classifieds you crazy cats might be interested in...
  238. After market muffler size check ... will it fit?
  239. Timing belt wisdom? (Also posted on B5 Forum...but maybe better here....)
  240. Anyone selling their recovery sleeve? I know it's a long shot, but...
  241. Little help with trouble code....
  242. can aff block fit with ahh heads?
  243. 12V performance chip bull****?
  244. engine code AFC parts request.need help.
  245. Change in Idle RPM
  246. Bolt size for allroad transmission mount conversion...STFA, that tidbit is nowhere...Is UrS4 dead?
  247. 98 a6 wagon turns over no start help
  248. Anyone looking for...
  249. exhaust leak enough to cause EGR code?
  250. Can the water pump be replaced without...
