View Full Version : 12v V6 Discussion
- AFC injectors, upper control arms, hydraulic lifters sale.
- 2111 error code when started
- Why can't I get belt to work?
- V6 Infamous for oil problems?
- p1106 p0170 HELP!!
- Intake plenum and Climate control for sale
- Fuel Issues?
- what are the symptoms of a bad POS (power output stage)
- anyone know how to get the Fuel Pressure Regulator appart?
- 1995 Audi 90Q Afc need advice on Engine removal procedure
- Engine Block Coolant Drain Plug location?
- RPM & Speedometer issue wont work sometimes.
- Anyone seen this happen?
- Head gasket job - Questions
- Radiator Cooling Fan Resister Pack
- Power Steering Pump and Pulley replacement
- Help... cam is 180 degrees off
- stripped head bolt
- How long does lifter noise on new head install last?
- Looking for AAH heads (92 100S FWD)
- How to Replace your A/C Compressor DIY
- 2.6 ABC ECU re-mapping?
- Which IM?
- Head Bolt variations
- FAILED IAC valve (more commonly known as the Idle Stabilizer Valve, or ISV) HELP
- Timing belt pulleys are toast!!
- Improving gas mileage
- To rebuild or not to rebuild, that is the question . . .
- Forced induction
- 95 Coupe 2.8E(AAH) Rebuild-Looking for Workshop Manual
- Cam seals
- 97 A6 engine swap with 94 100CS
- Timing belt job. Just Great!
- 2 sensors front of engine
- Fuel injectors: 2-hole vs. 4-hole
- Compression test
- No AC high/low pressure nipples on 1996 B5 A4 AFC?
- 96' A4 AFC 2.8L swapp ok to my 95 90 Quattro?
- Oil pressure check
- upcoming jobs: combine?
- ow boy.... what am i getting myself in to again?
- a/c delete bypass serpintine belt update
- Engine noise
- 1995 A6 with blown engine, got a '93 90 engine for it - issues?
- 2.8V6 12V: 2 stage intake?
- Take Upper Intake off for cleaning?
- Injector O-rings
- Gas Mileage and O2 sensors
- vibration dampener
- Stripped threads on block - BOO!
- Wiring MAF 4-pin - please help me
- Anybody Got Timing Belt tools they want to sell?
- AH HA! ive found the source of the leakage
- replacing the water pump..already
- Lago Blue, this is my monthly pester for a update...
- So i took my car for a spin
- 12v bored out maf
- Timing Belt Success !
- Changing the timing belt
- Would anyone be interested in bored out TB's?
- Anyone knows what this contact is for?
- 1995 Audi 90 Quattro 2.8l Eng. Code AFC ?
- Issue after 3" airmassmeter and MAF fix
- Lago, when you replaced the grommet in your master cylinder....
- STB vs TB
- Oxygen Sensor Replacement
- Hey Lago Blue, any luck finding those O-Rings?
- price estamite for a clutch job on a FWD B4 (1995)
- Intake Manifold Cleaning Questions
- Center Muffler
- heat problem
- 1995 Audi A6
- What is this check valve?
- HELP!!! poor gas mileage!!!
- Starter
- Help with fuse location, please
- Noisy Tappets after Heads Replaced
- damaged cam lobe on 1996 12v 2.8
- Valve Seals
- Coolant Blow-By in Breather-Hoses
- Need help with O-ring sizes and materials please...
- Car hesitating when going from place and
- 15lbs flywheel from 034 motorsport, anyone interested?
- Parting my sled, 95 90 lots o mods
- coolant bleed issues...
- water pump seized
- Oil Leak, valley area
- air intake manifold, any upgrades?
- Coolant leak. Thermostat maybe?
- Cam Cover Vents Stand-Pipe Mod...
- Pesky P1504 code, engine hesitates
- Anyone have A4 exhaust system
- 3rd Crank-case vent...
- gasket-matched and polished intake manifold
- 12v power possibilities
- Idle problem
- Dirty Spark Plug and smoke...
- stut stut stuttering engine!!
- would it work
- Burning Oil
- 98 A6 Avant valve job
- Turbo!!! I'll try and do a write up and I will post pics
- Double Check Parts Needed for Oxygen Sensor Replacement
- Tour (II) Through a Modest (& Mostly OEM) Intake System; Intro...
- question about parts...
- My big fat green DIY MAF housing mod...
- Crazy engine stall----bad ground????
- 2000 A6 Engine Replacement
- Timing belt tools???
- Panning for oil...
- Top End Reassembly
- ARP Head studs???
- finishing exhaust
- screw 2.8 timing!!!!
- its just not fair
- oil poll
- electric fan wont turn on, no a/c and overheating help
- head gasket and bolts, where to find?
- exhaust manifold up grade?
- 12v ReAssembly issues. Few Questions
- How to Install Dipstick Tube
- 4.2 swap + a s4 or a8 tranny swap?
- AAH 12v Running Problem - Help!
- AAH engine throttle, some simple questions
- problem! maybe motor or tranny mounts. or maybe motor or tranny!
- car drives WAY better
- overheating!
- Low oil pressure.
- HELP !!!
- Performance chip?
- Changed spark plugs...big problem!!
- idle control valve replacement
- ignition system sensors
- good engine for replacement?
- just dyno'd my car and WHAT?
- climate control issues
- Porting intake ports on head while its on the car?
- Looking For Mance Recovery Sleeve For 12v
- White smoke from exhaust
- Coolant temp rises at prolonged idle...
- Transmission troubles
- A/C Low pressure valve
- lost spark!
- Question on Ram-air setup
- Does anybody still do throttle body porting?
- Gains from replacing plenum..?
- Looking for some induction parts!
- Random stalling has begun..
- just swapped a 97 12v into a 96 and now no spark and injector pulse
- Engine speed sensor r&r
- I need the panel behind the passenger headlight ....
- No wonder VAP lurks here no longer...
- leaking gas out of charcoal canister?
- Is VAP still around?
- Rev Limit on Healthy V6
- Fuel issues....
- 12v V6 woes
- Help me identify this TB
- In1 and In2
- starting to build my 97 12v please read!!
- anyone got pictures of SXTB or anything simular? a wrightup would be greate too :-)
- Who has bypassed their A/C compressors ...
- Just finished installing the new belt tensioner ....
- Question about bored maf
- 12 VALVE POWER LIMITS?
- Oil Pressure but I don't think oil is making it to the heads
- P1402 Code
- MAF, ABS, MFS problems 96 A4 2.8L Q
- Motor seized
- Part and Sell or sell as whole?
- '95 A6 motor into '93 90q?
- Hesitation
- Bad accel/throttle issue, need help please
- Exhaust Manifold Strangeness
- 12V v6 Vac line
- Alternator failure: early recognition, fix & prevention.
- please help me!
- 95 AUDI A6 2.8L CANT FIND STARTER HELP!!!!
- Bucking/Pulsing under part throttle
- forced induction: 1996 audi a4 2.8 12v
- Low Idle on Cold Start
- 2.8l v6 12v Will not start
- 1999 Audi A4 Transmission compatibility?
- O2 sensor removal
- Bored MAF
- coolant temp sensor
- help with engine tuning on A4
- Oil Pressure - Mechanical Gage Reading
- 97 A6Q 2.8 AFC w auto CJDTransmission Filter Part number or coupling shape or image?
- Audi 90 vs. A Big Rock
- 1993 90 Quattro V6: Oil Pan Pullage!!
- Help with oil leak
- Problem with starting
- Testing fuel pressure/ regulator operation
- 97 A6Q Oil on back top passenger side of engine
- Bent Valves with an Intact Timing Belt?
- VAP still selling intakes?
- 95 90 Airbox mods
- Fine Tuning for the 4 to 3 wire MAF
- piston blown please help
- Timing issues.
- 1997 12v a4 hard start
- Help Engine overheating, and wipers not working.
- Head change problem.
- Noctious smoking Exhaust
- cylinder schematic
- Any idea what this stuff is?
- 4 to 3 wire MAF swap, testing/setting 1kohm pot
- How to disconnect transmission cooler lines from radiator
- '95 Audi 90 Quattro Head Gaskets
- Silicone fittings for intake
- Coolant
- Coolant.
- Later model maf mods? what and where to find data or post!
- Exhaust upgrades???
- Manifold tuning valve
- New to forum / 12v FAQ thread
- what happened to all the earlier threads?
- Odd Smoking Exhaust
- 80 B4 2.6 to 2.8 conversion?
- FS: XTB+ Throttle Body for 12v 2.8L
- Help with lifter tick / check valve part number
- 96 A4 12V Timing Belt
- Where is everbody?
- Goin nuts here.. Misfire on 4,5 and 6...
- 12v V6 (To Rebuild Heads or Not to Rebuild)
- manifold switchover valves
- MSD coil setup??
- Flex pipe for 96 A4
- Man, so many posts here, its hard sifting through it all!
- LOL 2 posts!!!
- Silicone Inlet Hose???
- No start after MAF cleaning - in a little trouble here!
- IM workshop on the way, huge missmatch
- why does 12v devel. suck now? it used to be awesome. now, not so much!
- Cam and crank sensor faults
- Electrical Issues
- Mori and other oil Gurus...I am thinking of switching to a high mileage oil..
- Hey Mori! and anyone else wondering about Auto Rx
- JWG, what mods have you done?
- Is MANCE still making parts? If so..
- Camshaft has moved during timing belt replacement.
- a few engine questions
- Ok quick question for a blog im writing:
- What the heck is this inside the valve cover?
- Goodbye, 12v Forum! The past six years were much fun.
- Engine Mount Stop .....
- Recommended oil
- O2 Sensor
- did my Timing belt job this weekend......
